    3. Einsteigerfragen
    4. Sonoff SNZB-02D Thermometer, Fehlermeldung [gelöst]
    • Duffy
      Duffy last edited by Duffy
      ich hatte gerade gelesen das man seine Fragen nicht an ein bereits gelöstes Thema anhängen soll, deshalb mache ich hier noch mal ein neues Thema auf.
      Ich verwende bei meinem ioBroker einen Sonoff Zigbee Stick mit dem Zigbee Adapter 1.8.10.
      Nun wollte ich in diese Zigbee Netzwerk einen Sonoff ZNZB-02D Thermometer einbinden.
      Beim koppeln kommt nun folgende Fehlermeldung:
      Pairing time left
      Pairing time left: 1
      Pairing time left: 2
      Pairing time left: 3
      Pairing time left: 4
      Pairing time left: 5
      Pairing time left: 6
      Error: DeviceConfigure:Failed to DeviceConfigure.configure 0x30fb10fffe6ec573 SNZB-02D (TypeError: Cannot read properties of undefined (reading 'error')
          at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/sonoff.js:193:24)
          at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13)
          at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17)). undefined
      Pairing time left: 7
      Pairing time left: 8
      Pairing time left: 9
      Pairing time left: 10
      Pairing time left: 11
      Pairing time left: 12
      Pairing time left: 13
      Pairing time left: 14
      Pairing time left: 15
      Pairing time left: 16
      Pairing time left: 17
      Pairing time left: 18
      Pairing time left: 19
      Pairing time left: 20
      Pairing time left: 21
      Pairing time left: 22
      Pairing time left: 23
      Pairing time left: 24
      Pairing time left: 25
      New device joined '0x30fb10fffe6ec573' model SNZB-02D
      Interview successful: {"friendly_name":"0x30fb10fffe6ec573","model":"SNZB-02D","vendor":"SONOFF","description":"Temperature and humidity sensor with screen","supported":true}
      Pairing time left: 26
      Pairing time left: 27
      Pairing time left: 28
      Pairing time left: 29
      Pairing time left: 30
      Pairing time left: 31
      Pairing time left: 32
      Pairing time left: 33
      Pairing time left: 34
      Pairing time left: 35
      Pairing time left: 36
      Pairing time left: 37
      Pairing time left: 38
      Pairing time left: 39
      Pairing time left: 40
      Pairing time left: 41
      Pairing time left: 42
      Pairing time left: 43
      Device '0x30fb10fffe6ec573' announced itself
      Pairing time left: 44
      Pairing time left: 45
      Pairing time left: 46
      Pairing time left: 47
      Pairing time left: 48
      Pairing time left: 49
      Pairing time left: 50
      Pairing time left: 51
      Pairing time left: 52
      Interview started: 0x30fb10fffe6ec573
      Pairing time left: 53
      Pairing time left: 54
      Pairing time left: 55
      Pairing time left: 56
      Pairing time left: 57
      Pairing time left: 58
      Pairing time left: 59
      Pairing time left: 60
      Pairing started
      Das Thermometer erscheint nun zwar im Zigbee Adapter, sogar mit dem entsprechenden Bild des Thermometers auch werden in den Objekten Temperatur und Feuchtigkeit angezeigt und auch aktualisiert:
      Edit
      Das wäre für mich, da es ja eigentlich zu funktionieren scheint, so weit trotzdem ok, wäre da nicht im Protokoll eine immer wiederkehrende Fehlermeldung:
      	DeviceConfigure:Failed to DeviceConfigure.configure 0x30fb10fffe6ec573 SNZB-02D (TypeError: Cannot read properties of undefined (reading 'error') at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/sonoff.js:193:24) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17))
      Configuring 0x30fb10fffe6ec573 SNZB-02D
      usw.
      Kann mir bitte jemand sagen warum ich das Thermometer nicht fehlerfrei koppeln kann?
      Ich habe da etwas von "zigbee-herdsmann-converters" gelesen kann es möglicherweise daran liegen? Wenn ich es richtig verstanden habe werden in dieser Datei(?) Daten für die verschiedenen Sensoren gespeichert und das da vielleicht dieses Thermometer noch fehlt.
      Ach ja, für den Fall das diese Informationen notwendig sind:
      VG Duffy
      PS: mit dem Conbee 2 Stick mit entsprechendem Adapter würde es funktionieren aber das Zigbee Netzwerk ist halt mit dem Sonoff Stick dem Zigbee Adapter und repeatern gespannt.
        hast du mal den adapter von GIT istalliert ?? gehts damit ?
          hammerhead86 last edited by
          Ich schließe mich dem Thema Mal an.
          Selber Gerät und selber Problem/Fehlermeldungen.
          Jemand nen Rat?
          Adapter Version ist aktuell aus'm Stable
            arteck Developer Most Active @hammerhead86 last edited by arteck
            @hammerhead86 dann aktualisiere mal von GIT
            • Duffy
              Duffy @arteck last edited by Duffy
              @arteck
              Das werde ich einmal versuchen, danke.
              Gruss Duffy
              Edit:
              @arteck; kannst du mir bitte noch sagen wie ich das über Git aktualisieren muss?
              Ist das über die Katze?
              Edit; bin ich hier richtig?
                arteck Developer Most Active @Duffy last edited by
                @duffy https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                Duffy 2 Replies Last reply Reply Quote 0
                • Duffy
                  @arteck
                  Danke schön für den tipp, kann es gerade nicht testen lasse aber von mir hören.
                  Viele Grüße Duffy
                  • Duffy
                    @arteck
                    hier meine Rückmeldung.
                    Die GIT Version habe ich nicht mehr getestet da inzwischen der Zigbee Adapter 1.8.12 als stable erschienen ist und seitdem gehören die Probleme mit dem SonofSNZB-02D der Vergangenheit an. Er wird nun sauber erkannt und es erscheinen keine Fehler mehr im Protokoll.
                    Danke für das einpflegen der für die Funktion nötigen Daten.
                    Gruß Duffy
