    3. Off Topic
    4. InfluxDB
    5. InfluxDB auf Raspberry PI4 meldet: 404 page not found
    • Alexander Apel
      Alexander Apel @Thomas Braun last edited by
      das habe ich auch gerade gesehen, laut der Anleitungen im Netz sollte hier auch "InfluxDB started" oder sowas mit "http Port 8086" stehen, das tut es aber nicht.
      admin@ioBroker:~ $ systemctl status influx*
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: active (running) since Sun 2023-07-02 13:08:50 CEST; 22h ago
             Docs: https://docs.influxdata.com/influxdb/
         Main PID: 2154 (influxd)
            Tasks: 14 (limit: 3933)
              CPU: 4min 52.245s
           CGroup: /system.slice/influxdb.service
                   └─2154 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
      Jul 03 11:46:42 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:11:46:42 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      Jul 03 11:51:01 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:11:51:01 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      Jul 03 11:51:42 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:11:51:42 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      Jul 03 11:56:02 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:11:56:02 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      Jul 03 11:56:42 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:11:56:42 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      Jul 03 12:01:42 ioBroker influxd-systemd-start.sh[2154]: [httpd] 127.0.0.1 - admin [03/Jul/2023:12:01:42 +0200] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1>
      lines 1-20/20 (END)
        Thomas Braun Most Active @Alexander Apel last edited by
        @alexander-apel sagte in InfluxDB auf Raspberry PI4 meldet: 404 page not found:
        influxdb.service
        Ich weiß nicht ob das nicht der Prozess zur influxdb1 ist.
        Müsste dir jemand sagen, bei dem influxdb2 läuft.
        crunchip Alexander Apel 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Thomas Braun last edited by
          @thomas-braun sagte in InfluxDB auf Raspberry PI4 meldet: 404 page not found:
          scheint wohl so
          hat er wohl nicht
          @crunchip sagte in InfluxDB auf Raspberry PI4 meldet: 404 page not found:
          influxdb deinstallieren
          sudo apt-get autoremove --purge influxdb
          ausgeführt
          Alexander Apel 1 Reply Last reply Reply Quote 0
          • Alexander Apel
            ich habe gerade gesehen das es ein Upgrade gegeben hätte https://docs.influxdata.com/influxdb/v2.0/upgrade/v1-to-v2/automatic-upgrade/ schade das ich kein Backup vom alten Stand habe um das zu versuchen.
            Erstaunlich ist auch das mein Grafana weiter Daten ausspuckt, anscheint ist die alte Datenbank noch da oder die neue geht schon...
            • Alexander Apel
              Alexander Apel @crunchip last edited by
              @crunchip said in InfluxDB auf Raspberry PI4 meldet: 404 page not found:
              hat er wohl nicht
              ausgeführt
              doch das hatte ich gemacht
                Kann auch sein, dass da die 'Installation' aus dem tarball (.tar.gz) noch herumspukt.
                • Alexander Apel
                  ok, ich würde jetzt einfach das Teil einmal platt machen und mit einem leeren OS Image vom vom PI Imager starten. Das Raspberry PI OS Lite (64-bit) sollte doch ausreichen oder?
                  Zur Installation von Influx dann nur das hier oder übersehe ich etwas?
                  wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                  echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                  rm influxdata-archive_compat.key
                  sudo apt update
                  Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                    Ja, das ist perfekt.
                    Nein, das ist genau richtig.
                    Dann aus dem Repo halt influxdb2-client und influxdb2 installieren.
                    • Alexander Apel
                      ok dafür dann diese beiden - richtig?
                      sudo apt install influxdb2
                      sudo apt install influxdb2-client
                        @alexander-apel
                        Ja. Kannste auch in eine Zeile packen.
                        sudo apt install influxdb2 influxdb2-client
                        • Marc Berg
                          Marc Berg Most Active @Alexander Apel last edited by
                          Noch ein Tipp: Nach der Neuinstallation der InfluxDB 2.x KEINE Config manuell anlegen, sondern
                          influx setup
                          auf der Kommandozeile, dies legt dann automatisch die korrekte Config an.
                          • Alexander Apel
                            bekomme jetzt beim Installieren diese Meldung
                            dpkg: error processing archive /var/cache/apt/archives/influxdb2-client_2.7.1-1_arm64.deb (--unpack):
                             trying to overwrite '/usr/bin/influx', which is also in package influxdb2-cli 2.7.3-1
                            dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                            Errors were encountered while processing:
                            E: Sub-process /usr/bin/dpkg returned an error code (1)
                            ist das schlimm?
                            • Alexander Apel
                              Alexander Apel @Marc Berg last edited by
                              @marc-berg
                              jetzt bekomme ich schonmal eine andere Meldung
                              admin@ioBroker:~ $ influx setup
                              Error: failed to check if already set up: Get "http://localhost:8086/api/v2/setup": dial tcp [::1]:8086: connect: connection refused
                              aber ich glaube das liegt daran das der iobroker noch fehlt - das hole ich mal schnell nach
                              • Marc Berg
                                Nein, das hat damit nichts zu tun. Die InfluxDb ist noch nicht richtig installiert.
                                • Alexander Apel
                                  @marc-berg
                                  aber nach der iobroker installation geht es weiter 🙂
                                  > Welcome to InfluxDB 2.0!
                                  ? Please type your primary username
                                  Das mache ich das Setup mal und schaue was dann passiert
                                  • Alexander Apel
                                    ich wer verrückt - jetzt gehts 🙂
                                    Vielen dank an euch alle!!!
                                      ist das schlimm?
                                      Jein, da ist influxdb2-cli schon installiert.
                                      Kannst du deinstallieren, dafür dann influxdb2-client installieren.
                                      sudo apt remove influxdb2-cli
                                      Die Version passt von der Versionsnummer besser zum Hauptprogramm.
                                      Kannst du aber auch so lassen.
                                      • Alexander Apel
                                        @thomas-braun da jetzt gerade alles geht würde ich es erstmal so lassen, mein Smartmeter sowie die Fritz Dect Geräte sind auch schon wieder da - von daher passt das so für mich.
                                        Es sei denn Grafana macht jetzt mucken - dann melde ich mich nochmal 😉
                                          @alexander-apel
                                          Ja, lass es so.
                                          2681
