    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
    • gelberlemmy
      gelberlemmy @crunchip last edited by
      @crunchip für iorboker.pro. Sonst kann ich nicht auf alle Adapetereinstellungen von der Ferne zugreifen
        Thomas Braun Most Active @gelberlemmy last edited by
        @gelberlemmy
        Nach
        2023-07-01 21:44:13.180  - info: host.IOBroker-Proxmox iobroker.js-controller version 5.0.5 js-controller starting
        seh ich nur INFO.
        gelberlemmy 2 Replies Last reply Reply Quote 0
        • gelberlemmy
          gelberlemmy @Thomas Braun last edited by
          @thomas-braun sagte in Troubleshooting NodeJS update:
          @gelberlemmy
          Nach
          seh ich nur INFO.
          ach Mensch, ist der falsche Teil des Logs... Warte
          • gelberlemmy
            023-07-01 22:09:15.913  - info: host.IOBroker-Proxmox instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
            2023-07-01 22:09:15.942  - warn: host.IOBroker-Proxmox instance system.adapter.sonoff.0 terminated due to SIGTERM
            2023-07-01 22:09:15.942  - info: host.IOBroker-Proxmox instance system.adapter.sonoff.0 terminated with code null ()
            2023-07-01 22:09:16.015  - warn: host.IOBroker-Proxmox instance system.adapter.homeconnect.0 terminated due to SIGTERM
            2023-07-01 22:09:16.015  - info: host.IOBroker-Proxmox instance system.adapter.homeconnect.0 terminated with code null ()
            2023-07-01 22:09:16.015  - warn: host.IOBroker-Proxmox instance system.adapter.hue-extended.0 terminated due to SIGTERM
            2023-07-01 22:09:16.015  - info: host.IOBroker-Proxmox instance system.adapter.hue-extended.0 terminated with code null ()
            2023-07-01 22:09:16.057  - warn: host.IOBroker-Proxmox instance system.adapter.zigbee.0 terminated due to SIGTERM
            2023-07-01 22:09:16.057  - info: host.IOBroker-Proxmox instance system.adapter.zigbee.0 terminated with code null ()
            2023-07-01 22:09:16.838  - warn: host.IOBroker-Proxmox instance system.adapter.javascript.0 terminated due to SIGTERM
            2023-07-01 22:09:16.838  - info: host.IOBroker-Proxmox instance system.adapter.javascript.0 terminated with code null ()
            2023-07-01 22:09:17.016  - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Object.onceWrapper (node:events:628:26)
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.emit (node:events:513:28)
            2023-07-01 22:09:17.017  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.emit (node:domain:489:12)
            2023-07-01 22:09:17.018  - error: host.IOBroker-Proxmox Caught by controller[0]:     at TCP.<anonymous> (node:net:322:12)
            2023-07-01 22:09:17.018  - warn: host.IOBroker-Proxmox instance system.adapter.nut.0 terminated due to SIGTERM
            2023-07-01 22:09:17.018  - info: host.IOBroker-Proxmox instance system.adapter.nut.0 terminated with code null ()
            2023-07-01 22:09:17.081  - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2023-07-01 22:09:17.081  - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
            2023-07-01 22:09:17.081  - error: host.IOBroker-Proxmox Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
            2023-07-01 22:09:17.081  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
            2023-07-01 22:09:17.082  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Object.onceWrapper (node:events:628:26)
            2023-07-01 22:09:17.082  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.emit (node:events:513:28)
            2023-07-01 22:09:17.082  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Socket.emit (node:domain:489:12)
            2023-07-01 22:09:17.082  - error: host.IOBroker-Proxmox Caught by controller[0]:     at TCP.<anonymous> (node:net:322:12)
            2023-07-01 22:09:17.082  - warn: host.IOBroker-Proxmox instance system.adapter.netatmo.0 terminated due to SIGTERM
            2023-07-01 22:09:17.082  - info: host.IOBroker-Proxmox instance system.adapter.netatmo.0 terminated with code null ()
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7591:34)
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
            2023-07-01 22:09:17.083  - error: host.IOBroker-Proxmox Caught by controller[0]:     at processImmediate (node:internal/timers:447:9)
            2023-07-01 22:09:17.083  - warn: host.IOBroker-Proxmox instance system.adapter.shelly.0 terminated due to SIGTERM
            2023-07-01 22:09:17.084  - info: host.IOBroker-Proxmox instance system.adapter.shelly.0 terminated with code null ()
            2023-07-01 22:09:17.112  - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2023-07-01 22:09:17.112  - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
            2023-07-01 22:09:17.112  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            2023-07-01 22:09:17.112  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            2023-07-01 22:09:17.112  - error: host.IOBroker-Proxmox Caught by controller[0]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
            2023-07-01 22:09:17.113  - error: host.IOBroker-Proxmox Caught by controller[0]:     at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7591:34)
            2023-07-01 22:09:17.113  - warn: host.IOBroker-Proxmox instance system.adapter.shelly.1 terminated due to SIGTERM
            2023-07-01 22:09:17.113  - info: host.IOBroker-Proxmox instance system.adapter.shelly.1 terminated with code null ()
            2023-07-01 22:09:17.163  - warn: host.IOBroker-Proxmox instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
            2023-07-01 22:09:17.163  - info: host.IOBroker-Proxmox instance system.adapter.fb-checkpresence.0 terminated with code null ()
            2023-07-01 22:09:17.190  - info: host.IOBroker-Proxmox instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
              @gelberlemmy
              Das ist ein shut down? Auch nicht ungewöhnlich.
              gelberlemmy 1 Reply Last reply Reply Quote 0
                crunchip Forum Testing Most Active @gelberlemmy last edited by
                @gelberlemmy sagte in Troubleshooting NodeJS update:
                is nicht der falsche Teil, nur zu wenig, die Adapterstarts kommen doch erst nach und nach
                • gelberlemmy
                  @gelberlemmy
                  Nein ein Neustart
                    Thomas Braun Most Active @gelberlemmy last edited by Thomas Braun
                    @gelberlemmy
                    Das kann aber nicht sein, SIGTERM ist das Signal für das Beenden eines Prozesses.
                    Ein Neustart hat auch mehr als 52 Zeilen im Log.
                    • gelberlemmy
                      @crunchip sagte in Troubleshooting NodeJS update:
                      Ich wollte alles Posten, da hat mir das Forum einen Strich durch die Rechnung gemacht. Musste es einkürzen, dann durfte ich es posten
                      • gelberlemmy
                        @gelberlemmy
                        Definitiv ein Neustart. Konnte das ganze Log nicht Posten. Werde es morgen einmal in Ruhe loggen und zwischenspeichern.
                          @gelberlemmy
                          Ich versteh gar nicht wo das Problem ist. Mach ein Terminal auf, hol dir per
                          iob logs | uniq
                          das Log auf den Screen, scroll hoch bis du das Copyright des ioBrokers siehst und ab da alles bis zum Ende markieren, fertig.
                          gelberlemmy 1 Reply Last reply Reply Quote 1
                          • gelberlemmy
                            @thomas-braun das geht in dem Terminl in Proxmox nicht. Der löscht nach einer gewissen Anzahl an Spalten die ersten Einträge. Daher mal werde ich das mal.morgen per Putty machen.
                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                              @gelberlemmy
                              Ich rede ja auch von 'richtigen' Terminalprogrammen. puTTY ist imho auch kein gescheites.
                              Die Windows PowerShell ist hier z. B. im Einsatz.
                                @gelberlemmy es reicht auch wenn du im browser öffnest, kannst genauso rauskopieren
                                • gelberlemmy
                                  @thomas-braun guten morgen. Kann es sein, dass der Log vom Shutdown beim nächsten Start mit angezeigt wird ? So würden die ganzen Errors beim Shutdown kommen. Dann habe ich dies falsch interpretiert. Aber diese Errors hatte ich mit der Version 16 nicht.
                                  23-07-02 08:22:19.793 - info: host.IOBroker-Proxmox stopInstance system.adapter.admin.1 send kill signal
                                  2023-07-02 08:22:19.793 - info: host.IOBroker-Proxmox stopInstance system.adapter.email.0 send kill signal
                                  2023-07-02 08:22:19.793 - info: host.IOBroker-Proxmox stopInstance system.adapter.javascript.0 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.telegram.0 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.telegram.1 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.alexa2.0 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.ham.0 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.hmip.0 send kill signal
                                  2023-07-02 08:22:19.794 - info: host.IOBroker-Proxmox stopInstance system.adapter.mqtt.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.netatmo.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.shelly.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.sonoff.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.zigbee.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.nut.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.samsung.0 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.shelly.1 send kill signal
                                  2023-07-02 08:22:19.795 - info: host.IOBroker-Proxmox stopInstance system.adapter.tr-064.0 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.alarm.0 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.alarm.1 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.alarm.2 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.amazon-dash.0 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.backitup.0 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.cloud.0 send kill signal
                                  2023-07-02 08:22:19.796 - info: host.IOBroker-Proxmox stopInstance system.adapter.device-reminder.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.discovery.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.enocean.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.fb-checkpresence.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.homeconnect.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.hue-extended.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.info.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.iot.0 send kill signal
                                  2023-07-02 08:22:19.797 - info: host.IOBroker-Proxmox stopInstance system.adapter.octoprint.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.pushsafer.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.sourceanalytix.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.text2command.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.trashschedule.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.web.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.zwave2.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.proxmox.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.worx.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.senec.0 send kill signal
                                  2023-07-02 08:22:19.798 - info: host.IOBroker-Proxmox stopInstance system.adapter.accuweather.0 send kill signal
                                  2023-07-02 08:22:19.799 - info: host.IOBroker-Proxmox stopInstance system.adapter.jarvis.0 send kill signal
                                  2023-07-02 08:22:19.799 - info: host.IOBroker-Proxmox stopInstance system.adapter.energiefluss.0 send kill signal
                                  2023-07-02 08:22:19.804 - info: jarvis.0 (1035) terminating with timeout
                                  2023-07-02 08:22:19.805 - info: worx.0 (994) terminating with timeout
                                  2023-07-02 08:22:19.811 - info: energiefluss.0 (1046) terminating with timeout
                                  2023-07-02 08:22:19.813 - info: web.0 (957) terminating with timeout
                                  2023-07-02 08:22:19.824 - info: telegram.0 (2000) terminating with timeout
                                  2023-07-02 08:22:19.826 - info: cloud.0 (740) terminating with timeout
                                  2023-07-02 08:22:19.830 - info: zigbee.0 (596) terminating with timeout
                                  2023-07-02 08:22:19.833 - info: telegram.1 (2006) terminating with timeout
                                  2023-07-02 08:22:19.836 - info: alexa2.0 (2385) terminating with timeout
                                  2023-07-02 08:22:19.846 - info: backitup.0 (729) terminating with timeout
                                  2023-07-02 08:22:19.863 - info: accuweather.0 (1020) terminating with timeout
                                  2023-07-02 08:22:19.864 - info: admin.1 (351) terminating with timeout
                                  2023-07-02 08:22:19.879 - info: info.0 (835) terminating with timeout
                                  2023-07-02 08:22:19.884 - info: trashschedule.0 (946) terminating with timeout
                                  2023-07-02 08:22:19.885 - info: hmip.0 (490) terminating with timeout
                                  2023-07-02 08:22:19.895 - info: enocean.0 (781) terminating with timeout
                                  2023-07-02 08:22:19.898 - info: senec.0 (1009) terminating with timeout
                                  2023-07-02 08:22:19.899 - info: ham.0 (479) terminating with timeout
                                  2023-07-02 08:22:19.927 - info: amazon-dash.0 (718) terminating with timeout
                                  2023-07-02 08:22:20.042 - info: fb-checkpresence.0 (794) terminating
                                  2023-07-02 08:22:20.038 - warn: senec.0 (1009) redis get senec.0._calc.LIVE_GRID_EXPORT.refMonth, error - Connection is closed.
                                  2023-07-02 08:22:20.044 - warn: senec.0 (1009) redis get senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.refValueYear, error - DB closed
                                  2023-07-02 08:22:20.049 - warn: shelly.0 (563) redis get shelly.0.SHUNI-1#349454790800#1.Relay0.Timer, error - Connection is closed.
                                  2023-07-02 08:22:20.055 - warn: shelly.0 (563) get state error: Connection is closed.
                                  2023-07-02 08:22:20.059 - warn: shelly.1 (641) get state error: Connection is closed.
                                  2023-07-02 08:22:20.052 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.052 - error: senec.0 (1009) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:20.053 - error: senec.0 (1009) Error: DB closed
                                  at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                  at TCP. (node:net:322:12)
                                  2023-07-02 08:22:20.054 - error: senec.0 (1009) DB closed
                                  2023-07-02 08:22:20.086 - warn: senec.0 (1009) redis get senec.0._calc.LIVE_GRID_IMPORT.year, error - Connection is closed.
                                  2023-07-02 08:22:20.087 - warn: senec.0 (1009) redis get senec.0._calc.LIVE_BAT_CHARGE_MASTER.year, error - Connection is closed.
                                  2023-07-02 08:22:20.105 - warn: senec.0 (1009) redis get senec.0._calc.Autarky.today, error - Connection is closed.
                                  2023-07-02 08:22:20.207 - warn: senec.0 (1009) redis get senec.0.STATISTIC.LIVE_GRID_EXPORT, error - Connection is closed.
                                  2023-07-02 08:22:20.342 - warn: senec.0 (1009) redis get senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year, error - Connection is closed.
                                  2023-07-02 08:22:20.390 - info: fb-checkpresence.0 (794) terminating with timeout
                                  2023-07-02 08:22:20.413 - error: senec.0 (1009) Cannot check object existence of "senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year": DB closed
                                  2023-07-02 08:22:20.414 - warn: senec.0 (1009) Could not perform strict object check of state senec.0._calc.Autarky.today: DB closed
                                  2023-07-02 08:22:20.415 - warn: senec.0 (1009) get state error: Connection is closed.
                                  2023-07-02 08:22:20.415 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.415 - error: senec.0 (1009) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:20.415 - error: senec.0 (1009) Error: DB closed
                                  2023-07-02 08:22:20.416 - error: senec.0 (1009) DB closed
                                  2023-07-02 08:22:20.416 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.416 - error: senec.0 (1009) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:20.417 - error: senec.0 (1009) Error: DB closed
                                  2023-07-02 08:22:20.417 - error: senec.0 (1009) DB closed
                                  2023-07-02 08:22:20.417 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.417 - error: senec.0 (1009) unhandled promise rejection: Could not check object existence of senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year: Cannot check object existence of "senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year": DB closed
                                  2023-07-02 08:22:20.420 - error: senec.0 (1009) Error: Could not check object existence of senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year: Cannot check object existence of "senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year": DB closed
                                  at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
                                  at Senec._setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3416:49)
                                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  2023-07-02 08:22:20.420 - error: senec.0 (1009) Could not check object existence of senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year: Cannot check object existence of "senec.0._calc.LIVE_BAT_DISCHARGE_MASTER.year": DB closed
                                  2023-07-02 08:22:20.428 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.428 - error: senec.0 (1009) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:20.429 - error: senec.0 (1009) Error: DB closed
                                  2023-07-02 08:22:20.429 - error: senec.0 (1009) DB closed
                                  2023-07-02 08:22:20.450 - error: senec.0 (1009) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.450 - error: senec.0 (1009) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:20.451 - error: senec.0 (1009) Error: DB closed
                                  at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:521:40)
                                  at Senec._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5472:34)
                                  at process.processImmediate (node:internal/timers:447:9)
                                  2023-07-02 08:22:20.451 - error: senec.0 (1009) DB closed
                                  2023-07-02 08:22:20.650 - warn: zwave2.0 (972) Could not perform strict object check of state zwave2.0.Node_001.ready: DB closed
                                  2023-07-02 08:22:20.652 - warn: zwave2.0 (972) get state error: Connection is closed.
                                  2023-07-02 08:22:20.653 - warn: zwave2.0 (972) get state error: Connection is closed.
                                  2023-07-02 08:22:20.653 - info: zwave2.0 (972) terminating
                                  2023-07-02 08:22:21.004 - info: host.IOBroker-Proxmox stopInstance system.adapter.admin.1 killing pid 351
                                  2023-07-02 08:22:21.027 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.Time: DB closed
                                  2023-07-02 08:22:21.028 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.030 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.alive: DB closed
                                  2023-07-02 08:22:21.031 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.032 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.Uptime: DB closed
                                  2023-07-02 08:22:21.033 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.052 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.UptimeSec: DB closed
                                  2023-07-02 08:22:21.052 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.064 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.Heap: DB closed
                                  2023-07-02 08:22:21.065 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.067 - warn: sonoff.0 (571) Could not perform strict object check of state sonoff.0.Trockner.SleepMode: DB closed
                                  2023-07-02 08:22:21.068 - warn: sonoff.0 (571) get state error: Connection is closed.
                                  2023-07-02 08:22:21.013 - info: host.IOBroker-Proxmox stopInstance system.adapter.javascript.0 killing pid 419
                                  2023-07-02 08:22:21.034 - info: host.IOBroker-Proxmox stopInstance system.adapter.telegram.0 killing pid 2000
                                  2023-07-02 08:22:21.048 - info: host.IOBroker-Proxmox stopInstance system.adapter.telegram.1 killing pid 2006
                                  2023-07-02 08:22:21.065 - info: host.IOBroker-Proxmox stopInstance system.adapter.ham.0 killing pid 479
                                  2023-07-02 08:22:21.066 - info: host.IOBroker-Proxmox stopInstance system.adapter.hmip.0 killing pid 490
                                  2023-07-02 08:22:21.075 - info: host.IOBroker-Proxmox stopInstance system.adapter.mqtt.0 killing pid 520
                                  2023-07-02 08:22:21.084 - info: host.IOBroker-Proxmox stopInstance system.adapter.shelly.0 killing pid 563
                                  2023-07-02 08:22:21.086 - info: host.IOBroker-Proxmox stopInstance system.adapter.sonoff.0 killing pid 571
                                  2023-07-02 08:22:21.087 - info: host.IOBroker-Proxmox stopInstance system.adapter.zigbee.0 killing pid 596
                                  2023-07-02 08:22:21.106 - info: host.IOBroker-Proxmox stopInstance system.adapter.samsung.0 killing pid 614
                                  2023-07-02 08:22:21.107 - info: host.IOBroker-Proxmox stopInstance system.adapter.shelly.1 killing pid 641
                                  2023-07-02 08:22:21.107 - info: host.IOBroker-Proxmox stopInstance system.adapter.tr-064.0 killing pid 652
                                  2023-07-02 08:22:21.108 - info: host.IOBroker-Proxmox stopInstance system.adapter.amazon-dash.0 killing pid 718
                                  2023-07-02 08:22:21.108 - info: host.IOBroker-Proxmox stopInstance system.adapter.device-reminder.0 killing pid 751
                                  2023-07-02 08:22:21.109 - info: host.IOBroker-Proxmox stopInstance system.adapter.hue-extended.0 killing pid 820
                                  2023-07-02 08:22:21.109 - info: host.IOBroker-Proxmox stopInstance system.adapter.octoprint.0 killing pid 877
                                  2023-07-02 08:22:21.109 - info: host.IOBroker-Proxmox stopInstance system.adapter.pushsafer.0 killing pid 896
                                  2023-07-02 08:22:21.111 - info: host.IOBroker-Proxmox stopInstance system.adapter.sourceanalytix.0 killing pid 916
                                  2023-07-02 08:22:21.112 - info: host.IOBroker-Proxmox stopInstance system.adapter.text2command.0 killing pid 927
                                  2023-07-02 08:22:21.114 - info: host.IOBroker-Proxmox stopInstance system.adapter.trashschedule.0 killing pid 946
                                  2023-07-02 08:22:21.114 - info: host.IOBroker-Proxmox stopInstance system.adapter.web.0 killing pid 957
                                  2023-07-02 08:22:21.114 - info: host.IOBroker-Proxmox stopInstance system.adapter.zwave2.0 killing pid 972
                                  2023-07-02 08:22:21.136 - info: host.IOBroker-Proxmox stopInstance system.adapter.proxmox.0 killing pid 979
                                  2023-07-02 08:22:21.136 - info: host.IOBroker-Proxmox stopInstance system.adapter.jarvis.0 killing pid 1035
                                  2023-07-02 08:22:20.096 - error: shelly.0 (563) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.097 - error: shelly.0 (563) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:21.359 - error: shelly.0 (563) Error: DB closed
                                  2023-07-02 08:22:21.360 - error: shelly.0 (563) DB closed
                                  2023-07-02 08:22:20.061 - error: shelly.1 (641) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-07-02 08:22:20.061 - error: shelly.1 (641) unhandled promise rejection: DB closed
                                  2023-07-02 08:22:21.510 - error: shelly.1 (641) Error: DB closed
                                  2023-07-02 08:22:21.511 - error: shelly.1 (641) DB closed
                                  2023-07-02 08:22:21.698 - info: host.IOBroker-Proxmox instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:23.719 - info: host.IOBroker-Proxmox instance system.adapter.email.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.178 - info: host.IOBroker-Proxmox instance system.adapter.netatmo.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.218 - info: host.IOBroker-Proxmox instance system.adapter.alarm.1 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.383 - info: host.IOBroker-Proxmox instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.384 - info: host.IOBroker-Proxmox instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.507 - info: host.IOBroker-Proxmox instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.563 - info: host.IOBroker-Proxmox instance system.adapter.enocean.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.637 - info: host.IOBroker-Proxmox instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.637 - info: host.IOBroker-Proxmox instance system.adapter.accuweather.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.683 - info: host.IOBroker-Proxmox instance system.adapter.energiefluss.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.712 - info: host.IOBroker-Proxmox instance system.adapter.alarm.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.804 - info: host.IOBroker-Proxmox instance system.adapter.alarm.2 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.804 - info: host.IOBroker-Proxmox instance system.adapter.fb-checkpresence.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.834 - info: host.IOBroker-Proxmox instance system.adapter.homeconnect.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.864 - info: host.IOBroker-Proxmox instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.956 - info: host.IOBroker-Proxmox instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.956 - info: host.IOBroker-Proxmox instance system.adapter.senec.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:26.986 - info: host.IOBroker-Proxmox instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.016 - info: host.IOBroker-Proxmox instance system.adapter.nut.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.187 - info: host.IOBroker-Proxmox instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.187 - info: host.IOBroker-Proxmox instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.304 - info: host.IOBroker-Proxmox instance system.adapter.hmip.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.491 - warn: host.IOBroker-Proxmox instance system.adapter.mqtt.0 terminated due to SIGTERM
                                  2023-07-02 08:22:27.491 - info: host.IOBroker-Proxmox instance system.adapter.mqtt.0 terminated with code null ()
                                  2023-07-02 08:22:27.491 - info: host.IOBroker-Proxmox instance system.adapter.samsung.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.532 - info: host.IOBroker-Proxmox instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.574 - info: host.IOBroker-Proxmox instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.639 - info: host.IOBroker-Proxmox instance system.adapter.device-reminder.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.640 - info: host.IOBroker-Proxmox instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.683 - info: host.IOBroker-Proxmox instance system.adapter.octoprint.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.712 - warn: host.IOBroker-Proxmox instance system.adapter.pushsafer.0 terminated due to SIGTERM
                                  2023-07-02 08:22:27.712 - info: host.IOBroker-Proxmox instance system.adapter.pushsafer.0 terminated with code null ()
                                  2023-07-02 08:22:27.797 - info: host.IOBroker-Proxmox instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.797 - info: host.IOBroker-Proxmox instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:27.826 - warn: host.IOBroker-Proxmox instance system.adapter.web.0 terminated due to SIGTERM
                                  2023-07-02 08:22:27.826 - info: host.IOBroker-Proxmox instance system.adapter.web.0 terminated with code null ()
                                  2023-07-02 08:22:27.856 - warn: host.IOBroker-Proxmox instance system.adapter.telegram.0 terminated due to SIGTERM
                                  2023-07-02 08:22:27.857 - info: host.IOBroker-Proxmox instance system.adapter.telegram.0 terminated with code null ()
                                  2023-07-02 08:22:27.947 - warn: host.IOBroker-Proxmox instance system.adapter.telegram.1 terminated due to SIGTERM
                                  2023-07-02 08:22:27.947 - info: host.IOBroker-Proxmox instance system.adapter.telegram.1 terminated with code null ()
                                  2023-07-02 08:22:27.948 - warn: host.IOBroker-Proxmox instance system.adapter.javascript.0 terminated due to SIGTERM
                                  2023-07-02 08:22:27.948 - info: host.IOBroker-Proxmox instance system.adapter.javascript.0 terminated with code null ()
                                  2023-07-02 08:22:28.091 - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-07-02 08:22:28.091 - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
                                  2023-07-02 08:22:28.091 - error: host.IOBroker-Proxmox Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-07-02 08:22:28.092 - error: host.IOBroker-Proxmox Caught by controller[0]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-07-02 08:22:28.092 - error: host.IOBroker-Proxmox Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-07-02 08:22:28.092 - error: host.IOBroker-Proxmox Caught by controller[0]: at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7591:34)
                                  2023-07-02 08:22:28.092 - warn: host.IOBroker-Proxmox instance system.adapter.shelly.0 terminated due to SIGTERM
                                  2023-07-02 08:22:28.093 - info: host.IOBroker-Proxmox instance system.adapter.shelly.0 terminated with code null ()
                                  2023-07-02 08:22:28.211 - warn: host.IOBroker-Proxmox instance system.adapter.sonoff.0 terminated due to SIGTERM
                                  2023-07-02 08:22:28.211 - info: host.IOBroker-Proxmox instance system.adapter.sonoff.0 terminated with code null ()
                                  2023-07-02 08:22:28.266 - warn: host.IOBroker-Proxmox instance system.adapter.zigbee.0 terminated due to SIGTERM
                                  2023-07-02 08:22:28.266 - info: host.IOBroker-Proxmox instance system.adapter.zigbee.0 terminated with code null ()
                                  2023-07-02 08:22:28.266 - error: host.IOBroker-Proxmox Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                  2023-07-02 08:22:28.266 - error: host.IOBroker-Proxmox Caught by controller[0]: Error: DB closed
                                  2023-07-02 08:22:28.266 - error: host.IOBroker-Proxmox Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  2023-07-02 08:22:28.267 - error: host.IOBroker-Proxmox Caught by controller[0]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  2023-07-02 08:22:28.267 - error: host.IOBroker-Proxmox Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                  2023-07-02 08:22:28.267 - error: host.IOBroker-Proxmox Caught by controller[0]: at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7591:34)
                                  2023-07-02 08:22:28.267 - warn: host.IOBroker-Proxmox instance system.adapter.shelly.1 terminated due to SIGTERM
                                  2023-07-02 08:22:28.267 - info: host.IOBroker-Proxmox instance system.adapter.shelly.1 terminated with code null ()
                                  2023-07-02 08:22:28.324 - warn: host.IOBroker-Proxmox instance system.adapter.text2command.0 terminated due to SIGTERM
                                  2023-07-02 08:22:28.324 - info: host.IOBroker-Proxmox instance system.adapter.text2command.0 terminated with code null ()
                                  2023-07-02 08:22:28.378 - warn: host.IOBroker-Proxmox instance system.adapter.zwave2.0 terminated due to SIGTERM
                                  2023-07-02 08:22:28.378 - info: host.IOBroker-Proxmox instance system.adapter.zwave2.0 terminated with code null ()
                                  2023-07-02 08:22:28.378 - info: host.IOBroker-Proxmox instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:28.416 - info: host.IOBroker-Proxmox instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:28.461 - info: host.IOBroker-Proxmox instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                  2023-07-02 08:22:28.461 - info: host.IOBroker-Proxmox All instances are stopped.
                                  2023-07-02 08:22:28.548 - info: host.IOBroker-Proxmox terminated
                                  2023-07-02 08:22:40.258 - info: host.IOBroker-Proxmox iobroker.js-controller version 5.0.5 js-controller starting
                                  2023-07-02 08:22:40.264 - info: host.IOBroker-Proxmox Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                  2023-07-02 08:22:40.264 - info: host.IOBroker-Proxmox hostname: IOBroker-Proxmox, node: v18.16.1
                                  2023-07-02 08:22:40.265 - info: host.IOBroker-Proxmox ip addresses: 192.168.171.35 fe80::a8d4:caff:fe76:9b25
                                  2023-07-02 08:22:42.861 - info: host.IOBroker-Proxmox connected to Objects and States
                                  2023-07-02 08:22:42.929 - info: host.IOBroker-Proxmox added notifications configuration of host
                                  2023-07-02 08:22:44.098 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.nodeCurrent"
                                  2023-07-02 08:22:44.099 - info: host.IOBroker-Proxmox 52 instances found
                                  2023-07-02 08:22:44.201 - info: host.IOBroker-Proxmox starting 47 instances
                                  2023-07-02 08:22:44.398 - info: host.IOBroker-Proxmox instance system.adapter.admin.0 started with pid 304
                                  2023-07-02 08:22:44.411 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.nodeNewest"
                                  2023-07-02 08:22:44.460 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.nodeNewestNext"
                                  2023-07-02 08:22:44.466 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.npmCurrent"
                                  2023-07-02 08:22:44.472 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.npmNewest"
                                  2023-07-02 08:22:44.478 - info: host.IOBroker-Proxmox Delete state "system.host.IOBroker-Proxmox.versions.npmNewestNext"
                                  2023-07-02 08:22:44.484 - info: host.IOBroker-Proxmox Some obsolete host states deleted.
                                  2023-07-02 08:22:47.062 - info: admin.0 (304) starting. Version 6.5.9 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:22:47.238 - info: admin.0 (304) requesting all states
                                  2023-07-02 08:22:47.239 - info: admin.0 (304) requesting all objects
                                  2023-07-02 08:22:49.031 - info: admin.0 (304) Request actual repository...
                                  2023-07-02 08:22:50.673 - info: host.IOBroker-Proxmox instance system.adapter.admin.1 started with pid 331
                                  2023-07-02 08:22:52.406 - info: admin.0 (304) received all objects
                                  2023-07-02 08:22:52.747 - info: host.IOBroker-Proxmox instance system.adapter.email.0 started with pid 338
                                  2023-07-02 08:22:53.503 - info: admin.0 (304) Secure socket.io server listening on port 8081
                                  2023-07-02 08:22:53.516 - info: admin.0 (304) https server listening on port 8081
                                  2023-07-02 08:22:53.516 - info: admin.0 (304) Use link "https://127.0.0.1:8081" to configure.
                                  2023-07-02 08:22:53.959 - info: host.IOBroker-Proxmox Updating repository "Alternativ latest" under "http://iobroker.live/repo/sources-dist-latest.json"
                                  2023-07-02 08:22:56.111 - info: admin.0 (304) Repository received successfully.
                                  2023-07-02 08:22:57.236 - info: host.IOBroker-Proxmox instance system.adapter.history.0 started with pid 353
                                  2023-07-02 08:22:58.740 - info: admin.1 (331) starting. Version 6.5.9 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:22:58.863 - info: admin.1 (331) requesting all states
                                  2023-07-02 08:22:58.866 - info: admin.1 (331) requesting all objects
                                  2023-07-02 08:22:59.468 - info: email.0 (338) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.email, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:03.023 - info: host.IOBroker-Proxmox instance system.adapter.javascript.0 started with pid 384
                                  2023-07-02 08:23:04.036 - info: admin.1 (331) received all objects
                                  2023-07-02 08:23:04.638 - info: admin.1 (331) Request actual repository...
                                  2023-07-02 08:23:04.712 - info: admin.1 (331) socket.io server listening on port 8088
                                  2023-07-02 08:23:04.714 - info: admin.1 (331) http server listening on port 8088
                                  2023-07-02 08:23:04.715 - info: admin.1 (331) Use link "http://127.0.0.1:8088" to configure.
                                  2023-07-02 08:23:05.163 - info: host.IOBroker-Proxmox Updating repository "Alternativ latest" under "http://iobroker.live/repo/sources-dist-latest.json"
                                  2023-07-02 08:23:05.328 - info: host.IOBroker-Proxmox instance system.adapter.telegram.0 started with pid 391
                                  2023-07-02 08:23:07.569 - info: history.0 (353) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:07.973 - info: history.0 (353) enabled logging of alias.0.Steckdosen.Steckdose Datenschrank.value_electric_w_consumed (Count=1), Alias=false
                                  2023-07-02 08:23:07.975 - info: history.0 (353) enabled logging of alias.0.Steckdosen.Steckdose_Geschirrspüler.Power (Count=2), Alias=false
                                  2023-07-02 08:23:07.976 - info: history.0 (353) enabled logging of alias.0.Steckdosen.Steckdose_Trockner.ENERGY_Power (Count=3), Alias=false
                                  2023-07-02 08:23:07.976 - info: history.0 (353) enabled logging of shelly.0.SHPLG-S#9D8C29#1.Relay0.Power (Count=4), Alias=false
                                  2023-07-02 08:23:07.977 - info: history.0 (353) enabled logging of sonoff.0.Trockner.ENERGY_Power (Count=5), Alias=false
                                  2023-07-02 08:23:07.977 - info: history.0 (353) enabled logging of fb-checkpresence.0.Nadine (Count=6), Alias=false
                                  2023-07-02 08:23:07.978 - info: history.0 (353) enabled logging of fb-checkpresence.0.Andre (Count=7), Alias=false
                                  2023-07-02 08:23:08.102 - info: admin.1 (331) Repository received successfully.
                                  2023-07-02 08:23:08.902 - info: host.IOBroker-Proxmox instance system.adapter.telegram.1 started with pid 406
                                  2023-07-02 08:23:12.610 - info: host.IOBroker-Proxmox instance system.adapter.alexa2.0 started with pid 421
                                  2023-07-02 08:23:13.911 - info: javascript.0 (384) starting. Version 7.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:14.001 - info: telegram.0 (391) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:16.752 - info: javascript.0 (384) requesting all states
                                  2023-07-02 08:23:16.754 - info: javascript.0 (384) requesting all objects
                                  2023-07-02 08:23:16.935 - info: host.IOBroker-Proxmox instance system.adapter.ham.0 started with pid 440
                                  2023-07-02 08:23:21.513 - info: host.IOBroker-Proxmox instance system.adapter.hmip.0 started with pid 451
                                  2023-07-02 08:23:22.514 - info: telegram.1 (406) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:24.032 - info: ham.0 (440) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.ham, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:24.158 - info: alexa2.0 (421) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.16.1, js-controller: 5.0.5
                                  2023-07-02 08:23:24.217 - info: javascript.0 (384) received all objects
                                  2023-07-02 08:23:24.130 - info: ham.0 (440) Install/Update the following Libraries: homebridge-govee@7.8.0
                                  2023-07-02 08:23:24.161 - info: ham.0 (440) Install/Update homebridge-govee@7.8.0
                                  2023-07-02 08:23:24.179 - info: ham.0 (440) All Libraries installed/updated
                                  2023-07-02 08:23:24.181 - info: ham.0 (440) Adapter uses Wrapper mode
                                  2023-07-02 08:23:26.489 - info: alexa2.0 (421) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
                                  2023-07-02 08:23:26.792 - info: javascript.0 (384) received all states
                                  2023-07-02 08:23:26.835 - info: host.IOBroker-Proxmox instance scheduled system.adapter.ical.0 0,30 * * * *
                                  2023-07-02 08:23:26.903 - info: host.IOBroker-Proxmox instance system.adapter.ical.0 started with pid 476
                                  2023-07-02 08:23:27.793 - info: javascript.0 (384) script.js.global.icon_mapping: compiling TypeScript source...
                                  2023-07-02 08:23:29.301 - info: javascript.0 (384) script.js.global.icon_mapping: source code did not change, using cached compilation result...
                                  2023-07-02 08:23:30.634 - info: host.IOBroker-Proxmox instance system.adapter.mqtt.0 started with pid 498
                                    Das Log geht immer von 0 Uhr bis 24h.
                                    • gelberlemmy
                                      Ja das ist klar. Wenn man das Log herunterlädt. Ich habe mein System neu gestartet. Und nach dem Neustart werden dann erst die Daten vom Shutdown angezeigt unter Protokolle in der WebGui. Das war mir nicht bewusst. Das war mein Denkfehler.
                                        @gelberlemmy
                                        Die WebGUI ist an der Stelle eh 'kaputt', meiner Meinung nach. Z. B. ist die Chronologie verkehrt herum. Das Logo sollte anders scrollen.
                                        • gelberlemmy
                                          @gelberlemmy
                                          Das habe ich jetzt gelernt. Im Log schauen..... Aber die ganzen Errors beim Shutdown.... Kann man diese vernachlässigen ?
                                            @gelberlemmy
                                            Das sind Meldungen, weil die Datenbank da schon heruntergefahren wurde und die Adapter nicht wissen wohin damit.
                                            Welche Datenbank wird von dir verwendet?
                                            Edit: Typo.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143633
