    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      GerdSo @Wolfgang Gary last edited by
      @wolfgang-gary dito bei mir. Keine Verbindung zu Kia seit 29.06 um 3:45h
        die appid hat sich geändert und bluelinky ist noch nicht aktualisiert..
        der PR ist gestellt .. mal schauen wie lange der braucht
        Wolfgang Gary A 2 Replies Last reply Reply Quote 2
        • Wolfgang Gary
          Wolfgang Gary @arteck last edited by
          @arteck said in Adapter Hyundai (Bluelink) oder KIA (UVO):
          👍 danke für dein Engagement!
            A Former User @Newan last edited by A Former User
            @newan @arteck
            seit heute morgen wieder der hier, kann man das nicht schoener abfangen?
            System: Debian Bookworm, Node 18.16.1., NPM 9.5.1, js-controller 5.0.6, Bluelink von Git V2.3.2
            2023-07-03 08:22:00.220  - info: host.iobrokerS2 "system.adapter.bluelink.0" enabled
            2023-07-03 08:22:00.297  - info: host.iobrokerS2 instance system.adapter.bluelink.0 started with pid 969636
            2023-07-03 08:22:03.523  - info: bluelink.0 (969636) starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.1, js-controller: 5.0.6
            2023-07-03 08:22:03.563  - info: bluelink.0 (969636) Login to api
            2023-07-03 08:22:07.794  - info: influxdb.0 (959597) Store 5745 buffered influxDB history points
            2023-07-03 08:22:07.922  - info: bluelink.0 (969636) 1 Vehicles found
            2023-07-03 08:22:07.929  - info: bluelink.0 (969636) Read new update for KMHxxxxxxx from the server
            2023-07-03 08:22:08.503  - info: bluelink.0 (969636) Update for KMHxxxxxx successfull
            2023-07-03 08:22:08.768  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.768  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.770  - error: bluelink.0 (969636) Error: undefined is not a valid state value
                at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
                at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5388:49)
                at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5349:21)
                at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:121:34)
                at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:92:21)
                at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:253:17)
                at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:90:21)
                at async Bluelink.driveHistory (/opt/iobroker/node_modules/iobroker.bluelink/main.js:406:17)
                at async Oe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:237:29)
            2023-07-03 08:22:08.770  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.773  - info: bluelink.0 (969636) Adapter bluelink cleaned up everything...
            2023-07-03 08:22:08.774  - info: bluelink.0 (969636) terminating
            2023-07-03 08:22:08.774  - warn: bluelink.0 (969636) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-07-03 08:22:08.776  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.777  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.777  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.777  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.782  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.782  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.783  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.783  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.787  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.788  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.789  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.789  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.792  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.793  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.793  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.793  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.799  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.800  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.800  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.801  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:08.805  - error: bluelink.0 (969636) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-07-03 08:22:08.805  - error: bluelink.0 (969636) unhandled promise rejection: undefined is not a valid state value
            2023-07-03 08:22:08.806  - error: bluelink.0 (969636) Error: undefined is not a valid state value
            2023-07-03 08:22:08.806  - error: bluelink.0 (969636) undefined is not a valid state value
            2023-07-03 08:22:09.276  - info: bluelink.0 (969636) terminating
            2023-07-03 08:22:09.341  - error: host.iobrokerS2 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-07-03 08:22:09.342  - info: host.iobrokerS2 Restart adapter system.adapter.bluelink.0 because enabled
              arteck Developer Most Active @Guest last edited by
              @ilovegym abgefangen ist es ...
              kein plan was da hackt..
              installier nochmal von GIT
                A Former User @arteck last edited by
                @arteck gemacht... kommt beim abrufen vom Fahrverlauf und Tripinfo ein Phone-Registration error.. also Serverproblem, nehm ich an.. ?
                Hab den Haken bei Fahrverlauf und Tripinfo raus, jetzt laeuft der Adapter und holt daten.. .. die Tripinfos brauch ich jetzt grad nich..
                  Aiouh @arteck last edited by
                  Hallo @arteck, es sieht so aus als ob das Problem in bluelinky gefixt wäre
                  ... denkt der Laie in der Hoffnung die Experten können damit "unser Problem" auch lösen.
                  Und egal wie lange es dauert, vielen Dank für Eure Arbeit mit dem Adapter.
                  https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/issues/348#issuecomment-1618739517
                  zulufoxtrot created this issue in Hyundai-Kia-Connect/hyundai_kia_connect_api
                  closed [EU] Login fails: "Invalid request body - Invalid parameter." #348
                    installiert mal von GIT
                    nik82 A G 3 Replies Last reply Reply Quote 1
                    • nik82
                      nik82 Most Active @arteck last edited by
                      @arteck
                      Du bist der beste 🙂 Funktioniert wieder!!! 👍
                      Vielen, vielen Dank...
                      P.S. Vielleicht funktioniert ja jetzt auch der Klimastart bei mir, bekomme Fahrzeug erst wieder in ein paar Tagen, dann werde ich testen.
                        Aiouh @arteck last edited by Aiouh
                        @arteck Login Funktioniert wieder ! Danke.👍
                        Allerdings bekomme ich jetzt beim Start Fehlermeldungen:
                        bluelink.0 2023-07-04 12:09:20.963	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance"
                        bluelink.0 2023-07-04 12:09:20.954	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen"
                        bluelink.0 2023-07-04 12:09:20.946	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery"
                        bluelink.0 2023-07-04 12:09:20.938	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices"
                        bluelink.0 2023-07-04 12:09:20.921	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate"
                        bluelink.0 2023-07-04 12:09:20.892	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine"
                        bluelink.0 2023-07-04 12:09:20.880	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total"
                        bluelink.0 2023-07-04 12:09:19.303	info	Update for KNAxxxxxxxxxxxxxxx successfull
                        bluelink.0 2023-07-04 12:09:05.008	info	Read new update for KNAxxxxxxxxxxxxxxx directly from the car
                        bluelink.0 2023-07-04 12:09:04.928	info	1 Vehicles found
                        bluelink.0 2023-07-04 12:09:01.221	info	Login to api
                          arteck Developer Most Active @Aiouh last edited by
                          @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                          wo ..ich seh da keine.. nur info
                            A Former User last edited by
                            @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            ja nur info, hier auch, aber bei JEDEM start.. das ist irritierend.. 🙂
                            Hab auch schon genau die Datenpunkte geloescht und Adapter neu gestartet...
                              @ilovegym guckmal jetzt
                                @arteck
                                Immer noch….
                                  @arteck sorry, ja sind nur Infos. Ich stell einfach mal den loglevel um, ist als workaround für mich absolut OK.
                                    GerdSo @arteck last edited by
                                    @arteck Bei mir kann er sich zwar einloggen, danach stürzt er aber ab. Aktuelle Version von git und Objekte gelöscht
                                    bluelink.0 2023-07-04 14:51:33.380	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    bluelink.0 2023-07-04 14:51:33.380	info	terminating
                                    bluelink.0 2023-07-04 14:51:33.379	info	Adapter bluelink cleaned up everything...
                                    bluelink.0 2023-07-04 14:51:33.377	error	Cannot read properties of null (reading 'val')
                                    bluelink.0 2023-07-04 14:51:33.377	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:290:61) at async Te.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:211:17)
                                    bluelink.0 2023-07-04 14:51:33.376	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
                                    bluelink.0 2023-07-04 14:51:33.376	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    bluelink.0 2023-07-04 14:51:33.372	debug	Read new status from api for xxxxx
                                    bluelink.0 2023-07-04 14:51:33.369	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro","regDate":"2023-01-18 13:33:04.996","brandIndicator":"H","id":"3e953589-376b-43a5-8bb4-bd47cae87ef0","vin": --snip-- "_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
                                    bluelink.0 2023-07-04 14:51:33.369	info	1 Vehicles found
                                    bluelink.0 2023-07-04 14:51:31.518	info	Login to api
                                    bluelink.0 2023-07-04 14:51:31.496	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#54a2a58f9f1bd540237a380c9ea08ce2d8657ea3) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                                    nik82 1 Reply Last reply Reply Quote 0
                                    • nik82
                                      nik82 Most Active @GerdSo last edited by
                                      @gerdso
                                      Als ich deinen Post jetzt gelesen habe, habe ich auch mal den Adapter gestoppt und alle Objekte gelöscht, da ja die Klima jetzt in einem anderen Ordner ist.
                                      Habe dann wieder gestartet und jetzt habe ich das gleiche Problem wie du und den gleichen Fehler im Log.
                                      • Meister Mopper
                                        Meister Mopper last edited by Meister Mopper
                                        @arteck
                                        Ich bekomme den von github nicht installiert. Es kommt der bekannte 'error 25' bei der Installation.
                                        edit:
                                        Ich Depp hatte den falschen von github geladen 🤦‍♂️
                                        Läuft jetzt, vielen Dank!
                                          stefan.cloer last edited by
                                          Ich habe den gleichen Fehler wie @GerdSo. Auch ich habe vor der Installation alle Objekte gelöscht.
                                            jetzt nochmal von GIT
                                            G nik82 2 Replies Last reply Reply Quote 1
                                            1.2k
                                            81.1k
                                            2277
                                            851760
