    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @Negalein last edited by
      @negalein sagte in iob diag - Skript:
      Gibt also kein neueres?
      Keine neueres LTS-Release. Das nächste LongTermSupport-Ding kommt im April 2024. Dazwischen sind nur Test-Releases am Start.
        Aber gut, der Code zur Auswertung von
        Recommended versions are nodejs 18.16.1 and npm 9.5.1
        funktioniert also.
        • bahnuhr
          Habe dies gemacht:
          curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
          chmod 744 iob_diag
          ./iob_diag
          Ist dies jetzt was anderes ?
          Skript v.2023-06-21
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-vm
                     Chassis: vm
                  Machine ID: dd59139b4ae040898d227e04f86103f0
                     Boot ID: 83384625b8db43beaf0c2c2962e5a98f
              Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-23-amd64
                Architecture: x86-64
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           21:55:10 up  3:56,  1 user,  load average: 1.39, 1.35, 1.35
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Sun 2023-07-02 21:55:10 CEST
                     Universal time: Sun 2023-07-02 19:55:10 UTC
                           RTC time: Sun 2023-07-02 19:55:11
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          dieter
          /home/dieter
          dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            5.9G        4.7G        379M        0.0K        869M        995M
          Swap:           974M          0B        974M
          Total:          6.9G        4.7G        1.4G
                   5928 M total memory
                   4680 M used memory
                    377 M active memory
                   4841 M inactive memory
                    378 M free memory
                    110 M buffer memory
                    758 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          Filesystem                Type      Size  Used Avail Use% Mounted on
          udev                      devtmpfs  2.9G     0  2.9G   0% /dev
          tmpfs                     tmpfs     593M  516K  593M   1% /run
          /dev/sda1                 ext4       31G  7.2G   22G  25% /
          tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
          tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
          //192.168.243.100/1_Sound cifs      238G  120G  118G  51% /mnt
          tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
          [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems (real ones only):
          TARGET SOURCE                    FSTYPE OPTIONS
          /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
          `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bs
          /var:
          869M    /var/
          371M    /var/cache
          364M    /var/cache/apt
          330M    /var/log
          313M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
          Archived and active journals take up 56.0M in the file system.
          /opt/iobroker/backups:
          380M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          625M    /opt/iobroker/iobroker-data/files
          298M    /opt/iobroker/iobroker-data/files/vis.0
          248M    /opt/iobroker/iobroker-data/files/vis.0/wav
          235M    /opt/iobroker/iobroker-data/sqlite
          235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
          154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
          40M     /opt/iobroker/iobroker-data/objects.jsonl
          34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
          32M     /opt/iobroker/iobroker-data/states.jsonl
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.16.1
          /usr/bin/node           v18.16.1
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 0.0.0.0
          States:                     jsonl on 0.0.0.0
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     7.0.3
          Adapters from github:   12
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
            system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
          + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
          + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
          + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
            system.adapter.openligadb.0             : openligadb            : iobroker                                 - disabled
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
          + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
          + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
          + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
          + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "bmw"          : 2.5.7    , installed 2.6.0
          Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "doorio"       : 2.1.4    , installed 2.1.4
          Adapter    "dwd"          : 2.8.3    , installed 2.8.5
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
          Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "libre"        : 0.0.4    , installed 0.0.5
          Adapter    "linux-control": 1.1.3    , installed 1.1.3
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "musiccast"    : 1.1.0    , installed 1.1.2
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
          Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
          Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 4.2.0    , installed 6.3.5
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "telegram"     : 1.15.6   , installed 1.15.6
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "viessmann"    : 1.4.4    , installed 1.4.4
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 4.3.0    , installed 6.0.1
          Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
          Adapter    "ws"           : 1.3.0    , installed 2.3.6
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Objects and States
          Objects:        23378
          States:         19280
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
          Reading package lists... Done
          Pending Updates: 3
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1429       428/sshd: /usr/sbin
          tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       14772      735/io.hm-rpc.2
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       16724      830/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       15047      841/io.mqtt.2
          tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       10228      716/io.hm-rpc.1
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14146      409/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       14139      409/iobroker.js-con
          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        1454       406/asterisk
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11187      1/init
          tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       10230      709/io.hm-rpc.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22650      1327/io.ws.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1431       428/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22598      1241/io.simple-api.
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1147       1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14204      563/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20758      1321/io.web.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13155      359/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12243      1/init
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       20474      1214/io.musiccast.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1891       796/io.mihome-vacuu
          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        1467       406/asterisk
          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        1468       406/asterisk
          udp        0      0 0.0.0.0:37967           0.0.0.0:*                           108        14127      406/asterisk
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15848      890/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15849      890/io.tuya.0
          udp6       0      0 :::53083                :::*                                108        14128      406/asterisk
          udp6       0      0 :::111                  :::*                                0          9730       1/init
          2023-07-02 21:53:34.067  - info: octoprint.0 (1220) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
          2023-07-02 21:53:49.579  - info: javascript.0 (601) script.js.Scripte.Licht.Bad_EG: Licht Bad EG ausgeschaltet.
          2023-07-02 21:54:00.102  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13298, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:54:00", "unix": 1688334840}, "successful": true}
          2023-07-02 21:54:00.416  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
          2023-07-02 21:54:18.279  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
          2023-07-02 21:54:50.767  - info: javascript.0 (601) script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG ausgeschaltet.
          2023-07-02 21:54:56.031  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
          2023-07-02 21:54:56.070  - info: javascript.0 (601) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
          2023-07-02 21:55:00.113  - info: javascript.0 (601) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
          2023-07-02 21:55:00.295  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
          2023-07-02 21:55:00.299  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 86 %.
          2023-07-02 21:55:00.331  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 70 %.
          2023-07-02 21:55:00.347  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12556
          2023-07-02 21:55:00.368  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
          2023-07-02 21:55:00.461  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 52 %.
          2023-07-02 21:55:00.487  - info: javascript.0 (601) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
          2023-07-02 21:55:01.018  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
          2023-07-02 21:55:06.507  - info: dwd.0 (12556) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
          2023-07-02 21:55:11.266  - info: dwd.0 (12556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-07-02 21:55:11.803  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-07-02 21:55:33.536  - info: javascript.0 (601) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
          2023-07-02 21:56:00.099  - info: javascript.0 (601) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 13418, "mode": 0, "battery": 100, "hours": 968}, "timer": {"status": 2, "next": {"date": "2023-07-04", "time": "10:00:00", "unix": 1688464800}}, "blades": {"quality": 38, "hours": 186, "days": 96}, "wlan": {"signal": -77}, "health": {"temperature": 31, "humidity": 23}, "clock": {"date": "2023-07-02", "time": "21:56:00", "unix": 1688334960}, "successful": true}
          2023-07-02 21:56:20.832  - info: javascript.0 (601) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
          2023-07-02 21:56:23.013  - info: javascript.0 (601) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 296° / Sonne: Elevation: -25.6° / Mond: Azimut: 124° / Mond: Elevation: 32.7°
          2023-07-02 21:56:40.642  - info: javascript.0 (601) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
          iob diag has finished.
          Press any key for a summary
                               v.2023-06-21
                     Chassis: vm
              Virtualization: kvm
          Installation:           kvm
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     3
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          Recommended versions are nodejs 16.20.1 and npm 8.19.4
          MEMORY:
          Mem:            5.9G        4.5G        574M        0.0K        832M        1.2G
          Swap:           974M        0.0K        974M
          Total:          6.9G        4.5G        1.5G
          Active iob-Instances:   52
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                23378
          States:                 19280
          Size of iob-Database:
          36M     /opt/iobroker/iobroker-data/states.jsonl
            Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
            @bahnuhr sagte in iob diag - Skript:
            Ja, das ist Skript v.2023-06-21.
            Danke dir.
            Mist...
            Da sollte natürlich 18 und 9 erscheinen...
            • bahnuhr
              bahnuhr Forum Testing Most Active @Thomas Braun last edited by
              dort steht: Multihost discovery server: disabled
              Ist das richtig ?
              habe multihost
                Ist das richtig ?
                Ja, das ist richtig.
                Ich hab noch keinen Weg gefunden, den Status sicher festzunageln.
                • bahnuhr
                  Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
                  Wollten wir irgendwann nochmal thematisieren.
                  Muss ich da nochmal ran?
                  • uweklatt
                    uweklatt last edited by uweklatt
                    ich nutze hier Docker innerhalb LXC auf Proxmox.
                    Das Script liefert hier folgende Ausgaben:
                    *** iob diag is starting up, please wait ***
                    *** ioBroker Diagnosis ***
                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                    https://forum.iobroker.net
                    Just copy and paste the Summary Page, including the  characters at start and end.
                    It helps us to help you!
                    Press any key to continue
                    Skript v.2023-06-21
                    *** BASE SYSTEM ***
                    Hardware Vendor : LENOVO
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Virtualization  : Docker
                    Kernel          : x86_64
                    Userland        : amd64
                     18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
                    CPU threads: 4
                    Mon Jul  3 16:58:39 UTC 2023
                    Mon Jul  3 18:58:39 CEST 2023
                    CEST +0200
                    Etc/UTC
                    root
                    /root
                    root
                    X-Server: 	false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
                    Swap:           7.8G         21M        7.8G
                    Total:           15G        3.3G        8.6G
                             7824 M total memory
                             3242 M used memory
                             1453 M active memory
                             5083 M inactive memory
                              764 M free memory
                              661 M buffer memory
                             3156 M swap cache
                             7835 M total swap
                               21 M used swap
                             7814 M free swap
                    *** FILESYSTEM ***
                    overlay                          overlay   61G  9.0G   49G  16% /
                    tmpfs                            tmpfs     64M     0   64M   0% /dev
                    shm                              tmpfs     64M     0   64M   0% /dev/shm
                    /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
                    tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
                    [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                    [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                    [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
                    [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
                    [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
                    /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
                    /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
                    /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
                    /var:
                    33M	/var/
                    31M	/var/lib
                    18M	/var/lib/apt/lists
                    18M	/var/lib/apt
                    13M	/var/lib/dpkg
                    5.5M	/opt/iobroker/backups/
                    196M	/opt/iobroker/iobroker-data/
                    104M	/opt/iobroker/iobroker-data/files
                    63M	/opt/iobroker/iobroker-data/backup-objects
                    52M	/opt/iobroker/iobroker-data/files/javascript.admin
                    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                    23M	/opt/iobroker/iobroker-data/objects.jsonl
                    7.2M	/opt/iobroker/iobroker-data/states.jsonl
                    6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
                    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                    5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
                    /usr/bin/npm 		9.5.1
                    /usr/bin/npx 		9.5.1
                    nodejs:
                      Version table:
                            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                    jsonl on 127.0.0.1
                    States:                     jsonl on 127.0.0.1
                    admin: 		6.3.5
                    javascript: 	7.0.3
                    Adapter State
                    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                    + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
                      system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
                    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                      system.adapter.info.0                   : info                  : iobroker                                 - disabled
                      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
                    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                      system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                    + instance is alive
                    stable        : http://iobroker.live/repo/sources-dist.json
                    beta          : http://iobroker.live/repo/sources-dist-latest.json
                    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                    Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                    Adapter    "info"         : 1.9.26   , installed 1.9.26
                    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
                    Objects and States
                    Objects: 	3398
                    States: 	3035
                    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
                    tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
                    tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
                    tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
                    udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
                    Copy text starting here:
                    		     v.2023-06-21
                    model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Installation: 		Docker
                    Kernel: 		x86_64
                    Userland: 		amd64
                    Timezone: 		Etc/UTC
                    User-ID: 		0
                    X-Server: 		false
                    Pending OS-Updates: 	0
                    			/usr/bin/npm 		9.5.1
                    			/usr/bin/npx 		9.5.1
                    MEMORY:
                    Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
                    Swap:           7.8G         21M        7.8G
                    Active iob-Instances: 	14
                    			admin 			6.3.5
                    ioBroker Status: 	iobroker is running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		3398
                    States: 		3035
                    === Mark text until here for copying ===
                    Tschau
                    Uwe
                    DJMarc75 Meister Mopper 2 Replies Last reply Reply Quote 0
                    • DJMarc75
                      DJMarc75 @uweklatt last edited by
                      @uweklatt sagte in iob diag - Skript:
                      Tschau
                      und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
                        Thomas Braun Most Active @DJMarc75 last edited by
                        @djmarc75 sagte in iob diag - Skript:
                        Keine Frage, das war nur ein Test der Beta-Version des Skripts.
                        @uweklatt Danke schön!
                        DJMarc75 B 2 Replies Last reply Reply Quote 0
                        • DJMarc75
                          DJMarc75 @Thomas Braun last edited by DJMarc75
                          @thomas-braun sagte in iob diag - Skript:
                          Dann entschuldige ich mich natürlich ! ... bei @uweklatt
                          uweklatt 1 Reply Last reply Reply Quote 0
                          • uweklatt
                            uweklatt @DJMarc75 last edited by
                            @djmarc75 🍻
                            • Meister Mopper
                              Meister Mopper @uweklatt last edited by
                              Warum wird das noch immer gemacht, wo doch selbst Proxmox aus Sicherheitsgründen eine docker Umgebung in einer VM empfiehlt.
                              Ja, es läuft auch im LXC, aber 🤷‍♂️ 😬
                              • uweklatt
                                uweklatt @Meister Mopper last edited by
                                @meister-mopper
                                ...weil es resourcensparender ist.
                                Tschau
                                Uwe
                                  bommel_030 @Thomas Braun last edited by
                                  Neben vielen anderen hübschen Dingen erfährt man ja auch
                                  Adapters from github:   8
                                  Kannst du in deinem Skript auch einbauen, dass die betroffenen Adapter namentlich erwähnt werden? Oder hast du nen Hinweis wo ich das rausfinde?
                                    Thomas Braun Most Active @bommel_030 last edited by
                                    @bommel_030 sagte in iob diag - Skript:
                                    Könnte ich. Hab ich aber bewusst nicht, damit die Liste nicht so lang wird.
                                    cd /opt/iobroker && npm ls | grep github
                                    schmeißt dir die raus.
                                      Stmiko last edited by
                                      cooles script, aber:
                                      Wenn ich 'iob diag' eingebe passiert nichts. Muss ich das script händisch nachinstallieren?
                                      Der installation_fixer hats auch nicht geheilt?
                                      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh funktioniert 🙂
                                      Lg
                                        Thomas Braun Most Active @Stmiko last edited by
                                        @stmiko
                                        In welcher Umgebung rufst du das auf?
                                        Kannst ja den Output aus dem manuellen Aufruf verwenden...
                                          Stmiko @Thomas Braun last edited by
                                          @thomas-braun Ist ein Proxmox LXC mit Debian:
                                                               v.2023-04-16
                                          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                          Kernel:                 6.2.16-4-pve
                                          Installation:           lxc
                                          Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                                          Timezone:
                                          User-ID:                0
                                          X-Server:               false
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
                                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                                          MEMORY:
                                          Mem:            8.2G        2.8G        2.6G        0.0K        2.8G        5.4G
                                          Swap:             0B          0B          0B
                                          Total:          8.2G        2.8G        2.6G
                                          Active iob-Instances:   28
                                          Active repo(s): beta
                                          ioBroker Core:          js-controller           5.0.8
        admin                   6.6.0
                                          Objects type: jsonl
                                          States  type: jsonl
                                          + system.adapter.admin.0                  : admin                 : LXC-Debian10                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : LXC-Debian10                             -  enabled
                                          + system.adapter.web.0                    : web                   : LXC-Debian10                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          Objects:                36921
                                          States:                 27584
                                          30M     /opt/iobroker/iobroker-data/objects.jsonl
                                          18M     /opt/iobroker/iobroker-data/objects.json.migrated
                                          18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          8.0M    /opt/iobroker/iobroker-data/states.jsonl
                                          3.7M    /opt/iobroker/iobroker-data/states.json.migrated
                                          3.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                            @stmiko sagte in iob diag - Skript:
                                            Und root shell. Lass den Mist bleiben.
                                            738
                                            154296
