    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • nik82
      nik82 Most Active @arteck last edited by
      @arteck
      Du bist der beste 🙂 Funktioniert wieder!!! 👍
      Vielen, vielen Dank...
      P.S. Vielleicht funktioniert ja jetzt auch der Klimastart bei mir, bekomme Fahrzeug erst wieder in ein paar Tagen, dann werde ich testen.
        Aiouh @arteck last edited by Aiouh
        @arteck Login Funktioniert wieder ! Danke.👍
        Allerdings bekomme ich jetzt beim Start Fehlermeldungen:
        bluelink.0 2023-07-04 12:09:20.963	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance"
        bluelink.0 2023-07-04 12:09:20.954	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen"
        bluelink.0 2023-07-04 12:09:20.946	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery"
        bluelink.0 2023-07-04 12:09:20.938	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices"
        bluelink.0 2023-07-04 12:09:20.921	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate"
        bluelink.0 2023-07-04 12:09:20.892	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine"
        bluelink.0 2023-07-04 12:09:20.880	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total"
        bluelink.0 2023-07-04 12:09:19.303	info	Update for KNAxxxxxxxxxxxxxxx successfull
        bluelink.0 2023-07-04 12:09:05.008	info	Read new update for KNAxxxxxxxxxxxxxxx directly from the car
        bluelink.0 2023-07-04 12:09:04.928	info	1 Vehicles found
        bluelink.0 2023-07-04 12:09:01.221	info	Login to api
          arteck Developer Most Active @Aiouh last edited by
          @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          wo ..ich seh da keine.. nur info
            A Former User last edited by
            @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
            ja nur info, hier auch, aber bei JEDEM start.. das ist irritierend.. 🙂
            Hab auch schon genau die Datenpunkte geloescht und Adapter neu gestartet...
              arteck Developer Most Active @Guest last edited by
              @ilovegym guckmal jetzt
                A Former User @arteck last edited by
                @arteck
                Immer noch….
                  @arteck sorry, ja sind nur Infos. Ich stell einfach mal den loglevel um, ist als workaround für mich absolut OK.
                    GerdSo @arteck last edited by
                    @arteck Bei mir kann er sich zwar einloggen, danach stürzt er aber ab. Aktuelle Version von git und Objekte gelöscht
                    bluelink.0 2023-07-04 14:51:33.380	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    bluelink.0 2023-07-04 14:51:33.380	info	terminating
                    bluelink.0 2023-07-04 14:51:33.379	info	Adapter bluelink cleaned up everything...
                    bluelink.0 2023-07-04 14:51:33.377	error	Cannot read properties of null (reading 'val')
                    bluelink.0 2023-07-04 14:51:33.377	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:290:61) at async Te.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:211:17)
                    bluelink.0 2023-07-04 14:51:33.376	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
                    bluelink.0 2023-07-04 14:51:33.376	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    bluelink.0 2023-07-04 14:51:33.372	debug	Read new status from api for xxxxx
                    bluelink.0 2023-07-04 14:51:33.369	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro","regDate":"2023-01-18 13:33:04.996","brandIndicator":"H","id":"3e953589-376b-43a5-8bb4-bd47cae87ef0","vin": --snip-- "_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
                    bluelink.0 2023-07-04 14:51:33.369	info	1 Vehicles found
                    bluelink.0 2023-07-04 14:51:31.518	info	Login to api
                    bluelink.0 2023-07-04 14:51:31.496	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#54a2a58f9f1bd540237a380c9ea08ce2d8657ea3) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                    nik82 1 Reply Last reply Reply Quote 0
                    • nik82
                      nik82 Most Active @GerdSo last edited by
                      @gerdso
                      Als ich deinen Post jetzt gelesen habe, habe ich auch mal den Adapter gestoppt und alle Objekte gelöscht, da ja die Klima jetzt in einem anderen Ordner ist.
                      Habe dann wieder gestartet und jetzt habe ich das gleiche Problem wie du und den gleichen Fehler im Log.
                      • Meister Mopper
                        Meister Mopper last edited by Meister Mopper
                        @arteck
                        Ich bekomme den von github nicht installiert. Es kommt der bekannte 'error 25' bei der Installation.
                        edit:
                        Ich Depp hatte den falschen von github geladen 🤦‍♂️
                        Läuft jetzt, vielen Dank!
                          stefan.cloer last edited by
                          Ich habe den gleichen Fehler wie @GerdSo. Auch ich habe vor der Installation alle Objekte gelöscht.
                            jetzt nochmal von GIT
                            G nik82 2 Replies Last reply Reply Quote 1
                              @arteck funktioniert, Danke ❤
                              • nik82
                                @arteck
                                Bist echt der Wahnsinn!!!
                                Funktioniert, vielen Dank👍
                                P.S. Klimatest kann ich noch nicht machen, Fahrzeug leider noch nicht da...
                                  Michael Loddoch last edited by
                                  Hallo!
                                  Leider läuft der tolle Adapter seit 10 Tagen nicht mehr bei mir.
                                  Ich bekomme diese Meldungen:
                                  Hat jemand vielleicht eine Idee, wie ich ihn wieder zum Laufen bekomme?
                                  Ganz viele Grüße!
                                  Michael
                                  [KIA Ceed SW Plug-in Hybrid]
                                    arteck Developer Most Active @Michael Loddoch last edited by arteck
                                    @michael-loddoch du kannst da nix machen.. die Serer spinnen wieder..es nervt langsam bei KIA
                                      GerdSo last edited by GerdSo
                                      @michael-loddoch hast Du die aktuelle Version von github installiert? Der login Mechanismus wurde geändert und dazu brauchst Du die neue Version
                                        Ich habe bisher alle Instanzen über die Adapterauswahl im IObroker installiert. Demnach habe ich Version 2.2.5.
                                        Auf github habe ich 2.3.2 gefunden. Wäre das die richtige?
                                        Wie man die in IObroker bekommt, muss ich (als Anfänger) aber erst einmal herausfinden ...
                                          DaLugi @Michael Loddoch last edited by
                                          Ich habe die 2.3.2 und es geht bei mir anscheinend auch nicht:
                                          Login-Daten sollten aber passen. Geht das beim Rest noch oder habe ich irgendetwas falsch gemacht?
                                          A M 2 Replies Last reply Reply Quote 0
                                            Aiouh @DaLugi last edited by
                                            @dalugi ich habe auch V2.3.2 und habe es gerade mal getestet
                                            Login funktioniert, es gibt lediglich ein paar falsche datentypen bei der drive history, was mich nicht stört, die Objekte nutze ich eh nicht.
                                            bluelink.0 2023-07-10 12:16:05.622	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.577	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.534	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.488	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.444	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.400	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:05.371	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total" has to be type "undefined" but received type "number"
                                            bluelink.0 2023-07-10 12:16:03.766	info	Update for xxxxxxxxxxxxxxxxxxx successfull
                                            bluelink.0 2023-07-10 12:15:30.437	info	Read new update for xxxxxxxxxxxxxxxxxxx directly from the car
                                            bluelink.0 2023-07-10 12:15:30.424	info	1 Vehicles found
                                            bluelink.0 2023-07-10 12:15:26.332	info	Login to api
                                            bluelink.0 2023-07-10 12:15:26.068	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#d92a933047aa0b2276f21f9e8efd25f9a9142a2a) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                                            1.2k
                                            81.1k
                                            2277
                                            851705
