    3. Einsteigerfragen
    4. e-charts adapter kann nicht installiert werden
    • I
      ichwersonst @DJMarc75 last edited by
      @djmarc75
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       21:12:00 up 44 days,  1:01,  1 user,  load average: 4.07, 3.02, 3.69
      CPU threads: 4
      Raspberry only:
      throttled=0x80008
      Other values than 0x0 hint to temperature/voltage problems
      temp=66.6'C
      volt=1.2500V
      *** Time and Time Zones ***
                     Local time: Fri 2023-06-23 21:12:00 CEST
                 Universal time: Fri 2023-06-23 19:12:00 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            972M        696M         58M        0.0K        216M        215M
      Swap:            99M         99M          0B
      Total:          1.1G        796M         58M
                972 M total memory
                696 M used memory
                180 M active memory
                635 M inactive memory
                 58 M free memory
                 26 M buffer memory
                190 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G   15G   14G  53% /
      devtmpfs       devtmpfs  454M     0  454M   0% /dev
      tmpfs          tmpfs     487M     0  487M   0% /dev/shm
      tmpfs          tmpfs     195M  980K  194M   1% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      98M   36K   98M   1% /run/user/1000
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      4.1G    /var/
      3.3G    /var/log
      3.0G    /var/log/journal/1dfdb4734fa941c381b94fb0796fc84d
      480M    /var/cache
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      123M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      199M    /opt/iobroker/iobroker-data/
      136M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      52M     /opt/iobroker/iobroker-data/backup-objects
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js
      7.4M    /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.1
      /usr/bin/node           v18.16.1
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           16.20.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : RaspberryVPN                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.broadlink2.0             : broadlink2            : RaspberryVPN                             -  enabled
      + system.adapter.broadlink2.1             : broadlink2            : RaspberryVPN                             -  enabled
      + system.adapter.deconz.0                 : deconz                : RaspberryVPN                             -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : RaspberryVPN                             - disabled
      + system.adapter.info.0                   : info                  : RaspberryVPN                             -  enabled
      + system.adapter.javascript.0             : javascript            : RaspberryVPN                             -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : RaspberryVPN                             -  enabled
      + system.adapter.pushbullet.0             : pushbullet            : RaspberryVPN                             -  enabled
      + system.adapter.sayit.0                  : sayit                 : RaspberryVPN                             -  enabled
      + system.adapter.shelly.0                 : shelly                : RaspberryVPN                             -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : RaspberryVPN                             - disabled, port: 8087, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.socketio.0               : socketio              : RaspberryVPN                             - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.spotify-premium.0        : spotify-premium       : RaspberryVPN                             -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RaspberryVPN                             - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RaspberryVPN                             - disabled
        system.adapter.vis-map.0                : vis-map               : RaspberryVPN                             -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : RaspberryVPN                             -  enabled
        system.adapter.vis.0                    : vis                   : RaspberryVPN                             -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : RaspberryVPN                             -  enabled
      + system.adapter.web.0                    : web                   : RaspberryVPN                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : RaspberryVPN                             -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Objects and States
      Objects:        4713
      States:         3547
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       435539915  23870/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       435539900  23870/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13088      578/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       268436901  8759/deCONZ
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          347891055  19271/connmand
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       435544275  24049/io.shelly.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          427095173  5212/cupsd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       268438553  8759/deCONZ
      tcp6       0      0 127.0.0.1:3350          :::*                    LISTEN      0          13456      572/xrdp-sesman
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13090      578/sshd: /usr/sbin
      tcp6       0      0 :::3389                 :::*                    LISTEN      111        13625      638/xrdp
      tcp6       0      0 :::4369                 :::*                    LISTEN      0          347876480  1/systemd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       435541921  24146/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       435541728  23930/io.admin.0
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          347891047  19271/connmand
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13143      513/dhcpcd
      udp        0      0 0.0.0.0:38484           0.0.0.0:*                           1001       435544340  24261/io.broadlink2
      udp        0      0 0.0.0.0:33881           0.0.0.0:*                           1001       435544419  24261/io.broadlink2
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          427093256  5238/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       435542749  24298/io.broadlink2
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       435542710  24261/io.broadlink2
      udp        0      0 0.0.0.0:53408           0.0.0.0:*                           0          347891310  19271/connmand
      udp        0      0 0.0.0.0:49859           0.0.0.0:*                           1001       435542752  24298/io.broadlink2
      udp        0      0 0.0.0.0:37608           0.0.0.0:*                           108        347889567  19801/avahi-daemon:
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       435545311  24621/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        347889565  19801/avahi-daemon:
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       435541998  24379/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       435541997  24379/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       268437005  8759/deCONZ
      udp        0      0 0.0.0.0:33764           0.0.0.0:*                           1001       435544341  24261/io.broadlink2
      udp        0      0 0.0.0.0:52748           0.0.0.0:*                           1001       435543648  24298/io.broadlink2
      udp        0      0 0.0.0.0:35351           0.0.0.0:*                           1001       435542753  24298/io.broadlink2
      udp6       0      0 :::5353                 :::*                                108        347889566  19801/avahi-daemon:
      udp6       0      0 :::41795                :::*                                108        347889568  19801/avahi-daemon:
      2023-06-23 21:10:35.262  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.ResetAll) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:35.398  - info: vw-connect.0 (24685) Found 1 vehicles
      2023-06-23 21:10:36.464  - info: sayit.0 (24796) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.16.1, js-controller: 4.0.24
      2023-06-23 21:10:36.530  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.GoToBed) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:36.640  - info: sayit.0 (24796) Upload announce mp3 files
      2023-06-23 21:10:37.029  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SunriseStart) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:37.196  - info: wled.0 (24621) Try to contact : "Wandbord" on IP : 192.168.178.36
      2023-06-23 21:10:37.254  - info: wled.0 (24621) Tiki connected
      2023-06-23 21:10:37.312  - info: wled.0 (24621) Initialising : " Wandbord" on IP :  192.168.178.36
      2023-06-23 21:10:37.544  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.LeaveHomeRun1) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:38.045  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IOBrokerRestarted) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:38.549  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IoBrokerRestartTime) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:38.750  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.IoBrokerRestartDate) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:39.063  - info: javascript.0 (24000) script.js.common.ResetAll: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.ResetAll) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:42.876  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempelAkkuStatus) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:42.913  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempelAkkuLadezeit) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:44.562  - info: javascript.0 (24000) script.js.common.Skoda: Own states (javascript.0.scriptEnabled.Eigene_Datenpunkte.NeueDatenPunkte.SkodaZeitstempel) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
      2023-06-23 21:10:47.583  - info: wled.0 (24621) Bonjour service started, new  devices  will  be detected automatically
      2023-06-23 21:10:47.616  - info: info.0 (24421) Reading user data every 8 seconds.
      2023-06-23 21:10:47.730  - info: wled.0 (24621) Wandbord connected
      2023-06-23 21:10:49.067  - info: info.0 (24421) Reading process data every 8 seconds.
      2023-06-23 21:10:50.911  - info: info.0 (24421) Reading disk data every 8 seconds.
      2023-06-23 21:10:53.611  - info: info.0 (24421) Reading network data every 3 seconds.
      2023-06-23 21:10:57.595  - info: wled.0 (24621) WLED initialisation finalized, ready to do my job have fun !
      2023-06-23 21:12:00.822  - info: admin.0 (23930) ==> Connected system.user.admin from ::ffff:192.168.178.20
      DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @ichwersonst last edited by
        @ichwersonst sagte in e-charts adapter kann nicht installiert werden:
        wow
        temp=66.6'C
        wow
        58 M free memory
        puh...
          Homoran Global Moderator Administrators @ichwersonst last edited by
          temp=66.6'C
          schon heftig, deswegen drosseltver auch.
          passt dazu. an der Grenze.
          ram geht aus, swapped gewaltig, kostet Zeit und Leistung
          Adapter State
          13 aktive Instanzen sind zu viel für 1GB RAM
          I 2 Replies Last reply Reply Quote 0
          • I
            ichwersonst @Homoran last edited by
            shit ja 66°C sind heftig viel.
            Kann ich den ram beim raspi 3 model b einfach erweitern ?
            Oder gibt es noch anderen Möglichkeiten ?
              Thomas Braun Most Active @ichwersonst last edited by
              Nein, die Bausteine sind gelötet.
              • I
                Wenn ich im Reiter Instanzen schauen liegt die Auslastung bei 766MB.
                Ist doch IO bei 1GB RAM oder ? Unabhängig davon wie viele Instanzen aktiv sind ...
                • I
                  ichwersonst @Thomas Braun last edited by
                  schade ... also ein anderer PI?
                  • DJMarc75
                    DJMarc75 last edited by DJMarc75
                    ups...
                    Beitragstitel : e-charts adapter kann nicht installiert werden
                    völlig vernachlässigt
                      oder!
                      sobald eine scheduled Instanz startet ist Ende
                      Möglicherweise reicht der RAM auch bei dem Versuch der Installation nicht mehr
                      • I
                        das könnte ich ja testen, in dem ich mal paar anhalte bevor ich den adapter installiere ?
                          @ichwersonst ja könntest du.
                          Wenn es dann klappt hast du boch eine Instanz mehr.
                          1GB schafft allerhöchstens 10 Instanzen
                          • I
                            okay, also neuer Pi mit mehr RAM ?
                              @ichwersonst wäre eine Möglichkeit.
                              • I
                                was wäre noch eine Möglichkeit ? Außer Instanzen stoppen ...benutze halt alle ^^
                                  Eine Kiste mit mehr Hubraum.
                                    alles was mehrcRAM hat. auch andere Mütter haben schöne Töchter. muss ja kein pi sein.
                                    • I
                                      alles klar,
                                      nennt mir mal Alternativen zum Pi die eine ähnliche Baugröße haben ✌
                                        @ichwersonst da gibt es vieeele
                                        verfügbar und bezahlbar: odroid c4
                                          @ichwersonst
                                          Guckstu:
                                          https://all3dp.com/de/1/single-board-computer-raspberry-pi-alternative/
                                          • I
                                            cool danke 🙂
                                            Dann gleich noch die Frage ob es hier eine Anleitung gibt, ordentlich bullseye und IObroker zu installieren.
                                            Hab ja nun mittlerweile gelernt, dass es im Netzt auch viele suboptimale Anleitungen gibt 😄
                                            Aber ich hab jetzt mal 4 Adapter gestoppt - Problem bleibt 😞
                                            1603
