    4. Test Intext App v0.0.x
      Diamand2k22 @PLCHome 0 last edited by
      @plchome-0
      Ok danke, was mir gleich beim ersten Test aufgefallen ist, wenn ich nur dir IP eingebe und keinen Port und dann speichern schließen mache, geht der Adapter in einen Error Loop.
      2023-06-21 22:51:04.538 - info: host.pi4b stopInstance system.adapter.intex.0 (force=false, process=true)
      2023-06-21 22:51:04.556 - info: intex.0 (223594) Got terminate signal TERMINATE_YOURSELF
      2023-06-21 22:51:04.561 - info: intex.0 (223594) terminating
      2023-06-21 22:51:04.566 - info: intex.0 (223594) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-21 22:51:04.771 - info: host.pi4b stopInstance system.adapter.intex.0 send kill signal
      2023-06-21 22:51:04.924 - info: admin.0 (223324) <== Disconnect system.user.admin from ::ffff:192.168.178.201
      2023-06-21 22:51:05.069 - info: intex.0 (223594) terminating
      2023-06-21 22:51:05.238 - info: host.pi4b instance system.adapter.intex.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-21 22:51:07.978 - info: host.pi4b instance system.adapter.intex.0 started with pid 223731
      2023-06-21 22:51:08.346 - info: javascript.0 (223106) script.js.common.Allgemein.PV.PV-Überschuss-Steuerung: Bezug 2776.4 Leistungsstufe 0
      2023-06-21 22:51:11.272 - info: intex.0 (223731) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.intex) in /opt/iobroker/node_modules/iobroker.intex, node: v18.16.0, js-controller: 5.0.5
      2023-06-21 22:51:11.487 - error: intex.0 (223731) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-06-21 22:51:11.489 - error: intex.0 (223731) unhandled promise rejection: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:11.497 - error: intex.0 (223731) TypeError: The "options.port" property must be one of type number or string. Received null
      at new NodeError (node:internal/errors:399:5)
      at lookupAndConnect (node:net:1224:13)
      at Socket.connect (node:net:1193:5)
      at /opt/iobroker/node_modules/iobroker.intex/main.js:359:20
      at new Promise ()
      at Intex.updateLocalDevice (/opt/iobroker/node_modules/iobroker.intex/main.js:331:16)
      at Intex.onReady (/opt/iobroker/node_modules/iobroker.intex/main.js:97:24)
      2023-06-21 22:51:11.498 - error: intex.0 (223731) Exception-Code: ERR_INVALID_ARG_TYPE: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:11.521 - info: intex.0 (223731) terminating
      2023-06-21 22:51:11.523 - warn: intex.0 (223731) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-06-21 22:51:12.034 - info: intex.0 (223731) terminating
      2023-06-21 22:51:12.172 - warn: intex.0 (223731) get state error: Connection is closed.
      2023-06-21 22:51:12.325 - error: host.pi4b Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: TypeError: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at lookupAndConnect (node:net:1224:13)
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at Socket.connect (node:net:1193:5)
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.intex/main.js:359:20
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at new Promise ()
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at Intex.updateLocalDevice (/opt/iobroker/node_modules/iobroker.intex/main.js:331:16)
      2023-06-21 22:51:12.326 - error: host.pi4b Caught by controller[1]: at Intex.onReady (/opt/iobroker/node_modules/iobroker.intex/main.js:97:24)
      2023-06-21 22:51:12.327 - error: host.pi4b instance system.adapter.intex.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-06-21 22:51:12.327 - info: host.pi4b Restart adapter system.adapter.intex.0 because enabled
      2023-06-21 22:51:38.237 - info: javascript.0 (223106) script.js.common.Allgemein.PV.PV-Überschuss-Steuerung: Bezug 2776.6 Leistungsstufe 0
      2023-06-21 22:51:42.477 - info: host.pi4b instance system.adapter.intex.0 started with pid 223761
      2023-06-21 22:51:45.667 - info: intex.0 (223761) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.intex) in /opt/iobroker/node_modules/iobroker.intex, node: v18.16.0, js-controller: 5.0.5
      2023-06-21 22:51:45.757 - error: intex.0 (223761) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-06-21 22:51:45.758 - error: intex.0 (223761) unhandled promise rejection: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:45.766 - error: intex.0 (223761) TypeError: The "options.port" property must be one of type number or string. Received null
      at new Promise ()
      2023-06-21 22:51:45.766 - error: intex.0 (223761) Exception-Code: ERR_INVALID_ARG_TYPE: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:45.805 - info: intex.0 (223761) terminating
      2023-06-21 22:51:45.808 - warn: intex.0 (223761) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-06-21 22:51:46.312 - info: intex.0 (223761) terminating
      2023-06-21 22:51:47.820 - error: host.pi4b Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-06-21 22:51:47.821 - error: host.pi4b Caught by controller[0]: TypeError: The "options.port" property must be one of type number or string. Received null
      2023-06-21 22:51:47.821 - error: host.pi4b Caught by controller[0]: at new NodeError (node:internal/errors:399:5)
      2023-06-21 22:51:47.821 - error: host.pi4b Caught by controller[0]: at lookupAndConnect (node:net:1224:13)
      2023-06-21 22:51:47.821 - error: host.pi4b Caught by controller[0]: at Socket.connect (node:net:1193:5)
      2023-06-21 22:51:47.821 - error: host.pi4b Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.intex/main.js:359:20
      2023-06-21 22:51:47.822 - error: host.pi4b Caught by controller[0]: at new Promise ()
      2023-06-21 22:51:47.822 - error: host.pi4b Caught by controller[0]: at Intex.updateLocalDevice (/opt/iobroker/node_modules/iobroker.intex/main.js:331:16)
      2023-06-21 22:51:47.822 - error: host.pi4b Caught by controller[0]: at Intex.onReady (/opt/iobroker/node_modules/iobroker.intex/main.js:97:24)
      2023-06-21 22:51:47.822 - error: host.pi4b instance system.adapter.intex.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-06-21 22:51:47.822 - info: host.pi4b Restart adapter system.adapter.intex.0 because enabled
      2023-06-21 22:51:52.914 - info: host.pi4b "system.adapter.intex.0" disabled
      PLCHome 0 1 Reply Last reply Reply Quote 0
      • PLCHome 0
        PLCHome 0 Developer @Diamand2k22 last edited by PLCHome 0
        @diamand2k22 ok mit dem Port kann ich nochmal nacharbeiten. Bei einer neuen Instanz sollte er belegt sein. Funktioniert die Suche nach dem Pool bei dir?
        Ich glaube das muss ich auch noch beschreiben, die Suche geht nur wenn der Adapter läuft. Und ich muss nochmal prüfen ob ich kein Henne Ei Problem bekomme
        Wie gesagt kannst auch die Cloud drin lassen. Der holt nur die Poolinfo und geht dann nach Lokal. Wenn er die Info für den Pool nicht bekommt, funktioniert er trotzdem.
        Die Cloud funktioniert übrigens wieder. Ich hab Intex mal ihr Problem erklärt 👮 und siehe da, seit gestern alle ok…
        D D 2 Replies Last reply Reply Quote 0
          @plchome-0
          Tatsache, die Intex App funktionier wieder 👏
          Wenn ich auf die Lupe klicke, geht aber kein Fenster auf mit Suchergebnnissen,
          Aktuell habe ich über Cloud eingestellt und läuft! 👍
          Muss der Haken hier gesetzt sein?
          • PLCHome 0
            @diamand2k22 Nein, dann geht er zu 100% über die Cloud.
            Wenn aus dann versucht er den Pool online zu finden
              @plchome-0
              Ok aber der Button mit der Lupe funktioniert bei mir nicht. Sonst läuft es erstmal 😉
              • PLCHome 0
                @diamand2k22
                Bitte noch mal testen 🙂
                Ich habe die Endlosschleife beseitigt und die Checkboxen wieder ausgebaut ...
                  @plchome-0
                  Danke für die neue Version 👍
                  hab mir die neue Version gerade aus GitHub installiert, schaut schon besser aus als die vorherige Version, vor allem die Texte sind jetzt verständlicher. ich werde weiter testen und berichten.
                  • PLCHome 0
                    PLCHome 0 Developer last edited by PLCHome 0
                    So der Adapter ist gepostet als 0.1.0 wenn keine negative Meldung kommt, nehme ich ihn nächste Woche nach Stable.
                    Ich betreibe ihn aktuell mit Cloud, nur lokale Kommandos. Funktioniert mit dem Handy schneller als am Paneel wegen dem Entsperren 😉
                    • PLCHome 0
                      PLCHome 0 Developer @PLCHome 0 last edited by
                      Der Adapier ist in Stable.... Lasst mich wissen, wenn es noch Probleme gibt
                        @plchome-0
                        Hallo plchome-0, der Adapter funktioniert bis jetzt einwandfrei.
                        Aktuell scheint die Intex App auf dem Smartphone wieder nicht zu funktionieren, aber der Cloud Mist ist ja jetzt dank lokalem Zugriff Geschichte. 👍 👏
                        • PLCHome 0
                          @diamand2k22
                          Die App ist komisch, ich hatte ein Ticket aufgemacht. Danach ging sie für ein paar Tage. Scheint wohl dort niemand wirklich selber zu benutzen .... Die haben bestimmt etwas besseres Zuhause zu stehen.
                          • Dx3 One
                            Dx3 One last edited by
                            die App nervt wirklich total, ich habe jetzt mal das Zertifikatspinning in der App entfernt um mit zu sniffen, was da eigentlich passiert. Direkt nach dem Login kommen auch erstmal 404 zurück...
                            PLCHome 0 2 Replies Last reply Reply Quote 0
                            • PLCHome 0
                              PLCHome 0 Developer @Dx3 One last edited by
                              @dx3-one
                              Ja liegt an Intex. Die App geht ja auch nicht.
                              Eigentlich sollte der Adapter 0.1.0 keine Fehler mehr melden wenn er den Pool lokal erreichen kann.
                              Wenn nicht musst du sich darum kümmern das die IP Stimmt und der ioBroker ihn im lokalen Netz erreichen kann.
                              • PLCHome 0
                                @dx3-one Hast du die 0.1.0 getestet?
                                • Hobbit
                                  Hobbit last edited by
                                  erstmal vielen Dank für den Adapter, er funktioniert wirklich top. Jetzt mit der Möglichkeit lokal auf den Pool zuzugreifen ist nochmal wesentlich stabiler.
                                  Was ich noch nicht so richtig entdecken konnte, wo kann ich eventuelle Fehlermeldungen vom Pool als Datenpunkt sehen? Mein Pool würde einen Fehler E91 anzeigen wenn der Satzgehalt zu niedrig ist. Dies würde ich gern für ein Script abgreifen um mir zum Beispiel eine Nachricht zu schicken.
                                  Unter dem Ordner "status" gibt es die Datenpunkte value0 - 18, nur leider sagen mir diese nichts über den Inhalt. Enthält einer dieser Datenpunkte ggf. den aktuellen Poolstatus?
                                  • PLCHome 0
                                    PLCHome 0 Developer @Hobbit last edited by PLCHome 0
                                    @hobbit das ist aktuell nicht entschlüsselt. Es wird sich wohl in den Values verstecken. Dafür muss man Tatsächlich den Fehler auslösen und die Values mitschreiben z.B. in einer Datenbank. Mit Einwendung Glück wird es übertragen und man kann es nachvollziehen. Wenn die APP es anzeigt wird es bestimmt übertragen. Wenn du dir das anschauen mochtest nur zu ich kann das dann gerne einbauen wenn da was gefunden wurde. Ein paar Values sind bekannt.
                                    Value 5: Bit 0 bis 5 Status, Bit 6 und 7 unbekannt.
                                    Value 7: Ist Temp
                                    Value 15: Soll Temp
                                    Hobbit 1 Reply Last reply Reply Quote 0
                                    • Hobbit
                                      Hobbit @PLCHome 0 last edited by
                                      @plchome-0 ich schaue mal, wie ich einen Fehler provozieren kann. Im Moment läuft regelmäßig die Desinfizierung. Irgendwann muss der Fehler E91 kommen.
                                      Wenn ich etwas entdecke, werde ich es hier schreiben.
                                        Diamand2k22 @Hobbit last edited by
                                        Weiß jemand zufällig, wenn ich z.B. das Desinfizierungsprogramm per Skript anstarte und den Datenpunkt sanizer auf true stelle, schaltet das Programm dann nach der eingestellten Dauer am Display ab (1,3,5h) oder läuft das so lange, bis ich den Datenpunkte wieder auf false setzte?
                                        Danke und Grüße
                                        • PLCHome 0
                                          @diamand2k22 ich benutze es nicht, aber der Filter läuft solange wie zuletzt eingestellt. Als beim Filter zeigt es das Display auch an.
                                          Ach beim Desinfizieren zeigt das Display auch die Zeit an.
                                          Also JA
                                            @plchome-0
                                            ok hab jetzt mal 3h eingestellt bei dem sanizer Programm, und Filter lass ich immer per schedule skript 3 x a 2 Stunde laufen.
                                            203
                                            31911
