    4. go-e Adapter
    go-e Adapter
    • JohGre
      JohGre last edited by
      Dazu gibts in der Telegramm Gruppe etwas
      wierer-sigi 1 Reply Last reply Reply Quote 0
      • André Koschnik
        André Koschnik last edited by
        Moin,
        kann mir jemand helfen mein e-Go Adapter schmeißt fehler:
        	API response validation error: [{"message":"\"lod\" is not allowed","path":["lod"],"type":"object.unknown","context":{"child":"lod","label":"lod","value":65535,"key":"lod"}},{"message":"\"lts\" is not allowed","path":["lts"],"type":"object.unknown","context":{"child":"lts","label":"lts","value":0,"key":"lts"}},{"message":"\"pco\" is not allowed","path":["pco"],"type":"object.unknown","context":{"child":"pco","label":"pco","value":"","key":"pco"}},{"message":"\"cmf\" is not allowed","path":["cmf"],"type":"object.unknown","context":{"child":"cmf","label":"cmf","value":0,"key":"cmf"}},{"message":"\"ath\" is not allowed","path":["ath"],"type":"object.unknown","context":{"child":"ath","label":"ath","value":1200,"key":"ath"}},{"message":"\"psp\" is not allowed","path":["psp"],"type":"object.unknown","context":{"child":"psp","label":"psp","value":11300,"key":"psp"}},{"message":"\"cco\" is not allowed","path":["cco"],"type":"object.unknown","context":{"child":"cco","label":"cco","value":180,"key":"cco"}},{"message":"\"map\" is not allowed","path":["map"],"type":"object.unknown","context":{"child":"map","label":"map","value":123,"key":"map"}},{"message":"\"frm\" is not allowed","path":["frm"],"type":"object.unknown","context":{"child":"frm","label":"frm","value":1,"key":"frm"}},{"message":"\"los\" is not allowed","path":["los"],"type":"object.unknown","context":{"child":"los","label":"los","value":"{\"chg\":[[\"053644\",10,0,1,0,[1,2,3],6]]}","key":"los"}}]
        FW des go-e is 42
        Hardeware V2
        http://<IP>/status funktioniert
          kiste01 @André Koschnik last edited by kiste01
          @andré-koschnik @JohGre @wierer-sigi
          Ich hatte das Thema auch. Dem Hersteller ist das Problem inzwischen bekannt und sie arbeiten daran. Offenbar wird die lokale API blockiert / gestört ...
          Ihr braucht also nicht weiter probieren mit Rücksetzen etc.
          Update: Man prüft nach wie vor, warum die API nicht mehr funktioniert. Falls ihr dringend Hilfe braucht und z.B. ein Rücksetzen der Firmware unbedingt wollt, dann wendet euch individuell an support@go-e.com
          Die brauchen von euch idealerweise ein Foto der Chipkarte
          Viel Erfolg
          wierer-sigi 1 Reply Last reply Reply Quote 1
          • wierer-sigi
            wierer-sigi @JohGre last edited by
            @johgre sagte in Go e-charger:
            Danke für die Info. Dafür schein das Zusammenspiel der Go-E charger mit dem Controller für das Überschussladen zu funktionieren. Frage dadurch nur via API die Ladeleistung ab, damit die VIS wieder passt.
            Dann warten wir mal bis der iobroker Adapter wieder kappt.
            • JohGre
              habe nun seit Freitag mein E-Auto und soweit funktioniert die Überschussteuerung, nur wie am Chart erkennbar (rote Linie) bleibt er plötzlich bei 3,8kW hängen obwohl kein Überschuss vorhanden ist (gelbe Linie).
              Muss ich im da in der go-e Wallbox da auch irgendwas einstellen?
              nik82 1 Reply Last reply Reply Quote 0
              • nik82
                nik82 Most Active @JohGre last edited by
                @johgre
                Bist du auf 3-phasen? Das niedrigste wo er schaltet sind 6 Ampere.
                JohGre 1 Reply Last reply Reply Quote 0
                • JohGre
                  JohGre @nik82 last edited by JohGre
                  @nik82 Ja, was kann ich da noch einstellen.
                  Ok, habs jetzt verstanden, wenn ich auf eine Phase schalten, dann regelt er auch hier sauber runter. Muss mir nur mehr ein Logik zusammenbasteln wenn ich wieder auf 3 Phase umschalte.
                  • nik82
                    @johgre
                    Musst Phasenschaltung machen, musst aber eine V3 haben
                    Hab das hier alles zusammengefasst:
                    https://forum.iobroker.net/post/997951
                    • JohGre
                      @nik82 Soweit verstanden, aber regelt der Adapter nicht runter bei 0 Überproduktion. Bei mir geht er immer in den Netzbezug
                      • nik82
                        @johgre
                        Doch bei vollen Überschuss 16a und bei keinem überschuss regelt er runter auf 6a.
                        Unter 6a geht nicht.
                        • JohGre
                          @nik82 Danke schon mal für deine Hilfe
                          Bedeutet aber dann, dass ich mich um das ausschalten selber kümmern muss. Ich glaub du machst das mit 5 Minuten über 1000W Netzbezug, oder?
                          Mach ich eh dann mit setState('go-e.0.allow_charging'/*Allow Charging (alw)*/, 0); oder?
                          Wann regelst du auf 3 Phasen hoch?
                          Ich habe das Problem, dass ich nicht mehr als 4kW Einspeisen darf, kann also nicht überprüfen ob größer 4000W Überschuss.
                          • nik82
                            @johgre
                            Genau alles richtig.
                            Naja wenn du nicht weißt wieviel du einspeist, dann wirds schwierig, dann musst halt einfach ab 4kW Einspeisung schalten. Mit Phasenschaltung kann ich noch nicht viel sagen, weil ich mein Auto das 3 Phasen kann erst ein paar Tage habe, dass muss ich jetzt dann erstmal alles testen 🙂
                            Aber von der Theorie siehst du es ja in meiner Anleitung...
                            • wierer-sigi
                              wierer-sigi @nik82 last edited by wierer-sigi
                              Ich habe als Setup einen Go-E Charger V2 ( 42.0 ) und einen V3 ( 55.5 ) und den Go-E Controller.
                              Da es ja mit der mit der V2 42.0 Probleme gibt und dadurch meine selbstgebaute Überschussladelogik via Blocky nicht mehr geht, nutze ich das Überschussladen der Go-E App. Funktioniert soweit ganz gut.
                              Ich würde nur zwischen Überschussladen und Normales ( immer ) laden vom iobroker aus wechseln wollen.
                              Ich sehe zwar über den Modbus Adapter ( Register 200 ) mit 4 für Überschussladen ausgegeben wird. Aber ich kann im Holding Register den Wert nicht auf 0 ( offen ) abändern.
                              Hat jemand eine Idee was falsch sein könnte oder einen anderen Weg um diese Änderung vorzunehmen.
                              Gibt es einen API Befehl dafür?
                              • wierer-sigi
                                wierer-sigi @wierer-sigi last edited by
                                @wierer-sigi
                                Habe es herausgefunden:
                                Zum aktivieren von Überschussladen:
                                https://api.go-e.co/api?payload=ast=4&token=xxxxxxxxxx
                                xxxxxxxxx = Der Cloud-Token des Go-E
                                Zum zurückstellen auf normales laden:
                                https://api.go-e.co/api?payload=ast=1&token=xxxxxxxxxx
                                Ist leider in der sonst prima Doku in GitHub noch nicht aufgeführt.
                                https://github.com/goecharger/go-eCharger-API-v1/blob/master/go-eCharger%20API%20v1%20DE.md
                                • nik82
                                  nik82 Most Active @wierer-sigi last edited by
                                  @wierer-sigi
                                  Die Überschussladung funktioniert aber nur mit GoE-Controller oder?
                                  Weil woher soll der Go-E sonst wissen was er an Überschuss hat?
                                  wierer-sigi JohGre 2 Replies Last reply Reply Quote 0
                                  • wierer-sigi
                                    @nik82 sagte in Go e-charger:
                                    @wierer-sigi
                                    Ja, der Go-E controller, hat zwei Meßeingänge ( 3-phasing )
                                    1. Am Wechselrichter
                                    2. Am Zähler
                                    Diese sind dann auch wieder im iobroker über ModBus sichtbar
                                    • JohGre
                                      @nik82 Jein, mittels Script kannst du das auch nachbauen. Bin da selber gerade dran.
                                      • nik82
                                        @johgre
                                        Ja die Überschussregelung macht der Adapter ja, da brauch ich kein extra Script 🙂
                                        War nur interesse halber für was der Befehl ist.
                                        • JohGre
                                          Aber nur wenn du den go-e controller hast.
                                          • nik82
                                            @johgre
                                            Nein, mach doch alles der Adapter: https://forum.iobroker.net/post/997951
                                            1020
                                            331156
