    4. Test Adapter Awtrix-Light (Awtrix 3)
      bishop @haus-automatisierung last edited by
      hier mal ein Auszug aus den Logs
      awtrix-light.0
      	2023-06-29 12:34:59.279	debug	received 200 response from "/api/custom?name=verbrauch" with content: "OK"
      awtrix-light.0
      	2023-06-29 12:34:59.213	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-21 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:59.211	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:34:55.793	debug	received 200 response from "/api/stats" with content: {"bat":91,"bat_raw":649,"lux":"0","ldr_raw":84,"ram":158184,"bri":122,"temp":"25","hum":"29","uptime":"285291","wifi_signal":-59,"up_available":false,"messages":0,"version":"0.70","indicator1":false,"indicator2":false,"indicator3":false,"app":"verbrauch"}
      awtrix-light.0
      	2023-06-29 12:34:55.678	debug	re-creating refresh state timeout
      awtrix-light.0
      	2023-06-29 12:34:55.677	debug	sending "GET" request to "/api/stats" without data
      awtrix-light.0
      	2023-06-29 12:34:55.677	debug	refreshing device state
      awtrix-light.0
      	2023-06-29 12:34:47.302	debug	received 200 response from "/api/custom?name=verbrauch" with content: "OK"
      awtrix-light.0
      	2023-06-29 12:34:47.193	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-18 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:47.191	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:34:37.271	debug	received 200 response from "/api/custom?name=verbrauch" with content: "OK"
      awtrix-light.0
      	2023-06-29 12:34:37.190	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-10 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:37.188	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:34:30.193	warn	(custom?name=verbrauch) Unable to update custom app "verbrauch": AxiosError: timeout of 3000ms exceeded
      awtrix-light.0
      	2023-06-29 12:34:30.193	info	error ECONNABORTED from /api/custom?name=verbrauch: timeout of 3000ms exceeded
      awtrix-light.0
      	2023-06-29 12:34:27.191	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-17 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:27.188	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:34:17.326	debug	received 200 response from "/api/custom?name=verbrauch" with content: "OK"
      awtrix-light.0
      	2023-06-29 12:34:17.186	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-5 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:17.184	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:34:07.290	debug	received 200 response from "/api/custom?name=verbrauch" with content: "OK"
      awtrix-light.0
      	2023-06-29 12:34:07.189	debug	sending "POST" request to "/api/custom?name=verbrauch" with data: {"text":"-10 W","icon":"630","duration":15}
      awtrix-light.0
      	2023-06-29 12:34:07.188	debug	[refreshCustomApp] Refreshing custom app "verbrauch" with icon "630" and text "%s %u"
      awtrix-light.0
      	2023-06-29 12:33:55.718	debug	received 200 response from "/api/stats" with content: {"bat":92,"bat_raw":651,"lux":"0","ldr_raw":83,"ram":157716,"bri":122,"temp":"25","hum":"29","uptime":"285231","wifi_signal":-61,"up_available":false,"messages":0,"version":"0.70","indicator1":false,"indicator2":false,"indicator3":false,"app":"verbrauch"}
      awtrix-light.0
      	2023-06-29 12:33:55.677	debug	re-creating refresh state timeout
      hoffe das hilft etwas!?!
      • Fabio
        Fabio @haus-automatisierung last edited by
        @haus-automatisierung ich bekomme wenn ich auf die Fahne klicke beim Blokly immer die Fehlermeldung das der Block nicht richtig verbunden ist.
        Egal wie ich es versuche wird gemeckert. Kannst du das mal bitte prüfen.
        Trotz des Fehler funktioniert aber trotzdem alles.
        Herzliche Grüße
        Fabio
        • haus-automatisierung
          haus-automatisierung Developer Most Active @Fabio last edited by haus-automatisierung
          @fa-bio sagte in Test Adapter Awtrix-Light:
          Das liegt daran, dass manche Attribute nicht gesetzt sind. Wie beispielsweise "sound" oder "icon" (sieht man auf deinem Screenshot ja leider nicht). Die sind im Standard ja "frei". Das mag die Validierung scheinbar nicht.
          Fabio 1 Reply Last reply Reply Quote 0
            haus-automatisierung Developer Most Active last edited by
            @bishop sagte in Test Adapter Awtrix-Light:
            Nicht wirklich - was genau ging denn in dem Moment nicht als das Log aufgezeichnet wurde. Der Timeout in der Mitte ist etwas komisch. Danach ging ja alles normal weiter.
            • Fabio
              @haus-automatisierung ja richtig,
              die habe ich nicht gesetzt, da ich im Moment nur Text darstelle.
              Evtl. kannst du die Validierung dann so machen das wenn keine Attribute gewählt sind das trotzdem in Ordnung ist.
              Fabio
              • U
                umichel last edited by
                Kann man irgendwie die Text-Scrollgeschwindigkeit regeln?
                Zu Textspeed steht im Datenpunkt was von Übergangszeit der Apps?
                Die FPS stehen bei mir auf 23.
                Bei Änderungen von beiden Werten kann ich keine Veränderung feststellen.
                Ist das fest integriert, damit die Schrift flüssig läuft?
                Bzw. manchmal hat man den Eindruck, dass die Schrift leichte Ruckler hat.
                Fabio M 2 Replies Last reply Reply Quote 0
                • Fabio
                  Fabio @umichel last edited by Fabio
                  @umichel das fände ich auch gut wenn man das regeln könnte evtl. baut @haus-automatisierung 👍es ja noch in den Adapter mit ein und zwar das man es in der Instanz festlegen könnte als „Idee.“
                  Grüße Fabio
                    MCU @umichel last edited by MCU
                    @umichel FPS gibt es seit der neuesten Firmware 0.70 nicht mehr, es wird nicht mehr unterstützt.
                    Auch im Adapter sollte es gelöscht sein, evtl. noch von alter Version vorhanden.
                      bicmac last edited by
                      kann man eigentlich irgendwo einstellen das der Text der Custom APP nicht scrollt? Ich lasse mir meine aktuelle Außentemperatur anzeigen und die Wassertemperatur vom Pool und dazu ist eigentlich kein Scrollen nötig. Er tut es aber trotzdem und das ganze wirkt damit sehr unruhig im Vergleich zur Uhrzeit (Nur Stunden:Minuten) und stört meine Frau ein wenig 🙂
                      DJMarc75 haus-automatisierung 2 Replies Last reply Reply Quote 0
                      • DJMarc75
                        DJMarc75 @bicmac last edited by
                        @bicmac sagte in Test Adapter Awtrix-Light:
                        horizontal oder vertikal ?
                          haus-automatisierung Developer Most Active @bicmac last edited by
                          Die Option gibt es im Adapter aktuell nicht. So langsam gab es für jede verfügbare Option aber mittlerweile eine Anfrage. Mal gucken ob ich das irgendwie alles in die Tabelle bekomme
                            Thomas Braun Most Active @haus-automatisierung last edited by
                            Hatten wir 'Bedingtes Aktivieren' schon?
                            Also das eine Custom App nur bei bestimmten Werten angezeigt wird?
                            Hab mir eine Anzeige der in Auslieferung befindlichen Paketsendungen an mich gebastelt. Wird aber halt auch angezeigt, wenn nichts unterwegs ist.
                              haus-automatisierung Developer Most Active @Thomas Braun last edited by
                              @thomas-braun Das kannst Du doch über Visible eigentlich gut selbst steuern. Oder ist der Text dann komplett leer? Das sollte natürlich nicht angezeigt werden
                                Thomas Braun Most Active @haus-automatisierung last edited by Thomas Braun
                                Ich steh auf'm Schlauch...
                                Wo steuer ich denn 'Visible' in der Instanz?
                                Oder meinst du per Blocky/Skript?
                                Das wollte ich eigentlich vermeiden, da finde ich das Timing immer schwierig.
                                [Edit:] Ich bin dann auch vom Schlauch heruntergestiegen... Läuft jetzt...
                                  Michaelnorge last edited by
                                  Habe fertig 🙂
                                  arteck 1 Reply Last reply Reply Quote 1
                                    arteck Developer Most Active @Michaelnorge last edited by
                                    @michaelnorge nicht so mein Ding aber hast was
                                    • Matzebhv
                                      Matzebhv last edited by
                                      Moin,
                                      das oben beschriebene Phänomen mit dem verschwinden von Apps habe ich auch.
                                      Habe bei mir den PV-Ertrag eingebaut, das funktioniert den ganzen Tag einwandfrei. Bei mir wird dann abends in Abhängigkeit von der Helligkeit der Modbus-Adapter deaktiviert, der müllt mir sonst die ganze Nacht das Log voll.
                                      Morgens ist die App dann nicht mehr sichtbar, die verschwindet also irgendwann nachts. Ein Adapter-Neustart behebt das Problem dann bis zur nächsten Nacht.
                                      Liegt das eventuell an dem DP, der nachts ja eher tot ist und nicht mehr angefasst wird? Alle anderen Apps laufen.
                                      Matze
                                        bishop @Matzebhv last edited by bishop
                                        @matzebhv
                                        EDIT: zu früh gefreut, bricht trotzdem ab 😞
                                        hatte das Problem auch. Hab dann mal den Adapter gelöscht und alle DP auch.
                                        Danach neuinstalliert.
                                        Bis jetzt läuft die App durch, schmeißt zwar ab und zu
                                        2023-06-29 10:32:31.427  - info: awtrix-light.0 (3453893) error ECONNABORTED from /api/custom?name=verbrauch: timeout of 3000ms exceeded
                                        2023-06-29 10:32:31.427  - warn: awtrix-light.0 (3453893) (custom?name=verbrauch) Unable to update custom app "verbrauch": AxiosError: timeout of 3000ms exceeded
                                        fehler aber sie läuft weiter.
                                        • Ben1983
                                          Ben1983 last edited by
                                          Offtopic:
                                          Seit heute Morgen steht die Uhr auf 01.01.1970. (Hängt dauerhaft am USB)
                                          Sie war aus und nach dem Einschalten zeigt sie auch ihre IP an, aber ist nicht erreichbar (Auch nicht der Webserver).
                                          Hat jemand das Problem schon mal gehabt?
                                            Thomas Braun Most Active @Ben1983 last edited by
                                            @ben1983
                                            Hast du da einen NTP-Server eingestellt?
                                            Bei mir nutze ich z. B. den in der FritzBox eingebauten.
                                            Ben1983 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            2160
                                            1222144
