ZigBee neue Version 1.8.x
@arteck
danke - habe ich gemacht. Ist nun die 1.8.12 drauf. Scheint noch nicht besser zu sein. Irgendwie erreicht er meine Router-Steckdosen nicht und damit auch nicht die anderen Geräte. Wie lange sollte da max. dauern, nach der Installation? Hier noch der Screenshot vom Adapter:
Und das log zu Zigbee sieht so aus (ab 10:11 mit der neuen Version):zigbee.0 2023-07-02 10:12:02.077 warn DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F zigbee.0 2023-07-02 10:12:01.073 warn DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F zigbee.0 2023-07-02 10:12:00.946 warn DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220 zigbee.0 2023-07-02 10:12:00.736 warn DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F zigbee.0 2023-07-02 10:12:00.455 warn DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220 zigbee.0 2023-07-02 10:11:54.197 warn DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F zigbee.0 2023-07-02 10:11:49.366 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] zigbee.0 2023-07-02 10:11:43.044 info DeviceConfigure successful 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:11:43.021 error DeviceConfigure:Configure failed: Error: Bind 0x00124b00290f0c38/1 msTemperatureMeasurement from '0x00124b0024c2b43a/1' failed (AREQ - ZDO - bindRsp after 10000ms) zigbee.0 2023-07-02 10:11:33.650 error Device 0xa4c1385e4f940aa8 "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.613 error Device 0xa4c138394267e33d "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.606 error Device 0xa4c1388c67dcc204 "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:33.394 error Device 0xa4c1388ffe36decc "A1Z" not described in statesMapping. zigbee.0 2023-07-02 10:11:32.755 warn download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png zigbee.0 2023-07-02 10:11:32.678 info Zigbee started zigbee.0 2023-07-02 10:11:32.677 info 0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.675 info 0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.673 info 0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.670 info 0xa4c1385e4f940aa8 (addr 1047): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.668 info 0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.666 info 0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.664 info 0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.663 info 0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.662 info 0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.660 info 0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.659 info 0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.657 info 0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.656 info 0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.654 info 0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.653 info 0xa4c138394267e33d (addr 250): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.651 info 0xa4c1388c67dcc204 (addr 49199): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.649 info 0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.647 info 0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.646 info 0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:11:32.644 info 0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.641 info 0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:11:32.637 info 0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.634 info 0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.632 info 0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.629 info 0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.627 info 0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.625 info 0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.623 info 0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:11:32.621 info 0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.619 info 0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) zigbee.0 2023-07-02 10:11:32.617 info 0xa4c1388ffe36decc (addr 43646): A1Z - NOUS Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:11:32.602 info 0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:11:32.597 info Configuring 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:11:32.382 info Currently 32 devices are joined: zigbee.0 2023-07-02 10:11:32.357 info --> transmitPower : normal zigbee.0 2023-07-02 10:11:32.339 info Unable to disable LED, unsupported function. zigbee.0 2023-07-02 10:11:32.329 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}} zigbee.0 2023-07-02 10:11:31.925 info Installed Version: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683 zigbee.0 2023-07-02 10:11:31.220 info Starting Zigbee npm ... zigbee.0 2023-07-02 10:11:31.217 info delete old Backup files. keep only last 10 zigbee.0 2023-07-02 10:11:31.076 info starting. Version 1.8.12 (non-npm: ioBroker/ioBroker.zigbee#a63ee8fce6c013953b33e6d81737aa9815a65683) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-02 10:11:21.514 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zigbee.0 2023-07-02 10:11:21.511 info terminating zigbee.0 2023-07-02 10:11:21.114 info Zigbee: disabling joining new devices. zigbee.0 2023-07-02 10:11:20.989 info cleaned everything up... zigbee.0 2023-07-02 10:11:20.986 info Got terminate signal TERMINATE_YOURSELF zigbee.0 2023-07-02 10:09:18.924 info List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] zigbee.0 2023-07-02 10:05:48.454 warn Device '0x54ef4410000c39c2' announced itself zigbee.0 2023-07-02 10:04:58.623 warn DeviceAvailability:Failed to ping 0xa4c1388c67dcc204 TS011F zigbee.0 2023-07-02 10:04:58.529 warn DeviceAvailability:Failed to ping 0xc4988600000fc1b2 SP 220 zigbee.0 2023-07-02 10:04:57.651 warn DeviceAvailability:Failed to ping 0x18fc26000004a8e1 SP 220 zigbee.0 2023-07-02 10:04:57.630 warn DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F zigbee.0 2023-07-02 10:04:57.148 warn DeviceAvailability:Failed to ping 0xa4c138394267e33d TS011F zigbee.0 2023-07-02 10:04:53.424 warn DeviceAvailability:Failed to ping 0xa4c138f1b70d8be7 TS011F zigbee.0 2023-07-02 10:04:40.087 error DeviceConfigure:Failed to DeviceConfigure.configure 0x00124b00290f0c38 TH01 (TypeError: Cannot read properties of undefined (reading 'error') at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/sonoff.js:171:24) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1)) zigbee.0 2023-07-02 10:04:29.767 info Zigbee started zigbee.0 2023-07-02 10:04:29.765 info 0x00158d000911f1ac (addr 11855): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.764 info 0x00158d00090d8fa4 (addr 48824): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.759 info 0xa4c138f1b70d8be7 (addr 49228): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.755 info 0xa4c1385e4f940aa8 (addr 1047): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.753 info 0x00124b00290fe1f8 (addr 39009): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.751 info 0x00124b00290fe28c (addr 25949): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.749 info 0x00124b00290fd65b (addr 61986): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.748 info 0x00124b00290f8649 (addr 5483): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.746 info 0x00124b00290fda20 (addr 59334): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.744 info 0x00124b00290fd917 (addr 47233): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.742 info 0x00124b00290f0c38 (addr 18417): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.741 info 0x00124b00290f0c60 (addr 38503): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.739 info 0x00124b0029202889 (addr 34778): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.738 info 0x00124b00290fefe9 (addr 46783): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.736 info 0xa4c138394267e33d (addr 250): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.734 info 0xa4c1388c67dcc204 (addr 49199): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.730 info 0x84ba20fffe567412 (addr 26000): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.728 info 0x00158d0008c97feb (addr 44083): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.726 info 0xa4c138e29b759d31 (addr 12252): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:04:29.724 info 0x84ba20fffe56851a (addr 2021): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.721 info 0xa4c1382cc75bfab7 (addr 36665): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) zigbee.0 2023-07-02 10:04:29.719 info 0x84ba20fffe504f79 (addr 32527): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.716 info 0xc4988600000fc1b2 (addr 6351): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.714 info 0x84ba20fffe566f6f (addr 20732): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.710 info 0x54ef4410000c39c2 (addr 12431): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.708 info 0x00158d0008c9c98a (addr 62477): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.707 info 0x84ba20fffe82e9d2 (addr 53011): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.704 info 0x84ba20fffe50527f (addr 12231): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) zigbee.0 2023-07-02 10:04:29.701 info 0x18fc26000004a8e1 (addr 54644): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.699 info 0x00158d0007f80dd4 (addr 40938): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) zigbee.0 2023-07-02 10:04:29.696 info 0xa4c1388ffe36decc (addr 43646): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) zigbee.0 2023-07-02 10:04:29.679 info 0xc4988600000fc431 (addr 25243): SP 220 - Innr Smart plug (Router) zigbee.0 2023-07-02 10:04:29.671 info Configuring 0x00124b00290f0c38 TH01 zigbee.0 2023-07-02 10:04:29.508 info Currently 32 devices are joined: zigbee.0 2023-07-02 10:04:29.484 info --> transmitPower : normal zigbee.0 2023-07-02 10:04:29.458 info Unable to disable LED, unsupported function. zigbee.0 2023-07-02 10:04:29.449 info Coordinator firmware version: {"type":"zStack3x0","meta":"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}} zigbee.0 2023-07-02 10:04:25.774 info Installed Version: iobroker.zigbee@1.8.10 zigbee.0 2023-07-02 10:04:24.567 info Starting Zigbee npm ... zigbee.0 2023-07-02 10:04:24.564 info delete old Backup files. keep only last 10 zigbee.0 2023-07-02 10:04:24.212 info starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 -
@arteck
so siehts nun nach ca. 9h aus:
du bist auf Kanal 11, ist der auch frei? Schau mal in den Settings vom Adapter, da wird der beste ja angezeigt..
Hast ja nur 32 Devices.. die sind gleich wieder angelernt.. -
eigentlich war er das mal. Hatte aber mal mein Mesh WLAN sich optimieren lassen - gut möglich, dass es da herkommt. Habe mal ein paar Messungen durchgeführt (allerdings jetzt halt alle innerhalb der ca. letzten Stunde). Da wäre dann wohl 18 oder 23 der Gewinner (wobei die auch nicht immer 0 waren):
Wie geht man da am Besten vor? Erst alle Geräte löschen, dann Kanal umstellen und neu anlernen. Oder Nicht löschen? Schön wäre wenn die Aliase erhalten blieben
@mp_trixi sagte in ZigBee neue Version 1.8.x:
18 oder 23
mit den 2 bist du ausserhalb des Notmalen Bereicht. du wirst probleme haben mit dem Geräten
nimm 15 oder 25
und stelle das WLAN eher um
hast du dir das issue von mir mal angeschaut?
Wenn du die Hardware brauchst, schreib mir deine Adresse im Chat, kommt dann umgehend per Amazon von mir gesponsort..
Irgendwas muss sich bei den FRIENT Devices im Adapter von Version 1.8.9 auf alle hoeheren geaendert haben.. auch mit der aktuellen von Git reagiert der Melder nicht mehr auf manual start..Kann ja noch auf der 1.8.9 bleiben.. aber irgendwann wird das auch mal doof..
@ilovegym auch nicht wenn du den unter ausschliessen packst ?
@arteck sagte in ZigBee neue Version 1.8.x:
auch dann nicht... auf die neueste wieder geupdated, Device in Ausschliessen hinzugefuegt, Adapter gestoppt, gewartet... Adapter gestartet... gewartet... (bis die Karte sich aufgebaut hat..) dann nochmal getestet.. einmal von der Gui und einmal den Datenpunkt im Object-browser... keine Reaktion.. keine Fehlermeldung.. nix..
Edit doch Error:
2023-07-03 11:36:03.190 - error: zigbee.0 (1196700) uncaught exception: Cannot read properties of null (reading 'toString') 2023-07-03 11:36:03.190 - error: zigbee.0 (1196700) TypeError: Cannot read properties of null (reading 'toString') at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111) at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5) at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43 at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25) at processImmediate (node:internal/timers:478:21) 2023-07-03 11:36:03.191 - error: zigbee.0 (1196700) Cannot read properties of null (reading 'toString') 2023-07-03 11:36:03.217 - info: zigbee.0 (1196700) cleaned everything up... 2023-07-03 11:36:06.614 - error: host.iobrokerS2 Caught by controller[0]: TypeError: Cannot read properties of null (reading 'toString') 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at assertNumber (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:502:111) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at calibrateAndPrecisionRoundOptions (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/utils.ts:90:5) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at Object.convert (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/fromZigbee.js:414:37) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:534:43 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:183:25) 2023-07-03 11:36:06.615 - error: host.iobrokerS2 Caught by controller[0]: at processImmediate (node:internal/timers:478:21) 2023-07-03 11:36:06.616 - error: host.iobrokerS2 instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-07-03 11:36:06.616 - info: host.iobrokerS2 Restart adapter system.adapter.zigbee.0 because enabled -
@arteck Habe gestern ein Update auf 1.8.12 durchgeführt. Das letzte Update stammt von 02.23 ich meine auf 1.8.11.
Soweit alles gut.
Da ich ion diesem Zusammenhang mal wieder meine Tabellen genauer angesehen. Dabei fiel mir auf, das die batteriebetriebenen Zigbee-Geräte scheinbar keinen Stromverbrauch mehr haben??
Laut Zeitstempel werden bei ALLEN meinen batteriebetriebenen Zigbee-Geräte keine Spannung oder Prozentwert mehr angezeigt wird.
Hab ich da irgend eine Info verpasst?
Alle anderen Werte kommen wie gewohnt. Deshalb ist mir das bisher nicht aufgefallen.
Zum Test habe ich mal einen Sensor neu gepairt. Das hat keine Änderung gebracht.Was kann ich tun?
Gruß Reiner
@ilovegym der herdsamn hat da ein problem..
@arteck ah hab mir sowas schon gedacht.. also Issue beim Herdsmann aufmachen.. falls noch keins ist..
nimm 15 oder 25
und stelle das WLAN eher umbin jetzt auf 25 (hab hoffentlich das richtig verstanden, dass man den Kanal wählen soll bei dem der Adapter 0-wenige Prozente anzeigt). Dann wäre bei mir 25 besser als 15. Das WLAN kann ich leider nicht umstellen (das "optimiert" sich selbst).
Ich konnte jetzt aber meine Nous Steckdosen nicht mehr pairen, zumindest nicht funktional. Die gingen vorher mit der 1.8.10 mit allen Einstellungen und Werten (LED, Verbrauch etc.) - denke mal das liegt an der Adapterversion, nicht am neuen Kanal?!? Wie die ausgesehen haben sieht man im Bild oben. Jetzt erkennt er "etwas" und es sieht dann so aus (zur Anschauung habe ich die 04 bisher noch nicht versucht neu zu verbinden):
Im Log sieht das so aus:2023-07-03 16:04:53.714 - [32minfo[39m: zigbee.0 (2565) Starting interview of '0xa4c1388ffe36decc' 2023-07-03 16:04:53.722 - [33mwarn[39m: zigbee.0 (2565) Device '0xa4c1388ffe36decc' announced itself 2023-07-03 16:04:54.177 - [32minfo[39m: zigbee.0 (2565) Successfully interviewed '0xa4c1388ffe36decc', device has successfully been paired 2023-07-03 16:04:54.178 - [32minfo[39m: zigbee.0 (2565) Device '0xa4c1388ffe36decc' is supported, identified as: NOUS Smart plug (with power monitoring) (A1Z) 2023-07-03 16:04:54.183 - [32minfo[39m: zigbee.0 (2565) Configuring 0xa4c1388ffe36decc TS011F 2023-07-03 16:04:54.639 - [31merror[39m: zigbee.0 (2565) Device 0xa4c1388ffe36decc "A1Z" not described in statesMapping. 2023-07-03 16:04:57.191 - [33mwarn[39m: zigbee.0 (2565) Object a4c1388ffe36decc.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:04:57.192 - [33mwarn[39m: zigbee.0 (2565) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:04:57.193 - [33mwarn[39m: zigbee.0 (2565) Object a4c1388ffe36decc.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:04:57.194 - [33mwarn[39m: zigbee.0 (2565) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:04:57.220 - [33mwarn[39m: zigbee.0 (2565) Object zigbee.0.a4c1388ffe36decc.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:04:57.224 - [33mwarn[39m: zigbee.0 (2565) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:04:57.226 - [33mwarn[39m: zigbee.0 (2565) Object zigbee.0.a4c1388ffe36decc.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:04:57.227 - [33mwarn[39m: zigbee.0 (2565) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:05:08.077 - [32minfo[39m: zigbee.0 (2565) DeviceConfigure successful 0xa4c1388ffe36decc TS011F 2023-07-03 16:05:10.220 - [32minfo[39m: zigbee.0 (2565) Zigbee: stop joiningoder
2023-07-03 00:02:52.491 - [32minfo[39m: zigbee.0 (93100) Zigbee: allowing new devices to join. 2023-07-03 00:02:55.755 - [32minfo[39m: zigbee.0 (93100) Starting interview of '0xa4c1388c67dcc204' 2023-07-03 00:02:55.781 - [33mwarn[39m: zigbee.0 (93100) Device '0xa4c1388c67dcc204' announced itself 2023-07-03 00:02:57.594 - [31merror[39m: zigbee.0 (93100) Device 0xa4c1388c67dcc204 "A1Z" not described in statesMapping. 2023-07-03 00:02:57.959 - [33mwarn[39m: zigbee.0 (93100) Object a4c1388c67dcc204.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 00:02:57.960 - [33mwarn[39m: zigbee.0 (93100) This object will not be created in future versions. Please report this to the developer. 2023-07-03 00:02:58.017 - [33mwarn[39m: zigbee.0 (93100) Object a4c1388c67dcc204.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 00:02:58.018 - [33mwarn[39m: zigbee.0 (93100) This object will not be created in future versions. Please report this to the developer. 2023-07-03 00:02:58.027 - [33mwarn[39m: zigbee.0 (93100) Object zigbee.0.a4c1388c67dcc204.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 00:02:58.028 - [33mwarn[39m: zigbee.0 (93100) This object will not be created in future versions. Please report this to the developer. 2023-07-03 00:02:58.037 - [33mwarn[39m: zigbee.0 (93100) Object zigbee.0.a4c1388c67dcc204.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 00:02:58.037 - [33mwarn[39m: zigbee.0 (93100) This object will not be created in future versions. Please report this to the developer. 2023-07-03 00:03:00.724 - [32minfo[39m: zigbee.0 (93100) Successfully interviewed '0xa4c1388c67dcc204', device has successfully been paired 2023-07-03 00:03:00.725 - [32minfo[39m: zigbee.0 (93100) Device '0xa4c1388c67dcc204' is supported, identified as: NOUS Smart plug (with power monitoring) (A1Z) 2023-07-03 00:03:00.728 - [32minfo[39m: zigbee.0 (93100) Configuring 0xa4c1388c67dcc204 TS011F 2023-07-03 00:03:03.636 - [32minfo[39m: zigbee.0 (93100) DeviceConfigure successful 0xa4c1388c67dcc204 TS011F 2023-07-03 00:03:13.400 - [32minfo[39m: zigbee.0 (93100) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] 2023-07-03 00:03:53.757 - [32minfo[39m: zigbee.0 (93100) Zigbee: stop joiningIch hatte noch Tuya Steckdosen da. Mit denen habe ich jetzt erstmal die Nous erstetzt (wobei das schon schön wäre wenn wieder täten
). Bei den Tuya kamen auch Hinweise:2023-07-03 16:41:35.315 - [32minfo[39m: zigbee.0 (3815) Starting interview of '0xa4c138f1b70d8be7' 2023-07-03 16:41:35.450 - [33mwarn[39m: zigbee.0 (3815) Device '0xa4c138f1b70d8be7' announced itself 2023-07-03 16:41:42.201 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:42.214 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:42.361 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:42.376 - [31merror[39m: zigbee.0 (3815) Device 0xa4c138f1b70d8be7 "undefined" not described in statesMapping. 2023-07-03 16:41:42.428 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:42.469 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:43.525 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:43.829 - [33mwarn[39m: zigbee.0 (3815) download icon TS011F_plug_1 for undefined Device not available. Check your devices. 2023-07-03 16:41:49.940 - [32minfo[39m: zigbee.0 (3815) Successfully interviewed '0xa4c138f1b70d8be7', device has successfully been paired 2023-07-03 16:41:49.940 - [32minfo[39m: zigbee.0 (3815) Device '0xa4c138f1b70d8be7' is supported, identified as: TuYa Smart plug (with power monitoring) (TS011F_plug_1) 2023-07-03 16:41:49.942 - [32minfo[39m: zigbee.0 (3815) Configuring 0xa4c138f1b70d8be7 TS011F 2023-07-03 16:41:50.772 - [32minfo[39m: zigbee.0 (3815) DeviceConfigure successful 0xa4c138f1b70d8be7 TS011F 2023-07-03 16:41:52.278 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.279 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.279 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.279 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.293 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.294 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.295 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.295 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.296 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.296 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.296 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.297 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.304 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.304 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.305 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.305 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.306 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.306 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.306 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.307 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.308 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.308 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.308 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.309 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.309 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.310 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.330 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.331 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.339 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.340 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.340 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.340 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.347 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.347 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.348 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.348 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.349 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.350 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.350 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.351 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.352 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.353 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.353 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.354 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.355 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.355 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.356 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.356 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.357 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.357 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.358 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.358 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.359 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.360 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.361 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.361 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.362 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.362 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.363 - [33mwarn[39m: zigbee.0 (3815) Object a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.363 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.364 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.365 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.383 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.384 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.385 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.385 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.386 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.386 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.388 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.388 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.388 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.389 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.390 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.390 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.391 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.391 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.392 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.393 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.393 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.394 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.395 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.395 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.412 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.413 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.414 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.414 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.415 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.416 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.421 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.422 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.440 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.440 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.449 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.450 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.451 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.451 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.452 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.453 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.453 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.454 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.455 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.455 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.456 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.456 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.458 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.458 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.459 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.459 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.488 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.488 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. 2023-07-03 16:41:52.489 - [33mwarn[39m: zigbee.0 (3815) Object zigbee.0.a4c138f1b70d8be7.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" 2023-07-03 16:41:52.489 - [33mwarn[39m: zigbee.0 (3815) This object will not be created in future versions. Please report this to the developer. -
@mp_trixi mit den nuos stimmt was im converter nicht.. ist schon seid paar Tagen.
@arteck
Converter? D.h. da kann ich nichts machen sondern da wird dran gearbeitet?Was sagen mir die Meldungen beim Pairing der Tuya?
das hoffe ich mal...
für den rest brauche ich die shepherd.db von dir
muss mal schauen was der plug da macht.. -
@arteck
Meine Nous Steckdosen werden mit der 1.8.12 auch nicht mehr erkannt (mit der 1.8.10 problemlos). Wenn ich das richtig verstehe nutzt ZigBee 1.8.12 den zigbee-herdsmann-converter 15.33.0 . Im Changelog steht zur 15.33.1 sinngemäß "NOUS" wurde durch "Nous" ersetzt. Ist das ganze case sensitiv und das könnte schon die Lösung des Problems sein, oder ist das nur kosmetischer Natur? -
gibt es eine Möglichkeit hier den "Klarnamen" in der Fehlermeldung auszugeben. Ich weiss nicht welcher Taster gemeint ist.
2023-07-04 06:20:01.866 - error: zigbee.0 (52314) No converter available for 'E1743' with key 'state'Was soll mir diese Meldung, eigentlich sagen?
@bommel_030 auf GIT liegt der adapter mit der 15.34 ..teste mal bitte
wenn nicht dann kannst du mal lokal bei dir unter
/opt/iobroker/node-modules/zigbee-herdsman-converters/devices/nous.js oder .ts
editieren und da alle vendor: 'Nous' auf vendor: 'NOUS' ändern...
danach adapter neu starten -
@tt-tom sagte in ZigBee neue Version 1.8.x:
installier von GIT und schau nochmal
