      Homoran Global Moderator Administrators @tobitobsta last edited by
      @tobitobsta sagte in Test Adapter shuttercontrol v1.5.x:
      Temperatur outside: 31.3 > 24 AND Light: 0 > 15
      die Logik stimmt ja wohl nicht ganz 😂
      Wobei ich mich frage wieso das Licht 0 ist.
      ist der Sensor im Zimmer?
        tobitobsta @Homoran last edited by
        @homoran said in Test Adapter shuttercontrol v1.5.x:
        Touche 😉 also insofern habe ich nicht "dasselbe Problem". Ich habe gar keine Sensoren, die ich für die Sunprotect Entscheidung anziehe außer Himmelsrichtung:
        shuttercontrol.0 | 2023-06-24 16:31:21.029 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
        shuttercontrol.0 | 2023-06-24 16:31:21.028 | debug | #0 wait for shutter check end
        shuttercontrol.0 | 2023-06-24 16:31:07.350 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
        shuttercontrol.0 | 2023-06-24 16:31:07.349 | debug | #0 wait for shutter check end
        shuttercontrol.0 | 2023-06-24 16:31:07.327 | debug | Shutter state changed: Badezimmer old value = 100 new value = 30
        shuttercontrol.0 | 2023-06-24 16:31:07.326 | debug | #0 wait for shutter check end
        shuttercontrol.0 | 2023-06-24 16:30:21.026 | debug | #0 wait for shutter check started
        shuttercontrol.0 | 2023-06-24 16:30:07.348 | debug | #0 wait for shutter check started
        shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | Sunprotect Badezimmer old height: 100% new height: 30%
        shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | last automatic Action for Badezimmer: down_Sunprotect
        shuttercontrol.0 | 2023-06-24 16:30:07.330 | debug | RangeMinus: 184 < 248.7RangePlus: 310 > 248.7
        shuttercontrol.0 | 2023-06-24 16:30:07.329 | debug | Sunprotect for Badezimmer is active
        shuttercontrol.0 | 2023-06-24 16:30:07.323 | debug | #0 wait for shutter check started
        shuttercontrol.0 | 2023-06-24 16:30:07.319 | info | Sunprotect #416 Set ID: Badezimmer value: 30%
        shuttercontrol.0 | 2023-06-24 16:30:07.318 | debug | Badezimmer: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
        shuttercontrol.0 | 2023-06-24 16:30:00.039 | debug | Sun Elevation: 44.4°
        shuttercontrol.0 | 2023-06-24 16:30:00.038 | debug | Sun Azimut: 248.7°
        shuttercontrol.0 | 2023-06-24 16:30:00.036 | debug | calculate astrodata ...
        shuttercontrol.0 | 2023-06-24 16:25:43.425 | debug | #1 currentShutterStateTime: 60 seconds
        shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentShutterState: activated
        shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 oldHeight: 30 %
        shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentHeight: 100 %
        shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 triggerAction: up
        shuttercontrol.0 | 2023-06-24 16:25:43.424 | debug | #1 currentAction: up
        shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | #1 shutterState: 100 %
        shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | #1 shutterName: Badezimmer
        shuttercontrol.0 | 2023-06-24 16:25:43.423 | debug | Badezimmer Old value = 30. New value = 100. automatic is active
        shuttercontrol.0 | 2023-06-24 16:25:43.422 | debug | Shutter state changed: Badezimmer old value = 30 new value = 100
          und wie ist dann der Sonnenschutz konfiguriert?
            Himmelsrichtung
              Himmelsrichtung
              zeigen!
                Himmelsrichtung
                zeigen!
                  @tobitobsta siehste!
                  zeigen hilft.
                  das ist das Badezimmer, nicht die Kueche
                    meine Logs zeigen auch Badezimmer
                      Homoran Global Moderator Administrators @tobitobsta last edited by Homoran
                      @tobitobsta das von mir zitierte und kommentierte nicht!
                      edit:
                      im neuen log sehe ich nichts von Manu_Mode
                        uff... da stand ein "@tobitobsta". Sorry... mein Fehler... ich glaube das führt hier gerade zu nix und ich will hier nicht alle mit dem hin und her nerven.
                        Dass der Rolladen bei manueller Anpassung nicht auf Manu_Mode geht, wundert mich auch.
                        Ich ziehe mich jetzt erstmal zurück aber antworte gerne noch bei Bedarf.
                          wer sagt das?
                          ist nur für mich in dem log-Ausschnitt nicht zu sehen.
                          Aber wir wollen/sollen doch helfen 🤔
                          das versteh ich jetzt nicht
                            wer sagt das?
                            Kann ich das irgednwie anders rausfinden? habe ja nur die Logs. Ich versuche es jetzt einfach mal und schaue in den Datenpunkt...
                            nehme gerne eure Hilfe in Anspruch und bin auch sehr dankbar - hatte nur das Gefühl, dass ich hier gerade eher auf die Nerven falle...
                            alles gut - lass uns beim inhaltlichen bleiben.
                              1. Kueche meldet seltsames
                              2. Badezimmer geht in den Sonnenschutz
                                tobitobsta @Homoran last edited by tobitobsta
                                habs jetzt gerade mit "Küche Tür" ausprobiert (da der jetzt gerade in SunProtect ist, es verhalten sich aber alle gleich bei mir).
                                nach dem manuellen hochfahren geht der State in "up" und der AutoLevel bleibt bei "26%"
                                nach 5 min fährt er wieder unter ( @Homoran edited - thx):
                                shuttercontrol.0 2023-06-27 11:51:32.609	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                                shuttercontrol.0 2023-06-27 11:51:32.608	debug	#0 wait for shutter check end
                                shuttercontrol.0 2023-06-27 11:51:13.168	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                                shuttercontrol.0 2023-06-27 11:51:13.165	debug	#0 wait for shutter check end
                                shuttercontrol.0 2023-06-27 11:51:13.140	debug	Shutter state changed: Küche Tür old value = 100 new value = 26
                                shuttercontrol.0 2023-06-27 11:51:13.138	debug	#0 wait for shutter check end
                                shuttercontrol.0 2023-06-27 11:50:32.607	debug	#0 wait for shutter check started
                                shuttercontrol.0 2023-06-27 11:50:13.165	debug	#0 wait for shutter check started
                                shuttercontrol.0 2023-06-27 11:50:13.147	debug	Sunprotect Küche Tür old height: 100% new height: 26%
                                shuttercontrol.0 2023-06-27 11:50:13.147	debug	last automatic Action for Küche Tür: down_Sunprotect
                                shuttercontrol.0 2023-06-27 11:50:13.147	debug	RangeMinus: 115 < 139.1RangePlus: 243 > 139.1
                                shuttercontrol.0 2023-06-27 11:50:13.146	debug	Sunprotect for Küche Tür is active
                                shuttercontrol.0 2023-06-27 11:50:13.137	debug	#0 wait for shutter check started
                                shuttercontrol.0 2023-06-27 11:50:13.124	info	Sunprotect #416 Set ID: Küche Tür value: 26%
                                shuttercontrol.0 2023-06-27 11:50:13.123	debug	Küche Tür: Check basis for sunprotect. Height:100 > HeightDownSun: 26 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                shuttercontrol.0 2023-06-27 11:50:00.083	debug	Sun Elevation: 55.7°
                                shuttercontrol.0 2023-06-27 11:50:00.082	debug	Sun Azimut: 139.1°
                                shuttercontrol.0 2023-06-27 11:50:00.081	debug	calculate astrodata ...
                                shuttercontrol.0 2023-06-27 11:45:35.915	debug	#1 currentShutterStateTime: 60 seconds
                                shuttercontrol.0 2023-06-27 11:45:35.914	debug	#1 currentShutterState: activated
                                shuttercontrol.0 2023-06-27 11:45:35.914	debug	#1 oldHeight: 26 %
                                shuttercontrol.0 2023-06-27 11:45:35.913	debug	#1 currentHeight: 100 %
                                shuttercontrol.0 2023-06-27 11:45:35.912	debug	#1 triggerAction: up
                                shuttercontrol.0 2023-06-27 11:45:35.911	debug	#1 currentAction: up
                                shuttercontrol.0 2023-06-27 11:45:35.910	debug	#1 shutterState: 100 %
                                shuttercontrol.0 2023-06-27 11:45:35.910	debug	#1 shutterName: Küche Tür
                                shuttercontrol.0 2023-06-27 11:45:35.909	debug	Küche Tür Old value = 26. New value = 100. automatic is active
                                shuttercontrol.0 2023-06-27 11:45:35.904	debug	Shutter state changed: Küche Tür old value = 26 new value = 100
                                shuttercontrol.0 2023-06-27 11:45:35.901	debug	#0 wait for shutter check end
                                shuttercontrol.0 2023-06-27 11:45:00.028	debug	Sun Elevation: 55.2°
                                shuttercontrol.0 2023-06-27 11:45:00.027	debug	Sun Azimut: 137.3°
                                shuttercontrol.0 2023-06-27 11:45:00.026	debug	calculate astrodata ...
                                shuttercontrol.0 2023-06-27 11:44:35.901	debug	#0 wait for shutter check started
                                und dann ist der State wieder "sunprotect":
                                Homoran T 2 Replies Last reply Reply Quote 0
                                  nach 5 min fährt er wieder unter:
                                  bitte als Text in code-tags!
                                  ist am Handy nicht zu entziffern
                                  und zitieren klappt irgendwie auch nicht so richtig
                                  • RaspiUser
                                    RaspiUser @Homoran last edited by
                                    Dann lies es bitte nochmal im Zusammenhang!
                                    Doku und meine Erklärungen
                                    Hab ich und hab ich auch verstanden ... aber eigentlich sollten deine Erläuterungen zur Anleitung garnicht notwendig sein ...
                                    Dann braucht es nachher 500 Seiten Kommentare
                                    Natürlich nicht ... aber auch nicht über 6000 Diskussionsbeiträge die keiner mehr überblicken oder sinnvoll durchsuchen kann, oder ?
                                      Homoran Global Moderator Administrators @RaspiUser last edited by
                                      @raspiuser sagte in Test Adapter shuttercontrol v1.5.x:
                                      richtig!
                                      Weil es bereits eindeutig ist 😉
                                      RaspiUser 1 Reply Last reply Reply Quote 0
                                      • RaspiUser
                                        RaspiUser @simatec last edited by
                                        @simatec said in Test Adapter shuttercontrol v1.5.x:
                                        Ich hatte bereits mehrmals dazu eingeladen, sich aktiv an der Anleitung zu beteiligen... Leider gibt es halt hier nicht viele User, die sich da einbringen
                                        Ich kann deine Meinung verstehen.
                                        Ich selbst würde gern helfen, sehe mich aber nicht in der Lage dies zu tun, weil ich selbst nicht durchblicke um es zu beschreiben.
                                        Aber Hinweise, das die Anleitung an dieser oder jener Stelle besser werden kann darf man geben, oder?
                                        • RaspiUser
                                          Nein, sehe ich nicht so ... aber wir kommen hier nicht weiter ...
                                            du hast im letzten Satz zuerst immer Aussentemperatursensor gelesen und das hat zur Verwirrung geführt.
                                            Diese Verknüpfung bekommst du jetzt nicht mehr aus dem Kopf.
                                            Natürlich!
                                            Du kannst aber auch direkt eine für alle bessere Formulierung als pullrequest für die Doku zur Verfügung stellen.
                                            332
                                            7408
                                            10572069
