    4. Test eCharts Adapter
      heinzie @RK62 last edited by heinzie
      @rk62 sagte in Test eCharts Adapter:
      @heinzie Das ist genau die Stelle wo bei mir für den ioBroker-Container der massive Speicherhunger von 5GB entsteht und das System für eine Minute stehen bleibt bevor die Installation dann weiterläuft. Da hilft wohl nur RAM nachschieben (ich habe 10 GB Speicher verbaut) oder ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
      2023-06-20 23:14:51.685 - info: host.z-iobroker iobroker upload [28] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
      2023-06-20 23:14:52.018 - info: host.z-iobroker instance system.adapter.echarts.0 started with pid 954
      2023-06-20 23:14:53.480 - info: host.z-iobroker iobroker upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.LICENSE.txt chart/static/js/main.eb0afecd.js.LICENSE.txt text/plain
      2023-06-20 23:14:53.506 - info: host.z-iobroker iobroker upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.eb0afecd.js.map chart/static/js/main.eb0afecd.js.map application/json
      2023-06-20 23:14:55.188 - info: echarts.0 (954) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
      2023-06-20 23:15:15.885 - info: admin.0 (200) <== Disconnect system.user.admin from ::ffff:192.168.64.1 admin
      2023-06-20 23:15:18.736 - info: admin.0 (200) ==> Connected system.user.admin from ::ffff:192.168.64.1
      ==== Speicherbedarf steigt von 1 auf 5-6 GB ====
      2023-06-20 23:16:20.624 - info: host.z-iobroker iobroker upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
      2023-06-20 23:16:20.920 - info: host.z-iobroker iobroker upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      2023-06-20 23:16:21.152 - info: host.z-iobroker iobroker upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
      Danke, ich habe jetzt auch mal den Speicher erhöht und es läuft sofort ohne Probleme.
      Obwohl hier nur 65.21 MB angegeben werden
      RK62 1 Reply Last reply Reply Quote 0
      • RK62
        RK62 @heinzie last edited by
        @heinzie Prima! Die Installation braucht temporär den Speicher. Die 65MB ist der Speicher für den Betrieb des Adapters.
          ok, da kann ich problemlos mit leben. Nochmals Danke für die Hilfe.
          • Z
            zolpetol last edited by
            Nach etwas längerer Zeit will ich ein neues Diagramm mit E-Charts erstellen, bei Anwahl es TAB kommt die Meldung "File tab.html not found".
            Habe alle Updates gemacht und gegoogelt, keine Lösung.
            Hat jemand einen Tipp - danke!
            RK62 H 2 Replies Last reply Reply Quote 0
            • RK62
              RK62 @zolpetol last edited by
              @zolpetol Ja, etwas hochblättern, so bis 20.06. / 19:16
              • Z
                zolpetol @RK62 last edited by
                @rk62
                Danke, leider hilft das nicht. Das Symbol wird wieder korrekt dargestellt, es kommt aber immer noch die Meldung. Auch ein Downgrade auf 1.14.14 hat keine Änderung gebracht.
                • RK62
                  @zolpetol Ist die Installation denn im Log ohne Fehler zu Ende gekommen und das System neu gestartet?
                    @zolpetol
                    die Idee ist vielleicht gar nicht so falsch.
                    in den letzten Tagen gab es Meldungen, dass sich eCharts beim Update einen großen Schluck vom RAM gönnt.
                    Da kam es auch schon zu Problemen beim Update
                    • Z
                      zolpetol @Homoran last edited by
                      @homoran @RK62
                      Ich habe keine Fehler im Log gesehen und die virtuelle Maschine wurde neu gestartet - leider keine Änderung
                        heinzie @zolpetol last edited by
                        @zolpetol sagte in Test eCharts Adapter:
                        War bei mir der gleiche Fehler. Das einzige was funktioniert hat, war die Vergrößerung des Speichers.
                        • Z
                          zolpetol @heinzie last edited by
                          @heinzie
                          Ich habe den Speicher jetzt von 8 GB auf 10 GB vergrößert, neu gestartet und es hat sich nichts geändert.
                          RK62 S 2 Replies Last reply Reply Quote 0
                          • Ro75
                            Ro75 last edited by
                            Das ist jetzt zwar Offtopic. Aber genau das gleiche Problem hatte ich früher bei der Nutzung von eCharts auch. Es wurde schlimmer je mehr Charts ich verwendete. Seither verwende ich die Charts vom Materialdesign - mein Problem ist seither weg. Und davor hatte ich Flot eingesetz. Wie gesagt Offtopic.
                            Ro75.
                            • RK62
                              @zolpetol Der Speicher wird für die Installation benötigt, nicht für den Betrieb. Also andere Docker-Container runter fahren, System möglichst entlasten, eCharts installieren und Installationslog prüfen.
                              Wenn das nicht funktioniert, solltest Du ein Issue in Github aufmachen (https://github.com/ioBroker/ioBroker.echarts/issues).
                                sen @zolpetol last edited by
                                @zolpetol
                                Mein erster Beitrag nach Jahren des Lesens und Lernens.
                                An alle Entwickler und Supporter meinen Dank, ohne euch hätte ich aufgegeben!
                                Kann mich @zolpetol nur anschließen, habe alles probiert und viel Zeit investiert alles ohne Erfolg.
                                Erst eine Erhöhung des Arbeitsspeichers auf genau 10 Gbyte hat das Installationsproblem gelöst!
                                Für mich dank Proxmox recht einfach.
                                • Z
                                  @rk62
                                  Danke an RK62!
                                  Habe jetzt einige virtuelle Maschinen runtergefahren, Echarts neu installiert und jetzt funktioniert es.
                                    deifel last edited by
                                    ich nutze seit ein paar Tagen Echarts und finde es grundsätzlich wirklich klasse! Vielen Dank an dieser Stelle.
                                    Allerdings bekomme ich bei einem ganz einfachen Chart-Anspruch das Ganze nicht ans Laufen und vermute mal, dass es sich entweder um einen Bug oder eine Einstellung handelt, die ich nach stundenlangem Suchen nicht finden konnte.
                                    Ich möchte ein ganz normales Balkendiagramm für die Regentagesmenge erstellen.
                                    Die Daten sind im IOBroker im History-Adapter gespeichert und zeitlich auch korrekt.
                                    Die Werte werden um 2355 Uhr auf 0 gesetzt. Ich möchte also einen Balken je Tag haben.
                                    Mit Flot klappt das auch - die Tage stimmen.
                                    Bei Echarts bin ich eigenartigerweise immer einen Tag voraus versetzt.
                                    Im Beispiel sieht man, dass bereits Werte für den 29.07. drin stehen, obwohl das erst morgen ist und wenn ich mit die Daten im History-Adapter anschaue, dann ist alles korrekt.
                                    In Echarts habe ich unter Intervalle "1 Tag" gesetzt. Stelle ich hier testweise auf "1 Stunde" um, dann stimmen die Werte bzw. er geht nicht mehr in den Folgetag (aber stündlich bringt mir natürlich nichts).
                                    Kann mir jemand sagen, an was das liegt? Mache ich da was falsch oder ist das tatsächlich einfach so (falsch)?
                                    Danke und Grüße
                                      Homoran Global Moderator Administrators @deifel last edited by Homoran
                                      @deifel sagte in Test eCharts Adapter:
                                      dann darfst du nur einen Wert pro Tag in den Datenpunkt schreiben
                                      das verschobene Datum ist ein Bug
                                        sigi234 Forum Testing Most Active @Homoran last edited by
                                        @homoran sagte in Test eCharts Adapter:
                                        Wobei dieser leider schon sehr lange besteht.
                                        https://github.com/ioBroker/ioBroker.echarts/issues/279
                                        PalmManiac created this issue in ioBroker/ioBroker.echarts
                                        open Bar-Charts zeitlich versetzt in der Zukunft #279
                                        • flkontakt
                                          flkontakt @Bluefox last edited by
                                          @bluefox Hallo, siehe Bild, ich habe unter Markierungen einen Text eingetragen, dieser wird an 3 Positionen dargestellt. Mir würde an 1 Position reichen, kann ich das entsprechend einstellen? Danke!!!
                                          • BananaJoe
                                            BananaJoe Most Active @flkontakt last edited by
                                            @flkontakt schon mal das Feld neben den Textfeld angeklickt?
                                            flkontakt 1 Reply Last reply Reply Quote 0
                                            echarts
                                            101
                                            624
                                            142049
