    4. M-TEC Energy Butler
    M-TEC Energy Butler
    • metaxa
      metaxa @manrum1 last edited by
      @manrum1 sagte in M-TEC Energy Butler:
      nichts an der Anlage verändern
      das tue ich auch nicht, mein Solateur hat mir das BUS Kabel angeschlossen
      Warne ausdrücklich von der genannten Installationsfirma aus München!!!!
      In diese Versuchung kam ich in Wien nicht 🙂 aber herzlichen Dank für die Info!
      • metaxa
        metaxa @Homoran last edited by
        @homoran sagte in M-TEC Energy Butler:
        ist das nicht die Geräte ID?
        Mahhhh, richtig
        Der Fehler ist jetzt einmal weg, bleiben aber noch genügend andere 😰
        modbus.0
        2023-06-23 21:45:17.734	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
        modbus.0
        2023-06-23 21:45:17.701	error	unknown function code: 0x0, 0xef
        modbus.0
        2023-06-23 21:45:17.636	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.620	error	Wrong CRC for frame: 0,3,20,144,90,247,3,128,232,0,18,120,165,247,3,36,21,8,39,15,0,2,0,248,255
        modbus.0
        2023-06-23 21:45:17.527	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,74,0,5,19,136,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,64,0,37,19,134,0,0,0,0,2,225,0,0,0,0,0,0,0,0,9,82,0,3,19,139,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,3,37,0,0,0,0,0,0,0,0,0,0,0,82,0,0,0,0,0,0,0,0,0,0,3,7,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,29,0
        modbus.0
        2023-06-23 21:45:17.341	error	Wrong CRC for frame: 1,1,0,0,0
        modbus.0
        2023-06-23 21:45:17.320	error	unknown function code: 0x0, 0x40
        modbus.0
        2023-06-23 21:45:17.317	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.285	error	unknown function code: 0x26, 0x0
        modbus.0
        2023-06-23 21:45:17.269	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.253	error	Wrong CRC for frame: 247,3,42,254,0,60,56,165,247,3,120,16,41,16,34,16,35,9,78,0,9,9,83,0,34,9,83,0,10,19,134,0,0,3,25,0,0,1,36,0,0,1,129,0,0,0,31
        modbus.0
        2023-06-23 21:45:17.148	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.125	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.116	error	unknown function code: 0x22, 0x0
        modbus.0
        2023-06-23 21:45:17.095	error	Wrong CRC for frame: 247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247
        modbus.0
        2023-06-23 21:45:16.064	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
        modbus.0
        2023-06-23 21:45:16.055	debug	Initialization of scale factors done!
        modbus.0
        2023-06-23 21:45:16.042	debug	[DevID_247] Poll start ---------------------
        modbus.0
        2023-06-23 21:45:16.041	info	Connected to slave
          Homoran Global Moderator Administrators @metaxa last edited by
          @metaxa wrong crc hab ich noch nie gehabt
          A/B richtig rum?
          metaxa 1 Reply Last reply Reply Quote 0
          • metaxa
            metaxa @Homoran last edited by metaxa
            A/B richtig rum?
            Wie gesagt, mein Elektriker hat das gemacht. Aber ich springe mal in den Keller und tausche A/B um.
            hast du den Waveshare?
            Ja, den von dir empfohlenen (habe ihn auf 5V geschalten seitlich).
              @metaxa sagte in M-TEC Energy Butler:
              da hatcder Elektriker auch angeklemmt?
              • metaxa
                Ja, aber nur am Stecker
                Könnte diese Einstellung auch falsch sein?
                Ich gehe jetzt einmal umklemmen 🙂
                Homoran metaxa 2 Replies Last reply Reply Quote 0
                  ja, aber die hätte ich auch genommen.
                  Ab jetzt fische ich auch im trüben und würde in den allgemeinen Parametern spielen.
                  Alias mal aus -> was dann?
                  und auch die anderen Checkboxen mal testen
                  • metaxa
                    metaxa @metaxa last edited by metaxa
                    Uiiiiiii ..... das sind mehr Fehler als vorher
                    modbus.0
                    2023-06-23 21:59:39.687	info	Disconnected from slave
                    modbus.0
                    2023-06-23 21:59:39.583	error	Wrong CRC for frame: 255,1,2,2,52,252,255
                    modbus.0
                    2023-06-23 21:59:39.567	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.552	error	unknown function code: 0x7e, 0xb5
                    modbus.0
                    2023-06-23 21:59:39.500	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.491	error	Error response: fd
                    modbus.0
                    2023-06-23 21:59:39.470	error	unknown function code: 0x7e, 0xdb
                    modbus.0
                    2023-06-23 21:59:39.441	error	unknown function code: 0x7e, 0x5e
                    modbus.0
                    2023-06-23 21:59:39.393	error	Error response: e2
                    modbus.0
                    2023-06-23 21:59:39.381	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.366	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.348	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.336	error	Error response: f9
                    modbus.0
                    2023-06-23 21:59:39.318	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.302	error	unknown function code: 0x65, 0xff
                    modbus.0
                    2023-06-23 21:59:39.297	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.282	error	Error response: af
                    modbus.0
                    2023-06-23 21:59:39.277	error	Error response: fe
                    modbus.0
                    2023-06-23 21:59:39.259	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.242	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.182	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.174	error	Error response: a9
                    modbus.0
                    2023-06-23 21:59:39.158	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.144	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.129	error	Error response: fd
                    modbus.0
                    2023-06-23 21:59:39.110	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.093	error	Error response: eb
                    modbus.0
                    2023-06-23 21:59:39.075	error	Wrong CRC for frame: 0,4,126,181,131,239,13,58,0,4,126,247,255,255,255,1,2,2,140,252,255,255,241,255,255,255,255,3,93,0,4,126,108,247,233,201,43,0,4,126,186,169,103,103,179,102,246,182,246,246,44,150,246,182,54,214,54,110,255,255,255,255,131,154,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4,126,181,128,135,143,181,0,4,126,232,183,251,151,247,151,107,97,255
                    modbus.0
                    2023-06-23 21:59:38.686	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    2023-06-23 21:59:38.685	error	Request timed out.
                    modbus.0
                    2023-06-23 21:59:38.684	warn	Error: undefined
                    modbus.0
                    2023-06-23 21:59:36.679	error	Error response: e7
                    modbus.0
                    2023-06-23 21:59:36.664	error	Error response: fb
                    modbus.0
                    2023-06-23 21:59:36.657	error	Error response: fb
                    modbus.0
                    2023-06-23 21:59:36.641	error	unknown function code: 0x7e, 0xdb
                    modbus.0
                    2023-06-23 21:59:36.626	error	unknown function code: 0x7e, 0x5e
                    modbus.0
                    2023-06-23 21:59:36.570	error	Error response: 52
                    modbus.0
                    2023-06-23 21:59:36.564	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.548	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.532	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.523	error	Error response: f9
                    modbus.0
                    2023-06-23 21:59:36.504	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.489	error	unknown function code: 0x65, 0xff
                    modbus.0
                    2023-06-23 21:59:36.483	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.467	error	unknown function code: 0x79, 0xff
                    modbus.0
                    2023-06-23 21:59:36.462	error	Error response: f3
                    modbus.0
                    2023-06-23 21:59:36.444	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:36.428	error	Wrong CRC for frame: 0,4,126,232,247,251,183,247,151,107,103,255,237,237,103,255,183,237,91,255,235,217,243,254,255,249,241,254,255,253,179,255,255,253,249,254,255,255,193,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,253,157,250,129,250,187,250,129,134,115,225,185,255,255,255,253,255,255,255,253,99,191,101,49,198,129,255,255,173,137,254,255,255,251,91,117,225,1,254,225,253,253,255,127,195,169,134,169,174,111,159,143,235,239,173,247,253,253,255,255,255,255,255,255,255,255,255,255,37,154,0,4,126,69,224,135
                    modbus.0
                    2023-06-23 21:59:36.230	error	Wrong CRC for frame: 0,4,126,108,247,233,201,43,0,4,126,186,169,103,103,179,102,246,182,246,246,44,150,246,182,54,214,54,110,255,255,255,255,131,154,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4
                    modbus.0
                    2023-06-23 21:59:33.671	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
                    modbus.0
                    2023-06-23 21:59:33.670	debug	Initialization of scale factors done!
                    modbus.0
                    2023-06-23 21:59:33.667	debug	[DevID_247] Poll start ---------------------
                    modbus.0
                    2023-06-23 21:59:33.665	info	Connected to slave
                    modbus.0
                    2023-06-23 21:59:33.636	debug	connect to serial /dev/ttyUSB1 with 9600
                    modbus.0
                    2023-06-23 21:59:32.476	debug	Initialize Objects for holdingRegs: []
                    modbus.0
                    2023-06-23 21:59:32.473	debug	Add inputRegisters.33000_State_of_Charge_(SOC): {"_id":"inputRegisters.33000_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":247,"type":"uint16be","len":1,"offset":0,"factor":1}}
                    modbus.0
                    2023-06-23 21:59:32.469	debug	Initialize Objects for inputRegs: [{"_address":"33000","name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":2999,"deviceId":247,"id":"inputRegisters.33000_State_of_Charge_(SOC)"}]
                    modbus.0
                    2023-06-23 21:59:32.461	debug	Initialize Objects for coils: []
                    modbus.0
                    2023-06-23 21:59:32.458	debug	Initialize Objects for disInputs: []
                    modbus.0
                    2023-06-23 21:59:31.818	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
                    Klemme wieder zurück!
                      ja! wie blinkt es denn?
                      • metaxa
                        wie blinkt es denn?
                        Kurz nur die rechte LED flackert nach dem Bestromen blau hört aber nach 2 Sekunden wieder auf und bleibt finster, links Power bleibt brav rot.
                          Homoran Global Moderator Administrators @metaxa last edited by Homoran
                          @metaxa der müsste jede Sekunde Blinken.
                          Brauchst du so viele Daten? sonst setz das Intervall runter 5000msec müssten vollkommen reichen.
                          • metaxa
                            Habe jetzt wieder zurückgeklemmt, paar von diesen 16Bit Einträgen ausprobiert, es kommt immer dieser "Wrong SRC for frame"
                            modbus.0
                            2023-06-23 22:16:39.630	debug	[DevID_247] Poll start ---------------------
                            modbus.0
                            2023-06-23 22:16:37.896	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,71,0,3,19,134,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,64,0,38,19,136,0,0,0,0,2,161,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,28,0,0,0,0,0,0,0,0,0,0,2,230,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,173,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,9,27,0
                            modbus.0
                            2023-06-23 22:16:37.561	error	Error response: 28
                            modbus.0
                            2023-06-23 22:16:37.497	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:37.486	error	Wrong CRC for frame: 247,3,128,232,0,18,120,165,247,3,36,19,92,39,15,0,2,0,244,255,255,255,255,255,255,255,255,0,0,1,1,0,0,0,230,0,0,12,195,0,0,12,183,0,0,0,0,226,200,247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,255,255,255,243,0,0,0,7,0,0,0,0,235,1,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0
                            modbus.0
                            2023-06-23 22:16:35.088	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,67,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,67,0,36,19,134,0,0,0,0,2,166,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,235,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,184,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
                            modbus.0
                            2023-06-23 22:16:34.750	error	unknown function code: 0x28, 0xf7
                            modbus.0
                            2023-06-23 22:16:34.687	error	Wrong CRC for frame: 247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
                            modbus.0
                            2023-06-23 22:16:34.589	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:34.574	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,13,0,0,0,7,0,0,0,26,115,95,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
                            modbus.0
                            2023-06-23 22:16:32.338	error	Error response: Value is not accepted by slave
                            modbus.0
                            2023-06-23 22:16:32.337	error	Error response for FCx119: Illegal Data Value
                            modbus.0
                            2023-06-23 22:16:32.275	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,69,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,62,0,35,19,134,0,0,0,0,2,162,0,0,0,0,0,0,0,0,9,76,0,2,19,134,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,231,0,0,0,0,0,0,0,0,0,0,0,84,0,0,0,0,0,0,0,0,0,0,2,237,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
                            modbus.0
                            2023-06-23 22:16:31.940	error	Error response: 28
                            modbus.0
                            2023-06-23 22:16:31.879	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:31.861	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:31.843	error	unknown function code: 0x3d, 0xf7
                            modbus.0
                            2023-06-23 22:16:31.835	error	unknown function code: 0x0, 0xbe
                            modbus.0
                            2023-06-23 22:16:31.766	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,20,0,0,0,7,0,0,0,33,149,28,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
                            modbus.0
                            2023-06-23 22:16:29.577	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
                            modbus.0
                            2023-06-23 22:16:29.527	error	Error response: f7
                            modbus.0
                            2023-06-23 22:16:29.468	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.447	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.432	error	unknown function code: 0x53, 0x0
                            modbus.0
                            2023-06-23 22:16:29.416	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.400	error	unknown function code: 0x13, 0x86
                            modbus.0
                            2023-06-23 22:16:29.384	error	unknown function code: 0x0, 0x2
                            modbus.0
                            2023-06-23 22:16:29.371	error	Wrong CRC for frame: 0,3,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,215,40,247,3,42,254,0,60,56,165,247,3,120,16,25,16,24,16,29,9,73,0,9,9,76,0,32,9,77,0,10,19,135,0,0,3,1,0,0,1,41,0,0,1,134,0,0,0,31,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,176,1,190,1,161,1,190,30,63,15,30,0,0,0,1,0,0,0,1,78,32,78,6,78,45,0,0,41,187,0,0,0,2,81,199,15,255,0,15,1,1,0,64,30,163,30,163,19,93,48,56,10,8,41,4,1,1,0,0,0,0,0,0,0,0,0,0,245,199,247,3,117,248,0,60,202,176,247,3,120,9,68,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,66,0,37
                            modbus.0
                            2023-06-23 22:16:28.445	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
                            modbus.0
                            2023-06-23 22:16:28.444	debug	Initialization of scale factors done!
                            modbus.0
                            2023-06-23 22:16:28.440	debug	[DevID_247] Poll start ---------------------
                            modbus.0
                            2023-06-23 22:16:28.438	info	Connected to slave
                            modbus.0
                            2023-06-23 22:16:28.415	debug	connect to serial /dev/ttyUSB1 with 9600
                            modbus.0
                            2023-06-23 22:16:27.710	debug	Initialize Objects for holdingRegs: []
                            modbus.0
                            2023-06-23 22:16:27.709	debug	Add inputRegisters.2999_State_of_Charge_(SOC): {"_id":"inputRegisters.2999_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":247,"type":"int16le","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-06-23 22:16:27.708	debug	Initialize Objects for inputRegs: [{"_address":2999,"name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"int16le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":false,"isScale":"","address":2999,"deviceId":247,"id":"inputRegisters.2999_State_of_Charge_(SOC)"}]
                            modbus.0
                            2023-06-23 22:16:27.707	debug	Initialize Objects for coils: []
                            modbus.0
                            2023-06-23 22:16:27.706	debug	Initialize Objects for disInputs: []
                            modbus.0
                            2023-06-23 22:16:27.222	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
                            alais Checkbox hat nix verändert.
                            • metaxa
                              Kann ich aus dem LOG erkennen ob da am anderen Ende überhaupt Daten sind, die Busschnittstelle die richtige ist?
                                @metaxa das versuche ich die ganze Zeit zu erkennen.
                                was sagt denn lsusb?
                                • metaxa
                                  lsusb
                                  andreas@iOProduktiv:~$ lsusb -t
                                  /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                  /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                  /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
                                  /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                      |__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                                      |__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
                                  /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
                                      |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbfs, 12M
                                  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                      |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                                  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
                                  andreas@iOProduktiv:~$ ls -l /dev/serial/by-id
                                  insgesamt 0
                                  lrwxrwxrwx 1 root root 13 23. Jun 19:53 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
                                  lrwxrwxrwx 1 root root 13 23. Jun 22:09 usb-FTDI_FT232R_USB_UART_A10N5R2A-if00-port0 -> ../../ttyUSB1
                                    @metaxa was hängt denn noch dran?
                                    pi@tinkerboard:~$ ls -l /dev/serial/by-id
                                    insgesamt 0
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:54 usb-FTDI_FT232R_USB_UART_A10NBMVW-if00-port0 -> ../../ttyUSB1
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-FTDI_FT232R_USB_UART_AB0OH9QR-if00-port0 -> ../../ttyUSB2
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01066523-if00-port0 -> ../../ttyUSB0
                                    ich hab 2 dran
                                    • metaxa
                                      NUC -->
                                      1x USB für NUT (APC)
                                      1x USB Hub (Hama)
                                      --> ZigbeeStick
                                      --> Waveshare
                                        @metaxa dann bist du mit usb1 wohl richtig
                                        • metaxa
                                          Ich stehe momentan an, habe keine Idee zur Zeit.
                                          Aber großen Dank zum 100sten Mal für deine Zeit und deine Geduld.
                                          mxa
                                            @metaxa Geduld hilft dir nicht wirklich.
                                            Hab keine Ahnung wo so ein Checksummenfehler herkommt und was man tun kann.
                                            ganz tief im Bauch meint jemsnd dass da was in die Leitungen einstreut.
                                            Aber glaub ich ehrlich nicht
                                            Dann erst mal gute Nacht
                                            metaxa Homoran 2 Replies Last reply Reply Quote 1
                                            201
                                            51677
