[HowTo] ioBroker Restore unter Linux durchführen
@thomas-braun dann müsste
iob setup customja redis zeigen/enthalten -
hier nochmal neu - obdiagSkript v.2023-04-16 *** BASE SYSTEM *** Architecture : x86_64 Docker : false Virtualization : lxc Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 21:54:02 up 6 min, 1 user, load average: 0.13, 0.11, 0.08 CPU threads: 8 *** Time and Time Zones *** Local time: Tue 2023-06-27 21:54:03 CEST Universal time: Tue 2023-06-27 19:54:03 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** User and Groups *** admin /home/admin admin adm sudo iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 4.1G 127M 2.9G 0.0K 1.1G 4.0G Swap: 512M 0B 512M Total: 4.6G 127M 3.4G 4096 M total memory 127 M used memory 229 M active memory 942 M inactive memory 2851 M free memory 0 M buffer memory 1117 M swap cache 512 M total swap 0 M used swap 512 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--100--disk--1 ext4 63G 2.3G 57G 4% / none tmpfs 492K 4.0K 488K 1% /dev tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.1G 132K 3.1G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.6G 0 1.6G 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Jun 19 16:20:05 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Mon Jun 19 16:20:06 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none. [Tue Jun 27 18:40:35 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Tue Jun 27 20:47:38 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Tue Jun 27 20:52:55 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_prote ct:326: MMP interval 42 higher than expected, please wait. [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): 1 orphan inode deleted [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): recovery complete [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Tue Jun 27 21:46:42 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_prote ct:326: MMP interval 42 higher than expected, please wait. [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): 1 orphan inode deleted [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): recovery complete [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--100--disk--1 ext4 rw,relatime,stripe=16 Files in neuralgic directories: /var: 409M /var/ 224M /var/cache 220M /var/cache/apt 153M /var/cache/apt/archives 136M /var/lib Archived and active journals take up 48.0M in the file system. /opt/iobroker/backups: 392M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 33M /opt/iobroker/iobroker-data/ 15M /opt/iobroker/iobroker-data/files 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static 13M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: 17M /opt/iobroker/iobroker-data/objects.jsonl 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js.map 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js 1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionD etai-57e02d.0886b730.chunk.js.map 1.5M /opt/iobroker/iobroker-data/states.jsonl *** NodeJS-Installation *** /usr/bin/nodejs v18.16.1 /usr/bin/node v18.16.1 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.1-deb-1nodesource1 Candidate: 18.16.1-deb-1nodesource1 Version table: *** 18.16.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org bullseye-security/main amd64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://ftp.debian.org/debian bullseye/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status Cannot read system.config: null (OK when migrating or restoring) iobroker is running on this host. Objects type: file States type: redis Uncaught Rejection: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker /db-objects-redis/lib/objects/objectsInRedisClient.js:3841:59) at process.processTicksAndRejections (node:internal/process/task_queues:95:5 ) Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: "javascript" not found Adapters from github: 0 Adapter State Cannot read system.config: null (OK when migrating or restoring) + instance is alive Enabled adapters with bindings ioBroker-Repositories Cannot read system.config: null (OK when migrating or restoring) List is empty Installed ioBroker-Instances Cannot read system.config: null (OK when migrating or restoring) Error: Object "system.config" not found Objects and States Please stand by - This may take a while Objects: 33 States: 25 *** OS-Repositories and Updates *** Hit:1 http://ftp.debian.org/debian bullseye InRelease Hit:2 http://security.debian.org bullseye-security InRelease Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 109 8072231 1813/redis-server 1 tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 104 8047162 108/systemd-resolve tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 8047223 313/master tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 104 8047168 108/systemd-resolve tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 8070683 1945/iobroker.js-co tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 8054435 1/init tcp6 0 0 ::1:25 :::* LISTEN 0 8047224 313/master tcp6 0 0 :::5355 :::* LISTEN 104 8047165 108/systemd-resolve tcp6 0 0 ::1:6379 :::* LISTEN 109 8072232 1813/redis-server 1 tcp6 0 0 :::111 :::* LISTEN 0 8047060 1/init tcp6 0 0 :::22 :::* LISTEN 0 8052412 1/init udp 0 0 0.0.0.0:5355 0.0.0.0:* 104 8047161 108/systemd-resolve udp 0 0 127.0.0.53:53 0.0.0.0:* 104 8047167 108/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 8056836 1/init udp6 0 0 :::5355 :::* 104 8047164 108/systemd-resolve udp6 0 0 :::111 :::* 0 8055870 1/init *** Log File - Last 25 Lines *** 2023-06-27 21:53:46.393 - info: host.IoBroker received SIGTERM 2023-06-27 21:53:46.396 - info: host.IoBroker iobroker exit null 2023-06-27 21:53:46.397 - warn: host.IoBroker get state error: Connection is closed. 2023-06-27 21:53:46.398 - info: host.IoBroker terminated 2023-06-27 21:53:47.393 - info: host.IoBroker iobroker.js-controller version 4.0.24 js-controller starting 2023-06-27 21:53:47.395 - info: host.IoBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker 2023-06-27 21:53:47.395 - info: host.IoBroker hostname: IoBroker, node: v18.16.1 2023-06-27 21:53:47.395 - info: host.IoBroker ip addresses: 192.168.178.100 fdc8:6d06:a691:4a6d:f434:68ff:fe39:49bc fe80::f434:68ff:fe39:49bc 2023-06-27 21:53:47.462 - error: host.IoBroker Cannot read system.config: null (OK when migrating or restoring) 2023-06-27 21:53:47.508 - error: host.IoBroker Cannot find view "system" for search "host" 2023-06-27 21:53:47.521 - info: host.IoBroker connected to Objects and States 2023-06-27 21:53:47.524 - info: host.IoBroker Node.js version has changed from unknown to 18.16.1 2023-06-27 21:53:47.533 - info: host.IoBroker added notifications configuration of host 2023-06-27 21:53:47.534 - error: host.IoBroker Cannot find view "system" for search "instance" 2023-06-27 21:53:47.534 - error: host.IoBroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system" 2023-06-27 21:53:47.537 - info: host.IoBroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2023-06-27 21:53:47.538 - info: host.IoBroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node 2023-06-27 21:53:47.539 - error: host.IoBroker Cannot find view "system" for search "host" 2023-06-27 21:53:47.604 - error: host.IoBroker Cannot find view "system" for search "state" 2023-06-27 21:53:47.604 - error: host.IoBroker Cannot find view "system" for search "instance" 2023-06-27 21:53:47.605 - error: host.IoBroker Could not collect system.host.IoBroker states to check for obsolete states: Error: Cannot find view "system" 2023-06-27 21:53:47.605 - error: host.IoBroker _design/system missing - call node iobroker.js setup 2023-06-27 21:53:47.605 - info: host.IoBroker no instances found 2023-06-27 21:53:47.605 - info: host.IoBroker no instances found 2023-06-27 21:53:47.751 - info: host.IoBroker Created UUID: 0f610e92-bb95-3196-4662-047ef0e42f92den ext4 Fehler bekomme ich nicht weg
hier noch iob setup custom config
Current configuration: - Objects database: - Type: file - Host/Unix Socket: 127.0.0.1 - Port: 9001 - States database: - Type: redis - Host/Unix Socket: 127.0.0.1 - Port: 6379 - Data Directory: ../../iobroker-data/hatte da beim letzten mal auf redis umgestellt wenn ich mich nicht irre
@habedere sagte in [HowTo] ioBroker Restore unter Linux durchführen:
Kann es sein, dass du da irgendwas doppelt mountest?
Das wäre dann allerdings komplett OT hier in diesem HowTo.
Nicht dass ich wüsste. Weiß nicht mal ob ich das Problem über das Backup rein gezogen habe. Hätte ich vorher mal testen sollen.
Evtl kommt das vom Snapshot Rollback. Kenne mich da ebenso wenig aus und hangel mich da überall durch
nicht schön - aber klappt meistensJetzt muss ich noch Objects Database Filetyp auf Redis umstellen oder?
Jedenfalls sehe ich bei anderen LXC solche Meldungen nicht:
[Tue Jun 27 20:52:55 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:326: MMP interval 42 higher than expected, please wait. [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): 1 orphan inode deletedDa ist bestimmt irgendwas falsch.
Nein, man kann auch file/redis fahren.
Ok danke. Hmm leider springt die Kiste immer noch nicht an…Cannot read system.config: null (OK when migrating or restoring) + instance is aliveHast du eine Idee was ich probieren könnte?
Schau mal ob du damit weiterkommst:
DankeNicht wirklich…
admin@IoBroker:~$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects -rw-rw-r--+ 1 iobroker iobroker 64 Jun 27 21:51 2023-06-27_21-51_objects.json.gz -rw-rw-r--+ 1 iobroker iobroker 3.6K Jun 27 21:53 2023-06-27_21-53_objects.json.gz -rw-rw-r--+ 1 iobroker iobroker 3.6K Jun 28 20:14 2023-06-28_20-14_objects.json.gzBei den States kommt garnichts…
Dann weiß ich auch nicht.
Schade - aber trotzdem vielen Dank!Gute Nachricht -> ich habe ein etwas älteres Backup verwendet - das hat geklappt! jetzt nur noch die DatenBackups einspielen...
PS: beim komplett neu aufgesetzten, Snapshot zurück gesetzten ioBroker ist beim Diag wieder der ext4 Fehler drin
Von Containern hab ich keine Ahnung. Sieht aber für mich nach etwas aus, das man sich mal anschauen sollte.
@habedere das liegt wohl an deinem snapshot zurück spielen disk1, normal wäre disk0
Bin aber gerade nur am Handy -
@crunchip
ahh ok - die wichtigste Frage - ist das schlimm?! bzw. kann ich das so lassen?
würde gerade laufen - zumindest grob
Gelöschte inodes sind schlimm.
Hallo, ziehe langsam mit meinem iobroker um von pi4 auf nuc beelink(proxmox). Beim restore von redis bekomme ich
"Not configured"als Meldung und nichts passiert. Oder ist redis wurscht?
iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis -
@ticaki der pi lief mit redis/redis?
dann musst du bei deinem beelink ebenfalls vor dem restore redis installieren und glaub auch umstellen bevor du dann das backup einspielst -
@crunchip
der Pi läuft problemlos... bin ja nicht blöd
-redis ist installiert, ist umgestellt,
-iobroker backup ist drin,
-https läuft
-die hälfte der Adapter ist grünIch mache einen Adapter nach dem anderen grün und ein paar kann ich erst wenn alles fürs umschalten vorbereitet ist testen.
Im Moment frage ich mich ob das redis backup wichtig ist. Hab glaube ich keine Dateien im ioBroker abgelegt, dann sollte es doch egal sein oder?
In der redis-Datenbank werden die States / Objects abgelegt.
@ticaki sagte in [HowTo] ioBroker Restore unter Linux durchführen:
@thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
wenn du den iobroker installierst, steht er ja default auf jsonl, daher musst du auf redis umstellen dein backup einspielen und auch den restore der Datenbank vollziehen
iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redisist umgestellt, daher verstehe ich die Fehlermeldung eben nicht.
