    3. Entwicklung
    4. Adapter: milight
    Adapter: milight
      Ralf last edited by
      hier der Log (milight Adapter im Debug), Zone 1 "on" gedrückt und Zone all "on". Nix passiert.
      ! :idea:````
      milight.0 2017-09-09 09:20:29.136 debug keep alive response
      milight.0 2017-09-09 09:20:29.103 debug Sending: d000000002f402
      milight.0 2017-09-09 09:20:19.265 debug keep alive response
      milight.0 2017-09-09 09:20:19.093 debug Sending: d000000002f402
      milight.0 2017-09-09 09:20:09.229 debug keep alive response
      milight.0 2017-09-09 09:20:09.090 debug Sending: d000000002f402
      milight.0 2017-09-09 09:19:59.205 debug keep alive response
      milight.0 2017-09-09 09:19:59.085 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:49.237 debug keep alive response
      milight.0 2017-09-09 07:19:49.074 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:39.282 debug keep alive response
      milight.0 2017-09-09 07:19:39.044 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:32.882 debug 244
      milight.0 2017-09-09 07:19:32.882 debug 000400
      milight.0 2017-09-09 07:19:32.880 debug 0:8800000003000400
      milight.0 2017-09-09 07:19:32.792 debug inMem message milight.0.* milight.0.zoneAll.on val=true, ack=true, ts=1504941572783, q=0, from=system.adapter.milight.0, lc=1504941572750
      milight.0 2017-09-09 07:19:32.760 debug Sending: 8000000011f402000400310000000303000000010038
      milight.0 2017-09-09 07:19:32.759 debug #128,0,0,0,17,244,2,0,4,0,49,0,0,0,3,3,0,0,0,1,0,56
      milight.0 2017-09-09 07:19:32.757 debug V6 Send to zone 0 "on": NaN
      milight.0 2017-09-09 07:19:32.755 debug inMem message milight.0.* milight.0.zoneAll.on val=true, ack=false, ts=1504941572750, q=0, from=system.adapter.admin.0, lc=1504941572750
      milight.0 2017-09-09 07:19:29.681 debug keep alive response
      milight.0 2017-09-09 07:19:29.036 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:19.132 debug keep alive response
      milight.0 2017-09-09 07:19:19.024 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:09.394 debug keep alive response
      milight.0 2017-09-09 07:19:09.022 debug Sending: d000000002f402
      milight.0 2017-09-09 07:19:00.997 debug 244
      milight.0 2017-09-09 07:19:00.997 debug 000300
      milight.0 2017-09-09 07:19:00.996 debug 0:8800000003000300
      milight.0 2017-09-09 07:19:00.938 debug inMem message milight.0.* milight.0.zone1.on val=true, ack=true, ts=1504941540930, q=0, from=system.adapter.milight.0, lc=1504785649007
      milight.0 2017-09-09 07:19:00.912 debug Sending: 8000000011f40200030031000007030100000001003d
      milight.0 2017-09-09 07:19:00.911 debug #128,0,0,0,17,244,2,0,3,0,49,0,0,7,3,1,0,0,0,1,0,61
      milight.0 2017-09-09 07:19:00.904 debug V6 Send to zone 1 "on": NaN
      milight.0 2017-09-09 07:19:00.900 debug inMem message milight.0.* milight.0.zone1.on val=true, ack=false, ts=1504941540892, q=0, from=system.adapter.admin.0, lc=1504785649007
      milight.0 2017-09-09 07:18:59.135 debug keep alive response
      milight.0 2017-09-09 07:18:59.019 debug Sending: d000000002f402
      milight.0 2017-09-09 07:18:49.116 debug keep alive response
      milight.0 2017-09-09 07:18:49.009 debug Sending: d000000002f402
      milight.0 2017-09-09 07:18:39.670 debug keep alive response
      milight.0 2017-09-09 07:18:39.005 debug Sending: d000000002f402
      milight.0 2017-09-09 07:18:29.076 debug 244
      milight.0 2017-09-09 07:18:29.075 debug 000200
      milight.0 2017-09-09 07:18:29.071 debug 0:8800000003000200
      milight.0 2017-09-09 07:18:29.015 debug inMem message milight.0.* milight.0.info.connection val=true, ack=true, ts=1504941509002, q=0, from=system.adapter.milight.0, lc=1504941509002
      milight.0 2017-09-09 07:18:28.997 debug Sending: 8000000011f40200020033000000000000000000000033
      milight.0 2017-09-09 07:18:28.996 debug out: 8000000011f40200020033000000000000000000000033
      milight.0 2017-09-09 07:18:28.989 debug WB: 244 2 CMD: 51,0,0,0,0,0,0,0,0,0
      milight.0 2017-09-09 07:18:28.987 debug BridgeID2: 2
      milight.0 2017-09-09 07:18:28.986 debug BridgeID: 244
      milight.0 2017-09-09 07:18:28.979 debug Padding: 0200
      milight.0 2017-09-09 07:18:28.979 debug Counter: f4
      milight.0 2017-09-09 07:18:28.978 debug 3: 2a070001
      milight.0 2017-09-09 07:18:28.978 debug 2a: 12a2
      milight.0 2017-09-09 07:18:28.977 debug MAC: f0fe6b4b136c
      milight.0 2017-09-09 07:18:28.977 debug 1: 0002
      milight.0 2017-09-09 07:18:28.976 debug Message: 28000000110002f0fe6b4b136c12a22a070001f40200
      milight.0 2017-09-09 07:18:28.667 debug Sending: 200000001602623ad5eda301ae082d466141a7f6dcaffef700001e
      milight.0 2017-09-09 07:18:28.666 debug 200000001602623ad5eda301ae082d466141a7f6dcaffef700001e
      milight.0 2017-09-09 07:18:18.627 info starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.milight, node: v4.8.4
      milight.0 2017-09-09 07:18:18.538 debug statesDB connected
      milight.0 2017-09-09 07:18:18.455 debug objectDB connected
      host.raspberrypi 2017-09-09 07:18:16.948 info instance system.adapter.milight.0 started with pid 14262
      host.raspberrypi 2017-09-09 07:18:14.543 info instance system.adapter.milight.0 terminated with code 0 (OK)
      host.raspberrypi 2017-09-09 07:18:14.425 info stopInstance system.adapter.milight.0 killing pid 27415
      host.raspberrypi 2017-09-09 07:18:14.424 info stopInstance system.adapter.milight.0
      Geändert: code in code-tags und spoiler; ****Homoran (Mod)****
        Ralf last edited by
        ist erledigt. Nach langem Probieren, Deinstallation des milight Adapters und neuer Installation
        gings mit der Einstellung im Screeshot :
        Muss bei meiner HW auf Version 6 und alle Zonen auf RGBWW/Dimmer stehen.
        Ausserdem hatte ich vorher die IP von Hand eingetragen. Diesmal suchen lassen.
        ich weis nicht, ob das auch eine Rolle gespielt hat.
          foxthefox Developer last edited by
          @Ralf:
          ich weis nicht, ob das auch eine Rolle gespielt hat. `
          Das freut mich aber.
          Hatte die IP auch im Verdacht, aber die schien ja korrekt zu sein 😉
          Mit der Suchfunktion erhält man bei der V6 auf jeden Fall die antwortende Box.
            slemy last edited by
            kann mir bitte jemand sagen, was ich unter Cloud wählen muss, damit man über Alexa die Farbe ( zum Beispiel Grün , Blau Rot u.s.w ) wählen kann?
            Ich kann alles wie AN/AUS Zonen 1-4 und Dimmen wählen, nur die Farben kann ich nicht.
            THX
            • kmxak
              Es gibt für die Milight Lampen ein alternatives Gateway.
              Hier gibt es weitere Infos.
              https://github.com/sidoh/esp8266_milight_hub/
              Die originalen Gateways können ja max. 2 Geräte speichern. Mit dem alternativen kann man nun wohl "unendlich" speichern.
              Es ist von den Kosten her auch fast identisch.
              Falls da einer Probleme mit den Geräten hat und das mal testen möchte bitte Rückinfo 8-)
                @kmxak:
                Falls da einer Probleme mit den Geräten hat und das mal testen möchte bitte Rückinfo 8-) `
                esp8266_milight_hub benutze ich auch mit AZDelivery NodeMCU Lua Amica Module V2 ESP8266 ESP-12E für 8€ und funktioniert 1A .
                • kmxak
                  Ok kannst du mir sagen ob das "besser" ist? Kann man damit mehr oder ist das 1:1 Umsetzung
                  Gesendet von meinem SM-G930F mit Tapatalk
                    @kmxak:
                    Gesendet von meinem SM-G930F mit Tapatalk `
                    klar ist es besser , zb Gateway Servers Protocol 5 / 6 kann parallel benutzt werden , mehrere Gateway .
                    benutze es erst seit ein Woche ,bin aber beim ioBroker hängen geblieben wegen RGBW Einstellungen , und auch nicht weiter getestet was noch so kann .
                      Gibt es überraubt eine Möglichkeit RGBW mit dem Milight-Adapter zu bedienen ?
                        Mr.X last edited by
                        Guten morgen zusammen,
                        ich bin seit 1 Woche mit ioBroker unterwegs. Meinen Broadlink Adapter konnte ich schon erfolgreich mit Blockly mit Alexa verbinden.
                        Nach vieeel gefummel kann ich nun endlich auch meine V5 Milights (RGBWW-Leuchten) zumindest manuel steuern.
                        Auf Seite 1 oder zwei hier wird gezeigt, wie im cloud Adapapter ein Gerät hinzugefügt wird und dann die Befehle AN/AUS/%/rauf/runter hat. Das kriege ich bei mir hin wenn ich brightness einer Zone einfüge.
                        Aber Alexa sagt immer:" "<size size="85">Name des Smarten Gerätes</size>" unterstützt das nicht."
                        Muss ich noch irgendwas weiteres einstellen?
                        Slemmy schrieb oben, dass er auch nicht so genau weiß, wie man die Milights per Alex steuert. Vielleicht hätte jemand Zeit die wichtigsten Schritte zu erklären. Dies scheint ja der wesentlichste Thread zu Milight zu sein. Mehr infos habe ich nirgends gefunden.
                        Sobald das dann bei mir hoffentlich mal läuft: Kann ich von dem Adapter eine weitere Instanz installieren und somit eine weitere Bridge/Lampen stuern?
                          Mr.X last edited by
                          Also ich muss was ergänzen,
                          Der Befehl: "Alexa, schalte Zone AN" funktioniert. Alle Lampen gehen tatsächlich aus.
                          Aber "Alexa, schalte Zone aus" oder setze auf 50%, schalte auf 50%, dimme auf 50% ergibt immer, dass es nicht unterstützt wird.
                          Den Wert bei AN, kann ich einstellen wie ich will, es schaltet sich immer das letzte eingestellte ein.
                          Bleibt also bei voller Helligkeit, wenn ich auf 10% stelle.
                          Füge ich aber einen normalen Switch, also nur AN/AUS, ein funktioniert alles wunderbar.
                          Im Cloud Adapter sieht das so aus:
                            @tadek:
                            Im Cloud Adapter sieht das so aus: `
                            versuch mal damit zb Alexa , dimme auf 50% 40% oder 10 % +/-
                            udp://192.168.X.X:8899/0x420055
                            udp://192.168.X.X:8899/0x4E${intensity.math((X27)/255)}55*
                            ohne stern am anfang und ende !!! IP auch anpassen .
                              Mr.X last edited by
                              Ähm, Danke sehr,
                              Aber was ist das für ein Menu? Habe es nirgends gefunden?
                              Sieht irgendwie nach HA-Bridge aus?
                                @tadek:
                                Ähm, Danke sehr,
                                Sieht irgendwie nach HA-Bridge aus? `
                                sorry :lol: hab so viel getestet das ich jetzt mit ioBroker verwechselt habe , ja es ist HA-Bridge
                                da funktioniert auch alles bis auf RGBW , habe es auch nicht hinbekommen .
                                Helligkeit kann ich heute Abend nochmal testen wenn ich Zuhause bin , dann meld ich mich wieder .
                                  Mr.X last edited by
                                  Also, mit "Alexa, dimme Lampe auf 10%c
                                  Scheint zu funktionieren.
                                  Kann aber erst abends genauer testen.
                                    @tadek:
                                    Kann aber erst abends genauer testen. `
                                    also mit Alexa dimmen geht bei mir auch mit "Zone 4 Brightness level.dimmer "
                                    was bei mir nicht geht ist RGB
                                    nur wenn ich unter "Zone 4 Color RGB level.rgb " 111 wähle schaltet dann auf Grün.
                                    über Alexa schaltet nur von Weiß auf Blau und umgekehrt , Blau zb. ist dann 255
                                    mit Alexa schon alles versucht , Alexa licht auf Grün ,nichts Alexa Licht auf 111 usw.
                                    verstehe nicht , benutzt hier keiner RGBW das mir einer hilft ?
                                    • cvidal
                                      bei mir werden in der Vis.App die Milight Widgets nicht angezeigt, ist das bei euch auch so?
                                      Gruß Christian
                                        @cvidal:
                                        Gruß Christian `
                                        vielleicht hilft dir das weiter
                                        h**ps://http://www.youtube.com/watch?v=Uf6pen5Fj_0
                                          @cvidal:
                                          Gruß Christian `
                                          Habe gestern ganz frisch installiert und da war es in VIS auch angezeigt.
                                          In einem der vorhergehenden posts, steht auch der Hinweis es mit "iobroker visdebug milight"hochzuladen.
                                          • cvidal
                                            Warum auch immer sind die Widgets seit Gestern zusehen, ich hatte nur den Orange Pi rebootet das aber aus einem anderen Grund…
                                            naja jetzt läuft es ja.
                                            Gruß Christian
                                            314
                                            73904
