    4. Test Adapter OpenDTU
      Thomas Braun Most Active @axel last edited by
      @axel sagte in Test Adapter OpenDTU:
      Es gibt aber leider Websocket Errors: Unexpeced Server Response 302
      Bei mir nicht.
      A 2 Replies Last reply Reply Quote 0
        axel @Thomas Braun last edited by
        @thomas-braun Der Port ist 80, oder?
        • DJMarc75
          DJMarc75 @axel last edited by
          @axel ja
          https://github.com/o0shojo0o/ioBroker.opendtu
            axel @DJMarc75 last edited by
            @djmarc75 Danke. Dann werde ich morgen mein System mal komplett neu starten. Mal sehen was dann passiert.
              @thomas-braun Also Neustar hat nix geholfen. Hast Du noch ne Idee?
                @axel
                Dann poste mal was aus dem LogFile dazu. Am besten mit Debug-Log-Level.
                  Hier der relevante Teil:
                  0a2e2ab5-35b0-4fd0-8ea4-4fa539aad065-grafik.png 2023-06-29 14:22:00.614 - info: host.smarthome instance system.adapter.opendtu.0 started with pid 1809
                  2023-06-29 14:22:01.118 - debug: opendtu.0 (1809) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2023-06-29 14:22:01.145 - debug: opendtu.0 (1809) Objects client ready ... initialize now
                  2023-06-29 14:22:01.146 - debug: opendtu.0 (1809) Objects create System PubSub Client
                  2023-06-29 14:22:01.146 - debug: opendtu.0 (1809) Objects create User PubSub Client
                  2023-06-29 14:22:01.186 - debug: opendtu.0 (1809) Objects client initialize lua scripts
                  2023-06-29 14:22:01.188 - debug: opendtu.0 (1809) Objects connected to redis: 127.0.0.1:9001
                  2023-06-29 14:22:01.208 - debug: opendtu.0 (1809) Redis States: Use Redis connection: 127.0.0.1:9000
                  2023-06-29 14:22:01.220 - debug: opendtu.0 (1809) States create System PubSub Client
                  2023-06-29 14:22:01.221 - debug: opendtu.0 (1809) States create User PubSub Client
                  2023-06-29 14:22:01.243 - debug: opendtu.0 (1809) States connected to redis: 127.0.0.1:9000
                  2023-06-29 14:22:01.385 - info: opendtu.0 (1809) starting. Version 0.1.5 (non-npm: o0shojo0o/ioBroker.opendtu#27a02ed048bc0cc2c48692ce0eeac280ecf891c1) in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.16.0, js-controller: 4.0.24
                  2023-06-29 14:22:01.649 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:01.654 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:02.747 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:02.747 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:03.873 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:03.873 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:04.999 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:05.000 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:06.130 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:06.130 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:07.266 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:07.267 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:08.379 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:08.379 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:09.504 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:09.504 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:10.636 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:10.636 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:11.759 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:11.759 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:12.888 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:12.888 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:14.010 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:14.011 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:15.140 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:15.141 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:16.269 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:16.270 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:17.412 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:17.412 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:18.514 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:18.515 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:19.642 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:19.642 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:20.665 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:20.666 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:21.791 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:21.792 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:22.924 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:22.924 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:24.050 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:24.050 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:25.201 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:25.202 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:26.298 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:26.298 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:27.425 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:27.425 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:28.549 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:28.550 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:29.679 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:29.679 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:30.700 - debug: opendtu.0 (1809) Websocket error: Error: Unexpected server response: 302
                  2023-06-29 14:22:30.700 - debug: opendtu.0 (1809) Start try again in 1 seconds...
                  2023-06-29 14:22:31.623 - info: host.smarthome "system.adapter.opendtu.0" disabled
                  2023-06-29 14:22:31.624 - info: host.smarthome stopInstance system.adapter.opendtu.0 (force=false, process=true)
                  2023-06-29 14:22:31.626 - info: host.smarthome stopInstance system.adapter.opendtu.0 send kill signal
                  2023-06-29 14:22:31.626 - info: opendtu.0 (1809) Got terminate signal TERMINATE_YOURSELF
                  2023-06-29 14:22:31.627 - info: opendtu.0 (1809) terminating
                  2023-06-29 14:22:31.628 - info: opendtu.0 (1809) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-06-29 14:22:32.159 - info: host.smarthome instance system.adapter.opendtu.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    Thomas Braun Most Active @axel last edited by Thomas Braun
                    @axel
                    Setz das bitte in CodeTags.
                    Und die openDTU ist wie aufgesetzt?
                    302 ist ja ein redirect. Warum auch immer der da geschmissen wird.
                      @axel
                      Instanz:
                      openDTU:
                        r1schleicher @Thomas Braun last edited by
                        @axel deaktiviere die original DTU
                          axel @r1schleicher last edited by
                          @r1schleicher Ja, ich hatte eine original DTU testweise im Einzatz. War aber Mist. Wie deaktiviere ich das?
                            @thomas-braun Also, es ist ein ESP32S Dev Kit C V4 NodeMCU mit einem NRF24L01 + PA + LNA Funk-Transceiver-Modul 2.4G. Geflasht habe ich das Ganze mit Hilfe von https://ahoydtu.de/getting_started/.
                              @axel
                              openDTU und AhoyDTU sind aber zwei Paar Schuhe.
                                @thomas-braun ... dann habe ich da wohl eine falsche SW geflasht...
                                  @axel
                                  Das sieht so aus...
                                    @thomas-braun gibt es ein HowTo für die richtige Firmware?
                                    Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                      @axel
                                      https://github.com/tbnobody/OpenDTU
                                        axel last edited by
                                        Danke.
                                        Wow, das sieht sehr komplex aus! Mal sehen ob ich das hinbekomme. Mach ich in der kommenden Woche.
                                          @axel
                                          Du hast doch Ahoy auch irgendwie auf die Kiste gebügelt. Großartig anders geht das bei openDTU auch nicht.
                                            @thomas-braun Ja. Aber das war ein geführter Prozess. Hier steht was von PIN-reallignment und einstellbare Ports... Der USB-Portz ist klar, ist der, in den ich das board einstecke. Monitor_Port läuft mir zum ersten mal über den Weg. Das Ding arbeitet monitorlos. Ich habe eine WebUI auf meinem IOS-Gerät. Jetzt möchte ich die Daten noch über ioBroker in meine SQL ablegen und über Grafana verfügbar machen. Funktioniert alles bestens, nur eben die DTU-Integration.
                                            dtu hoymiles opendtu solar
                                            47
                                            457
                                            122202
