    4. [Adapter] Sonoff- Tasmota
    • chucky666
      chucky666 last edited by
      Hallo
      Wird der Sonoff S20 auch unterstützt ?
      Gesendet von iPad mit Tapatalk Pro
      • Bluefox
        Bluefox last edited by
        @kmxak:
        nachdem ich die datei geändert habe und den adapter 2 mal neugestartet habe kamen erste meldungen:
        ! host.ioBroker 2017-10-09 13:00:27.890 info instance system.adapter.sonoff.0 started with pid 4118 host.ioBroker 2017-10-09 13:00:25.507 info instance system.adapter.sonoff.0 terminated with code 0 (OK) Caught 2017-10-09 13:00:25.507 error by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) Caught 2017-10-09 13:00:25.507 error by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) Caught 2017-10-09 13:00:25.506 error by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) Caught 2017-10-09 13:00:25.506 error by controller[1]: at Writable.write (_stream_writable.js:243:11) Caught 2017-10-09 13:00:25.506 error by controller[1]: at writeOrBuffer (_stream_writable.js:317:5) Caught 2017-10-09 13:00:25.506 error by controller[1]: at doWrite (_stream_writable.js:331:12) Caught 2017-10-09 13:00:25.505 error by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) Caught 2017-10-09 13:00:25.505 error by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) Caught 2017-10-09 13:00:25.505 error by controller[1]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) Caught 2017-10-09 13:00:25.505 error by controller[1]: ReferenceError: __line is not defined Caught 2017-10-09 13:00:25.505 error by controller[0]: at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) Caught 2017-10-09 13:00:25.505 error by controller[0]: at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) Caught 2017-10-09 13:00:25.505 error by controller[0]: at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write (_stream_writable.js:243:11) Caught 2017-10-09 13:00:25.504 error by controller[0]: at writeOrBuffer (_stream_writable.js:317:5) Caught 2017-10-09 13:00:25.504 error by controller[0]: at doWrite (_stream_writable.js:331:12) Caught 2017-10-09 13:00:25.504 error by controller[0]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) Caught 2017-10-09 13:00:25.504 error by controller[0]: at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) Caught 2017-10-09 13:00:25.503 error by controller[0]: at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) Caught 2017-10-09 13:00:25.503 error by controller[0]: ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.480 info terminating sonoff.0 2017-10-09 13:00:25.466 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) sonoff.0 2017-10-09 13:00:25.466 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) sonoff.0 2017-10-09 13:00:25.466 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) sonoff.0 2017-10-09 13:00:25.466 error at Writable.write (_stream_writable.js:243:11) sonoff.0 2017-10-09 13:00:25.466 error at writeOrBuffer (_stream_writable.js:317:5) sonoff.0 2017-10-09 13:00:25.466 error at doWrite (_stream_writable.js:331:12) sonoff.0 2017-10-09 13:00:25.466 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) sonoff.0 2017-10-09 13:00:25.466 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) sonoff.0 2017-10-09 13:00:25.466 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) sonoff.0 2017-10-09 13:00:25.466 error ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.466 error uncaught exception: __line is not defined sonoff.0 2017-10-09 13:00:25.465 info Client [SonoffPOW] closed sonoff.0 2017-10-09 13:00:25.464 info Client [Sonoff4ch] closed sonoff.0 2017-10-09 13:00:25.463 warn Client error [ESPClient5]: Error: This socket is closed sonoff.0 2017-10-09 13:00:25.458 info Client [ESPClient5] closed sonoff.0 2017-10-09 13:00:25.458 error at Connection.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:241:11) sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:302:5) sonoff.0 2017-10-09 13:00:25.458 error at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:313:64) sonoff.0 2017-10-09 13:00:25.458 error at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:201:22) sonoff.0 2017-10-09 13:00:25.458 error at Writable.write (_stream_writable.js:243:11) sonoff.0 2017-10-09 13:00:25.458 error at writeOrBuffer (_stream_writable.js:317:5) sonoff.0 2017-10-09 13:00:25.458 error at doWrite (_stream_writable.js:331:12) sonoff.0 2017-10-09 13:00:25.458 error at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:10:9) sonoff.0 2017-10-09 13:00:25.458 error at generate (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:33:14) sonoff.0 2017-10-09 13:00:25.458 error at publish (/opt/iobroker/node_modules/mqtt-packet/writeToStream.js:270:59) sonoff.0 2017-10-09 13:00:25.458 error ReferenceError: __line is not defined sonoff.0 2017-10-09 13:00:25.458 error uncaught exception: __line is not defined sonoff.0 2017-10-09 13:00:25.427 info Client [Sonoff4ch] closed `
        Ist vermutlich alte node.js Version.
        dann ersetze __line mit unterschiedlichen Buchstaben: A, B, C,… so dass du die unterscheiden kannst.
        • Bluefox
          @chucky666:
          Hallo
          Gesendet von iPad mit Tapatalk Pro `
          Keine Ahnung. Hast du probiert oder fragst du?
          • chucky666
            Ich frage , wollte mir eine testweise bestellen
            • kmxak
              @Bluefox:
              dann ersetze __line mit unterschiedlichen Buchstaben: A, B, C,… so dass du die unterscheiden kannst. `
              wo soll ich was ersetzen?`
              Die node.js ist aktuell:
              root@ioBroker:/home/alex# node -v
              v6.11.4
              root@ioBroker:/home/alex# nodejs -v
              v6.11.4
              • Bluefox
                @kmxak:
                @Bluefox:
                v6.11.4
                v6.11.4
                stream.emit('error', new Error('Invalid messageId ' + __line))
                stream.emit('error', new Error('Invalid messageId A'))
                stream.emit('error', new Error('Invalid messageId B'))
                stream.emit('error', new Error('Invalid messageId C'))
                stream.emit('error', new Error('Invalid messageId ...'))
                • kmxak
                  Bislang bekomme ich als einzigen Fehler
                  sonoff.0	2017-10-11 20:49:16.932	warn	Client error [Sonoff4ch]: Error: Invalid messageId A
                  • Bluefox
                    @kmxak:
                    Und welche Zeile ist das? in node_modules/mqtt-packet/writeToStream.js
                    • kmxak
                      hier ein ausschnitt (Zeile 270)
                      // Topic must be a non-empty string or Buffer
                        if (typeof topic === 'string') length += Buffer.byteLength(topic) + 2
                        else if (Buffer.isBuffer(topic)) length += topic.length + 2
                        else {
                          stream.emit('error', new Error('Invalid topic'))
                          return false
                        // Get the payload length
                        if (!Buffer.isBuffer(payload)) length += Buffer.byteLength(payload)
                        else length += payload.length
                        // Message ID must a number if qos > 0
                        if (qos && typeof id !== 'number') {
                          return false
                        } else if (qos) length += 2
                        // Header
                        stream.write(protocol.PUBLISH_HEADER[qos][opts.dup ? 1 : 0][retain ? 1 : 0])
                        // Remaining length
                        writeLength(stream, length)
                        // Topic
                        writeNumber(stream, byteLength(topic))
                        stream.write(topic)
                        Master77 last edited by
                        Hallo zusammen.
                        Danke erst mal für den Adapter. Nach ein wenig probieren funktioniert er richtig gut. Habe jetzt nur eine Frage bezüglich der Einbindung in Alexa. Habe nach neuen Geräten gesucht, jedoch findet sie keine neuen Geräte. Kann mir da einer auf die Sprünge helfen. Danke im voraus für die Hilfe.
                        Gruß Markus
                        Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                        • kmxak
                          Alle Geräte die Alexa finden soll müssen im Cloud Adapter erst angelegt werden unter Smarte Geräte
                          • chucky666
                            Hallo
                            Der Adapter läuft sehr gut , ich hoffe das die Sonoff Th10/16 mit Temperatur Sensor bald auch Unterstützt werden .
                              @kmxak:
                              Alle Geräte die Alexa finden soll müssen im Cloud Adapter erst angelegt werden unter Smarte Geräte ` Super, danke für die Info.
                              • kmxak
                                @chucky666:
                                Hallo
                                bitte stelle den Adapter auf Debug und poste was da ankommt dann kann Bluefox es einbauen 😉
                                • Bluefox
                                  Bitte 0.3.1 testen
                                    andyb last edited by
                                    Sorry, aber find im Forum nix….
                                    Muss ich in Verbindung mit diesem Adapter irgendwas an den Sonoffs noch löten/flashen oder geht das so?
                                      simpixo last edited by
                                      Du musst eine Alternative Firmware drauf spielen, diese heißt Tasmota! Es gibt auch andere die mit dem Adapter funktionieren!
                                      Um die Firmware drauf spielen zu können musst du 5 Pins anlöten damit du mit einem usb zu serial Adapter das tun kannst
                                      Adrian
                                        maniac last edited by
                                        Darf ich mal eben fragen ob die Sonoff 4CH PRO auch mit Tasmota unterstützt werden?
                                        Im FHEM Wiki zum flashen https://wiki.fhem.de/wiki/Sonoff finde ich die nicht.
                                        https://www.amazon.de/Switches-Funkfern … 0751B6WX5/
                                        Hat da jemand Erfahrung?
                                        • Schubi
                                          Schubi last edited by
                                          Ich habe folgendes Verhalten eines SONOFF Basic Moduls:
                                          1.) Das Modul ist via WEBIF ansprechbar und verhält sich normal.
                                          2.) In der Objektliste steht alive auf true.
                                          3.) Unter Info.Connection des Sonoff Adapters scheint das Modul nicht auf!
                                          4.) Es sendet die Zustände an den Adapter.
                                          5.) Es nimmt keine Befehle vom Adapter an.
                                          Bei der Bedienung äußert sich das folgendermaßen: Man setzt POWER auf true - am Modul pasiert nichts.
                                          Nach einer gewissen Zeit - wenn das Modul wieder seinen Status sendet (alle 600s) wechselt POWER wieder auf false.
                                          Es scheit so, dass das Modul anscheinend sendet, aber nicht empfängt.
                                          Schön wäre es zumindest, wenn das Modul nicht in der Liste connection steht - es auch nicht mehr alive ist.
                                          Log-File:
                                          2017-10-25 06:58:09.224  - [32minfo[39m: sonoff.0 Client [EG_KE_01] connected
                                          2017-10-25 06:58:10.581  - [33mwarn[39m: sonoff.0 Client error [EG_KE_01]: Error: read ECONNRESET
                                          2017-10-25 06:58:10.619  - [33mwarn[39m: sonoff.0 Client error [EG_KE_01]: Error: This socket is closed
                                          2017-10-25 06:58:10.622  - [31merror[39m: sonoff.0 Closed because of error
                                          2017-10-25 06:58:10.623  - [32minfo[39m: sonoff.0 Client [EG_KE_01] closed
                                          Ich habe bereits einen Verdacht - es könnte damit zusammenhängen, dass ich im Modul nicht die IP-Adresse für den MQTT-Server, sondern einen Namen eingetragen habe.
                                          Es scheint so als gäbe es da einen Bug im ESP-Code beim auflösen von DNS-Anfragen (Vermutung aus einem anderen Forum).
                                          Das muss ich erst testen…
                                          LG Schubi
                                          • Bluefox
                                            @maniac:
                                            Hat da jemand Erfahrung? `
                                            Auf der Liste steht dass JA:
                                            https://github.com/arendst/Sonoff-Tasmo … nformation
                                            Es wird unterstützt. Ich habe aber nicht getestet.
                                            720
                                            202137
