nach Updates der node Versionen geht nichts mehr
@marc91 sagte in nach Updates der node Versionen geht nichts mehr:
hm das heißt, ich muss eine neue Ubuntu Version installieren?
natürlich
@djmarc75
Danke!wenn ich nun sudo apt update eingebe kommt folgendes:
Hit:1 https://deb.nodesource.com/node_18.x bullseye InRelease Ign:2 http://archive.ubuntu.com/ubuntu hirsute InRelease Ign:3 http://archive.ubuntu.com/ubuntu hirsute-updates InRelease Ign:4 http://archive.ubuntu.com/ubuntu hirsute-security InRelease Err:5 http://archive.ubuntu.com/ubuntu hirsute Release 404 Not Found [IP: 91.189.91.38 80] Err:6 http://archive.ubuntu.com/ubuntu hirsute-updates Release 404 Not Found [IP: 91.189.91.38 80] Err:7 http://archive.ubuntu.com/ubuntu hirsute-security Release 404 Not Found [IP: 91.189.91.38 80] Reading package lists... Done E: The repository 'http://archive.ubuntu.com/ubuntu hirsute Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://archive.ubuntu.com/ubuntu hirsute-updates Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://archive.ubuntu.com/ubuntu hirsute-security Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.und danach bei apt upgrade:
Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following NEW packages will be installed: distro-info libllvm12 The following packages will be upgraded: accountsservice apparmor apt apt-utils base-passwd bind9-dnsutils bind9-host bind9-libs busybox-static ca-certificates command-not-found cpio curl distro-info-data isc-dhcp-client isc-dhcp-common libaccountsservice0 libapparmor1 libapt-pkg6.0 libcurl4 libdrm-amdgpu1 libdrm-common libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libdrm2 libgcrypt20 libgl1-mesa-dri libglapi-mesa libglib2.0-data libglx-mesa0 libhogweed6 liblz4-1 libnettle8 libntfs-3g883 libpam-modules libpam-modules-bin libpam-runtime libpolkit-gobject-1-0 libprocps8 libpython3.9-minimal libpython3.9-stdlib libssh-4 libssl1.1 libuv1 libx11-data libxml2 login manpages networkd-dispatcher ntfs-3g openssh-client openssh-server openssh-sftp-server openssl passwd postfix procps python-apt-common python3-apt python3-commandnotfound python3-distupgrade python3-gdbm python3-update-manager python3.9 python3.9-minimal ssh tzdata ubuntu-advantage-tools ubuntu-release-upgrader-core ufw update-manager-core usrmerge vim-common vim-tiny xxd 76 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 52.7 MB of archives. After this operation, 93.8 MB of additional disk space will be used. Do you want to continue? [Y/n] y Err:1 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 login amd64 1:4.8.1-1ubuntu8.1 404 Not Found [IP: 185.125.190.36 80] Err:2 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 base-passwd amd64 3.5.49ubuntu1 404 Not Found [IP: 185.125.190.36 80] Ign:3 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgcrypt20 amd64 1.8.7-2ubuntu2.1 Ign:4 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 liblz4-1 amd64 1.9.3-1ubuntu0.1 Err:5 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libapt-pkg6.0 amd64 2.2.4ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:6 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apt amd64 2.2.4ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:7 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apt-utils amd64 2.2.4ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:8 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-modules-bin amd64 1.3.1-5ubuntu6.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:9 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-modules amd64 1.3.1-5ubuntu6.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:10 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssl1.1 amd64 1.1.1j-1ubuntu3.6 404 Not Found [IP: 185.125.190.36 80] Ign:11 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9 amd64 3.9.5-3ubuntu0~21.04.1 Ign:12 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-stdlib amd64 3.9.5-3ubuntu0~21.04.1 Ign:13 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1 Ign:14 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1 Ign:15 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 tzdata all 2021e-0ubuntu0.21.04 Ign:16 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ntfs-3g amd64 1:2017.3.23AR.3-3ubuntu4.1 Ign:17 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libntfs-3g883 amd64 1:2017.3.23AR.3-3ubuntu4.1 Err:18 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-sftp-server amd64 1:8.4p1-5ubuntu1.2 404 Not Found [IP: 185.125.190.36 80] Err:19 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpam-runtime all 1.3.1-5ubuntu6.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:20 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libprocps8 amd64 2:3.3.16-5ubuntu3.1 404 Not Found [IP: 185.125.190.36 80] Err:21 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 procps amd64 2:3.3.16-5ubuntu3.1 404 Not Found [IP: 185.125.190.36 80] Err:22 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-server amd64 1:8.4p1-5ubuntu1.2 404 Not Found [IP: 185.125.190.36 80] Err:23 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 passwd amd64 1:4.8.1-1ubuntu8.1 404 Not Found [IP: 185.125.190.36 80] Err:24 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssh-client amd64 1:8.4p1-5ubuntu1.2 404 Not Found [IP: 185.125.190.36 80] Err:25 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ssh all 1:8.4p1-5ubuntu1.2 404 Not Found [IP: 185.125.190.36 80] Ign:26 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libnettle8 amd64 3.7-2.1ubuntu1.1 Ign:27 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libhogweed6 amd64 3.7-2.1ubuntu1.1 Err:28 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 usrmerge all 24ubuntu3.1 404 Not Found [IP: 185.125.190.36 80] Err:29 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 openssl amd64 1.1.1j-1ubuntu3.6 404 Not Found [IP: 185.125.190.36 80] Ign:30 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ca-certificates all 20210119ubuntu0.21.04.1 Ign:31 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 distro-info-data all 0.46ubuntu4.3 Ign:32 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.2ubuntu6.2 Ign:33 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.2ubuntu6.2 Err:34 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libapparmor1 amd64 3.0.0-0ubuntu7.1 404 Not Found [IP: 185.125.190.36 80] Err:35 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglib2.0-data all 2.68.1-1~ubuntu21.04.1 404 Not Found [IP: 185.125.190.36 80] Ign:36 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libxml2 amd64 2.9.10+dfsg-6.3ubuntu0.1 Err:37 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 networkd-dispatcher all 2.1-2~ubuntu21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:38 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python-apt-common all 2.2.0~ubuntu0.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:39 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-apt amd64 2.2.0~ubuntu0.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:40 http://archive.ubuntu.com/ubuntu hirsute/main amd64 distro-info amd64 1.0 404 Not Found [IP: 185.125.190.36 80] Err:41 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ubuntu-advantage-tools amd64 27.5~21.04.1 404 Not Found [IP: 185.125.190.36 80] Ign:42 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 xxd amd64 2:8.2.2434-1ubuntu1.3 Ign:43 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-tiny amd64 2:8.2.2434-1ubuntu1.3 Ign:44 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-common all 2:8.2.2434-1ubuntu1.3 Ign:45 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 accountsservice amd64 0.6.55-0ubuntu13.3 Ign:46 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libaccountsservice0 amd64 0.6.55-0ubuntu13.3 Ign:47 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpolkit-gobject-1-0 amd64 0.105-30ubuntu0.1 Err:48 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 apparmor amd64 3.0.0-0ubuntu7.1 404 Not Found [IP: 185.125.190.36 80] Ign:49 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libuv1 amd64 1.40.0-1ubuntu0.1 Ign:50 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-dnsutils amd64 1:9.16.8-1ubuntu3.3 Ign:51 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-libs amd64 1:9.16.8-1ubuntu3.3 Ign:52 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-host amd64 1:9.16.8-1ubuntu3.3 Ign:53 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 busybox-static amd64 1:1.30.1-6ubuntu2.1 Ign:54 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04 Err:55 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 command-not-found all 20.10.2 404 Not Found [IP: 185.125.190.36 80] Err:56 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-commandnotfound all 20.10.2 404 Not Found [IP: 185.125.190.36 80] Ign:57 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 cpio amd64 2.13+dfsg-4ubuntu0.3 Err:58 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-common all 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:59 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm2 amd64 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Ign:60 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libx11-data all 2:1.7.0-2ubuntu0.1 Err:61 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 manpages all 5.10-1ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:62 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ubuntu-release-upgrader-core all 1:21.04.17 404 Not Found [IP: 185.125.190.36 80] Err:63 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-distupgrade all 1:21.04.17 404 Not Found [IP: 185.125.190.36 80] Err:64 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-update-manager all 1:21.04.10 404 Not Found [IP: 185.125.190.36 80] Err:65 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 update-manager-core all 1:21.04.10 404 Not Found [IP: 185.125.190.36 80] Err:66 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ufw all 0.36-7.1ubuntu1 404 Not Found [IP: 185.125.190.36 80] Ign:67 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssh-4 amd64 0.9.5-1ubuntu0.1 Ign:68 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 curl amd64 7.74.0-1ubuntu2.3 Ign:69 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libcurl4 amd64 7.74.0-1ubuntu2.3 Err:70 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-amdgpu1 amd64 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:71 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-intel1 amd64 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:72 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-nouveau2 amd64 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:73 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libdrm-radeon1 amd64 2.4.105-3~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:74 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglx-mesa0 amd64 21.0.3-0ubuntu0.3 404 Not Found [IP: 185.125.190.36 80] Err:75 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgl1-mesa-dri amd64 21.0.3-0ubuntu0.3 404 Not Found [IP: 185.125.190.36 80] Err:76 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libglapi-mesa amd64 21.0.3-0ubuntu0.3 404 Not Found [IP: 185.125.190.36 80] Err:77 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libllvm12 amd64 1:12.0.0-3ubuntu1~21.04.2 404 Not Found [IP: 185.125.190.36 80] Err:78 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 postfix amd64 3.5.6-1ubuntu0.2 404 Not Found [IP: 185.125.190.36 80] Err:3 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libgcrypt20 amd64 1.8.7-2ubuntu2.1 404 Not Found [IP: 185.125.190.36 80] Err:4 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 liblz4-1 amd64 1.9.3-1ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:11 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9 amd64 3.9.5-3ubuntu0~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:12 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-stdlib amd64 3.9.5-3ubuntu0~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:13 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:14 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpython3.9-minimal amd64 3.9.5-3ubuntu0~21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:15 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 tzdata all 2021e-0ubuntu0.21.04 404 Not Found [IP: 185.125.190.36 80] Err:16 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ntfs-3g amd64 1:2017.3.23AR.3-3ubuntu4.1 404 Not Found [IP: 185.125.190.36 80] Err:17 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libntfs-3g883 amd64 1:2017.3.23AR.3-3ubuntu4.1 404 Not Found [IP: 185.125.190.36 80] Err:26 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libnettle8 amd64 3.7-2.1ubuntu1.1 404 Not Found [IP: 185.125.190.36 80] Err:27 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libhogweed6 amd64 3.7-2.1ubuntu1.1 404 Not Found [IP: 185.125.190.36 80] Err:30 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 ca-certificates all 20210119ubuntu0.21.04.1 404 Not Found [IP: 185.125.190.36 80] Err:31 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 distro-info-data all 0.46ubuntu4.3 404 Not Found [IP: 185.125.190.36 80] Err:32 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.2ubuntu6.2 404 Not Found [IP: 185.125.190.36 80] Err:33 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.2ubuntu6.2 404 Not Found [IP: 185.125.190.36 80] Err:36 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libxml2 amd64 2.9.10+dfsg-6.3ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:42 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 xxd amd64 2:8.2.2434-1ubuntu1.3 404 Not Found [IP: 185.125.190.36 80] Err:43 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-tiny amd64 2:8.2.2434-1ubuntu1.3 404 Not Found [IP: 185.125.190.36 80] Err:44 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 vim-common all 2:8.2.2434-1ubuntu1.3 404 Not Found [IP: 185.125.190.36 80] Err:45 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 accountsservice amd64 0.6.55-0ubuntu13.3 404 Not Found [IP: 185.125.190.36 80] Err:46 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libaccountsservice0 amd64 0.6.55-0ubuntu13.3 404 Not Found [IP: 185.125.190.36 80] Err:47 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libpolkit-gobject-1-0 amd64 0.105-30ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:49 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libuv1 amd64 1.40.0-1ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:50 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-dnsutils amd64 1:9.16.8-1ubuntu3.3 404 Not Found [IP: 185.125.190.36 80] Err:51 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-libs amd64 1:9.16.8-1ubuntu3.3 404 Not Found [IP: 185.125.190.36 80] Err:52 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 bind9-host amd64 1:9.16.8-1ubuntu3.3 404 Not Found [IP: 185.125.190.36 80] Err:53 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 busybox-static amd64 1:1.30.1-6ubuntu2.1 404 Not Found [IP: 185.125.190.36 80] Err:54 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04 404 Not Found [IP: 185.125.190.36 80] Err:57 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 cpio amd64 2.13+dfsg-4ubuntu0.3 404 Not Found [IP: 185.125.190.36 80] Err:60 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libx11-data all 2:1.7.0-2ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:67 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libssh-4 amd64 0.9.5-1ubuntu0.1 404 Not Found [IP: 185.125.190.36 80] Err:68 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 curl amd64 7.74.0-1ubuntu2.3 404 Not Found [IP: 185.125.190.36 80] Err:69 http://archive.ubuntu.com/ubuntu hirsute-updates/main amd64 libcurl4 amd64 7.74.0-1ubuntu2.3 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/shadow/login_4.8.1-1ubuntu8.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/base-passwd/base-passwd_3.5.49ubuntu1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libg/libgcrypt20/libgcrypt20_1.8.7-2ubuntu2.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/lz4/liblz4-1_1.9.3-1ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.2.4ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.2.4ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.2.4ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-modules-bin_1.3.1-5ubuntu6.21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-modules_1.3.1-5ubuntu6.21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1j-1ubuntu3.6_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9_3.9.5-3ubuntu0~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/libpython3.9-stdlib_3.9.5-3ubuntu0~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9-minimal_3.9.5-3ubuntu0~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3.9/libpython3.9-minimal_3.9.5-3ubuntu0~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/t/tzdata/tzdata_2021e-0ubuntu0.21.04_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/ntfs-3g/ntfs-3g_2017.3.23AR.3-3ubuntu4.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/ntfs-3g/libntfs-3g883_2017.3.23AR.3-3ubuntu4.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-sftp-server_8.4p1-5ubuntu1.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/pam/libpam-runtime_1.3.1-5ubuntu6.21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/procps/libprocps8_3.3.16-5ubuntu3.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/procps/procps_3.3.16-5ubuntu3.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-server_8.4p1-5ubuntu1.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/shadow/passwd_4.8.1-1ubuntu8.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-client_8.4p1-5ubuntu1.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/ssh_8.4p1-5ubuntu1.2_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nettle/libnettle8_3.7-2.1ubuntu1.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nettle/libhogweed6_3.7-2.1ubuntu1.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/usrmerge/usrmerge_24ubuntu3.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1j-1ubuntu3.6_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/ca-certificates/ca-certificates_20210119ubuntu0.21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/d/distro-info-data/distro-info-data_0.46ubuntu4.3_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.2ubuntu6.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.2ubuntu6.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apparmor/libapparmor1_3.0.0-0ubuntu7.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/glib2.0/libglib2.0-data_2.68.1-1~ubuntu21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libx/libxml2/libxml2_2.9.10+dfsg-6.3ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/networkd-dispatcher/networkd-dispatcher_2.1-2~ubuntu21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python-apt/python-apt-common_2.2.0~ubuntu0.21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python-apt/python3-apt_2.2.0~ubuntu0.21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/d/distro-info/distro-info_1.0_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.5~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/xxd_8.2.2434-1ubuntu1.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/vim-tiny_8.2.2434-1ubuntu1.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/v/vim/vim-common_8.2.2434-1ubuntu1.3_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/accountsservice/accountsservice_0.6.55-0ubuntu13.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/accountsservice/libaccountsservice0_0.6.55-0ubuntu13.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/policykit-1/libpolkit-gobject-1-0_0.105-30ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apparmor/apparmor_3.0.0-0ubuntu7.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libu/libuv1/libuv1_1.40.0-1ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-dnsutils_9.16.8-1ubuntu3.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-libs_9.16.8-1ubuntu3.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/bind9/bind9-host_9.16.8-1ubuntu3.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/b/busybox/busybox-static_1.30.1-6ubuntu2.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/python3-stdlib-extensions/python3-gdbm_3.9.5-0ubuntu3~21.04_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/command-not-found/command-not-found_20.10.2_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/command-not-found/python3-commandnotfound_20.10.2_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/cpio/cpio_2.13+dfsg-4ubuntu0.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-common_2.4.105-3~21.04.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm2_2.4.105-3~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libx/libx11/libx11-data_1.7.0-2ubuntu0.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/manpages/manpages_5.10-1ubuntu0.1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.04.17_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.04.17_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/update-manager/python3-update-manager_21.04.10_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/update-manager/update-manager-core_21.04.10_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ufw/ufw_0.36-7.1ubuntu1_all.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libs/libssh/libssh-4_0.9.5-1ubuntu0.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/curl_7.74.0-1ubuntu2.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/libcurl4_7.74.0-1ubuntu2.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-amdgpu1_2.4.105-3~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-intel1_2.4.105-3~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-nouveau2_2.4.105-3~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-radeon1_2.4.105-3~21.04.1_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libglx-mesa0_21.0.3-0ubuntu0.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libgl1-mesa-dri_21.0.3-0ubuntu0.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libglapi-mesa_21.0.3-0ubuntu0.3_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/l/llvm-toolchain-12/libllvm12_12.0.0-3ubuntu1~21.04.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/p/postfix/postfix_3.5.6-1ubuntu0.2_amd64.deb 404 Not Found [IP: 185.125.190.36 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?kannst du mir helfen was da schiefläuft ?
weil
@djmarc75 sagte in nach Updates der node Versionen geht nichts mehr:
was hattest du denn vor mit
nein, nutze kein Ubuntu und wollte Dir nur einen Hinweis geben.
Zumal Du auch nicht auf die aktuelle Version von Ubuntu upgegraded hastImmernoch hirsuite !
@homoran ich dachte das ich mit den befehlen eine neue Ubuntu Version Installiere.
kann diese denn Updaten ohne das System neu aufzusetzen? -
nee, damit kann man nur die bestehende Version aktualisieren
ok danke!kannst du mir sagen wie oder wo ich nachlesen kann wie ich die veraltete Version erneuern kann?
leider nein!
ich nutze ein Release Upgrade immer um mein System neu aufzubauen.
Nach ca. 2 Jahren halte ichbdas für angebracht.
Backup sichern
Neu installieren mit allen aktuellen Versionen
Backup wieder herstellenfertig!
@Thomas-Braun hat ein Tutorial für Debian geschrieben
damit kann ich etwas anfangen.
vielen dank für die Hilfe! -
In die Ubuntu-Falle gelaufen.
Andere als die LTS-Versionen haben nur eine Lebenserwartung von 9 Monaten, danach werden die auch Recht zügig von den Servern gekratzt.Installier das aktuelle Debian Bookworm, damit hast du so ca. 2,5 Jahre Ruhe.
Vielen Dank für die Hilfe!
System neu aufgesetzt, Benutzer erstellt um nicht weiter als Root etwas zu versaubeuteln und statt Ubuntu Debian Bookworm installiert.
Das System läuft nun wieder ohne Probleme.
