    4. Easee Wallbox mit iobroker
    • Newan
      Newan @warp-it last edited by
      @warp-it Ist ein neuer commit online.. Mal testen dann mach ich ne Version
      K W 2 Replies Last reply Reply Quote 0
        kaffeschluerfer @Newan last edited by
        @newan hab gerade aus Github installiert und getestet - leider immernoch dasselbe Problem. Ohne SignalIR gehts aber.
        easee.0
        	2023-05-10 17:01:03.759	info	starting. Version 1.0.7 (non-npm: Newan/ioBroker.easee) in /opt/iobroker/node_modules/iobroker.easee, node: v16.19.1, js-controller: 4.0.24
        easee.0
        	2023-05-10 17:00:39.847	warn	get state error: Connection is closed.
        easee.0
        	2023-05-10 17:00:39.846	warn	Could not perform strict object check of state easee.0.EH7J4CYM.name: DB closed
        easee.0
        	2023-05-10 17:00:39.335	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        easee.0
        	2023-05-10 17:00:39.335	info	terminating
        easee.0
        	2023-05-10 17:00:39.334	info	Adaptor easee cleaned up everything...
        easee.0
        	2023-05-10 17:00:39.302	error	Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure')
        easee.0
        	2023-05-10 17:00:39.302	error	Error: Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure') at HttpConnection._getNegotiationResponse (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:256:35) at async HttpConnection._startInternal (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:172:41) at async HttpConnection.start (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HttpConnection.js:75:9) at async HubConnection._startInternal (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HubConnection.js:132:9) at async HubConnection._startWithStateTransitions (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/HubConnection.js:109:13)
        easee.0
        	2023-05-10 17:00:39.301	error	unhandled promise rejection: Failed to complete negotiation with the server: TypeError: Cannot read properties of undefined (reading 'secure')
        easee.0
        	2023-05-10 17:00:39.300	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        easee.0
        	2023-05-10 17:00:39.225	info	Starting SignalR
        easee.0
        	2023-05-10 17:00:38.965	info	Easee Api Login successful
        easee.0
        	2023-05-10 17:00:38.634	info	starting. Version 1.0.7 (non-npm: Newan/ioBroker.easee) in /opt/iobroker/node_modules/iobroker.easee, node: v16.19.1, js-controller: 4.0.24
          Thomas Braun Most Active @kaffeschluerfer last edited by
          @kaffeschluerfer sagte in Easee Wallbox mit iobroker:
          node: v16.19.1
          Versuch es mit der aktuellen Empfehlung nodejs@18.
            @thomas-braun said in Easee Wallbox mit iobroker:
            jap, das war's. Funktioniert wieder mit SignalIR. Hatte übersehen dass ich nodejs aktualisieren sollte... Danke!
              Smokey @kaffeschluerfer last edited by
              Ich habe leider immer noch ein Problem:
              easee.0 2023-05-15 10:03:50.813 error Easee API error on charger session - stop refresh
              easee.0 2023-05-15 10:03:50.812 error Error: Request failed with status code 403
              Da ich mein System ohnehin am WE neu aufsetzen musste, habe ich soweit alles auf dem letzten Stand. Ob SignalIR an oder aus macht keinen Unterschied. Aufgefallen ist mir, dass mein Adapter die Version 1.07 hat. Auf Git sehe ich allerdings nur eine 1.04 als aktuelle.
              Noch irgendwelche Ideen?
                K_o_bold @Smokey last edited by
                @smokey sagte in Easee Wallbox mit iobroker:
                Kommt bei mir auch öfters und heute früh bei mir auch. Ich glaube nicht, dass das am Adapter liegt. Bei Easee seint es mal wieder Probleme gegeben zu haben.
                Seit 11:25 Uhr sind die errors weg.
                  Smokey @K_o_bold last edited by
                  @k_o_bold sagte in Easee Wallbox mit iobroker:
                  stimmt... genau 11:25. Und jetzt 13:28 hatte ich sie noch mal.... ok, dann kann ich die lokale Fehlersuche aufgeben 🙂 Danke!
                    warp-it @Newan last edited by
                    @newan said in Easee Wallbox mit iobroker:
                    Ich habe den easee Adpter 1.07 installiert. Wenn ich SignalR aktiviere, startet der Adaapter nicht mehr.
                    Unter Adapters wird mir kein Update angeboten.
                    Falls eine neuere Version existiert, so ist mir nicht klar, wie ich das Update anstoßen kann.
                      k_b @warp-it last edited by
                      @warp-it sagte in Easee Wallbox mit iobroker:
                      Die aktuelle Version bekommst Du, wenn Du den Master von iobroker.easee installierst.
                      Das machst Du, indem Du im Expertenmodus bei Adapter auf die Katze gehst.
                      Dann mittleren Reiter "von Github" auswählen und easee als Stichwort eingeben.
                      "easee [newman]" auswählen. Dann hast Du noch keine Instanz. Die musst Du unter Adapter "easee" mit Hilfe des "+" hinzufügen.
                      Vorher natürlich die 1.0.7 löschen (Instanz und Adapter).
                        warp-it @k_b last edited by
                        @k_b
                        Hmmm,
                        habe Instanz und Adapter gelöscht, und von Github neu installiert.
                        Versionsnummer ist noch immer 1.07 und mit SignalR stratet die Instanz nach wie vor nicht.
                        Ohne SignalR startet sie.
                        Was ist zu tun?
                        Newan 1 Reply Last reply Reply Quote 0
                        • Newan
                          @warp-it mal ein debug log posten ob man was sieht.
                          Kann Adapter sein oder der eassee Server
                            @newan @k_b Sorry,
                            habe hoch gescrollt und nodejs von 16 auf 18 aktualisiert, und jetzt funktioniert auch SignalR.
                            Vielen Dank für Eure Unterstützung.
                              MHeymann last edited by MHeymann
                              Hallo Zusammen,
                              mein Logfile wird seit einiger Zeit alle zwei Minuten mit dem Fehler "undefined is not a valid state value" zu gespammt. Habe die Easee Box und denn Adapter jeweils neu gestartet. Aber leider keine Veränderung.
                              Adapter Version: 1.0.7
                              Wallbox Version: 310
                              Weis jemand woran das liegen könnte bzw. wie ich die Fehlermeldung weg bekomme?
                              LG Marko
                              easee.0
                              2023-06-27 19:43:55.901	error	undefined is not a valid state value
                              easee.0
                              2023-06-27 19:43:55.876	debug	{"isEnabled":true,"lockCablePermanently":true,"authorizationRequired":false,"remoteStartRequired":null,"smartButtonEnabled":false,"wiFiSSID":"XXX","detectedPowerGridType":1,"offlineChargingMode":null,"circuitMaxCurrentP1":16,"circuitMaxCurrentP2":16,"circuitMaxCurrentP3":16,"enableIdleCurrent":true,"limitToSinglePhaseCharging":null,"phaseMode":2,"localNodeType":1,"localAuthorizationRequired":false,"localRadioChannel":0,"localShortAddress":0,"localParentAddrOrNumOfNodes":0,"localPreAuthorizeEnabled":false,"localAuthorizeOfflineEnabled":true,"allowOfflineTxForUnknownId":true,"maxChargerCurrent":16,"ledStripBrightness":25,"chargingSchedule":""}
                              easee.0
                              2023-06-27 19:43:55.876	debug	Charger config ausgelesen mit id:
                              easee.0
                              2023-06-27 19:43:55.740	debug	{"smartCharging":true,"cableLocked":true,"chargerOpMode":2,"totalPower":0,"sessionEnergy":0,"energyPerHour":0,"wiFiRSSI":-58,"cellRSSI":-65,"localRSSI":null,"outputPhase":0,"dynamicCircuitCurrentP1":16,"dynamicCircuitCurrentP2":0,"dynamicCircuitCurrentP3":0,"chargerFirmware":310,"chargerRAT":1,"lockCablePermanently":true,"inCurrentT2":0,"inCurrentT3":0.007000000216066837,"inCurrentT4":0.008999999612569809,"inCurrentT5":0.007000000216066837,"outputCurrent":0,"inVoltageT1T2":null,"inVoltageT1T3":null,"inVoltageT1T4":null,"inVoltageT1T5":null,"inVoltageT2T3":220.14199829101562,"inVoltageT2T4":223.1719970703125,"inVoltageT2T5":222.67999267578125,"inVoltageT3T4":null,"inVoltageT3T5":null,"inVoltageT4T5":null,"ledMode":21,"cableRating":20,"dynamicChargerCurrent":0,"circuitTotalAllocatedPhaseConductorCurrentL1":0,"circuitTotalAllocatedPhaseConductorCurrentL2":0,"circuitTotalAllocatedPhaseConductorCurrentL3":0,"circuitTotalPhaseConductorCurrentL1":0.007000000216066837,"circuitTotalPhaseConductorCurrentL2":0.008999999612569809,"circuitTotalPhaseConductorCurrentL3":0.007000000216066837,"reasonForNoCurrent":52,"wiFiAPEnabled":false,"lifetimeEnergy":2700.030728333338,"offlineMaxCircuitCurrentP1":16,"offlineMaxCircuitCurrentP2":16,"offlineMaxCircuitCurrentP3":16,"errorCode":0,"fatalErrorCode":0,"eqAvailableCurrentP1":null,"eqAvailableCurrentP2":null,"eqAvailableCurrentP3":null,"deratedCurrent":null,"deratingActive":false,"connectedToCloud":true,"isOnline":true,"voltage":220.14199829101562,"latestPulse":"2023-06-27T17:40:47.983Z","errors":[]}
                              easee.0
                              2023-06-27 19:43:55.740	debug	Charger status ausgelesen mit id:
                              easee.0
                              2023-06-27 19:43:55.622	debug	Hole Energiedaten: 2
                              easee.0
                              2023-06-27 19:43:55.618	debug	{"id":"","name":"Wall","color":5,"createdOn":"2021-06-01T08:38:44.618192","updatedOn":"2022-05-22T11:24:52.667486","levelOfAccess":1,"productCode":1}
                              easee.0
                              2023-06-27 19:43:55.618	debug	Charger found
                              easee.0
                              2023-06-27 19:43:55.618	debug	[{"id":"","name":"Wall E","color":5,"createdOn":"2021-06-01T08:38:44.618192","updatedOn":"2022-05-22T11:24:52.667486","levelOfAccess":1,"productCode":1}]
                              easee.0
                              2023-06-27 19:43:55.618	debug	Chargers ausgelesen
                              easee.0
                              2023-06-27 19:43:55.508	debug	read new states from the API
                                K_o_bold @MHeymann last edited by
                                bin der einzige bei dem der Eassee Adaper folgende errors hat?
                                Es passiert seit heute und ich habe nichts verändert.
                                Die Eassee App läuft Problemlos
                                easee.0
                                2023-08-03 21:09:01.640	error	Request failed with status code 429
                                easee.0
                                2023-08-03 21:09:01.637	error	Api login error - check Username and password
                                • Alex Warkentin
                                  Alex Warkentin last edited by
                                  Ist die Entwicklung dieses Adapters eingestellt worden? Die Anmeldung funktioniert bei mir auch nicht mehr, wie beim Vorredner.
                                  Newan A 2 Replies Last reply Reply Quote 0
                                  • Newan
                                    Newan @Alex Warkentin last edited by
                                    @alex-warkentin Gerne einen PullREquest für einen fix bereitstellen.
                                    Ist halt alles Hobby und andere Themen haben auch prio, beruflich & familie haben da leider Vorrang 😉
                                      Aiouh @Alex Warkentin last edited by
                                      Hallo @alex-warkentin, ich kann nur von meinem Setup berichten, läuft auch heute problemlos.
                                      ioBroker ist komplett aktuell und der Easee Adapter is 1.0.10.
                                      • Alex Warkentin
                                        Ich habe schon ein Request bei Github eröffnet. Habe auch die 10er Version installiert und im Sommer lief alles bestens. Seitdem die Sonne aus Deutschland verschwunden ist, lade ich übers Netz und habe gar nicht mitbekommen, das erwas nicht stimmt. Habe jetzt mein Script gestoppt und den Adapter mehrere Tage pausiert gelassen, aber es hilft nix. Anmeldung in der Cloud funktioniert problemlos.
                                          Karacho @Alex Warkentin last edited by Karacho
                                          ich habe seit einigen Tagen bzgl meiner Box Fehler code 504
                                          Kann jemand weiterhelfen?
                                          Gruss
                                          Karacho
                                          easee.0
                                          2025-01-10 16:21:58.553	error	Easee API error on charger state - stop refresh
                                          easee.0
                                          2025-01-10 16:21:58.552	error	AxiosError: Request failed with status code 504
                                            Aiouh @Karacho last edited by
                                            @karacho Ist bei mir auch so, aber heute besonders ausgeprägt. Hängt wahrscheinlich mit dem aktuellen Easee Cloud Problem zusammen https://status.easee.com/incidents/pv4jvw3x0tnr
                                            Ich warte einfach ab.
                                            31.7k
                                            79.7k
                                            adapter easee wallbox
                                            59
                                            503
                                            90442
