    4. Adapter "smartmeter"
    • surfer09
      surfer09 @Homoran last edited by surfer09
      Ich habe leider seit heute Abend ein Problem mit dem Smarmeter Adapter (3.3.4). Der Adapter wird nach Neustart nicht mehr grün.
      2023-06-17 21:27:05.284 - debug: smartmeter.0 (11476) Redis Objects: Use Redis connection: 192.168.1.25:9001
      2023-06-17 21:27:05.305 - debug: smartmeter.0 (11476) Objects client ready ... initialize now
      2023-06-17 21:27:05.306 - debug: smartmeter.0 (11476) Objects create System PubSub Client
      2023-06-17 21:27:05.307 - debug: smartmeter.0 (11476) Objects create User PubSub Client
      2023-06-17 21:27:05.333 - debug: smartmeter.0 (11476) Objects client initialize lua scripts
      2023-06-17 21:27:05.338 - debug: smartmeter.0 (11476) Objects connected to redis: 192.168.1.25:9001
      2023-06-17 21:27:05.340 - silly: smartmeter.0 (11476) redis psubscribe cfg.o.system.user.*
      2023-06-17 21:27:05.351 - silly: smartmeter.0 (11476) redis psubscribe cfg.o.enum.*
      2023-06-17 21:27:05.357 - silly: smartmeter.0 (11476) objectDB connected
      2023-06-17 21:27:05.360 - debug: smartmeter.0 (11476) Redis States: Use Redis connection: 192.168.1.25:9000
      2023-06-17 21:27:05.370 - debug: smartmeter.0 (11476) States create System PubSub Client
      2023-06-17 21:27:05.371 - debug: smartmeter.0 (11476) States create User PubSub Client
      2023-06-17 21:27:05.433 - debug: smartmeter.0 (11476) States connected to redis: 192.168.1.25:9000
      2023-06-17 21:27:05.433 - silly: smartmeter.0 (11476) statesDB connected
      2023-06-17 21:27:05.471 - debug: smartmeter.0 (11476) Plugin sentry Initialize Plugin (enabled=true)
      2023-06-17 21:27:05.635 - info: smartmeter.0 (11476) starting. Version 3.3.4 in I:/ioBroker/node_modules/iobroker.smartmeter, node: v18.16.0, js-controller: 4.0.24
      2023-06-17 21:27:05.645 - debug: smartmeter.0 (11476) SmartmeterObis options: {"debug":0,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"30","transportSerialPort":"COM5","transportSerialBaudrate":9600,"transportSerialMessageTimeout":20000,"protocolSmlIgnoreInvalidCRC":true,"obisFallbackMedium":1}
      2023-06-17 21:27:05.698 - silly: smartmeter.0 (11476) States system redis pmessage system.adapter.smartmeter.0.logLevel/system.adapter.smartmeter.0.logLevel:{"val":"silly","ack":true,"ts":1687030025648,"q":0,"from":"system.adapter.smartmeter.0","lc":1687030025648}
      2023-06-17 21:27:05.700 - debug: smartmeter.0 (11476) connected set to false
      2023-06-17 21:27:25.675 - warn: smartmeter.0 (11476) No or too long answer from Serial Device after last request.
      2023-06-17 21:27:25.676 - debug: smartmeter.0 (11476) Error: No or too long answer from Serial Device after last request.
      Ich weiß leider nicht, was das Problem sein könnte. Es hat jetzt über ein Jahr funktioniert und jetzt auf einmal nichts mehr...
        klassisch Most Active @surfer09 last edited by
        @surfer09
        Ich gehe mal davon aus, daß nichts verändert wurde, der Lesekopf nicht verrutscht ist und kein SW Update unmittelbar vor dem Ausfall gemacht wurde.
        Was für eine Zählerfirma? Es gibt einige, bei denen sie Sendediode altert, z.B. Holley. Von Weidmann gibt es eine Liste mit Verdächtigen https://shop.weidmann-elektronik.de/media/files_public/67303f78bbcd558d664d0095291562d3/BekannteProblememitZhlermodellen.pdf
        • surfer09
          surfer09 @klassisch last edited by
          @klassisch Nein, ich habe kein Update oder ähnliches gemacht. So ein Mist! Ich habe einen Holley DTZ541-ZDBA. Ich denke, dann wird das mit der Diode wohl zutreffen.
            @surfer09 Ja, leider. Immerhin weißt Du jetzt Bescheid und mußt nicht mehr rumsuchen. Du kannst ja mal hier im Forum nach Holley suchen. Da hibt es einige Geschichten von Leidensgenossen, z.B. Bayernwerke scheint die einzusetzen.
            Meßstellenbetreiber kontaktieren. Die sollen einen neuen einbauen, möglichst einen anderen. Info-Schnittstelle ist laut FNN Lasteheft eine zugesicherte Eigenschaft.
              MortnMX @ichtyp last edited by MortnMX
              @ichtyp Hi, wie hast du das denn hinbekommen? Ich versuche seit Tagen rauszufinden wie ich INFO an oder zumindest PIN ausmachen kann bei dem Zähler... In meiner alten Wohnung hatte ich zwei Zähler (Honeywell AS 2018), bei denen das Problemlos ging... Ich hoffe du oder sonst irgendwer kann mir helfen. 😞
                Homoran Global Moderator Administrators @MortnMX last edited by
                @mortnmx sagte in Adapter "smartmeter":
                über das Menü mittels einblinken.
                Wo hängt es denn?
                bei welchem Zähler
                  MortnMX @Homoran last edited by
                  @homoran Sorry jetzt erst gesehen dass eine Antwort kam.
                  Zähler AS2018 von Honeywell. Die Pin eingabe klappt problemlos, aber der Zähler stellt sich immer wieder zurück. Ich kenne das von zwei anderen Zählern die ich mal hatte, das es normalerweise ein PIN setting im Zähler gibt wo die Pineingabe deaktiviert werden kann. Aber ich finde das nirgens.
                  Das auslesen über die IR schnittstelle klappt auch nur mäßig und auch nur wenn der PIN eingegeben ist. 😞
                  K Homoran 2 Replies Last reply Reply Quote 0
                    klassisch Most Active @MortnMX last edited by
                    @mortnmx klingt jetzt blöd: Bedienungsanleitung vom Zähler suchen und lesen. Bei manchen Zählern muß man nach der PIN oder "ON" Eingabe nochmals lange anleuchten, damt das übernommen wird.
                      MortnMX @klassisch last edited by
                      @klassisch die Bedienungsanleitungen die ich gefunden hab haben keinen Punkt wo man PIN auf OFF stellen kann. Generell weiß ich ja wie das geht, aber die normalen punkte nach dem entriegeln des Zählers, sind nur die historischen werte und das zurücksettzen der selbigen. Aber keine option PIN... Das ist ja genau mein problem. Ich habe auch schon versuche Honeywell selbst zu erreichen, aber deren support ist quasi nicht existent.
                        auf 0?
                        oder was?
                        natürlich
                        hast du inf auf on gestellt?
                          @homoran es gibt leider keine option PIN oder INF oder INFO oder sonst was. nur den aktuellen verbrauch und die verbräuche für 1d, 7d, etc... und CLR
                            @mortnmx zeig mal die Anleitung
                              @homoran https://www.manualslib.de/manual/745898/Honeywell-As2018.html#manual zum beispiel. steht bei allen versionen die ich gefunden hab, genau das gleiche drin. keine weitergehenden informationen.
                                das würde aber dem Pflichtenheft widersprechen.
                                die Schnittstelle muss verfügbar sein.
                                Wo hast du den Zähler her?
                                  @homoran Den Zähler hat mein Grundversorger (Stadtwerke) eingebaut (getauscht mit dem alten Ferraris zähler, oder wie die heißen)
                                    und keine spezifizierte Anleitung mitgegeben?
                                    dann solltest du da mal anrufen
                                      @homoran keine Anleitung überhaupt. Da wurde nur das Ding in den Schaltschrank reingeworfen und angeschlossen. Hab ich versucht. Momentan sind die irendwie nicht erreichbar. 😕
                                        @mortnmx Wann wurde das getauscht? In den letzten 3 Jahren oder viel früher? Und hast Du eine "Moderne Meßeinrichtung" oder ein "Intelligentes Meßsystem" bekommen?
                                          @klassisch Dieses Jahr im Januar. Hab darum gebeten, den Zähler zu bekommen der eh demnächst (ich glaub nächstes jahr) verpflichtend kommen soll. Was genau es ist weiß ich nicht.
                                            das ist jetzt nicht gerade eine belastbare Definition.
                                            Da soll viel demnächst kommen.
                                            Aber da wird noch viel Wasser die Donau, den Rhein und die Mosel runterfließen bevor diese Ideen auch umgesetzt werden.
                                            3625
                                            2287576
