    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      g.polat @Guest last edited by g.polat
      @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
      @g-polat
      bei mir laeuft er seit 5.x Alpha problemlos... welche Node und NPM Version, welches BS ?
      dein Logauszug ist etwas kurz.. das wichtigste fehlt.. ( was vorher passiert und warum..)
      Bei so Sachen bitte immer den Adapter auf Debug stellen und das Log von Start an posten, da werden auch NPM usw mit angezeigt.
      Habe soeben auf 5.0.4 geupdatet, leider wieder gleicher Fehler 😞
      Node:
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v16.20.0
      v16.20.0
      8.19.4
      8.19.4
      Log:
      bluelink.0
      2023-06-16 10:45:17.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bluelink.0
      2023-06-16 10:45:17.797	error	undefined is not a valid state value
      bluelink.0
      2023-06-16 10:45:17.797	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5372:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5333:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:390:17) at async Oe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:225:29)
      bluelink.0
      2023-06-16 10:45:17.796	error	unhandled promise rejection: undefined is not a valid state value
      bluelink.0
      2023-06-16 10:45:17.796	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bluelink.0
      2023-06-16 10:45:17.786	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      bluelink.0
      2023-06-16 10:45:17.786	info	terminating
      bluelink.0
      2023-06-16 10:45:17.780	info	Adapter bluelink cleaned up everything...
      bluelink.0
      2023-06-16 10:45:17.772	error	undefined is not a valid state value
      bluelink.0
      2023-06-16 10:45:17.772	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5372:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5333:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:390:17) at async Oe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:225:29)
      bluelink.0
      2023-06-16 10:45:17.770	error	unhandled promise rejection: undefined is not a valid state value
      bluelink.0
      2023-06-16 10:45:17.769	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bluelink.0
      2023-06-16 10:45:17.302	info	1 Vehicles found
      bluelink.0
      2023-06-16 10:45:13.482	info	Login to api
      bluelink.0
      2023-06-16 10:45:13.435	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#488b418ad72b6f3821ce26c9a0e0fbd853946cbe) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.20.0, js-controller: 5.0.4
      host.iobroker
      2023-06-16 10:45:03.771	info	instance system.adapter.bluelink.0 started with pid 5074
      host.iobroker
      2023-06-16 10:45:02.502	info	"system.adapter.bluelink.0" enabled
      Habe soeben alle DP gelöscht und Iobroker neu gestartet:
      bluelink.0
      2023-06-16 10:50:52.744	warn	This object will not be created in future versions. Please report this to the developer.
      bluelink.0
      2023-06-16 10:50:52.744	warn	Object bluelink.0.TMAJE812DNJ024584.driveHistory.cumulated01.consumption.engine is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
      bluelink.0
      2023-06-16 10:50:52.724	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      bluelink.0
      2023-06-16 10:50:52.723	info	terminating
      bluelink.0
      2023-06-16 10:50:52.717	info	Adapter bluelink cleaned up everything...
      bluelink.0
      2023-06-16 10:50:52.708	error	undefined is not a valid state value
      bluelink.0
      2023-06-16 10:50:52.707	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5372:49) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5333:21) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21) at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21) at async Bluelink.receiveEVInformation (/opt/iobroker/node_modules/iobroker.bluelink/main.js:390:17) at async Oe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:225:29)
      bluelink.0
      2023-06-16 10:50:52.705	error	unhandled promise rejection: undefined is not a valid state value
      bluelink.0
      2023-06-16 10:50:52.705	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bluelink.0
      2023-06-16 10:50:52.681	warn	This object will not be created in future versions. Please report this to the developer.
      bluelink.0
      2023-06-16 10:50:52.680	warn	Object bluelink.0.TMAJE812DNJ024584.driveHistory.cumulated01.consumption.total is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
      bluelink.0
      2023-06-16 10:50:51.525	info	1 Vehicles found
      bluelink.0
      2023-06-16 10:50:47.770	info	Login to api
      bluelink.0
      2023-06-16 10:50:47.741	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#488b418ad72b6f3821ce26c9a0e0fbd853946cbe) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.20.0, js-controller: 5.0.4
      host.iobroker
      2023-06-16 10:50:45.112	info	instance system.adapter.bluelink.0 started with pid 8136
      host.iobroker
      2023-06-16 10:50:44.532	info	"system.adapter.bluelink.0" enabled
        arteck Developer Most Active @g.polat last edited by
        @g-polat sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
        node: v16.20.0
        mach ein update auf 18 bitte
        • nik82
          nik82 Most Active last edited by
          kurze Frage: Den Gesamtkilometerstand des Fahrzeugs sieht man nicht in der App und somit natürlich auch nicht im Adapter oder?
          Meister Mopper ? 2 Replies Last reply Reply Quote 0
          • Meister Mopper
            Meister Mopper @nik82 last edited by
            @nik82 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
            Er wird nicht geliefert, wenn das Fzg beim Abrufen aus ist. Ich rufe mit Skript ab, wenn es eingeschaltet ist.
            nik82 1 Reply Last reply Reply Quote 0
            • nik82
              nik82 Most Active @Meister Mopper last edited by
              @meister-mopper
              Ah ok, das heißt der Datenpunkt kommt noch wenn das Fahrzeug eingeschaltet ist und ich einen force_refresh_from_car mache?
              Ok, teste ich, danke für die schnelle Rückinfo. Hab den Wagen erst zwei Tage, muss mich erst noch einfinden 🙂
                A Former User @nik82 last edited by
                @nik82
                Doch, in der App sieht man ihn, etwas versteckt unter Status / ganz unten Fahrzeugmanagement / Fahrzeugbericht
                Die Werte werden auch vom Adapter alle abgerufen.
                nik82 1 Reply Last reply Reply Quote 1
                • nik82
                  nik82 Most Active @Guest last edited by
                  @ilovegym
                  Ah da ist es in der App, danke 🙂
                  Und unter welchem Datenpunkt finde ich das dann im Adapter?
                    @nik82 odometer 🙂
                    Meister Mopper nik82 2 Replies Last reply Reply Quote 0
                    • Meister Mopper
                      Meister Mopper @Guest last edited by Meister Mopper
                      @ilovegym
                      Bei meinem Niro EV wird das nirgends angezeigt 🤷‍♂️
                        A Former User @Meister Mopper last edited by
                        @meister-mopper
                        Kann es sein, dass du ne Softwareversion auf dem Auto hast, die noch den KM-Bug hat?
                        Da gabs letztes Jahr mal was...
                        Hyundai Ioniq5:
                        • Meister Mopper
                          KA, ich glaube, sie ist Stand 11/2022
                          • nik82
                            @ilovegym
                            Ah ich war blind, hab alles durchgeschaut und das nicht gesehen 🙂
                            Top Danke.
                            @Meister-Propper
                            Stimmt doch alles, das Problem ist die App, bei dir steht in der App bei Kilometerzähler 0km, bei mir kommt da schon die richtige Kilometeranzahl, deswegen wird bei dir der value 0 angezeigt wahrscheinlich
                            • Meister Mopper
                              Stimmt doch alles
                              ??? Der hat aktuell 15.444 Kilometer auf dem Buckel.
                              • nik82
                                @meister-mopper
                                Ich meine ja vom Adapter her, weil in deiner App auch 0km steht:
                                Das scheint ein Bug der App oder Fahrzeug zu sein, wenn in der App schon der Fehler mit den 0km ist, dann kanns der Adapter ja auch nur falsch anzeigen.
                                  @meister-mopper sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Genau da war der Bug… wurde im Dezember Update behoben..
                                  mittlerweile sind wir beim Juni-Update..
                                  Meister Mopper 2 Replies Last reply Reply Quote 0
                                  • Meister Mopper
                                    @ilovegym
                                    Danke, dann hau ich das nachher mal drauf 👍
                                    • nik82
                                      @meister-mopper
                                      Bitte nicht steinigen für die dumme Frage, wie gesagt hab das Auto erst zwei Tage.
                                      Wie kannst du denn das Update einfach drauf machen? Ich habe gedacht für ein Software Update muss man in die Werkstatt?
                                      Ich kenne bis jetzt nur den Navigations Updater, aber der updatet ja nur die Navikarten dachte ich?
                                      • Meister Mopper
                                        Meister Mopper @nik82 last edited by Meister Mopper
                                        @nik82
                                        Da kommt, wenn vorhanden, auch neue Firmware mit. Einfach die Software auf einen Stick bruzzeln, Kfz einschalten und über das Menü updaten.
                                        Hier steht's
                                        • nik82
                                          @meister-mopper
                                          Cool, danke.
                                          • Meister Mopper
                                            Dann ist meine Kiste beratungsresistent. Auch nach dem Update funktioniert es nicht 🤷‍♂️
                                            1.2k
                                            81.1k
                                            2276
                                            850935
