    4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
    • R. Frase
      R. Frase @Thomas Braun last edited by R. Frase
      @thomas-braun sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      Jetzt hat das hier funktioniert:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       23:43:25 up  1:31,  1 user,  load average: 4.70, 3.45, 1.83
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=61.8'C
      volt=0.8625V
      *** Time and Time Zones ***
                     Local time: Wed 2023-06-21 23:43:36 CEST
                 Universal time: Wed 2023-06-21 21:43:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           1.9G        124M        834M        8.0M        913M        1.6G
      Swap:           99M          0B         99M
      Total:         2.0G        124M        934M
               1872 M total memory
                124 M used memory
                238 M active memory
                726 M inactive memory
                834 M free memory
                272 M buffer memory
                641 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  8.8G   20G  32% /
      devtmpfs       devtmpfs  776M     0  776M   0% /dev
      tmpfs          tmpfs     937M     0  937M   0% /dev/shm
      tmpfs          tmpfs     937M  8.6M  928M   1% /run
      tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
      [Wed Jun 21 22:11:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:12:E3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8578e3fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fsck.mode=force
      [Wed Jun 21 22:11:40 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Jun 21 22:11:40 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Jun 21 22:12:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      408M    /var/
      165M    /var/lib
      129M    /var/cache
      123M    /var/cache/apt
      69M     /var/lib/apt/lists
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      95M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      499M    /opt/iobroker/iobroker-data/
      341M    /opt/iobroker/iobroker-data/files
      96M     /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      28M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /home/pi/.nvm/versions/node/v16.13.0/bin/node           v16.13.0
      /home/pi/.nvm/versions/node/v16.13.0/bin/npm            8.1.0
      /home/pi/.nvm/versions/node/v16.13.0/bin/npx            8.1.0
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
      find: '/opt/iobroker/node_modules': No such file or directory
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1078
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
          at Module._load (node:internal/modules/cjs/loader:920:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.16.0
        throw err;
        requireStack: []
      Node.js v18.16.0
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.16.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.16.0
      admin:
        throw err;
        requireStack: []
      Node.js v18.16.0
      javascript:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.accuweather@1.2.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.admin@6.3.5, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.alexa2@3.23.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.coronavirus-statistics@^0.8.7, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.cul@2.0.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.daswetter@3.1.8, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.deconz@1.3.21, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@3.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.dwd@2.8.3, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.feiertage@1.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.fhem@^1.6.3, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.firetv@1.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.fritzdect@2.2.6, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.fullybrowser@2.1.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.hue-extended@2.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.hue@3.7.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.ical@1.13.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-addictive-flavour-png@0.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-fatcow-hosting@0.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-icons8@0.0.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-material-png@0.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-material-svg@0.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-mfd-png@1.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-mfd-svg@1.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-open-icon-library-png@0.1.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.iot@1.14.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.javascript@6.1.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@4.0.24, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.mqtt@4.1.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.octoprint@4.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.onvif@1.0.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.philips-tv@0.5.3, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.ping@1.5.3, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.plex@0.9.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.plexconnect@0.0.7, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.pollenflug@^1.0.6, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.scenes@2.3.9, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.simple-api@2.7.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.smartthings@0.0.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.spotify-premium@1.2.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.synology@2.1.13, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.tankerkoenig@^2.1.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.text2command@2.3.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.tr-064@4.2.18, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.trashschedule@2.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.tuya@3.14.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.upnp@1.0.21, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.virtualpowermeter@1.4.6, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-bars@^0.1.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-canvas-gauges@1.0.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-colorpicker@1.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-fancyswitch@1.1.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-history@1.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-hqwidgets@1.4.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-icontwo@0.93.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-inventwo@3.3.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-jqui-mfd@1.0.12, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-justgage@1.0.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-material-advanced@1.7.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-metro@1.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-players@0.1.6, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-rgraph@0.0.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis-timeandweather@1.2.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis@1.4.16, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.whatsapp-cmb@0.2.3, required by iobroker.inst@3.0.0
      npm ERR!     /home/pi/.npm/_logs/2023-06-21T21_43_48_180Z-debug.log
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.16.0
        throw err;
        requireStack: []
      Node.js v18.16.0
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.16.0
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.16.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://phoscon.de/apt/deconz buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
      Hit:4 https://dl.yarnpkg.com/debian stable InRelease
      Reading package lists... Donecom/node_18.x buster InRelease
      Pending Updates: 0sts... 0%
      *** Listening Ports ***
      tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17991      361/deCONZ
      tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19920      945/perl
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20894      864/sshd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       18004      361/deCONZ
      tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19921      945/perl
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20896      864/sshd
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        21378      815/grafana-server
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18020      813/dhcpcd
      udp        0      0 0.0.0.0:38564           0.0.0.0:*                           108        14951      352/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14949      352/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15209      361/deCONZ
      udp6       0      0 :::546                  :::*                                0          18039      813/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14950      352/avahi-daemon: r
      udp6       0      0 :::49470                :::*                                108        14952      352/avahi-daemon: r
      2023-06-21 20:11:26.179  - info: host.ioBroker instance system.adapter.fhem.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:26.180  - info: host.ioBroker instance system.adapter.hue-extended.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:26.211  - info: host.ioBroker instance system.adapter.smartthings.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:27.076  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:27.078  - warn: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
      2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated with code null ()
      2023-06-21 20:11:27.190  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
      2023-06-21 20:11:27.190  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
      2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.ping.0 terminated due to SIGTERM
      2023-06-21 20:11:27.191  - info: host.ioBroker instance system.adapter.ping.0 terminated with code null ()
      2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.hue.0 terminated due to SIGTERM
      2023-06-21 20:11:27.192  - info: host.ioBroker instance system.adapter.hue.0 terminated with code null ()
      2023-06-21 20:11:27.285  - warn: host.ioBroker instance system.adapter.text2command.0 terminated due to SIGTERM
      2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.text2command.0 terminated with code null ()
      2023-06-21 20:11:27.286  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
      2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
      2023-06-21 20:11:27.287  - warn: host.ioBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
      2023-06-21 20:11:27.287  - info: host.ioBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
      2023-06-21 20:11:27.358  - warn: host.ioBroker instance system.adapter.net-tools.0 terminated due to SIGTERM
      2023-06-21 20:11:27.358  - info: host.ioBroker instance system.adapter.net-tools.0 terminated with code null ()
      2023-06-21 20:11:27.359  - info: host.ioBroker instance system.adapter.virtualpowermeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:28.046  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-06-21 20:11:28.047  - info: host.ioBroker All instances are stopped.
      2023-06-21 20:11:28.277  - info: host.ioBroker terminated
      iob diag has finished.
      Ich lese, dass der js-controller nicht zu lesen ist und die Adapter sind auch alle nicht erreichbar.
      Ach ja, die Zusammenfassung:
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
      Kernel:                 5.10.103-v7l+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
        throw err;
        requireStack: []
      Node.js v18.16.0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:           1.9G        124M        859M        8.0M        887M        1.6G
      Swap:           99M          0B         99M
      Total:         2.0G        124M        959M
        throw err;
        requireStack: []
      Node.js v18.16.0
      Active iob-Instances:   0
        throw err;
        requireStack: []
      Node.js v18.16.0
        throw err;
        requireStack: []
      Node.js v18.16.0
      ioBroker Core:          js-controller
        throw err;
        requireStack: []
      Node.js v18.16.0
                              admin
        throw err;
        requireStack: []
      Node.js v18.16.0
      ioBroker Status:
        throw err;
        requireStack: []
      Node.js v18.16.0
      Objects:                0
      States:                 0
      Size of iob-Database:
      7.0M    /opt/iobroker/iobroker-data/states.jsonl
      2.8M    /opt/iobroker/iobroker-data/states.json.migrated
      2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @R. Frase last edited by
        @r-frase sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
        Lass die Finger von wirren Installationen via nvm oder sonstigem Kram.
        Softwarepakete werden ausschließlich via Paketmanager gehandhabt. Gerade wenn man sich nicht auskennt.
        Lösch den Mist:
        rm -rf /home/pi/.nvm/
        Schlecht...
        R. Frase 1 Reply Last reply Reply Quote 0
        • R. Frase
          Lösch den Mist:
          Schlecht...
          Lösch den Mist:
          okay... hab ich.
          Schlecht...
          das heißt ich hab ein echtes Problem?
            Thomas Braun Most Active @R. Frase last edited by Thomas Braun
            Möglicherweise.
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iob start
            • R. Frase
              Die Installation läuft gerade...
              Nebenbei: Der Ordner /opt/iobroker/node_modules_ existiert und ist gefüllt.
                Rühr da jetzt nicht drin rum!!
                • R. Frase
                  Oh nein - ganz sicher nicht!!! 😨
                  Die Installation bleibt bei 470k bis 540k ms... das dauert wohl eine Weile
                    @r-frase
                    Sooooo lange sollte das eigentlich auch nicht dauern.
                    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    sagt?
                    • R. Frase
                      Das sieht aus, als ob alle Module neu heruntergeladen und installiert werden.
                      Ich kann es leider nicht kopieren, weil das durch die aktualisierten ms-Zahlen verhindert wird.
                      unter anderem kamen einige npm WARN deprecated Warnungen.
                      darunter reify:localform und reify localforage bzgl. der Module.
                      Im Moment läuft die Schätzung auf über 900k ms und ich erhalte die nächste Eingabemöglichkeit bestimmt erst, wenn der Raspi fertig ist
                        Zweite Terminal-Session? Hat man i.d.R. eh mindestens zwei von offen.
                        • R. Frase
                          Ich komme üblicherweise mit einer durchs Leben 😇 - aber okay, ich versuche es!
                          Die zweite Session reagiert nicht - der Raspi ist wohl zu beschäftigt 🙄
                          ... doch, ich konnte mich anmelden. Es dauert leider...
                          ich konnte
                          eben eingeben... der Raspi arbeitet gerade an der Antwort
                          Zumindest bremst es den Raspi so aus, dass ich aus der anderen Session eine Kopie extrahieren kann:
                          reify:iobroker.iot: timing reifyNode:node_modules/iobroker.vis-icontwo Completed in 1773824ms
                            Sind ganz normale Meldungen, wenn die Module neugebaut werden.
                            • R. Frase
                              Ich habe Hoffnung!
                                @r-frase
                                Wobei ich zugeben muss, dass es nicht die brillianteste Idee von mir war, auf einen 2GB-RAM Raspberry auch noch die ganzen apt aktionen parallel drauf zu werfen... Und das gleich im Doppeldecker...
                                Brauchst halt was Geduld jetzt. Kann sein das die Kiste die Nacht dazu braucht.
                                • R. Frase
                                  Ich kenne die Sprache nicht in der Du schreibst, weil es bei mir mit Turbo-Pascal aufgehört hat. Hinter mir liegt ein Buch zur Einführung in PERL, weil ich mich grundsätzlich gerne mit Dingen auseinandersetze die einen Anreiz haben. In groben Zügen verstehe ich das über die ersten 30 Seiten (ich hab auch erst angefangen...)
                                  Sollte es die ganze Nacht dauern bin ich in jedem Fall schon sehr viel weiter als bevor ich mich hier gemeldet habe!
                                  Ich kann mich also morgen wieder melden - dann bekommen wir alle auch etwas Schlaf. Vielen lieben Dank schonmal!
                                    @r-frase
                                    Knall den zweiten Prozess mal mit Strg-C weg.
                                    sollte dann aber flugs durch laufen.
                                    • R. Frase
                                      @r-frase
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      v18.16.0
                                      v18.16.0
                                      9.5.1
                                      9.5.1
                                        @r-frase
                                        Ja, das sieht gut aus.
                                        • R. Frase
                                          @r-frase
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.16.0
                                          v18.16.0
                                          9.5.1
                                          9.5.1
                                          4.0.24
                                          pi
                                          /home/pi
                                          ^C
                                          ... das hat der Raspi bis dahin geschafft
                                            Und damit war das Kistlein dann überfordert:
                                            2x apt update ist bei 2GB RAM und parallel laufendem rebuild vom ioBroker ein wenig heftig. Hatte ich nicht dran gedacht...
                                            R. Frase 2 Replies Last reply Reply Quote 0
                                            10357
