    4. ZigBee neue Version 1.8.x
      arteck Developer Most Active @TT-Tom last edited by
      @tt-tom sagte in ZigBee neue Version 1.8.x:
      2023-07-04 06:20:01.866 - error: zigbee.0 (52314) No converter available for 'E1743' with key 'state'
      installier von GIT und schau nochmal
        bommel_030 @arteck last edited by
        @arteck
        Danke für den Versuch, daran lag es scheinbar nicht.
        2023-07-04 10:19:26.273  - error: zigbee.0 (31817) Device 0xa4c138db19fc6f09 "A1Z" not described in statesMapping.
        2023-07-04 10:19:26.286  - warn: zigbee.0 (31817) setObject info.debugmessages (type=state) property common.role missing!
        2023-07-04 10:19:26.513  - error: zigbee.0 (31817) Device 0xa4c138b625d22abb "A1Z" not described in statesMapping.
        2023-07-04 10:19:26.515  - error: zigbee.0 (31817) Device 0xa4c13893b02d38f0 "A1Z" not described in statesMapping.
        2023-07-04 10:19:26.520  - error: zigbee.0 (31817) Device 0xa4c138415565ab2d "A1Z" not described in statesMapping.
        2023-07-04 10:19:26.522  - error: zigbee.0 (31817) Device 0xa4c138e4b34d3f41 "A1Z" not described in statesMapping.
        2023-07-04 10:19:27.197  - error: zigbee.0 (31817) Device 0xa4c138499560c8ed "A1Z" not described in statesMapping.
        2023-07-04 10:19:27.199  - error: zigbee.0 (31817) Device 0xa4c138d8dee0f468 "A1Z" not described in statesMapping.
        2023-07-04 10:19:29.133  - warn: zigbee.0 (31817) Object cc86ecfffefa74ac.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.133  - warn: zigbee.0 (31817) This object will not be created in future versions. Please report this to the developer.
        2023-07-04 10:19:29.135  - warn: zigbee.0 (31817) Object b4e3f9fffeb6143a.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.135  - warn: zigbee.0 (31817) This object will not be created in future versions. Please report this to the developer.
        2023-07-04 10:19:29.135  - warn: zigbee.0 (31817) Object cc86ecfffef66b5b.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.136  - warn: zigbee.0 (31817) This object will not be created in future versions. Please report this to the developer.
        2023-07-04 10:19:29.142  - warn: zigbee.0 (31817) Object b4e3f9fffebc1fd5.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.142  - warn: zigbee.0 (31817) This object will not be created in future versions. Please report this to the developer.
        2023-07-04 10:19:29.142  - warn: zigbee.0 (31817) Object 0c4314fffe51aafe.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.143  - warn: zigbee.0 (31817) Object b4e3f9fffe74f3b3.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2023-07-04 10:19:29.143  - warn: zigbee.0 (31817) This object will not be created in future versions. Please report this to the developer.
        2023-07-04 10:19:29.220  - warn: zigbee.0 (31817) State "zigbee.0.a4c138db19fc6f09.available" has no existing object, this might lead to an error in future versions
        2023-07-04 10:19:29.220  - warn: zigbee.0 (31817) State "zigbee.0.a4c138db19fc6f09.link_quality" has no existing object, this might lead to an error in future versions
        Jeder Versuch zu schalten wir hiermit quittiert:
        2023-07-04 10:27:13.371  - error: zigbee.0 (31944) No state available for 'A1Z' with key 'state'
        Komischerweise wird bei allen die Verbindungsstärke aktualisiert. Bei einem sind dafür alle Punkte auf der Kachel verschwunden.
          arteck Developer Most Active @bommel_030 last edited by arteck
          @bommel_030 dreh die kachel mal und poste die Infos
          oder noch besser
          poste mir die shepherd.db
            bommel_030 @arteck last edited by bommel_030
            @arteck
            Mit der 1.8.10 Herdsmann 15.0.15 werden sie als diese Steckdosen erkannt.
            https://www.zigbee2mqtt.io/devices/TS011F_plug_1.html
            Mit der 1.8.12 Herdsmann 15.33.0 bzw. 15.34.0 als
            https://www.zigbee2mqtt.io/devices/A1Z.html
            Vom Bild her ist das letztere eigentlich richtiger.
            shepherd.db
              @bommel_030 das info brauch ich auch
                @arteck
                Sorry, vorhin vergessen anzuhängen.
                Zigbee 1.8.10
                Zigbee 1.8.12
                  TT-Tom @arteck last edited by TT-Tom
                  @arteck
                  bin seit Sonntag schon auf 1.8.12
                  so oder benutzdefiniert
                    bommel_030 @TT-Tom last edited by bommel_030
                    @tt-tom
                    Ja, über die Katze. Versionsnummer wird sich nicht ändern, aber der Inhalt.
                    In
                    /opt/iobroker/node_modules/zigbee-herdsman-converters/package.json
                    sollte dann 15.34.0 als Version stehen.
                      TT-Tom @bommel_030 last edited by
                      @bommel_030
                      okay, ist durch gelaufen, Version ist 15.34.0, kleiner Dreher bei dir bestimmt.
                      @arteck
                      werde das log beobachten, danke erst mal.
                        @tt-tom
                        War nur nen Test ob du aufpasst 😉 Habs oben korrigiert.
                          MP_Trixi @arteck last edited by MP_Trixi
                          @arteck sagte in ZigBee neue Version 1.8.x:
                          für den rest brauche ich die shepherd.db von dir
                          Hier das File
                          shepherd.db
                          Und noch die Device Info falls hilfreich:
                            @arteck
                            Guten Morgen,
                            an der Namensauflösung hat sich nichts geändert. Die Meldung hat immer noch das selbe Format.
                              für NOUS
                              https://forum.iobroker.net/topic/66714/zigbee-steckdose-nous-a1z-testen
                                @tt-tom was machst du dass die Meldung kommt ?? du versuchts wohl nicht den state manuell zu ändern oder ?
                                  @arteck
                                  oh, da muss ich mal genauer hinschauen. Taster und Led-Leiste sind über ein Blockly verbunden, damit ich es in HomeKit einbinden kann. Ich sehe mir das morgen nochmal in Ruhe, da habe ich mehr Zeit.
                                    @arteck
                                    Problem erkannt: ich schreibe wirklich in den State vom Taster. muss mal prüfen, ob ich eine andere Lösung finde.
                                      arteck Developer Most Active @MP_Trixi last edited by
                                      @mp_trixi installier mal GIT und schau nochmal
                                        @arteck
                                        hab wie im neuen Nous Post per Github installiert und dann die tuya.js ausgetauscht.
                                        Ein Pairing einer bereits verbunden Tuya erzeugt nun im Log nur:
                                        zigbee.0 2023-07-07 10:24:06.578	info	Zigbee: stop joining
                                        zigbee.0 2023-07-07 10:23:45.337	warn	Device '0xa4c1380afb5051e2' announced itself
                                        zigbee.0 2023-07-07 10:23:05.346	info	Zigbee: allowing new devices to join.
                                          @mp_trixi du brauchst nix tauschen... die version auf GIT ist schon so dass der A1Z läuft
                                            @arteck
                                            ok, da ich mir nicht sicher war, hatte ich die Datei nur umbenannt und nicht gelöscht/überschrieben. Hab die Instanz gestoppt, das File das per Katze kam wieder als tuya.js rein und neu gestartet. Jetzt sind auch die richtigen Bilder 🙂
                                            81.1k
                                            385
                                            85180
