    3. Einsteigerfragen
    4. e-charts adapter kann nicht installiert werden
    • I
      ichwersonst @ichwersonst last edited by
      @Thomas-Braun
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 5.15.84-v7+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     5
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/node           v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            972M        730M         84M        0.0K        156M        188M
      Swap:            99M         99M          0B
      Total:          1.1G        830M         84M
      Active iob-Instances:   15
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : RaspberryVPN                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : RaspberryVPN                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                4713
      States:                 3547
      Size of iob-Database:
      7.4M    /opt/iobroker/iobroker-data/objects.jsonl
      5.8M    /opt/iobroker/iobroker-data/states.jsonl
      Some problems detected, please run iob fix and try to have them fixed
      • I
        ichwersonst @Thomas Braun last edited by
        so hab jetzt auch noch auf node 18.16.1 geupdated.
        leider keine besserung
        • DJMarc75
          DJMarc75 @ichwersonst last edited by DJMarc75
          @ichwersonst sagte in e-charts adapter kann nicht installiert werden:
          und iob diag ?
          LANGFASSUNG
          • I
            ichwersonst @DJMarc75 last edited by
            @djmarc75
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 3 Model B Plus Rev 1.3
            Architecture    : armv7l
            Docker          : false
            Virtualization  : none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             21:12:00 up 44 days,  1:01,  1 user,  load average: 4.07, 3.02, 3.69
            CPU threads: 4
            Raspberry only:
            throttled=0x80008
            Other values than 0x0 hint to temperature/voltage problems
            temp=66.6'C
            volt=1.2500V
            *** Time and Time Zones ***
                           Local time: Fri 2023-06-23 21:12:00 CEST
                       Universal time: Fri 2023-06-23 19:12:00 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            972M        696M         58M        0.0K        216M        215M
            Swap:            99M         99M          0B
            Total:          1.1G        796M         58M
                      972 M total memory
                      696 M used memory
                      180 M active memory
                      635 M inactive memory
                       58 M free memory
                       26 M buffer memory
                      190 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       29G   15G   14G  53% /
            devtmpfs       devtmpfs  454M     0  454M   0% /dev
            tmpfs          tmpfs     487M     0  487M   0% /dev/shm
            tmpfs          tmpfs     195M  980K  194M   1% /run
            tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
            tmpfs          tmpfs      98M   36K   98M   1% /run/user/1000
            Show mounted filesystems (real ones only):
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            4.1G    /var/
            3.3G    /var/log
            3.0G    /var/log/journal/1dfdb4734fa941c381b94fb0796fc84d
            480M    /var/cache
            Archived and active journals take up 2.9G in the file system.
            /opt/iobroker/backups:
            123M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            199M    /opt/iobroker/iobroker-data/
            136M    /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            52M     /opt/iobroker/iobroker-data/backup-objects
            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js
            6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.16.1
            /usr/bin/node           v18.16.1
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.1-deb-1nodesource1
              Candidate: 18.16.1-deb-1nodesource1
              Version table:
             *** 18.16.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 16.20.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            MULTIHOSTSERVICE/enabled: false
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     7.0.3
            Adapters from github:   0
            Adapter State
            + system.adapter.broadlink2.0             : broadlink2            : RaspberryVPN                             -  enabled
            + system.adapter.broadlink2.1             : broadlink2            : RaspberryVPN                             -  enabled
            + system.adapter.deconz.0                 : deconz                : RaspberryVPN                             -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : RaspberryVPN                             - disabled
            + system.adapter.info.0                   : info                  : RaspberryVPN                             -  enabled
            + system.adapter.javascript.0             : javascript            : RaspberryVPN                             -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : RaspberryVPN                             -  enabled
            + system.adapter.pushbullet.0             : pushbullet            : RaspberryVPN                             -  enabled
            + system.adapter.sayit.0                  : sayit                 : RaspberryVPN                             -  enabled
            + system.adapter.shelly.0                 : shelly                : RaspberryVPN                             -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.simple-api.0             : simple-api            : RaspberryVPN                             - disabled, port: 8087, bind: 0.0.0.0 (SSL), run as: admin
              system.adapter.socketio.0               : socketio              : RaspberryVPN                             - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.spotify-premium.0        : spotify-premium       : RaspberryVPN                             -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RaspberryVPN                             - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RaspberryVPN                             - disabled
              system.adapter.vis-map.0                : vis-map               : RaspberryVPN                             -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : RaspberryVPN                             -  enabled
              system.adapter.vis.0                    : vis                   : RaspberryVPN                             -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : RaspberryVPN                             -  enabled
            + system.adapter.wled.0                   : wled                  : RaspberryVPN                             -  enabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "bring"        : 1.8.1    , installed 1.8.1
            Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "info"         : 1.9.26   , installed 1.9.26
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
            Adapter    "logparser"    : 2.2.0    , installed 2.2.0
            Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
            Adapter    "sayit"        : 3.0.5    , installed 3.0.5
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
            Adapter    "wled"         : 0.6.7    , installed 0.6.7
            Objects and States
            Objects:        4713
            States:         3547
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       435539915  23870/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       435539900  23870/iobroker.js-c
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13088      578/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       268436901  8759/deCONZ
            tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          347891055  19271/connmand
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       435544275  24049/io.shelly.0
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          427095173  5212/cupsd
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       268438553  8759/deCONZ
            tcp6       0      0 127.0.0.1:3350          :::*                    LISTEN      0          13456      572/xrdp-sesman
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13090      578/sshd: /usr/sbin
            tcp6       0      0 :::3389                 :::*                    LISTEN      111        13625      638/xrdp
            tcp6       0      0 :::4369                 :::*                    LISTEN      0          347876480  1/systemd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       435541921  24146/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       435541728  23930/io.admin.0
            udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          347891047  19271/connmand
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13143      513/dhcpcd
            udp        0      0 0.0.0.0:38484           0.0.0.0:*                           1001       435544340  24261/io.broadlink2
            udp        0      0 0.0.0.0:33881           0.0.0.0:*                           1001       435544419  24261/io.broadlink2
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          427093256  5238/cups-browsed
            udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       435542749  24298/io.broadlink2
            udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       435542710  24261/io.broadlink2
            udp        0      0 0.0.0.0:53408           0.0.0.0:*                           0          347891310  19271/connmand
            udp        0      0 0.0.0.0:49859           0.0.0.0:*                           1001       435542752  24298/io.broadlink2
            udp        0      0 0.0.0.0:37608           0.0.0.0:*                           108        347889567  19801/avahi-daemon:
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       435545311  24621/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        347889565  19801/avahi-daemon:
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       435541998  24379/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       435541997  24379/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       268437005  8759/deCONZ
            udp        0      0 0.0.0.0:33764           0.0.0.0:*                           1001       435544341  24261/io.broadlink2
            udp        0      0 0.0.0.0:52748           0.0.0.0:*                           1001       435543648  24298/io.broadlink2
            udp        0      0 0.0.0.0:35351           0.0.0.0:*                           1001       435542753  24298/io.broadlink2
            udp6       0      0 :::5353                 :::*                                108        347889566  19801/avahi-daemon:
            udp6       0      0 :::41795                :::*                                108        347889568  19801/avahi-daemon:
            2023-06-23 21:10:35.262  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.ResetAll) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:35.398  - info: vw-connect.0 (24685) Found 1 vehicles
            2023-06-23 21:10:36.464  - info: sayit.0 (24796) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.16.1, js-controller: 4.0.24
            2023-06-23 21:10:36.530  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.GoToBed) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:36.640  - info: sayit.0 (24796) Upload announce mp3 files
            2023-06-23 21:10:37.029  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SunriseStart) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:37.196  - info: wled.0 (24621) Try to contact : "Wandbord" on IP : 192.168.178.36
            2023-06-23 21:10:37.254  - info: wled.0 (24621) Tiki connected
            2023-06-23 21:10:37.312  - info: wled.0 (24621) Initialising : " Wandbord" on IP :  192.168.178.36
            2023-06-23 21:10:37.544  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.LeaveHomeRun1) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:38.045  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IOBrokerRestarted) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:38.549  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IoBrokerRestartTime) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:38.750  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IoBrokerRestartDate) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:39.063  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.ResetAll) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:42.876  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempelAkkuStatus) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:42.913  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempelAkkuLadezeit) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:44.562  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempel) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
            2023-06-23 21:10:47.583  - info: wled.0 (24621) Bonjour service started, new  devices  will  be detected automatically
            2023-06-23 21:10:47.616  - info: info.0 (24421) Reading user data every 8 seconds.
            2023-06-23 21:10:47.730  - info: wled.0 (24621) Wandbord connected
            2023-06-23 21:10:49.067  - info: info.0 (24421) Reading process data every 8 seconds.
            2023-06-23 21:10:50.911  - info: info.0 (24421) Reading disk data every 8 seconds.
            2023-06-23 21:10:53.611  - info: info.0 (24421) Reading network data every 3 seconds.
            2023-06-23 21:10:57.595  - info: wled.0 (24621) WLED initialisation finalized, ready to do my job have fun !
            2023-06-23 21:12:00.822  - info: admin.0 (23930) ==> Connected system.user.admin from ::ffff:192.168.178.20
            DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
            • DJMarc75
              wow
              temp=66.6'C
              wow
              58 M free memory
              puh...
                Homoran Global Moderator Administrators @ichwersonst last edited by
                temp=66.6'C
                schon heftig, deswegen drosseltver auch.
                passt dazu. an der Grenze.
                ram geht aus, swapped gewaltig, kostet Zeit und Leistung
                Adapter State
                13 aktive Instanzen sind zu viel für 1GB RAM
                I 2 Replies Last reply Reply Quote 0
                • I
                  ichwersonst @Homoran last edited by
                  shit ja 66°C sind heftig viel.
                  Kann ich den ram beim raspi 3 model b einfach erweitern ?
                  Oder gibt es noch anderen Möglichkeiten ?
                    Thomas Braun Most Active @ichwersonst last edited by
                    Nein, die Bausteine sind gelötet.
                    • I
                      Wenn ich im Reiter Instanzen schauen liegt die Auslastung bei 766MB.
                      Ist doch IO bei 1GB RAM oder ? Unabhängig davon wie viele Instanzen aktiv sind ...
                      • I
                        schade ... also ein anderer PI?
                        • DJMarc75
                          DJMarc75 last edited by DJMarc75
                          ups...
                          Beitragstitel : e-charts adapter kann nicht installiert werden
                          völlig vernachlässigt
                            oder!
                            sobald eine scheduled Instanz startet ist Ende
                            Möglicherweise reicht der RAM auch bei dem Versuch der Installation nicht mehr
                            • I
                              das könnte ich ja testen, in dem ich mal paar anhalte bevor ich den adapter installiere ?
                                @ichwersonst ja könntest du.
                                Wenn es dann klappt hast du boch eine Instanz mehr.
                                1GB schafft allerhöchstens 10 Instanzen
                                • I
                                  okay, also neuer Pi mit mehr RAM ?
                                    @ichwersonst wäre eine Möglichkeit.
                                    • I
                                      was wäre noch eine Möglichkeit ? Außer Instanzen stoppen ...benutze halt alle ^^
                                        Eine Kiste mit mehr Hubraum.
                                          alles was mehrcRAM hat. auch andere Mütter haben schöne Töchter. muss ja kein pi sein.
                                          • I
                                            alles klar,
                                            nennt mir mal Alternativen zum Pi die eine ähnliche Baugröße haben ✌
                                            1603
