ZigBee neue Version 1.8.x
@xsev sagte in ZigBee neue Version 1.8.x:
evtl. ist meine Firmware auf dem Stick auch zu alt mittlerweile?
das hat damit nix zu tun..
instellier mal die GIT version und schau nochmal
@arteck Danke für deine Hilfe. Ich hab die 1.8.11 über Git installiert. Leider kam es nach ein paar Stunden wieder zum absturz.
2023-06-27 11:30:43.149 info Currently 75 devices are joined: zigbee.0 2023-06-27 11:30:43.055 info --> transmitPower : high zigbee.0 2023-06-27 11:30:43.021 info Unable to disable LED, unsupported function. zigbee.0 2023-06-27 11:30:43.013 info Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}} zigbee.0 2023-06-27 11:30:42.689 info Installed Version: ioBroker/ioBroker.zigbee#ad21578c484248392fd8580b85e581548a0f80ba zigbee.0 2023-06-27 11:30:41.283 info Starting Zigbee npm ... zigbee.0 2023-06-27 11:30:41.279 info delete old Backup files. keep only last 10 zigbee.0 2023-06-27 11:30:41.012 info starting. Version 1.8.11 (non-npm: ioBroker/ioBroker.zigbee#ad21578c484248392fd8580b85e581548a0f80ba) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-06-27 11:30:00.690 warn Terminated (UNCAUGHT_EXCEPTION): Without reason zigbee.0 2023-06-27 11:30:00.687 info terminating zigbee.0 2023-06-27 11:30:00.611 info Zigbee: disabling joining new devices. zigbee.0 2023-06-27 11:29:59.761 info cleaned everything up... zigbee.0 2023-06-27 11:29:59.705 error Cannot read properties of undefined (reading 'Error') zigbee.0 2023-06-27 11:29:59.704 error TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22 zigbee.0 2023-06-27 11:29:59.607 error unhandled promise rejection: Cannot read properties of undefined (reading 'Error') zigbee.0 2023-06-27 11:29:59.606 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee.0 2023-06-27 11:29:59.602 error Send command to 0x001788010333e08a failed with no error code (Timeout - 53693 - 11 - 42 - 6 - 11 after 10000ms)anbei die Fehlermeldung. Auslöser war diesmal wieder eine Hue Lampe (wobei ich 2 davon habe aber nur eine dauernd im Fehlerlog auftaucht).
@xsev das scheint sentry zu sein.. da passt was nicht.
schalte es für den adapter aus.. im Admin . instanzen ganz links ist so ein grünes Symbol..da drauf klicken bis es grau wird -
@arteck Ich finde da leider nix mit Sentry, Admin - Instanzen is klar aber ich hab da nur die grünen Symbole für aktive Adapter.
edit:
Habs gefunden, sieht man nur im Expertenmodus. Ok habs deaktiviert werde berichten, danke! -
edit:
Habs gefunden, sieht man nur im Expertenmodus. Ok habs deaktiviert werde berichten, danke!Moin,
hier ein Beispiel:
VG
Bernd -
@arteck Adapter läuft jetzt seit über 15 Stunden wieder durch. Das deaktivieren von Sentry hat funktioniert.
Merci! -
ich habe einige Sonoff SNZB-02 Temp.-/Luftfeuchtesensoren. Koppeln ging. Bei einigen haben ich nach einiger Zeit aber die Verbindung verloren (disconnected). Bisher war es immer so, dass wenn man im Adapter auf Pairing gegangen ist und am Gerät eben die Bereitschaft hergestellt hat, er es wieder verbunden hat. Heute habe ich etwas Systempflege betrieben. Jetzt ist mir der Fehler beim Pairen aufgefallen, sprich die Geräte bleiben auf disconnected:
2023-06-30 16:29:45.463 - error: zigbee.0 (1074) DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b00290f0c38 TH01 (TypeError: Cannot read properties of undefined (reading 'error')im Adapter sieht es so aus:
Hat mir jemand einen Tipp? Danke
iob diag sagt:
Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 4 Model B Rev 1.4 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 14:39:10 up 5 min, 2 users, load average: 2.96, 2.38, 1.09 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=59.4'C volt=0.9160V *** Time and Time Zones *** Local time: Fri 2023-06-30 14:39:11 CEST Universal time: Fri 2023-06-30 12:39:11 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.5G 1.1G 0.0K 265M 1.3G Swap: 99M 2.0M 97M Total: 3.9G 2.5G 1.2G 3794 M total memory 2458 M used memory 617 M active memory 1974 M inactive memory 1069 M free memory 10 M buffer memory 255 M swap cache 99 M total swap 2 M used swap 97 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 28G 12G 15G 45% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 844K 759M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 253M 31M 222M 13% /boot tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Jun 30 14:33:37 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): recovery complete [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Jun 30 14:33:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Fri Jun 30 14:33:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 3.9G /var/ 3.1G /var/log 2.7G /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da 2.7G /var/log/journal 468M /var/lib Archived and active journals take up 2.6G in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 3.6G /opt/iobroker/iobroker-data/ 3.0G /opt/iobroker/iobroker-data/history 458M /opt/iobroker/iobroker-data/files 95M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png The five largest files in iobroker-data are: 55M /opt/iobroker/iobroker-data/objects.jsonl 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 16M /opt/iobroker/iobroker-data/states.jsonl 15M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map 8.6M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js *** NodeJS-Installation *** /usr/bin/nodejs v18.16.1 /usr/bin/node v18.16.1 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.1-deb-1nodesource1 Candidate: 18.16.1-deb-1nodesource1 Version table: *** 18.16.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 7.0.3 Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : smarthome - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.alexa2.0 : alexa2 : smarthome - enabled + system.adapter.backitup.0 : backitup : smarthome - enabled system.adapter.bmw.0 : bmw : smarthome - disabled system.adapter.devices.0 : devices : smarthome - enabled system.adapter.discovery.0 : discovery : smarthome - disabled + system.adapter.energiefluss.0 : energiefluss : smarthome - enabled system.adapter.feiertage.0 : feiertage : smarthome - enabled system.adapter.habpanel.0 : habpanel : smarthome - disabled + system.adapter.harmony.0 : harmony : smarthome - enabled system.adapter.heatingcontrol.0 : heatingcontrol : smarthome - disabled + system.adapter.history.0 : history : smarthome - enabled system.adapter.homeconnect.0 : homeconnect : smarthome - disabled + system.adapter.hue-extended.0 : hue-extended : smarthome - enabled system.adapter.ical.0 : ical : smarthome - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: smarthome - disabled system.adapter.icons-icons8.0 : icons-icons8 : smarthome - enabled system.adapter.icons-material-png.0 : icons-material-png : smarthome - disabled system.adapter.icons-material-svg.0 : icons-material-svg : smarthome - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : smarthome - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: smarthome - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : smarthome - disabled + system.adapter.influxdb.0 : influxdb : smarthome - enabled, port: 8086 + system.adapter.javascript.0 : javascript : smarthome - enabled system.adapter.javascript.1 : javascript : smarthome - disabled + system.adapter.logparser.0 : logparser : smarthome - enabled + system.adapter.meross.0 : meross : smarthome - enabled + system.adapter.mihome-vacuum.0 : mihome-vacuum : smarthome - enabled, port: 54321 + system.adapter.modbus.0 : modbus : smarthome - enabled + system.adapter.myenergi.0 : myenergi : smarthome - enabled + system.adapter.net-tools.0 : net-tools : smarthome - enabled system.adapter.openweathermap.0 : openweathermap : smarthome - enabled system.adapter.powerfox2.0 : powerfox2 : smarthome - enabled + system.adapter.pvforecast.0 : pvforecast : smarthome - enabled + system.adapter.rpi2.0 : rpi2 : smarthome - enabled system.adapter.schoolfree.0 : schoolfree : smarthome - enabled + system.adapter.selverf.0 : selverf : smarthome - enabled + system.adapter.shelly.0 : shelly : smarthome - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : smarthome - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : smarthome - enabled + system.adapter.synology.0 : synology : smarthome - enabled, port: 5501 + system.adapter.telegram.0 : telegram : smarthome - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.trashschedule.0 : trashschedule : smarthome - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : smarthome - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : smarthome - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : smarthome - enabled system.adapter.vis-icontwo.0 : vis-icontwo : smarthome - enabled system.adapter.vis-inventwo.0 : vis-inventwo : smarthome - disabled system.adapter.vis-map.0 : vis-map : smarthome - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : smarthome - enabled system.adapter.vis-material-webfont.0 : vis-material-webfont : smarthome - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : smarthome - enabled system.adapter.vis-metro.0 : vis-metro : smarthome - enabled system.adapter.vis-plumb.0 : vis-plumb : smarthome - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : smarthome - enabled system.adapter.vis-weather.0 : vis-weather : smarthome - enabled system.adapter.vis.0 : vis : smarthome - enabled + system.adapter.vw-connect.0 : vw-connect : smarthome - enabled + system.adapter.web.0 : web : smarthome - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : smarthome - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : smarthome - enabled + system.adapter.zigbee.0 : zigbee : smarthome - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : smarthome - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.influxdb.0 : influxdb : smarthome - enabled, port: 8086 + system.adapter.mihome-vacuum.0 : mihome-vacuum : smarthome - enabled, port: 54321 + system.adapter.shelly.0 : shelly : smarthome - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : smarthome - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.synology.0 : synology : smarthome - enabled, port: 5501 + system.adapter.telegram.0 : telegram : smarthome - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : smarthome - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : smarthome - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : smarthome - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json Active repo(s): live-stable Installed ioBroker-Instances Used repository: live-stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alexa2" : 3.23.2 , installed 3.23.2 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "bmw" : 2.5.7 , installed 2.5.7 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "feiertage" : 1.1.0 , installed 1.1.0 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "heatingcontrol": 2.10.6 , installed 2.10.6 Adapter "history" : 2.2.4 , installed 2.2.4 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "javascript" : 7.0.3 , installed 7.0.3 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "logparser" : 2.2.0 , installed 2.2.0 Adapter "meross" : 1.15.1 , installed 1.15.1 Adapter "mihome-vacuum": 3.11.0 , installed 3.8.8 [Updatable] Adapter "modbus" : 5.0.11 , installed 5.0.5 [Updatable] Adapter "myenergi" : 0.0.3 , installed 0.0.3 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "openweathermap": 0.3.9 , installed 0.3.9 Adapter "powerfox2" : 0.0.12 , installed 0.0.12 Adapter "pvforecast" : 2.7.1 , installed 2.7.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "schoolfree" : 1.1.1 , installed 1.1.1 Adapter "selverf" : 0.6.2 , installed 0.6.2 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "synology" : 2.1.13 , installed 2.1.13 Adapter "telegram" : 1.15.6 , installed 1.15.6 Adapter "trashschedule": 2.2.0 , installed 2.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.94.0 , installed 0.94.0 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.6 , installed 2.5.6 Adapter "vw-connect" : 0.0.67 , installed 0.0.67 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "yahka" : 0.17.0 , installed 0.17.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 22941 States: 20154 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Hit:7 https://apt.grafana.com stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 13248 740/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 13255 740/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 11262 565/sshd: /usr/sbin tcp 0 0 127.0.0.1:41421 0.0.0.0:* LISTEN 1001 21828 1642/io.yahka.0 tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 14024 684/influxd tcp 0 0 0.0.0.0:35981 0.0.0.0:* LISTEN 1001 18744 1642/io.yahka.0 tcp6 0 0 :::61991 :::* LISTEN 1001 16222 1679/io.harmony.0 tcp6 0 0 :::3000 :::* LISTEN 109 15373 735/grafana tcp6 0 0 :::22 :::* LISTEN 0 11264 565/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 19951 1482/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 14638 935/io.admin.0 tcp6 0 0 :::8087 :::* LISTEN 1001 19916 1493/io.simple-api. tcp6 0 0 :::8086 :::* LISTEN 999 12230 684/influxd tcp6 0 0 :::8084 :::* LISTEN 1001 21568 1771/io.ws.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11223 449/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 15918 1215/io.shelly.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12140 680/dhcpcd udp 0 0 0.0.0.0:57516 0.0.0.0:* 108 11225 449/avahi-daemon: r udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 16850 1238/io.mihome-vacu udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 16223 1679/io.harmony.0 udp6 0 0 :::5353 :::* 108 11224 449/avahi-daemon: r udp6 0 0 :::58916 :::* 108 11226 449/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-06-30 14:38:56.492 - info: sourceanalytix.0 (1723) Initialization of 0_userdata.0.Strom.WallboxGaN_Vortagesverbrauch_Gesamt successfully 2023-06-30 14:38:56.515 - info: sourceanalytix.0 (1723) Successfully activated SourceAnalytix for 8 of 8 states, will do my Job until you stop me! 2023-06-30 14:38:57.184 - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available 2023-06-30 14:38:57.185 - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined 2023-06-30 14:39:00.105 - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2062 2023-06-30 14:39:03.697 - info: powerfox2.0 (2062) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24 2023-06-30 14:39:05.531 - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work. 2023-06-30 14:39:05.533 - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2023-06-30 14:39:05.533 - info: alexa2.0 (1245) Device-type:A93SQJNJQLDSS - TV Schlafzimmer (CHANGE_NAME,SHARKNADO,MULTI_WAKEWORDS_SUPPORTED,SUPPORTS_LOCALE_SWITCH,SUPPORTS_LOCALE,ACTIVE_AFTER_FRO,SPEECH_RECOGNIZER_USS,VOLUME_SETTING,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,ARTHUR_TARGET,EQUALIZER_CONTROLLER_MIDRANGE,DIALOG_INTERFACE_VERSION,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MICROPHONE,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,EARCONS,REMINDERS,FLASH_BRIEFING,AUDIO_CONTROLS) 2023-06-30 14:39:08.790 - info: powerfox2.0 (2062) Terminated (NO_ERROR): Without reason 2023-06-30 14:39:09.497 - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR) 2023-06-30 14:39:17.583 - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work. 2023-06-30 14:39:17.584 - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2023-06-30 14:39:17.585 - info: alexa2.0 (1245) Device-type:A2N49KXGVA18AR - Philipps Fire (NO_TIME_ZONE_SETTING,ASX_TIME_ZONE,MICROPHONE,VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,REMINDERS) 2023-06-30 14:39:47.062 - info: alexa2.0 (1245) No smart home devices to query 2023-06-30 14:39:48.509 - info: alexa2.0 (1245) Subscribing to states... 2023-06-30 14:39:48.516 - info: alexa2.0 (1245) Deleting the following states: ["Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#enabled","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#delete","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.powerState","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity-reason","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#query","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#enabled","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#delete","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.powerState","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity-reason","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#query","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#enabled","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#delete","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.powerState","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity-reason","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#query","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#enabled","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#delete","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.powerState","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity-reason","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#query","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#enabled","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#delete","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.powerState","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity-reason","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#query","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.#delete","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.powerState","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-hue","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-saturation","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorRgb","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureInKelvin","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#enabled","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#delete","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.powerState","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#query","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#includeInAllQuery","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#includeInAllQuery","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#includeInAllQuery","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#includeInAllQuery"] 2023-06-30 14:39:50.615 - info: alexa2.0 (1245) Alexa-Push-Connection (macDms = true) established. Disable Polling 2023-06-30 14:40:00.573 - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2419 2023-06-30 14:40:03.328 - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available 2023-06-30 14:40:03.329 - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined 2023-06-30 14:40:04.250 - info: powerfox2.0 (2419) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24 2023-06-30 14:40:06.674 - info: powerfox2.0 (2419) Terminated (NO_ERROR): Without reason 2023-06-30 14:40:07.276 - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR) 2023-06-30 14:40:08.594 - info: alexa2.0 (1245) Initialization Done ... -
@mp_trixi sagte in ZigBee neue Version 1.8.x:
probier mal mit der neuen adapter version
Hi. Danke für die Antwort. Welche ist das? In der stable wird mir keine andere angeboten. Ist die via Github zu installieren?
@arteck
danke - habe ich gemacht. Ist nun die 1.8.12 drauf. Scheint noch nicht besser zu sein. Irgendwie erreicht er meine Router-Steckdosen nicht und damit auch nicht die anderen Geräte. Wie lange sollte da max. dauern, nach der Installation? Hier noch der Screenshot vom Adapter:
Und das log zu Zigbee sieht so aus (ab 10:11 mit der neuen Version):zigbee.0 2023-07-02 10:12:02.077 warn DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F zigbee.0 2023-07-02 10:12:01.073 warn DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F zigbee.0 2023-07-02 10:12:00.946 warn DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220 zigbee.0 2023-07-02 10:12:00.736 warn DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F zigbee.0 2023-07-02 10:12:00.455 warn DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220 zigbee.0 2023-07-02 10:11:54.197 warn DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F zigbee.0 2023-07-02 10:11:49.366 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] zigbee.0 2023-07-02 10:11:43.044 info DeviceConfigure successful 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:11:43.021 error DeviceConfigure:Configure failed: Error: Bind 0x00124b00290f0c38/1 msTemperatureMeasurement from '0x00124b0024c2b43a/1' failed (AREQ - ZDO - bindRsp after 10000ms) zigbee.0 2023-07-02 10:11:33.650 error Device 0xa4c1385e4f940aa8 "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.613 error Device 0xa4c138394267e33d "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.606 error Device 0xa4c1388c67dcc204 "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.394 error Device 0xa4c1388ffe36decc "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:32.755 warn download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png zigbee.0 2023-07-02 10:11:32.678 info Zigbee started zigbee.0 2023-07-02 10:11:32.677 info 0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.675 info 0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.673 info 0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.670 info 0xa4c1385e4f940aa8 (addr 1047): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.668 info 0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.666 info 0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.664 info 0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.663 info 0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.662 info 0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.660 info 0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.659 info 0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.657 info 0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.656 info 0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.654 info 0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.653 info 0xa4c138394267e33d (addr 250): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.651 info 0xa4c1388c67dcc204 (addr 49199): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.649 info 0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.647 info 0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.646 info 0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:11:32.644 info 0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.641 info 0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:11:32.637 info 0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.634 info 0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.632 info 0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.629 info 0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.627 info 0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.625 info 0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.623 info 0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.621 info 0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.619 info 0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.617 info 0xa4c1388ffe36decc (addr 43646): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.602 info 0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.597 info Configuring 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:11:32.382 info Currently 32 devices are joined: zigbee.0 2023-07-02 10:11:32.357 info --> transmitPower : normal zigbee.0 2023-07-02 10:11:32.339 info Unable to disable LED, unsupported function. zigbee.0 2023-07-02 10:11:32.329 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}} zigbee.0 2023-07-02 10:11:31.925 info Installed Version: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683 zigbee.0 2023-07-02 10:11:31.220 info Starting Zigbee npm ... zigbee.0 2023-07-02 10:11:31.217 info delete old Backup files. keep only last 10 zigbee.0 2023-07-02 10:11:31.076 info starting. Version 1.8.12 (non-npm: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-02 10:11:21.514 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zigbee.0 2023-07-02 10:11:21.511 info terminating zigbee.0 2023-07-02 10:11:21.114 info Zigbee: disabling joining new devices. zigbee.0 2023-07-02 10:11:20.989 info cleaned everything up... zigbee.0 2023-07-02 10:11:20.986 info Got terminate signal TERMINATE_YOURSELF zigbee.0 2023-07-02 10:09:18.924 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] zigbee.0 2023-07-02 10:05:48.454 warn Device '0x54ef4410000c39c2' announced itself zigbee.0 2023-07-02 10:04:58.623 warn DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F zigbee.0 2023-07-02 10:04:58.529 warn DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220 zigbee.0 2023-07-02 10:04:57.651 warn DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220 zigbee.0 2023-07-02 10:04:57.630 warn DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F zigbee.0 2023-07-02 10:04:57.148 warn DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F zigbee.0 2023-07-02 10:04:53.424 warn DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F zigbee.0 2023-07-02 10:04:40.087 error DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b00290f0c38 TH01 (TypeError: Cannot read properties of undefined (reading 'error') at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/sonoff.js:171:24) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1)) zigbee.0 2023-07-02 10:04:29.767 info Zigbee started zigbee.0 2023-07-02 10:04:29.765 info 0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.764 info 0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.759 info 0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.755 info 0xa4c1385e4f940aa8 (addr 1047): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.753 info 0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.751 info 0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.749 info 0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.748 info 0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.746 info 0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.744 info 0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.742 info 0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.741 info 0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.739 info 0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.738 info 0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.736 info 0xa4c138394267e33d (addr 250): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.734 info 0xa4c1388c67dcc204 (addr 49199): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.730 info 0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.728 info 0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.726 info 0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:04:29.724 info 0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.721 info 0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:04:29.719 info 0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.716 info 0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.714 info 0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.710 info 0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.708 info 0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.707 info 0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.704 info 0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.701 info 0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.699 info 0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.696 info 0xa4c1388ffe36decc (addr 43646): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.679 info 0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.671 info Configuring 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:04:29.508 info Currently 32 devices are joined: zigbee.0 2023-07-02 10:04:29.484 info --> transmitPower : normal zigbee.0 2023-07-02 10:04:29.458 info Unable to disable LED, unsupported function. zigbee.0 2023-07-02 10:04:29.449 info Coordinator firmware version: {"type":"zStack3x0","meta":"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}} zigbee.0 2023-07-02 10:04:25.774 info Installed Version: iobroker.zigbee@1.8.10 zigbee.0 2023-07-02 10:04:24.567 info Starting Zigbee npm ... zigbee.0 2023-07-02 10:04:24.564 info delete old Backup files. keep only last 10 zigbee.0 2023-07-02 10:04:24.212 info starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 -
@arteck
so siehts nun nach ca. 9h aus:
du bist auf Kanal 11, ist der auch frei? Schau mal in den Settings vom Adapter, da wird der beste ja angezeigt..
Hast ja nur 32 Devices.. die sind gleich wieder angelernt.. -
eigentlich war er das mal. Hatte aber mal mein Mesh WLAN sich optimieren lassen - gut möglich, dass es da herkommt. Habe mal ein paar Messungen durchgeführt (allerdings jetzt halt alle innerhalb der ca. letzten Stunde). Da wäre dann wohl 18 oder 23 der Gewinner (wobei die auch nicht immer 0 waren):
Wie geht man da am Besten vor? Erst alle Geräte löschen, dann Kanal umstellen und neu anlernen. Oder Nicht löschen? Schön wäre wenn die Aliase erhalten blieben
18 oder 23
mit den 2 bist du ausserhalb des Notmalen Bereicht. du wirst probleme haben mit dem Geräten
nimm 15 oder 25
und stelle das WLAN eher um
hast du dir das issue von mir mal angeschaut?
Wenn du die Hardware brauchst, schreib mir deine Adresse im Chat, kommt dann umgehend per Amazon von mir gesponsort..
Irgendwas muss sich bei den FRIENT Devices im Adapter von Version 1.8.9 auf alle hoeheren geaendert haben.. auch mit der aktuellen von Git reagiert der Melder nicht mehr auf manual start..Kann ja noch auf der 1.8.9 bleiben.. aber irgendwann wird das auch mal doof..
@ilovegym auch nicht wenn du den unter ausschliessen packst ?
@arteck sagte in ZigBee neue Version 1.8.x:
auch dann nicht... auf die neueste wieder geupdated, Device in Ausschliessen hinzugefuegt, Adapter gestoppt, gewartet... Adapter gestartet... gewartet... (bis die Karte sich aufgebaut hat..) dann nochmal getestet.. einmal von der Gui und einmal den Datenpunkt im Object-browser... keine Reaktion.. keine Fehlermeldung.. nix..
Edit doch Error:
2023-07-03 11:36:03.190 - error: zigbee.0 (1196700) uncaught exception: Cannot read properties of null (reading 'toString') 2023-07-03 11:36:03.190 - error: zigbee.0 (1196700) TypeError: Cannot read properties of null (reading 'toString') at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111) at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5) at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43 at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25) at processImmediate (node:internal/timers:478:21) 2023-07-03 11:36:03.191 - error: zigbee.0 (1196700) Cannot read properties of null (reading 'toString') 2023-07-03 11:36:03.217 - info: zigbee.0 (1196700) cleaned everything up... 2023-07-03 11:36:06.614 - error: host.iobrokerS2 Caught by controller[0]: TypeError: Cannot read properties of null (reading 'toString') 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at processImmediate (node:internal/timers:478:21) 2023-07-03 11:36:06.616 - error: host.iobrokerS2 instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-07-03 11:36:06.616 - info: host.iobrokerS2 Restart adapter system.adapter.zigbee.0 because enabled -
@arteck Habe gestern ein Update auf 1.8.12 durchgeführt. Das letzte Update stammt von 02.23 ich meine auf 1.8.11.
Soweit alles gut.
Da ich ion diesem Zusammenhang mal wieder meine Tabellen genauer angesehen. Dabei fiel mir auf, das die batteriebetriebenen Zigbee-Geräte scheinbar keinen Stromverbrauch mehr haben??
Laut Zeitstempel werden bei ALLEN meinen batteriebetriebenen Zigbee-Geräte keine Spannung oder Prozentwert mehr angezeigt wird.
Hab ich da irgend eine Info verpasst?
Alle anderen Werte kommen wie gewohnt. Deshalb ist mir das bisher nicht aufgefallen.
Zum Test habe ich mal einen Sensor neu gepairt. Das hat keine Änderung gebracht.Was kann ich tun?
Gruß Reiner
