    4. M-TEC Energy Butler
    M-TEC Energy Butler
      Homoran Global Moderator Administrators @metaxa last edited by Homoran
      @metaxa der müsste jede Sekunde Blinken.
      Brauchst du so viele Daten? sonst setz das Intervall runter 5000msec müssten vollkommen reichen.
      metaxa 1 Reply Last reply Reply Quote 0
      • metaxa
        metaxa @Homoran last edited by metaxa
        Habe jetzt wieder zurückgeklemmt, paar von diesen 16Bit Einträgen ausprobiert, es kommt immer dieser "Wrong SRC for frame"
        modbus.0
        2023-06-23 22:16:39.630	debug	[DevID_247] Poll start ---------------------
        modbus.0
        2023-06-23 22:16:37.896	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,71,0,3,19,134,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,64,0,38,19,136,0,0,0,0,2,161,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,28,0,0,0,0,0,0,0,0,0,0,2,230,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,173,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,9,27,0
        modbus.0
        2023-06-23 22:16:37.561	error	Error response: 28
        modbus.0
        2023-06-23 22:16:37.497	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:37.486	error	Wrong CRC for frame: 247,3,128,232,0,18,120,165,247,3,36,19,92,39,15,0,2,0,244,255,255,255,255,255,255,255,255,0,0,1,1,0,0,0,230,0,0,12,195,0,0,12,183,0,0,0,0,226,200,247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,255,255,255,243,0,0,0,7,0,0,0,0,235,1,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0
        modbus.0
        2023-06-23 22:16:35.088	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,67,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,67,0,36,19,134,0,0,0,0,2,166,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,235,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,184,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
        modbus.0
        2023-06-23 22:16:34.750	error	unknown function code: 0x28, 0xf7
        modbus.0
        2023-06-23 22:16:34.687	error	Wrong CRC for frame: 247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
        modbus.0
        2023-06-23 22:16:34.589	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:34.574	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,13,0,0,0,7,0,0,0,26,115,95,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
        modbus.0
        2023-06-23 22:16:32.338	error	Error response: Value is not accepted by slave
        modbus.0
        2023-06-23 22:16:32.337	error	Error response for FCx119: Illegal Data Value
        modbus.0
        2023-06-23 22:16:32.275	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,69,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,62,0,35,19,134,0,0,0,0,2,162,0,0,0,0,0,0,0,0,9,76,0,2,19,134,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,231,0,0,0,0,0,0,0,0,0,0,0,84,0,0,0,0,0,0,0,0,0,0,2,237,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
        modbus.0
        2023-06-23 22:16:31.940	error	Error response: 28
        modbus.0
        2023-06-23 22:16:31.879	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:31.861	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:31.843	error	unknown function code: 0x3d, 0xf7
        modbus.0
        2023-06-23 22:16:31.835	error	unknown function code: 0x0, 0xbe
        modbus.0
        2023-06-23 22:16:31.766	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,20,0,0,0,7,0,0,0,33,149,28,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
        modbus.0
        2023-06-23 22:16:29.577	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
        modbus.0
        2023-06-23 22:16:29.527	error	Error response: f7
        modbus.0
        2023-06-23 22:16:29.468	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:29.447	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:29.432	error	unknown function code: 0x53, 0x0
        modbus.0
        2023-06-23 22:16:29.416	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 22:16:29.400	error	unknown function code: 0x13, 0x86
        modbus.0
        2023-06-23 22:16:29.384	error	unknown function code: 0x0, 0x2
        modbus.0
        2023-06-23 22:16:29.371	error	Wrong CRC for frame: 0,3,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,215,40,247,3,42,254,0,60,56,165,247,3,120,16,25,16,24,16,29,9,73,0,9,9,76,0,32,9,77,0,10,19,135,0,0,3,1,0,0,1,41,0,0,1,134,0,0,0,31,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,176,1,190,1,161,1,190,30,63,15,30,0,0,0,1,0,0,0,1,78,32,78,6,78,45,0,0,41,187,0,0,0,2,81,199,15,255,0,15,1,1,0,64,30,163,30,163,19,93,48,56,10,8,41,4,1,1,0,0,0,0,0,0,0,0,0,0,245,199,247,3,117,248,0,60,202,176,247,3,120,9,68,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,66,0,37
        modbus.0
        2023-06-23 22:16:28.445	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
        modbus.0
        2023-06-23 22:16:28.444	debug	Initialization of scale factors done!
        modbus.0
        2023-06-23 22:16:28.440	debug	[DevID_247] Poll start ---------------------
        modbus.0
        2023-06-23 22:16:28.438	info	Connected to slave
        modbus.0
        2023-06-23 22:16:28.415	debug	connect to serial /dev/ttyUSB1 with 9600
        modbus.0
        2023-06-23 22:16:27.710	debug	Initialize Objects for holdingRegs: []
        modbus.0
        2023-06-23 22:16:27.709	debug	Add inputRegisters.2999_State_of_Charge_(SOC): {"_id":"inputRegisters.2999_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":247,"type":"int16le","len":1,"offset":0,"factor":1}}
        modbus.0
        2023-06-23 22:16:27.708	debug	Initialize Objects for inputRegs: [{"_address":2999,"name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"int16le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":false,"isScale":"","address":2999,"deviceId":247,"id":"inputRegisters.2999_State_of_Charge_(SOC)"}]
        modbus.0
        2023-06-23 22:16:27.707	debug	Initialize Objects for coils: []
        modbus.0
        2023-06-23 22:16:27.706	debug	Initialize Objects for disInputs: []
        modbus.0
        2023-06-23 22:16:27.222	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
        alais Checkbox hat nix verändert.
        • metaxa
          metaxa @metaxa last edited by
          Kann ich aus dem LOG erkennen ob da am anderen Ende überhaupt Daten sind, die Busschnittstelle die richtige ist?
            @metaxa das versuche ich die ganze Zeit zu erkennen.
            was sagt denn lsusb?
            • metaxa
              @homoran sagte in M-TEC Energy Butler:
              lsusb
              andreas@iOProduktiv:~$ lsusb -t
              /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
              /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
              /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
              /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                  |__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                  |__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
              /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
                  |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbfs, 12M
              /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                  |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
              /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
              andreas@iOProduktiv:~$ ls -l /dev/serial/by-id
              insgesamt 0
              lrwxrwxrwx 1 root root 13 23. Jun 19:53 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
              lrwxrwxrwx 1 root root 13 23. Jun 22:09 usb-FTDI_FT232R_USB_UART_A10N5R2A-if00-port0 -> ../../ttyUSB1
                @metaxa was hängt denn noch dran?
                pi@tinkerboard:~$ ls -l /dev/serial/by-id
                insgesamt 0
                lrwxrwxrwx 1 root root 13 14. Mai 22:54 usb-FTDI_FT232R_USB_UART_A10NBMVW-if00-port0 -> ../../ttyUSB1
                lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-FTDI_FT232R_USB_UART_AB0OH9QR-if00-port0 -> ../../ttyUSB2
                lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01066523-if00-port0 -> ../../ttyUSB0
                ich hab 2 dran
                • metaxa
                  NUC -->
                  1x USB für NUT (APC)
                  1x USB Hub (Hama)
                  --> ZigbeeStick
                  --> Waveshare
                    @metaxa dann bist du mit usb1 wohl richtig
                    • metaxa
                      Ich stehe momentan an, habe keine Idee zur Zeit.
                      Aber großen Dank zum 100sten Mal für deine Zeit und deine Geduld.
                      mxa
                        @metaxa Geduld hilft dir nicht wirklich.
                        Hab keine Ahnung wo so ein Checksummenfehler herkommt und was man tun kann.
                        ganz tief im Bauch meint jemsnd dass da was in die Leitungen einstreut.
                        Aber glaub ich ehrlich nicht
                        Dann erst mal gute Nacht
                        metaxa Homoran 2 Replies Last reply Reply Quote 1
                        • metaxa
                          @Homoran
                          Gute Nacht und nochmals Danke! Eventuell findet sich ja noch ein weiterer Modbus - System -Guru und erbarmt sich 🙂
                          • metaxa
                            metaxa @manrum1 last edited by
                            @manrum1 sagte in M-TEC Energy Butler:
                            Aber sicher werde ich danach die Anlage anbinden.
                            Was wurde denn alles bei dir an M-TEC Gerätschaften verbaut?
                            Bei mir
                            • Butler BMS
                            • 3x Energy Butler Batteriemodul 3,84 kWh
                            • E-Smart T4 (Vorsicht!)
                              Homoran Global Moderator Administrators @Homoran last edited by
                              oder doch.
                              hat mir keine Ruhe gelassen.
                              Anderes Gerät aber Modbus!
                              so wie ich schrob: Data muss ein verdrilltes Paar sein.
                              Verdrillen eines Paars für A und B mit GND hat mich von Anfang an irgendwie gestört.
                              Muss nichts heißen, kann aber sein
                              metaxa 2 Replies Last reply Reply Quote 0
                              • metaxa
                                @homoran Na dann baue ich das noch um, muss nur jetzt auch die Verkabelung vom Elektriker in seinem Verteilerschrank anfassen. ist mir aber wurscht, ist nur der Bus, im schlimmsten Fall sind paar Daten weg, die ich eh nicht im iO habe.
                                Mach das doch lieber erst morgen Früh.
                                Soll in GND auch mal weglassen?
                                  @metaxa sagte in M-TEC Energy Butler:
                                  auf jeden Fall auf einer Seite!
                                  • metaxa
                                    Jetzt:
                                    1 Paar A
                                    1 Paar B
                                    1 Paar GND
                                    Morgen:
                                    1 Paar A+B
                                    nix GND
                                      Jetzt:
                                      1 Paar A
                                      1 Paar B
                                      1 Paar GND
                                      das bringt ja nur was um höhere Stromstärken zu erlauben.
                                      Gegen Störungen hilft das gar nichts.
                                      Morgen:
                                      1 Paar A+B
                                      nix GND
                                      so hab ich es
                                      viel Glück!
                                      • metaxa
                                        so hab ich es
                                        ich werde es nachbauen und berichten und jetzt aber ab in die Waagerechte 🙂 habe dich schon lange genug beschäftigt!
                                          aber nicht blau oder grün nehmen, die sind IMHO nicht mit ihren weißen Partnern verdrillt.
                                          • metaxa
                                            @homoran Guten Morgen!
                                            Ich habe mir das jetzt im Keller einmal angesehen. Beide M-TEC Devices kommunizieren über Modbus sowie der 3P-Stromzähler. In beiden Fallen hat der Elektriker für beide 5m Kabelwege ein Cat5e Kabel genommen, jeweils 1 Pärchen für A und eines für B verdrillt und KEIN GND verwendet. Die Kommunikation funkt einwandfrei, selbst mit einem Cat5e Netzwerkkabel ohne extra geschirmter Pärchen.
                                            Für meine BUSLeitung habe ich Ihnen mein CAT7 Kabel gegeben, da ist ja sogar noch jedes Pärchen foliert. Die Leitungslänge ist maginal länger, ich glaube da nicht an übersprechen.
                                            Ein Unterschied ist GND, den gibt es nur bei meiner Leitung, aufgelegt am Anfang und am Ende.
                                            Ich werde GND beim RS485 Converter entfernen, bevor ich im laufenden neuen System einfach das BUS Kabel für 10 Minuten entferne um auf 1 Pärchen zu reduzieren.
                                            Homoran metaxa 2 Replies Last reply Reply Quote 0
                                            201
                                            51687
