    4. Node-Red
    5. Node Red Werte addieren
      siporax @mickym last edited by
      @mickym
      code_text
              "id": "02ad8ca016888437",
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": "",
              "env": []
              "id": "a872a7ba51fd3484",
              "type": "inject",
              "z": "02ad8ca016888437",
              "name": "",
              "props": [
                      "p": "trigger",
                      "v": "true",
                      "vt": "bool"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 190,
              "y": 240,
              "wires": [
                      "256da960d23f9755"
              "id": "256da960d23f9755",
              "type": "ioBroker get",
              "name": "Netzbezug L1",
              "topic": "modbus.0.inputRegisters.100.820_Netzbezug_L1",
              "attrname": "L1",
              "payloadType": "value",
              "errOnInvalidState": "nothing",
              "x": 360,
              "y": 240,
              "wires": [
                      "a4730fef776c6647"
              "id": "a4730fef776c6647",
              "name": "Netzbezug L2",
              "topic": "modbus.0.inputRegisters.100.821_Netzbezug_L2",
              "attrname": "L2",
              "x": 500,
              "y": 240,
              "wires": [
                      "d04d571a8162877c"
              "id": "c5166dda9c56917b",
              "type": "debug",
              "name": "Summe",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 1060,
              "y": 240,
              "wires": []
              "id": "9685e5e1edcb1ba4",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "L1 + L2 + L3",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 870,
              "y": 240,
              "wires": [
                      "c5166dda9c56917b"
              "id": "d04d571a8162877c",
              "name": "Netzbezug L3",
              "topic": "modbus.0.inputRegisters.100.822_Netzbezug_L3",
              "attrname": "L3",
              "x": 660,
              "y": 240,
              "wires": [
                      "9685e5e1edcb1ba4"
        siporax @siporax last edited by
        so besser habe den Payload um den L3 noch erweitert ich hoffe das wahr richtig.
        • mickym
          mickym Most Active @siporax last edited by
          @siporax Ja das passt schon
          ABER - das mit den Codetags hast Du noch nicht richtig raus - da soll kein ''' und auch kein anderer Text drin stehen:
                 "id": "1ce484e909033214",
                 "type": "inject",
                 "z": "7c4414c4c9653e12",
                 "name": "",
                 "props": [
                         "p": "trigger",
                         "v": "true",
                         "vt": "bool"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 170,
                 "y": 240,
                 "wires": [
                         "bfe50d1b1619adbc"
                 "id": "bfe50d1b1619adbc",
                 "attrname": "L1",
                 "x": 320,
                 "y": 240,
                 "wires": [
                         "91fe785f62b94a4f"
                 "id": "91fe785f62b94a4f",
                 "attrname": "L2",
                 "x": 500,
                 "y": 240,
                 "wires": [
                         "905a755e72a8bbdb"
                 "id": "1f07146054b4751b",
                 "type": "debug",
                 "name": "Summe",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1060,
                 "y": 240,
                 "wires": []
                 "id": "bc706d15e6b47333",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 870,
                 "y": 240,
                 "wires": [
                         "1f07146054b4751b"
                 "id": "905a755e72a8bbdb",
                 "attrname": "L3",
                 "x": 680,
                 "y": 240,
                 "wires": [
                         "bc706d15e6b47333"
          Wenn Du das sauber machst - kann man mit einem Klick auf Select All
          alles markieren und in die Zwischenablage kopieren.
          Also alles gut - aber für dir Zukunft einfach etwas benutzerfreundlicher machen.
            @mickym Werte kommen rein über L1 bis L3 aber kein Ergebnis dazu
            • mickym
              @siporax Du solltest doch im Status der Nodes die Werte sehen. Du kannst Dir ja mal in der Debug Node - das komplette Nachrichtenobjekt Dir ausgeben lassen.
                Ist das soweit dann richtig?
                • mickym
                  @siporax Ja klar - Du siehst doch was ausgelesen wird.
                  1468 + 102 + 6 = 1576
                  Das passt doch?
                    @mickym Ja du hast recht wie läuft das nun automatisch ab ich muss ja immer vorne das anklicken das es gezählt wird
                    • mickym
                      mickym Most Active @siporax last edited by mickym
                      @siporax Du kannst entweder in der Inject Node festlegen, dass die in bestimmten Zeiten selbstständig feuert oder die Frage ist ob die Punkte selbst feuern sollen. Das ist aber Logik. Du könntest auch sagen, wenn sich der Wert L3 ändert, dann sollen die anderen beiden geholt werden. Ich habe da keine Ahnung. Das musst Du halt alles genau sagen, was Du willst. Wie gesagt - das einfachste ist, dass Du die Inject Node in best. zeitlichen Abständen feuern lässt, aber ob das sinnvoll ist, kannst nur Du entscheiden.
                      Ich kann Dir nur helfen, aber das was Du willst musst Du schon genau formulieren.
                      Die Inject Node kann auch nur zu bestimmten Zeiten feuern - Du musst Dich nur mit den Fähigkeiten der Node beschäftigen.
                      In der Regel gibt es zu jeder Node eine Hilfe:
                      Man könnte den Flow auch so modifizieren, dass die Summen erst gebildet werden, wenn ERST ALLE 3 Datenpunkte aktualisiert wurden (also keine fixen Zeitintervalle). Dann würde man den Flow anders aufbauen. - Aber wie gesagt Du musst sagen, was Du willst.
                        siporax @mickym last edited by siporax
                        @mickym Okay verstanden das muss ich mir noch überlegen mir geht nur um die ANzeige denke jede Minute langt wird ja nicht gespeicher ist nur eine Anzeige.
                        Kann ich mir das auch wieder in den Iobroker zurückschreiben lassen den Wert ?
                        Soll zwar über Grafana später mal angezeigt werden aber soweit bin ich noch nicht.
                        • mickym
                          @siporax sagte in Node Red Werte addieren:
                          Ja Du kannst die payload mit der iobroker-Out Node wieder zurückschreiben. In dem Topic gibst Du wieder den Pfad zum Datenpunkt ein. Wenn es nur ein Wert ist und Du nichts steuern willst (also im Blockly aktualisiere) dann schreibst Du den Wert als Typ value zurück, falls Du was steuern willst - also unbestätigt - entspricht im Blockly steuere, dann schreibst Du es als Typ command in den Datenpunkt.
                            @mickym jetzt wird es kompliziert für den alten Mann .
                            • mickym
                              So lange ist der Weg nicht. Wenn Du einen Datenpunkt unter 0_userdata.0 anlegst und dann mit der iobroker-out Node beschreibst, dann brauchst Du nur wenn mit dem entsprechenden Adapter die Historie in eine Datenbank schreiben, also SQL oder Influx-DB usw. Grafana fragt dann nur diese Datenbank ab und visualisiert das dann.
                              • mickym
                                Nein
                                Nur in das topic den Pfad zum Datenpunkt eintragen und Typ auf value umstellen:
                                Das ist doch nicht kompliziert. Diese Node hängst einfach anstelle der Debug Node dahinter.
                                  @mickym okay das ist einleutend
                                  Aber wie stelle ich das im Broker an .
                                  Gefunden haben ich das was du beschrieben hast.
                                  • mickym
                                    @siporax Wie gesagt ersetze die Debug Node und konfiguriere die iobroker-Out Node wie beschrieben. Also Topic gibst Du dann
                                    0_userdata.0.example_state
                                    ein.
                                        @siporax so müsste es dann passen oder?
                                        • mickym
                                          @siporax Nein das ist kein Typ Folder, sondern Du willst doch Zahlen da rein schreiben.
                                            @mickym so habe ich erstellt im Broker
                                            Welches glied ist das im Node red denke Io Broker out
                                            aber da komme ich nicht auf meinen Datenpunkt wenn das Glied so stimmt
                                            Im Broker schreibt eine Null schon mal ,denke fast am Ziel.
                                            1.2k
                                            28342
