    4. Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden
      A Former User @ingranu last edited by A Former User
      @ingranu sagte in Tuya Presence Zy-m100-s mit dem Zigbee-Adapter einbinden:
      Active: active (running) since Tue 2023-06-27 15:09:04 CEST; 244ms ago
      Moin,
      schau mal öfter,
       Active: active (running) since Tue 2023-06-27 15:09:04 CEST; 244ms ago   <---
      So, oder so ähnlich sollte das aussehen, wenn es läuft, außer, dass Du noch nichts angelernt hast.
      $ systemctl status zigbee2mqtt.service
      ● zigbee2mqtt.service - zigbee2mqtt
           Loaded: loaded (/usr/lib/systemd/system/zigbee2mqtt.service; enabled; preset: disabled)
           Active: active (running) since Thu 2023-06-22 13:51:31 CEST; 5 days ago
         Main PID: 70 (node)
            Tasks: 11 (limit: 38344)
           Memory: 90.8M
              CPU: 16.016s
           CGroup: /system.slice/zigbee2mqtt.service
                   └─70 node index.js
      Jun 27 12:12:41 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:12:41: MQTT publish: topic 'zigbee2mqtt/BWM', payload '{"battery":74,"illuminance_above_threshold":false,"linkquality":97,"occupancy":true,"update":{"installed_version>
      Jun 27 12:15:41 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:15:41: MQTT publish: topic 'zigbee2mqtt/BWM', payload '{"battery":74,"illuminance_above_threshold":false,"linkquality":97,"occupancy":false,"update":{"installed_versio>
      Jun 27 12:25:30 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:25:30: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":31,"linkquality":162,"power_outage_count":63,"voltage":3045}'
      Jun 27 12:50:26 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 12:50:26: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":170,"power_outage_count":164,"voltage":3015}'
      Jun 27 13:12:42 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:12:42: MQTT publish: topic 'zigbee2mqtt/BWM/availability', payload '{"state":"offline"}'
      Jun 27 13:15:42 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:15:42: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":31,"linkquality":162,"power_outage_count":63,"voltage":3045}'
      Jun 27 13:40:36 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 13:40:36: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":168,"power_outage_count":164,"voltage":3015}'
      Jun 27 14:05:54 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:05:54: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device_temperature":30,"linkquality":162,"power_outage_count":63,"voltage":3045}'
      Jun 27 14:30:45 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:30:45: MQTT publish: topic 'zigbee2mqtt/0x00158d000404db9f', payload '{"battery":100,"device_temperature":35,"linkquality":168,"power_outage_count":164,"voltage":3015}'
      Jun 27 14:56:06 arch-iob node[70]: Zigbee2MQTT:info  2023-06-27 14:56:06: MQTT publish: topic 'zigbee2mqtt/0x00158d000404fcfa', payload '{"battery":100,"device
      Mach mal
      watch systemctl status zigbee2mqtt.service
      VG
      Bernd
      P.S.: und mal schauen was im journal steht
      journalctl -u node
      • mickym
        mickym Most Active @ingranu last edited by
        Startet eigentlich Dein zigbee2mqtt Adapter richtig?
        ingranu 1 Reply Last reply Reply Quote 0
          toralt @ingranu last edited by
          @ingranu websocket port ist NICHT MQTT Port, normal ist der websocket port 8080.
          • ingranu
            ingranu @toralt last edited by
            @toralt Yep hab ich nachgetragen, Danke
            • ingranu
              ingranu @mickym last edited by
              @mickym Nein bleibt auf gelb
              mickym ingranu 2 Replies Last reply Reply Quote 0
              • mickym
                @ingranu Warte mal der Service ist vielleicht deswegen nicht gestartet wegen 1883 als Websockets - die 1883 gibts du unten beim dem dummy mqtt-Server ein.
                • ingranu
                  ingranu @ingranu last edited by
                  Also Status update:
                  Der Adapter Zigbe2mqtt rennt jetzt auf dem iobroker.
                  Ich komme auch auf das Web Interface nun
                    @ingranu dein MQTT Port für den Dummy port müsste evtl noch geändert werden, zumindest Du im ioBroker auch einen MQTT Server mit dem gleichen Port laufen lässt.
                    Ich habe mosquitto am laufen (hatte zuerst den MQTT Broker Server des ioBroker, wollte aber Z2M am laufen halten wenn ioBroker down, daher Mosquitto)
                    Daher habe ich im adapter keinen dummy server, sondern Z2M ist mit dem MQTT Server verbunden. Im Adapter habe ich nur die websocket-Verbindung und die WEBUi-Verbindung (da sind dann beide IPs logischerweise identisch)
                    • mickym
                      mickym Most Active @toralt last edited by
                      @toralt Hat er nicht mehr - er hat den mqtt- Adapter runtergeschmissen.
                        toralt @mickym last edited by
                        @mickym das gibg zu schnell hier 😂 hab ich glatt übersehen
                        • mickym
                          Also Status update:
                          Dann ist doch alles gut - Glückwunsch!
                          • ingranu
                            Als erstes mal ganz Herzlichen Dank euch allen die mir hier geholfen haben, ist eigendlich ja keine grosse Sache, trotzdem wäre ich ohne euch gescheitert gaaanz klar 🙂
                            Also ich komme jetzt auf die Weboberfläche und der Adapter rennt auf grün.
                            Meine letzte Frage:
                            Wenn ich jetzt ein Gerät hinzufügen möchte, wie mache ich das über die Weboberfläche?
                            • mickym
                              mickym Most Active @ingranu last edited by mickym
                              @ingranu
                              In der Weboberfläche nur da draufklicken
                              • mickym
                                Ab jetzt müssen Dir aber die Leute helfen, die den zigbee2mqtt Adapter eingebunden haben. 😉 - Ich nutze den ja nicht. 😉
                                • ingranu
                                  Klappt alles wunderbar 🙂
                                  Der Tuya Presence Sensor wird nun auch richtig erkannt!
                                  Vielen lieben Dank euch 🙂
                                    Zigbee2MQTT:warn 2023-06-27 14:16:00: permit_join set to true in configuration.yaml.
                                    Moin,
                                    da Du, so weit ich das bis hierher verfolgt habe, das noch so in Deiner Konfiguration des zigbee2mqtt stehen hast, scannt er ständig nach neuen Geräten. Das solltest Du noch abstellen.
                                    Aus der Doku
                                    Configuration.yaml (not recommended)
                                    By setting permit_join: true in your configuration.yaml the joining will automatically be
                                    enabled when starting Zigbee2MQTT. Joining is not automatically disabled.
                                    Also, von
                                    permit_join: true
                                    auf
                                    permit_join: false
                                    umstellen
                                    VG
                                    Bernd
                                    • ingranu
                                      ingranu @Guest last edited by
                                      @dp20eic Danke für den Hinweis! Werde umstellen sobald ich alle Geräte wieder angelernt habe. Schaue gerade um ich die evtl vom alten Adapter migrieren kann.
                                        Moin,
                                        glaube, da hätten wir vorher noch evtl. einige Sachen umstellen müssen, z.b.: wenn Du Gruppen im Zigbee Adapter angelegt hattest und Devices dort aufgenommen hast, dann hätte man die Devices aus den Gruppen löschen müssen und dann die Gruppen löschen.
                                        Aber schau mal, wenn es nicht gerade 100 Geräte sind, dann würde ich die lieber neu anlernen. Erst die, die am Strom hängen, dann die mit Batterien.
                                        VG
                                        Bernd
                                        • ingranu
                                          @dp20eic Okey, ja sind ca 20 Stk das geht noch.
                                          Ist das normal das der Status auf Orange ist? Gerät wurde gefunden und erkannt, der Status bei den Lux und presence wechselt auch immer
                                            Moin,
                                            ja, wenn es sich um Geräte mit Batterie handelt, da die ja keine dauerhafte Verbindung zum Koordinator haben.
                                            Siehe bei mir, alle drei sind mit Batterie:
                                            Sobald ich da z. B. einen Taster betätige, werden die Werte grün und gehen wieder auf Orange.
                                            In der GUI im ioBroker sind sie auch als Online angezeigt
                                            VG
                                            Bernd
                                            7184
