    4. Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden
    • mickym
      mickym Most Active @ingranu last edited by
      @ingranu Wie ich vermutet habe - Du musst den zigbee Adapter ggf. ganz rausnehmen. Aber ich sehe auch dass Du den CC2531 verwendest. Mir gingen dieses Sticks alle nach 1 Jahr kaputt. Ggf. hast Du kein Softwareproblem und auch Dein zigbee Adapter würde noch tun und nur Dein Stick ist kaputt.
      ingranu 1 Reply Last reply Reply Quote 0
      • ingranu
        ingranu @mickym last edited by
        @mickym Zigbee Adapter komplett gelöscht. Ich habe ein ConbeeII Stick
        • ingranu
          ingranu @Guest last edited by
          @dp20eic ```
          igbee2MQTT:info 2023-06-27 14:15:59: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-06-27.14-15-59' filename: log.txt
          Zigbee2MQTT:info 2023-06-27 14:15:59: Starting Zigbee2MQTT version 1.31.2 (commit #21f5125)
          Zigbee2MQTT:info 2023-06-27 14:15:59: Starting zigbee-herdsman (0.14.117)
          Zigbee2MQTT:info 2023-06-27 14:16:00: zigbee-herdsman started (resumed)
          Zigbee2MQTT:info 2023-06-27 14:16:00: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":120,"product":0,"revision":"0x26780700","transportrev":0},"type":"ConBee2/RaspBee2"}'
          Zigbee2MQTT:info 2023-06-27 14:16:00: Currently 0 devices are joined:
          Zigbee2MQTT:warn 2023-06-27 14:16:00: permit_join set to true in configuration.yaml.
          Zigbee2MQTT:warn 2023-06-27 14:16:00: Allowing new devices to join.
          Zigbee2MQTT:warn 2023-06-27 14:16:00: Set permit_join to false once you joined all devices.
          Zigbee2MQTT:info 2023-06-27 14:16:00: Zigbee: allowing new devices to join.
          Zigbee2MQTT:info 2023-06-27 14:16:00: Connecting to MQTT server at mqtt://localhost
          Zigbee2MQTT:error 2023-06-27 14:16:00: MQTT error: connect ECONNREFUSED 127.0.0.1:1883
          Zigbee2MQTT:error 2023-06-27 14:16:00: MQTT failed to connect, exiting...
          Zigbee2MQTT:info 2023-06-27 14:16:00: Stopping zigbee-herdsman...
          Zigbee2MQTT:info 2023-06-27 14:16:00: Stopped zigbee-herdsman
          ? mickym 3 Replies Last reply Reply Quote 0
          • mickym
            @ingranu sagte in Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden:
            Ok den habe ich auch - dann sollte es gehen . Neu starten und mit systemctl status zigbee2mqtt prüfen - das muss laufen bevor was anderes nicht geht.
              A Former User @ingranu last edited by A Former User
              @dp20eic ```
              Moin,
              fast richtig 🙂
              die Code-Tags gehören immer in eine neue Zeile, dann der Text der gezeigt werden soll, dann neue Zeile und abschließend Code-Tag
              Wenn Du das Menü von oben nimmst, dann einfach enter, dann Code-Tag anklicken und den Text zwischen die drei ``` Zeichen setzen.
              VG
              Bernd
              • mickym
                Entscheide Dich erst mal ob Du mit dem zigbee2mqtt Adapter als Broker verwenden willst, dann brauchst Du den mqtt Adapter nicht.
                • ingranu
                  @mickym Ich habe alle Adapter deinstalliert und nur die Installation auf Linux gemacht vom Zigbe2mqtt gemacht.
                    A Former User @Guest last edited by A Former User
                    @dp20eic sagte in Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden:
                    @dp20eic Also die config sieht so aus:
                    Moin,
                    ich denke, dass da ein Fehler in der config ist.
                    Meine:
                    [sudo] password for dp20eic:
                    homeassistant: false
                    permit_join: false
                    mqtt:
                      base_topic: zigbee2mqtt
                      server: mqtt://ds716plus.fritz.box:1883          <--- Port sehe ich bei Dir nicht
                    serial:
                      port: /dev/ttyACM3
                      adapter: auto
                    frontend:
                      port: 8080
                    advanced:
                      homeassistant_legacy_entity_attributes: false
                      legacy_api: false
                      legacy_availability_payload: false
                    device_options:
                      legacy: false
                    VG
                    Bernd
                    P.S.: Nop, mein Fehler, Du setzt auf minimal, also ohne MQTT, dann muss da auch kein Port rein. Musste mich auch gerade erst einmal wieder einlesen 🙂
                    • ingranu
                      ingranu @Guest last edited by ingranu
                      @dp20eic Habe die Config jetzt angepasst und meine IP eingetragen sowie der Port:
                      permit_join: true
                      mqtt:
                      server: mqtt://192.168.3.7:1883
                      serial:
                      port: /dev/ttyACM0
                      adapter: auto
                      frontend:
                      port: 8080
                      advanced:
                      legacy_api: false
                      device_options:
                      legacy: false
                      Zigbee2MQTT:info  2023-06-27 14:36:21: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-06-27.14-36-21' filename: log.txt
                      Zigbee2MQTT:info  2023-06-27 14:36:21: Starting Zigbee2MQTT version 1.31.2 (commit #21f5125)
                      Zigbee2MQTT:info  2023-06-27 14:36:21: Starting zigbee-herdsman (0.14.117)
                      Zigbee2MQTT:info  2023-06-27 14:36:22: zigbee-herdsman started (resumed)
                      Zigbee2MQTT:info  2023-06-27 14:36:22: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":120,"product":0,"revision":"0x26780700","transportrev":0},"type":"ConBee2/RaspBee2"}'
                      Zigbee2MQTT:info  2023-06-27 14:36:22: Currently 0 devices are joined:
                      Zigbee2MQTT:warn  2023-06-27 14:36:22: `permit_join` set to  `true` in configuration.yaml.
                      Zigbee2MQTT:warn  2023-06-27 14:36:22: Allowing new devices to join.
                      Zigbee2MQTT:warn  2023-06-27 14:36:22: Set `permit_join` to `false` once you joined all devices.
                      Zigbee2MQTT:info  2023-06-27 14:36:22: Zigbee: allowing new devices to join.
                      Zigbee2MQTT:info  2023-06-27 14:36:22: Connecting to MQTT server at mqtt://192.168.3.7:1883
                      Zigbee2MQTT:error 2023-06-27 14:36:22: MQTT error: connect ECONNREFUSED 192.168.3.7:1883
                      Zigbee2MQTT:error 2023-06-27 14:36:22: MQTT failed to connect, exiting...
                      Zigbee2MQTT:info  2023-06-27 14:36:22: Stopping zigbee-herdsman...
                      Zigbee2MQTT:info  2023-06-27 14:36:23: Stopped zigbee-herdsman
                      iobroker komplett gestopt. Jedoch gehts trotzdem nicht
                      ? mickym 2 Replies Last reply Reply Quote 0
                        Moin,
                        hatte gerade ergänzt, dass ich da ein Fehler gemacht habe, da Du erst einmal ohne MQTT Server arbeiten willst, dann muss da auch kein Port rein und localhost ist auch ok.
                        Sorry für die Verwirrung, ist schon einige Zeit her 😉
                        VG
                        Bernd
                        • ingranu
                          @dp20eic Kein Ding 🙂 Hab beides versucht, gleiche Ergebniss
                          • mickym
                            @ingranu Du brauchst eine Broker - also entweder den zigbee2mqtt Adapter oder den mqtt Adapter als Broker - eines von beiden muss als Ziel dienen.
                            Was hast Du denn sonst noch für Adapter laufen?
                            also
                            sudo netstat -tulpen
                            und schauen, was für Prozesse laufen.
                            • ingranu
                              @mickym Ich habe den zigbe25mqtt am laufe, status sieht so aus:
                              Ausgabe:
                              root@iobroke-vm:/opt/zigbee2mqtt# sudo netstat -tulpen
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       28713      691/iobroker.js-con
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       27572      691/iobroker.js-con
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16778      1/init
                              tcp        0      0 192.168.3.7:2001        0.0.0.0:*               LISTEN      1001       29567      1772/io.hm-rpc.0
                              tcp        0      0 192.168.3.7:8081        0.0.0.0:*               LISTEN      1001       28970      1110/io.admin.0
                              tcp        0      0 192.168.3.7:8082        0.0.0.0:*               LISTEN      1001       35943      3525/io.web.0
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22085      663/systemd-resolve
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25848      756/sshd: /usr/sbin
                              tcp        0      0 192.168.3.7:8087        0.0.0.0:*               LISTEN      1001       35753      3464/io.simple-api.
                              tcp        0      0 192.168.3.7:2010        0.0.0.0:*               LISTEN      1001       30468      2019/io.hm-rpc.1
                              tcp        0      0 192.168.3.7:8701        0.0.0.0:*               LISTEN      1001       30890      2079/io.hm-rpc.2
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          16782      1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          25859      756/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30933      2113/io.shelly.0
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22084      663/systemd-resolve
                              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       29814      1298/io.radar2.0
                              udp        0      0 192.168.3.7:68          0.0.0.0:*                           100        22058      661/systemd-network
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16779      1/init
                              udp6       0      0 :::111                  :::*                                0          16785      1/init
                              • mickym
                                mickym Most Active @ingranu last edited by mickym
                                @ingranu Da Du keinen eigen Mqtt Broker hast - musst Du Dummy mqtt-Broker erstellen anhaken. Was Dir lieber ist. Und lass mal Websocket weg (wenn das geht) - keine Ahnung was Du da noch für Möglichkeiten hast. Und dann wieder prüfen, ob was auf 1883 hört. Im Moment siehst Du das nichts auf 1883 hört, deswegen kann sich Dein zigbee2mqtt Dienst nicht verbinden.
                                • ingranu
                                  ingranu @mickym last edited by ingranu
                                  @mickym stimmt das so ?
                                  tcp        0      0 192.168.3.7:1883        0.0.0.0:*               LISTEN      1001       42944      3948/io.zigbee2mqtt
                                  mickym T 2 Replies Last reply Reply Quote 0
                                  • mickym
                                    @ingranu Ja jetzt schaut das besser aus.
                                    Nun mit
                                    sudo systemctl restart zigbee2mqtt
                                    und mit
                                    kontrollieren
                                    • ingranu
                                      @mickym said in Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden:
                                      Erhalte ich diese Meldungen:
                                      zigbee2mqtt.service - zigbee2mqtt
                                           Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                                           Active: activating (auto-restart) (Result: exit-code) since Tue 2023-06-27 15:07:19 CEST; 6s ago
                                          Process: 3857 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
                                         Main PID: 3857 (code=exited, status=1/FAILURE)
                                      Scheint zu laufen:
                                           Active: active (running) since Tue 2023-06-27 15:09:04 CEST; 244ms ago
                                         Main PID: 4395 (npm)
                                            Tasks: 7 (limit: 9311)
                                           Memory: 30.1M
                                           CGroup: /system.slice/zigbee2mqtt.service
                                                   └─4395 npm
                                      Jun 27 15:09:04 iobroke-vm systemd[1]: Started zigbee2mqtt.
                                      mickym ? 2 Replies Last reply Reply Quote 0
                                      • mickym
                                        Na dann ist doch gut.
                                        • ingranu
                                          @mickym Bricht dann aber wieder ab:
                                               Active: activating (auto-restart) (Result: exit-code) since Tue 2023-06-27 15:11:28 CEST; 607ms ago
                                              Process: 1298 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
                                             Main PID: 1298 (code=exited, status=1/FAILURE)
                                          Sieht bei mir so aus:
                                          [Unit]
                                          Description=zigbee2mqtt
                                          After=network.target
                                          [Service]
                                          Environment=NODE_ENV=production
                                          WorkingDirectory=/opt/zigbee2mqtt
                                          StandardOutput=inherit
                                          # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options
                                          # see systemd.exec(5)
                                          StandardError=inherit
                                          Restart=always
                                          RestartSec=10s
                                          User=root
                                          [Install]
                                          WantedBy=multi-user.target
                                            Moin,
                                            schau mal öfter,
                                             Active: active (running) since Tue 2023-06-27 15:09:04 CEST; 244ms ago   <---
                                            So, oder so ähnlich sollte das aussehen, wenn es läuft, außer, dass Du noch nichts angelernt hast.
                                            $ systemctl status zigbee2mqtt.service
                                            ● zigbee2mqtt.service - zigbee2mqtt
                                                 Loaded: loaded (/usr/lib/systemd/system/zigbee2mqtt.service; enabled; preset: disabled)
                                                 Active: active (running) since Thu 2023-06-22 13:51:31 CEST; 5 days ago
                                               Main PID: 70 (node)
                                                  Tasks: 11 (limit: 38344)
                                                 Memory: 90.8M
                                                    CPU: 16.016s
                                                         └─70 node index.js
                                            Jun 27 12:12:41 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:12:41: MQTT publish: topic 'zigbee2mqtt/BWM', payload '{"battery":74,"illuminance_above_threshold":false,"linkquality":97,"occupancy":true,"update":{"installed_version>
                                            Jun 27 12:15:41 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:15:41: MQTT publish: topic 'zigbee2mqtt/BWM', payload '{"battery":74,"illuminance_above_threshold":false,"linkquality":97,"occupancy":false,"update":{"installed_versio>
                                            Jun 27 12:25:30 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:25:30: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":31,"linkquality":162,"power_outage_count":63,"voltage":3045}'
                                            Jun 27 12:50:26 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:50:26: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":170,"power_outage_count":164,"voltage":3015}'
                                            Jun 27 13:12:42 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:12:42: MQTT publish: topic 'zigbee2mqtt/BWM/availability', payload '{"state":"offline"}'
                                            Jun 27 13:15:42 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:15:42: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":31,"linkquality":162,"power_outage_count":63,"voltage":3045}'
                                            Jun 27 13:40:36 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:40:36: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":168,"power_outage_count":164,"voltage":3015}'
                                            Jun 27 14:05:54 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:05:54: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":30,"linkquality":162,"power_outage_count":63,"voltage":3045}'
                                            Jun 27 14:30:45 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:30:45: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":168,"power_outage_count":164,"voltage":3015}'
                                            Jun 27 14:56:06 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:56:06: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device
                                            Mach mal
                                            watch systemctl status zigbee2mqtt.service
                                            VG
                                            Bernd
                                            P.S.: und mal schauen was im journal steht
                                            journalctl -u node
                                            7220
