    4. js-controller 5.0.x jetzt in der BETA
    • ice987
      ice987 @foxriver76 last edited by ice987
      @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
      @ice987 und kommt gar nicht mehr wieder? Dann mach mal iob fix
      iob fix lief normal durch, anschliessend gleicher Fehler
      admin log:
      2023-07-03 18:50:42.689 - info: admin.0 (2482) ==> Connected system.user.admin from ::ffff:192.168.1.175
      2023-07-03 18:51:17.573 - info: host.iobroker-testsystem8 received SIGTERM
      2023-07-03 18:51:17.574 - info: admin.0 (2482) terminating https server on port 8081
      2023-07-03 18:51:17.577 - info: host.iobroker-testsystem8 stopInstance system.adapter.admin.0 (force=false, process=true)
      2023-07-03 18:51:17.578 - info: host.iobroker-testsystem8 stopInstance system.adapter.web.0 (force=false, process=true)
      2023-07-03 18:51:17.578 - info: host.iobroker-testsystem8 stopInstance system.adapter.vis-2-beta.0 (force=false, process=true)
      2023-07-03 18:51:17.595 - info: admin.0 (2482) Got terminate signal TERMINATE_YOURSELF
      2023-07-03 18:51:17.602 - info: host.iobroker-testsystem8 stopInstance system.adapter.admin.0 send kill signal
      2023-07-03 18:51:17.601 - info: admin.0 (2482) terminating
      2023-07-03 18:51:17.603 - info: host.iobroker-testsystem8 stopInstance system.adapter.web.0 send kill signal
      2023-07-03 18:51:17.604 - info: host.iobroker-testsystem8 stopInstance system.adapter.vis-2-beta.0 send kill signal
      2023-07-03 18:51:17.605 - info: admin.0 (2482) Terminated (NO_ERROR): Without reason
      2023-07-03 18:51:17.596 - info: vis-2-beta.0 (1345) Got terminate signal TERMINATE_YOURSELF
      2023-07-03 18:51:17.851 - info: vis-2-beta.0 (1345) terminating
      2023-07-03 18:51:17.853 - info: vis-2-beta.0 (1345) Terminated (NO_ERROR): Without reason
      2023-07-03 18:51:17.598 - info: web.0 (1622) Got terminate signal TERMINATE_YOURSELF
      2023-07-03 18:51:17.882 - debug: web.0 (1622) terminating http server on port 8082
      2023-07-03 18:51:17.885 - info: web.0 (1622) terminated http server on port 8082
      2023-07-03 18:51:17.934 - info: web.0 (1622) terminating
      2023-07-03 18:51:17.935 - debug: web.0 (1622) Plugin sentry destroyed
      2023-07-03 18:51:17.936 - info: web.0 (1622) Terminated (NO_ERROR): Without reason
      2023-07-03 18:51:18.080 - info: web.0 (1622) terminating
      2023-07-03 18:51:18.080 - info: vis-2-beta.0 (1345) terminating
      2023-07-03 18:51:18.084 - info: admin.0 (2482) terminating
      2023-07-03 18:51:18.179 - info: host.iobroker-testsystem8 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2023-07-03 18:51:18.404 - info: host.iobroker-testsystem8 instance system.adapter.vis-2-beta.0 terminated with code 0 (NO_ERROR)
      2023-07-03 18:51:18.489 - info: host.iobroker-testsystem8 instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      2023-07-03 18:51:18.490 - info: host.iobroker-testsystem8 All instances are stopped.
      2023-07-03 18:51:18.693 - info: host.iobroker-testsystem8 terminated
      2023-07-03 18:52:32.222 - info: host.iobroker-testsystem8 iobroker.js-controller version 5.0.5 js-controller starting
      2023-07-03 18:52:32.230 - info: host.iobroker-testsystem8 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2023-07-03 18:52:32.231 - info: host.iobroker-testsystem8 hostname: iobroker-testsystem8, node: v18.16.1
      2023-07-03 18:52:32.232 - info: host.iobroker-testsystem8 ip addresses: 192.168.1.168
      2023-07-03 18:52:33.035 - info: host.iobroker-testsystem8 connected to Objects and States
      2023-07-03 18:52:33.064 - info: host.iobroker-testsystem8 added notifications configuration of host
      2023-07-03 18:52:33.549 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.nodeCurrent"
      2023-07-03 18:52:33.557 - info: host.iobroker-testsystem8 3 instances found
      2023-07-03 18:52:33.566 - info: host.iobroker-testsystem8 starting 3 instances
      2023-07-03 18:52:33.598 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.nodeNewest"
      2023-07-03 18:52:33.638 - info: host.iobroker-testsystem8 instance system.adapter.admin.0 started with pid 28089
      2023-07-03 18:52:33.647 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.nodeNewestNext"
      2023-07-03 18:52:33.670 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.npmCurrent"
      2023-07-03 18:52:33.678 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.npmNewest"
      2023-07-03 18:52:33.687 - info: host.iobroker-testsystem8 Delete state "system.host.iobroker-testsystem8.versions.npmNewestNext"
      2023-07-03 18:52:33.698 - info: host.iobroker-testsystem8 Some obsolete host states deleted.
      2023-07-03 18:52:37.297 - info: admin.0 (28089) starting. Version 6.5.9 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 5.0.5
      2023-07-03 18:52:37.531 - info: admin.0 (28089) requesting all states
      2023-07-03 18:52:37.534 - info: admin.0 (28089) requesting all objects
      2023-07-03 18:52:37.919 - info: host.iobroker-testsystem8 instance system.adapter.web.0 started with pid 28112
      2023-07-03 18:52:38.975 - info: admin.0 (28089) Request actual repository...
      2023-07-03 18:52:40.986 - info: admin.0 (28089) received all objects
      2023-07-03 18:52:42.076 - info: host.iobroker-testsystem8 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2023-07-03 18:52:42.209 - info: host.iobroker-testsystem8 instance system.adapter.vis-2-beta.0 started with pid 28119
      2023-07-03 18:52:42.277 - info: admin.0 (28089) Secure socket.io server listening on port 8081
      2023-07-03 18:52:42.288 - info: admin.0 (28089) https server listening on port 8081
      2023-07-03 18:52:42.290 - info: admin.0 (28089) Use link "https://127.0.0.1:8081" to configure.
      2023-07-03 18:52:43.679 - debug: web.0 (28112) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-07-03 18:52:45.025 - debug: web.0 (28112) Objects client ready ... initialize now
      2023-07-03 18:52:45.030 - debug: web.0 (28112) Objects create System PubSub Client
      2023-07-03 18:52:45.071 - debug: web.0 (28112) Objects create User PubSub Client
      2023-07-03 18:52:45.105 - debug: web.0 (28112) Objects client initialize lua scripts
      2023-07-03 18:52:45.177 - debug: web.0 (28112) Objects connected to redis: 127.0.0.1:9001
      2023-07-03 18:52:45.204 - debug: web.0 (28112) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-07-03 18:52:45.271 - debug: web.0 (28112) States create System PubSub Client
      2023-07-03 18:52:45.273 - debug: web.0 (28112) States create User PubSub Client
      2023-07-03 18:52:45.321 - debug: web.0 (28112) States connected to redis: 127.0.0.1:9000
      2023-07-03 18:52:45.471 - info: admin.0 (28089) Repository received successfully.
      2023-07-03 18:52:45.474 - debug: web.0 (28112) Plugin sentry Initialize Plugin (enabled=true)
      2023-07-03 18:52:46.389 - info: web.0 (28112) starting. Version 5.5.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.16.1, js-controller: 5.0.5
      2023-07-03 18:52:46.577 - debug: web.0 (28112) Activating states & socket info
      2023-07-03 18:52:46.503 - debug: vis-2-beta.0 (28119) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-07-03 18:52:46.707 - debug: vis-2-beta.0 (28119) Objects client ready ... initialize now
      2023-07-03 18:52:46.735 - debug: vis-2-beta.0 (28119) Objects create System PubSub Client
      2023-07-03 18:52:46.738 - debug: vis-2-beta.0 (28119) Objects create User PubSub Client
      2023-07-03 18:52:46.762 - debug: vis-2-beta.0 (28119) Objects client initialize lua scripts
      2023-07-03 18:52:46.790 - debug: vis-2-beta.0 (28119) Objects connected to redis: 127.0.0.1:9001
      2023-07-03 18:52:46.826 - debug: vis-2-beta.0 (28119) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-07-03 18:52:46.837 - debug: vis-2-beta.0 (28119) States create System PubSub Client
      2023-07-03 18:52:46.839 - debug: vis-2-beta.0 (28119) States create User PubSub Client
      2023-07-03 18:52:46.853 - debug: vis-2-beta.0 (28119) States connected to redis: 127.0.0.1:9000
      2023-07-03 18:52:46.581 - warn: web.0 (28112) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
      2023-07-03 18:52:46.582 - debug: web.0 (28112) Using http createServer
      2023-07-03 18:52:46.591 - debug: web.0 (28112) Activating IOSocket
      2023-07-03 18:52:47.048 - info: web.0 (28112) socket.io server listening on port 8082
      2023-07-03 18:52:47.069 - debug: web.0 (28112) Activating extensions
      2023-07-03 18:52:47.071 - debug: web.0 (28112) Activating web files from objectDB
      2023-07-03 18:52:47.077 - info: web.0 (28112) http server listening on port 8082
      2023-07-03 18:52:47.119 - info: vis-2-beta.0 (28119) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.vis-2-beta, node: v18.16.1, js-controller: 5.0.5
      2023-07-03 18:52:47.225 - error: vis-2-beta.0 (28119) No license found for vis. Please get one on https://iobroker.net !
      2023-07-03 18:52:50.413 - info: admin.0 (28089) failed connection to socket.io from ::ffff:192.168.1.175: Passport was not initialized
      2023-07-03 18:52:55.524 - info: admin.0 (28089) ==> Connected system.user.admin from ::ffff:192.168.1.175
      2023-07-03 18:53:21.158 - info: host.iobroker-testsystem8 Controller will upgrade itself to version 5.0.6
      2023-07-03 18:53:24.803 - info: host.iobroker-testsystem8 [CONTROLLER_AUTO_UPGRADE] Stopping controller
      kann das log nicht kopieren und als Text einfügen, war auf dem iPad 😉
      • foxriver76
        foxriver76 Developer @ice987 last edited by
        @ice987 Ah ganz überlesen, dass es offizielles Docker Image ist. 😉
        Irgendwie wird der Upgrade Prozess wohl gekillt vom Container wenn wir den Controller stoppen - wir schauen es uns an.
        foxriver76 1 Reply Last reply Reply Quote 1
        • foxriver76
          foxriver76 Developer @foxriver76 last edited by
          @ice987 Konnten das Problem identifizieren, wird allerdings eine neue Version vom Docker Container benötigen.
          ice987 1 Reply Last reply Reply Quote 1
          • Feuersturm
            Feuersturm last edited by
            Master Slave Testsystem erfolgreich auf 5.0.6 ohne Probleme aktualisiert 🙂
            • ice987
              @foxriver76
              Wunderbar 🥳
              Lasst es uns wissen wann es was zum Testen gibt!
              vielen Dank für euren Einsatz!
                apollon77 @Marty56 last edited by
                @marty56 Den einen Alias Fehler hier hattest du gesehen?
                2023-07-02 07:57:45.395 - error: admin.0 (500372) source in "alias.0.Energie.Auto2" does not exist for "read" function: "val/1000"
                Hat aber wohl eher nichts mit dem Fehlerspike zu tun
                  Marty56 @apollon77 last edited by Marty56
                  @apollon77 Danke für die Analyse.
                  Ja, den Fehler hatte ich gesehen, bin aber ratlos, was ich ändern soll.
                  Der Alias funktioniert ohne Probleme (bis auf die Fehlermeldung)
                  Anbei die Alias Definition. Vielleicht findest Du einen Fehler.
                  Der Datenpunkt ist vorhanden und übermittelt auch Werte.
                    "common": {
                      "name": "Charged Energy",
                      "type": "number",
                      "unit": "kWh",
                      "alias": {
                        "id": "mqtt.0.evcc.loadpoints.1.chargedEnergy",
                        "read": "val/1000"
                      "role": "variable",
                      "desc": "mqtt server variable"
                    "native": {},
                    "type": "state",
                    "user": "system.user.admin",
                    "ts": 1687853277947,
                    "_id": "alias.0.Energie.Auto2",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                  Ich generiere meine Aliases mit einem Javascript.
                    Marty56 @Marty56 last edited by Marty56
                    Ich habe die 5.0.6 von js-controller installiert, aber der Fehlerspike ist gerade wieder aufgetreten.
                    Anbei das komplette Log File: log.txt
                    Es sind 349 Fehler. Ich habe aber 447 Alias. Es scheint, dass nicht jeder Alias einen Fehler erzeugt.
                    Beim Vergleich zu dem älteren Log File fällt auch auf, dass die Anzahl der Fehler (383) nicht konstant ist, obwohl ich keine neuen Alias definiert habe.
                    Es gibt Aliases, die in den früheren Log File, mit einem Fehler angezeigt wurden, und im neueren nicht. z.B. die Aliases auf "mqtt.0".
                    Es scheint irgendeine Zufälligkeit im Spiel zu sein.
                    • Loredo
                      Loredo Developer last edited by Loredo
                        CKassiopaia last edited by
                        Jetzt melde ich mich doch mal hier zu Wort und melde einen "Fehler":
                        Ich habe ein Multi-Host-System (wobei der Slave nur zu Testzwecken dabei ist) und es lässt sich leider nur der Slave auf die aktuelle JS-Controller-Version 5.0.6 installieren.
                        Der Master ist ein Raspberry Pi 4 mit 8 GB. Der Slave ein alter Zotac mit 1,8 GHz Atom und 4 GB mit Debian.
                        Auf dem Master habe ich seit 5.0.4 kein Update mehr durchführen können. Zudem lassen sich seit dem auch keine Updates der Adapter durchführen:
                        Wenn ich die Installation über Putty (direkt in Linux) durchführe kommen keine Fehlermeldungen. Die Updates der Adapter und des JS-Controller werden ohne Fehler durchgeführt... aber am Ende hat sich nichts verändert. Über die Admin-Konsole kommt folgendes:
                        npm ERR! code EBADENGINE
                        npm ERR! engine Unsupported engine
                        npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                        npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
                        npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
                        npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.1"}
                        npm ERR!     /root/.npm/_logs/2023-07-04T14_59_51_842Z-debug-0.log
                        Could not install js-controller@5.0.6
                        Das Problem wird also vielleicht am Daikin-Adapter liegen? Den habe ich jetzt mal deinstalliert... im Sommer ist die Wärmepumpe ohnehin aus 😉
                        ... und siehe da, dann funktioniert es auch. Also nach dem Entferndn des Daikin-Adapters konnte ich den JS-Controller aktualisieren. Jetzt lassen sich auch die anderen Adapter aktualisieren.
                        Also eigentlich ist dieser Post jetzt überflüssig, aber vielleicht interessiert es doch jemanden, dass via Putty keine Fehlermeldungen angezeigt wurden und der Daikin-Adapter noch nicht mit der neuen Version funktioniert.
                          ticaki last edited by ticaki
                          Seit dem Update auf 5.0.x (immer aktuell) und dem installieren des Notification-Managers schickt der mir beim jedem Restart des ioBrokers freundlicherweise diese Mitteilung:
                          Probleme mit der Datenbank
                          Es liegt ein Fehler mit der Datenbank vor.
                          Vielleicht hat die Datenbank interne Probleme oder ist falsch konfiguriert.
                          system.host.tims-pi1:
                          s-pi1: 3.7.2023, 23:41:57
                          Das dazu gehörige Log zeigt das es beim stoppen passiert.
                          2023-07-03 23:38:26.321 - info: host.tims-pi1 instance system.adapter.influxdb.1 terminated with code 0 (NO_ERROR)
                          2023-07-03 23:38:26.343 - error: host.tims-pi1 Caught by controller[0]: [ioredis] Unhandled error event: Error: write EPIPE
                          2023-07-03 23:38:26.344 - error: host.tims-pi1 Caught by controller[0]: at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                          2023-07-03 23:38:26.345 - error: host.tims-pi1 Caught by controller[0]: at writeGeneric (node:internal/stream_base_commons:151:3)
                          2023-07-03 23:38:26.345 - error: host.tims-pi1 Caught by controller[0]: at Socket._writeGeneric (node:net:930:11)
                          2023-07-03 23:38:26.345 - error: host.tims-pi1 Caught by controller[0]: at Socket._write (node:net:942:8)
                          2023-07-03 23:38:26.346 - error: host.tims-pi1 Caught by controller[0]: at writeOrBuffer (node:internal/streams/writable:392:12)
                          2023-07-03 23:38:26.346 - error: host.tims-pi1 Caught by controller[0]: at _write (node:internal/streams/writable:333:10)
                          2023-07-03 23:38:26.346 - error: host.tims-pi1 Caught by controller[0]: at Socket.Writable.write (node:internal/streams/writable:337:10)
                          2023-07-03 23:38:26.347 - error: host.tims-pi1 Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:679:33)
                          2023-07-03 23:38:26.347 - error: host.tims-pi1 Caught by controller[0]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                          2023-07-03 23:38:26.347 - error: host.tims-pi1 Caught by controller[0]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:817:35)
                          2023-07-03 23:38:26.347 - error: host.tims-pi1 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          2023-07-03 23:38:26.347 - error: host.tims-pi1 Caught by controller[0]: Error: DB closed
                          2023-07-03 23:38:26.348 - error: host.tims-pi1 Caught by controller[0]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                          2023-07-03 23:38:26.348 - error: host.tims-pi1 Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                          2023-07-03 23:38:26.348 - error: host.tims-pi1 Caught by controller[0]: at Object.onceWrapper (node:events:628:26)
                          2023-07-03 23:38:26.348 - error: host.tims-pi1 Caught by controller[0]: at Socket.emit (node:events:513:28)
                          2023-07-03 23:38:26.349 - error: host.tims-pi1 Caught by controller[0]: at Socket.emit (node:domain:489:12)
                          2023-07-03 23:38:26.349 - error: host.tims-pi1 Caught by controller[0]: at TCP. (node:net:322:12)
                          2023-07-03 23:38:26.349 - info: host.tims-pi1 instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                          2023-07-03 23:38:26.373 - error: host.tims-pi1 Caught by controller[0]: [ioredis] Unhandled error event: Error: write ECONNRESET
                          2023-07-03 23:38:26.373 - error: host.tims-pi1 Caught by controller[0]: at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at writeGeneric (node:internal/stream_base_commons:151:3)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at Socket._writeGeneric (node:net:930:11)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at Socket._write (node:net:942:8)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at writeOrBuffer (node:internal/streams/writable:392:12)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at _write (node:internal/streams/writable:333:10)
                          2023-07-03 23:38:26.374 - error: host.tims-pi1 Caught by controller[0]: at Writable.write (node:internal/streams/writable:337:10)
                          2023-07-03 23:38:26.375 - error: host.tims-pi1 Caught by controller[0]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:679:33)
                          2023-07-03 23:38:26.375 - error: host.tims-pi1 Caught by controller[0]: at Redis.evalsha (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                          2023-07-03 23:38:26.375 - error: host.tims-pi1 Caught by controller[0]: at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:3105:46)
                          2023-07-03 23:38:26.375 - info: host.tims-pi1 instance system.adapter.zigbee2mqtt.0 terminated with code 0 (NO_ERROR)
                          2023-07-03 23:38:27.224 - info: tuya.0 (1587) terminating
                          2023-07-03 23:38:27.228 - info: tuya.0 (1587) Terminated (NO_ERROR): Without reason
                          2023-07-03 23:38:27.814 - info: host.tims-pi1 instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
                          2023-07-03 23:38:27.815 - info: host.tims-pi1 All instances are stopped.
                          2023-07-03 23:38:27.845 - info: host.tims-pi1 terminated
                          2023-07-03 23:38:31.939 - info: host.tims-pi1 [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                          2023-07-03 23:38:32.123 - info: host.tims-pi1 [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:443
                          2023-07-03 23:39:17.791 - info: host.tims-pi1 [CONTROLLER_AUTO_UPGRADE]
                          Wäre mir ohne den Manager wohl nie aufgefallen... hm vielleicht ist es auch schon immer so. 🙂
                          EDIT: log verlängert
                          • LausiD
                            LausiD last edited by
                            Aktualisierung von 5.0.5 auf 5.0.6 Abbruch mit Fehler.
                            Jemand eine Idee?
                            host.raspberrypi
                            	2023-07-04 22:21:29.848	info	[CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
                            host.raspberrypi
                            	2023-07-04 22:21:24.686	info	[CONTROLLER_AUTO_UPGRADE] Final information delivered
                            host.raspberrypi
                            	2023-07-04 22:21:24.426	error	[CONTROLLER_AUTO_UPGRADE] Could not install js-controller@5.0.6
                            host.raspberrypi
                            	2023-07-04 22:21:24.418	error	[CONTROLLER_AUTO_UPGRADE] npm ERR! code 128npm ERR! An unknown git error occurrednpm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/iobroker-community-adapters/ioBroker.fhem.gitnpm ERR! command-line line 0: unsupported option "accept-new".npm ERR! fatal: Konnte nicht vom Remote-Repository lesen.npm ERR! npm ERR! Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehennpm ERR! und das Repository existiert.npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2023-07-04T20_20_52_309Z-debug-0.log
                            host.raspberrypi
                            	2023-07-04 22:20:49.887	info	[CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                            host.raspberrypi
                            	2023-07-04 22:20:49.871	info	[CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @LausiD last edited by
                              @lausid sagte in js-controller 5.0.x jetzt in der BETA:
                              Jemand eine Idee?
                              Auf einem raspberrypi nicht als root herumkaspern wäre die erste.
                              Dann nach dem fhem-Adapter schauen, da klemmt es wohl.
                              • foxriver76
                                foxriver76 Developer @apollon77 last edited by
                                @apollon77 sagte in js-controller 5.0.x jetzt in der BETA:
                                Neue erkannte Probleme, die noch nicht behandelt sind:
                                Ich schreibe mal meine Updates in klammern dahinter
                                • stiebel-isg update nötig
                                • lgtv zeigt Fehlermeldungen an (sollte fixed sein mit 1.1.12)
                                • web kann crashen falls Widgets in vis falsch konfiguriert sind (PR in socket-classes existiert bereits)
                                • js-controller upgrade via Admin startet js-controller nicht wieder
                                • Admin zeigt falsche Log grösse an -> Fixed in Admin 6.5.8+
                                • km200 muss geprüft werden (sollte gefixt sein mit 2.0.4)
                                • miio muss geprüft werden
                                • fakeroku muss geprüft werden (git version funktioniert, benötigt publish)
                                • pi-hole update nötig
                                • node-red muss geprüft werden
                                • enigma2.0 mindestens 1.4.0+
                                • doorbird update nötig
                                • linux-control update nötig
                                apollon77 B L 3 Replies Last reply Reply Quote 2
                                  apollon77 @CKassiopaia last edited by
                                  @ckassiopaia Daikin cloud von github installieren, dann ist der Fehler weg
                                    apollon77 @LausiD last edited by
                                    Also bei dem Fehler lande ich eher bei sowas https://serverfault.com/questions/1105812/command-line-line-0-unsupported-option-accept-new-how-to-fix-this
                                    Scheinbar ist da was an deiner SSH konfig verbogen? Lösungsdiskussion aber bitte in einem eigenen Thread!
                                    LausiD 1 Reply Last reply Reply Quote 0
                                      apollon77 @foxriver76 last edited by
                                      updated
                                        apollon77 @ticaki last edited by
                                        @ticaki sagte in js-controller 5.0.x jetzt in der BETA:
                                        Bitte nochmal groooossszügig verlängern!! Viel zu enig - vor allem nichts vom notification adapter zu sehen dort. mach mal paar minuten inklusive kurz BEVOR du ihn restartest.
                                        BTW: Wie restartest du?
                                          ticaki @apollon77 last edited by ticaki
                                          Ich habs verlängert, weil der Fehler diesesmal durch den "Restart" der vom js-controller update erzeugt wurde. und das steht in den letzten 3 Zeilen im Log.
                                          iobroker stop
                                          iobroker start
                                          sudo reboot
                                          Das sind die üblichen Befehle. Vorhin hab ich ihn hard ausgeschaltet, weil ich blöd bin 🙂 da kam auch die Nachricht über telegram, kann dazu aber nichts im log finden, gibts noch eine anderes log?
                                          Edit: log etwas viel verlängert. 1. Eintrag ist mein Anmelden am Server
                                          2023-07-03 23:37:49.026 - info: admin.0 (4902) ==> Connected system.user.admin from 192.168.178.133
                                          2023-07-03 23:38:20.457 - info: host.tims-pi1 Controller will upgrade itself to version 5.0.6
                                          2023-07-03 23:38:24.058 - info: host.tims-pi1 [CONTROLLER_AUTO_UPGRADE] Stopping controller
                                          2023-07-03 23:38:24.169 - info: host.tims-pi1 received SIGTERM
                                          2023-07-03 23:38:24.185 - info: javascript.0 (12330) Stop script script.js.common.Starte_AppleTV
                                          2023-07-03 23:38:24.152 - info: yahka.0 (1673) cleaning up ...
                                          2023-07-03 23:38:24.168 - info: yahka.0 (1673) cleaned up ...
                                          2023-07-03 23:38:24.214 - info: yahka.0 (1673) terminating
                                          2023-07-03 23:38:24.216 - info: yahka.0 (1673) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.201 - error: mihome-vacuum.0 (1609) Socket Close
                                          2023-07-03 23:38:24.184 - info: admin.0 (4902) terminating https server on port 443
                                          2023-07-03 23:38:24.251 - info: mihome-vacuum.0 (1609) terminating
                                          2023-07-03 23:38:24.184 - info: homepilot20.0 (1818) terminating homepilot20 adapter
                                          2023-07-03 23:38:24.188 - error: homepilot20.0 (1818) Adapter will be stopped
                                          2023-07-03 23:38:24.262 - info: homepilot20.0 (1818) terminating
                                          2023-07-03 23:38:24.227 - info: notification-manager.0 (1658) terminating
                                          2023-07-03 23:38:24.230 - info: notification-manager.0 (1658) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.269 - info: mihome-vacuum.0 (1609) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.186 - info: javascript.0 (12330) Stop script script.js.common.Haustürautomatik_BWMlicht
                                          2023-07-03 23:38:24.188 - info: javascript.0 (12330) Stop script script.js.common.Schlafenszeit_&_Nachmodus
                                          2023-07-03 23:38:24.189 - info: javascript.0 (12330) Stop script script.js.Messages.tankerkoenig
                                          2023-07-03 23:38:24.190 - info: javascript.0 (12330) Stop script script.js.common.Anyone_&_Calc_humi_&_frostig
                                          2023-07-03 23:38:24.191 - info: javascript.0 (12330) Stop script script.js.common.rollandensteuerung_Schlafzimmer
                                          2023-07-03 23:38:24.192 - info: javascript.0 (12330) Stop script script.js.Test.Fill_SQL
                                          2023-07-03 23:38:24.203 - info: javascript.0 (12330) Stop script script.js.common.StatusLights
                                          2023-07-03 23:38:24.205 - info: javascript.0 (12330) Stop script script.js.Messages.dwd_uwz_nina_script
                                          2023-07-03 23:38:24.207 - info: javascript.0 (12330) script.js.Messages.dwd_uwz_nina_script: info: Skripts gestoppt: ID:3827.050695965306
                                          2023-07-03 23:38:24.209 - info: javascript.0 (12330) Stop script script.js.Verwaltung.Luftbefeuchter
                                          2023-07-03 23:38:24.210 - info: javascript.0 (12330) Stop script script.js.Wohnzimmer.1_Hue_Dimmer_Switch
                                          2023-07-03 23:38:24.211 - info: javascript.0 (12330) Stop script script.js.common.check_internet_connection
                                          2023-07-03 23:38:24.212 - info: javascript.0 (12330) Stop script script.js.Messages.Telegramm
                                          2023-07-03 23:38:24.213 - info: javascript.0 (12330) Stop script script.js.common.comingHome_&_Steckdosen
                                          2023-07-03 23:38:24.221 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Treppenhausautomatik
                                          2023-07-03 23:38:24.222 - info: javascript.0 (12330) Stop script script.js.Test.Solcast
                                          2023-07-03 23:38:24.223 - info: javascript.0 (12330) Stop script script.js.Verwaltung.Climacontrol
                                          2023-07-03 23:38:24.224 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Shelly_Schlafzimmer_Licht
                                          2023-07-03 23:38:24.225 - info: javascript.0 (12330) Stop script script.js.Test.Skript_3
                                          2023-07-03 23:38:24.226 - info: javascript.0 (12330) Stop script script.js.common.Saugroboter
                                          2023-07-03 23:38:24.227 - info: javascript.0 (12330) Stop script script.js.Verwaltung.Kontrollzentrum
                                          2023-07-03 23:38:24.228 - info: javascript.0 (12330) Stop script script.js.Verwaltung.Heizung
                                          2023-07-03 23:38:24.229 - info: javascript.0 (12330) Stop script script.js.common.mqtt_datentransfer
                                          2023-07-03 23:38:24.230 - info: javascript.0 (12330) Stop script script.js.Messages.Battery
                                          2023-07-03 23:38:24.231 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Küche-bwm
                                          2023-07-03 23:38:24.231 - info: javascript.0 (12330) Stop script script.js.Wohnzimmer.calculateTempForLivingRoom
                                          2023-07-03 23:38:24.232 - info: javascript.0 (12330) Stop script script.js.common.Wecker-Sunrise
                                          2023-07-03 23:38:24.233 - info: javascript.0 (12330) Stop script script.js.Messages.Telegram-Handler
                                          2023-07-03 23:38:24.233 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Virtuelle_Light_on-off_0%-100%_brightness
                                          2023-07-03 23:38:24.234 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Flursteuerung
                                          2023-07-03 23:38:24.235 - info: javascript.0 (12330) Stop script script.js.Beleuchtung_(mehrere_Räume).Ankleidezimmer_Beleuchtung
                                          2023-07-03 23:38:24.236 - info: javascript.0 (12330) Stop script script.js.common.Solarstrom
                                          2023-07-03 23:38:24.198 - info: hm-rpc.0 (1557) xmlrpc -> 192.168.178.95:42001/ init ["http://192.168.178.96:42001",""]
                                          2023-07-03 23:38:24.191 - info: sma-em.0 (23059) cleaned everything up...
                                          2023-07-03 23:38:24.266 - info: sma-em.0 (23059) UDP Socket closed ...
                                          2023-07-03 23:38:24.298 - info: sma-em.0 (23059) terminating
                                          2023-07-03 23:38:24.300 - info: sma-em.0 (23059) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.304 - info: homepilot20.0 (1818) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.308 - info: hm-rpc.0 (1557) Disconnected
                                          2023-07-03 23:38:24.310 - warn: zigbee2mqtt.0 (4233) Start try again in 1 seconds...
                                          2023-07-03 23:38:24.319 - info: hm-rpc.0 (1557) terminating
                                          2023-07-03 23:38:24.276 - info: fritzdect.0 (1765) cleaned everything up...
                                          2023-07-03 23:38:24.324 - info: hm-rpc.0 (1557) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.227 - info: email.0 (1291) terminating
                                          2023-07-03 23:38:24.232 - info: email.0 (1291) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.166 - info: backitup.0 (1784) cleaned everything up...
                                          2023-07-03 23:38:24.196 - info: yahka.1 (30056) cleaning up ...
                                          2023-07-03 23:38:24.200 - info: yahka.1 (30056) cleaned up ...
                                          2023-07-03 23:38:24.233 - info: mqtt.0 (11274) Disconnected from 192.168.178.96: undefined
                                          2023-07-03 23:38:24.343 - info: yahka.1 (30056) terminating
                                          2023-07-03 23:38:24.348 - info: javascript.0 (12330) terminating
                                          2023-07-03 23:38:24.365 - info: admin.0 (4902) terminating
                                          2023-07-03 23:38:24.368 - info: admin.0 (4902) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.393 - info: fritzdect.0 (1765) terminating
                                          2023-07-03 23:38:24.395 - info: fritzdect.0 (1765) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.332 - info: backitup.0 (1784) terminating
                                          2023-07-03 23:38:24.221 - info: sql.0 (1362) terminating
                                          2023-07-03 23:38:24.349 - info: sql.0 (1362) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.363 - info: javascript.0 (12330) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.345 - info: yahka.1 (30056) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.405 - info: backitup.0 (1784) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.205 - info: host.tims-pi1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                          2023-07-03 23:38:24.206 - info: host.tims-pi1 stopInstance system.adapter.pushover.0 (force=false, process=true)
                                          2023-07-03 23:38:24.207 - info: host.tims-pi1 stopInstance system.adapter.email.0 (force=false, process=true)
                                          2023-07-03 23:38:24.208 - info: host.tims-pi1 stopInstance system.adapter.telegram.0 (force=false, process=true)
                                          2023-07-03 23:38:24.209 - info: host.tims-pi1 stopInstance system.adapter.influxdb.1 (force=false, process=true)
                                          2023-07-03 23:38:24.210 - info: host.tims-pi1 stopInstance system.adapter.javascript.0 (force=false, process=true)
                                          2023-07-03 23:38:24.211 - info: host.tims-pi1 stopInstance system.adapter.sql.0 (force=false, process=true)
                                          2023-07-03 23:38:24.212 - info: host.tims-pi1 stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                                          2023-07-03 23:38:24.213 - info: host.tims-pi1 stopInstance system.adapter.rpi2.0 (force=false, process=true)
                                          2023-07-03 23:38:24.277 - info: host.tims-pi1 stopInstance system.adapter.shelly.0 (force=false, process=true)
                                          2023-07-03 23:38:24.278 - info: host.tims-pi1 stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
                                          2023-07-03 23:38:24.280 - info: host.tims-pi1 stopInstance system.adapter.sonoff.0 (force=false, process=true)
                                          2023-07-03 23:38:24.281 - info: host.tims-pi1 stopInstance system.adapter.alexa2.0 (force=false, process=true)
                                          2023-07-03 23:38:24.282 - info: host.tims-pi1 stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                                          2023-07-03 23:38:24.282 - info: host.tims-pi1 stopInstance system.adapter.openweathermap.0 (force=false, process=false)
                                          2023-07-03 23:38:24.331 - info: host.tims-pi1 stopInstance canceled schedule system.adapter.openweathermap.0
                                          2023-07-03 23:38:24.332 - info: host.tims-pi1 stopInstance system.adapter.tuya.0 (force=false, process=true)
                                          2023-07-03 23:38:24.333 - info: host.tims-pi1 stopInstance system.adapter.modbus.0 (force=false, process=false)
                                          2023-07-03 23:38:24.333 - info: host.tims-pi1 stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                          2023-07-03 23:38:24.334 - info: host.tims-pi1 stopInstance system.adapter.daikin.0 (force=false, process=true)
                                          2023-07-03 23:38:24.335 - info: host.tims-pi1 stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                          2023-07-03 23:38:24.336 - info: host.tims-pi1 stopInstance system.adapter.notification-manager.0 (force=false, process=true)
                                          2023-07-03 23:38:24.337 - info: host.tims-pi1 stopInstance system.adapter.yahka.0 (force=false, process=true)
                                          2023-07-03 23:38:24.337 - info: host.tims-pi1 stopInstance system.adapter.hyperion_ng.0 (force=false, process=false)
                                          2023-07-03 23:38:24.338 - info: host.tims-pi1 stopInstance system.adapter.nuki.0 (force=false, process=true)
                                          2023-07-03 23:38:24.339 - info: host.tims-pi1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                          2023-07-03 23:38:24.354 - info: host.tims-pi1 stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                                          2023-07-03 23:38:24.359 - info: host.tims-pi1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                          2023-07-03 23:38:24.360 - info: host.tims-pi1 stopInstance system.adapter.iot.0 (force=false, process=true)
                                          2023-07-03 23:38:24.361 - info: host.tims-pi1 stopInstance system.adapter.wled.0 (force=false, process=true)
                                          2023-07-03 23:38:24.362 - info: host.tims-pi1 stopInstance system.adapter.homepilot20.0 (force=false, process=true)
                                          2023-07-03 23:38:24.383 - info: host.tims-pi1 stopInstance system.adapter.zigbee2mqtt.0 (force=false, process=true)
                                          2023-07-03 23:38:24.384 - info: host.tims-pi1 stopInstance system.adapter.info.0 (force=false, process=true)
                                          2023-07-03 23:38:24.385 - info: host.tims-pi1 stopInstance system.adapter.sma-em.0 (force=false, process=true)
                                          2023-07-03 23:38:24.385 - info: host.tims-pi1 stopInstance system.adapter.web.0 (force=false, process=true)
                                          2023-07-03 23:38:24.386 - info: host.tims-pi1 stopInstance system.adapter.yahka.1 (force=false, process=true)
                                          2023-07-03 23:38:24.387 - info: host.tims-pi1 stopInstance system.adapter.vis.0 (force=false, process=false)
                                          2023-07-03 23:38:24.440 - info: sonoff.0 (1527) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.437 - info: javascript.0 (12330) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.443 - info: hm-rpc.0 (1557) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.444 - info: fritzdect.0 (1765) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.445 - info: yahka.0 (1673) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.443 - info: backitup.0 (1784) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.447 - info: notification-manager.0 (1658) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.449 - info: mqtt.0 (11274) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.449 - info: admin.0 (4902) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.464 - info: mihome-vacuum.0 (1609) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.444 - info: email.0 (1291) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.438 - info: pushover.0 (1208) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.485 - info: host.tims-pi1 stopInstance system.adapter.admin.0 send kill signal
                                          2023-07-03 23:38:24.489 - info: yahka.1 (30056) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.491 - info: zigbee2mqtt.0 (4233) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.490 - info: sma-em.0 (23059) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.492 - info: homepilot20.0 (1818) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.443 - info: telegram.0 (25742) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.451 - info: tuya.0 (1587) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.488 - info: host.tims-pi1 stopInstance system.adapter.pushover.0 send kill signal
                                          2023-07-03 23:38:24.495 - info: host.tims-pi1 stopInstance system.adapter.email.0 send kill signal
                                          2023-07-03 23:38:24.496 - info: host.tims-pi1 stopInstance system.adapter.telegram.0 send kill signal
                                          2023-07-03 23:38:24.496 - info: host.tims-pi1 stopInstance system.adapter.javascript.0 send kill signal
                                          2023-07-03 23:38:24.502 - info: host.tims-pi1 stopInstance system.adapter.hm-rega.0 send kill signal
                                          2023-07-03 23:38:24.503 - info: host.tims-pi1 stopInstance system.adapter.rpi2.0 send kill signal
                                          2023-07-03 23:38:24.508 - info: host.tims-pi1 stopInstance system.adapter.shelly.0 send kill signal
                                          2023-07-03 23:38:24.509 - info: host.tims-pi1 stopInstance system.adapter.hm-rpc.1 send kill signal
                                          2023-07-03 23:38:24.510 - info: host.tims-pi1 stopInstance system.adapter.sonoff.0 send kill signal
                                          2023-07-03 23:38:24.510 - info: host.tims-pi1 stopInstance system.adapter.alexa2.0 send kill signal
                                          2023-07-03 23:38:24.511 - info: host.tims-pi1 stopInstance system.adapter.hm-rpc.0 send kill signal
                                          2023-07-03 23:38:24.511 - info: host.tims-pi1 stopInstance system.adapter.tuya.0 send kill signal
                                          2023-07-03 23:38:24.512 - info: host.tims-pi1 stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                          2023-07-03 23:38:24.512 - info: host.tims-pi1 stopInstance system.adapter.daikin.0 send kill signal
                                          2023-07-03 23:38:24.513 - info: host.tims-pi1 stopInstance system.adapter.mqtt.0 send kill signal
                                          2023-07-03 23:38:24.514 - info: host.tims-pi1 stopInstance system.adapter.notification-manager.0 send kill signal
                                          2023-07-03 23:38:24.515 - info: host.tims-pi1 stopInstance system.adapter.yahka.0 send kill signal
                                          2023-07-03 23:38:24.516 - info: host.tims-pi1 stopInstance system.adapter.nuki.0 send kill signal
                                          2023-07-03 23:38:24.517 - info: host.tims-pi1 stopInstance system.adapter.discovery.0 send kill signal
                                          2023-07-03 23:38:24.517 - info: host.tims-pi1 stopInstance system.adapter.fritzdect.0 send kill signal
                                          2023-07-03 23:38:24.518 - info: host.tims-pi1 stopInstance system.adapter.backitup.0 send kill signal
                                          2023-07-03 23:38:24.518 - info: host.tims-pi1 stopInstance system.adapter.iot.0 send kill signal
                                          2023-07-03 23:38:24.519 - info: host.tims-pi1 stopInstance system.adapter.wled.0 send kill signal
                                          2023-07-03 23:38:24.530 - info: host.tims-pi1 stopInstance system.adapter.homepilot20.0 send kill signal
                                          2023-07-03 23:38:24.531 - info: host.tims-pi1 stopInstance system.adapter.zigbee2mqtt.0 send kill signal
                                          2023-07-03 23:38:24.532 - info: host.tims-pi1 stopInstance system.adapter.info.0 send kill signal
                                          2023-07-03 23:38:24.532 - info: host.tims-pi1 stopInstance system.adapter.sma-em.0 send kill signal
                                          2023-07-03 23:38:24.533 - info: host.tims-pi1 stopInstance system.adapter.web.0 send kill signal
                                          2023-07-03 23:38:24.533 - info: host.tims-pi1 stopInstance system.adapter.yahka.1 send kill signal
                                          2023-07-03 23:38:24.419 - info: hm-rega.0 (1382) terminating
                                          2023-07-03 23:38:24.433 - info: hm-rega.0 (1382) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.550 - info: hm-rega.0 (1382) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.341 - info: iot.0 (1796) Connection changed: disconnect
                                          2023-07-03 23:38:24.558 - info: iot.0 (1796) Connection lost
                                          2023-07-03 23:38:24.244 - info: rpi2.0 (1431) terminating
                                          2023-07-03 23:38:24.493 - info: rpi2.0 (1431) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.253 - info: discovery.0 (1717) terminating
                                          2023-07-03 23:38:24.465 - info: discovery.0 (1717) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.572 - info: iot.0 (1796) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.148 - info: hm-rpc.1 (1512) xmlrpc -> 192.168.178.95:42010/ init ["http://192.168.178.96:42010",""]
                                          2023-07-03 23:38:24.576 - info: iot.0 (1796) terminating
                                          2023-07-03 23:38:24.579 - info: iot.0 (1796) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.271 - info: alexa2.0 (1542) terminating
                                          2023-07-03 23:38:24.439 - info: alexa2.0 (1542) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.162 - info: daikin.0 (1624) terminating
                                          2023-07-03 23:38:24.456 - info: daikin.0 (1624) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.581 - info: rpi2.0 (1431) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.586 - info: alexa2.0 (1542) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.579 - info: hm-rpc.1 (1512) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.594 - info: discovery.0 (1717) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.591 - info: daikin.0 (1624) Got terminate signal TERMINATE_YOURSELF
                                          2023-07-03 23:38:24.621 - info: hm-rpc.1 (1512) Disconnected
                                          2023-07-03 23:38:24.631 - info: hm-rpc.1 (1512) terminating
                                          2023-07-03 23:38:24.634 - info: hm-rpc.1 (1512) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.650 - info: email.0 (1291) terminating
                                          2023-07-03 23:38:24.664 - info: daikin.0 (1624) terminating
                                          2023-07-03 23:38:24.673 - info: yahka.0 (1673) terminating
                                          2023-07-03 23:38:24.680 - info: telegram.0 (25742) terminating
                                          2023-07-03 23:38:24.679 - warn: influxdb.1 (8576) Store data for 324 points and 0 conflicts
                                          2023-07-03 23:38:24.685 - info: sonoff.0 (1527) terminating
                                          2023-07-03 23:38:24.688 - info: sonoff.0 (1527) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.686 - info: iot.0 (1796) terminating
                                          2023-07-03 23:38:24.688 - info: javascript.0 (12330) terminating
                                          2023-07-03 23:38:24.695 - info: homepilot20.0 (1818) terminating
                                          2023-07-03 23:38:24.692 - info: telegram.0 (25742) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.699 - info: mihome-vacuum.0 (1609) terminating
                                          2023-07-03 23:38:24.706 - info: notification-manager.0 (1658) terminating
                                          2023-07-03 23:38:24.715 - info: discovery.0 (1717) terminating
                                          2023-07-03 23:38:24.717 - info: mqtt.0 (11274) terminating
                                          2023-07-03 23:38:24.722 - info: hm-rega.0 (1382) terminating
                                          2023-07-03 23:38:24.721 - info: mqtt.0 (11274) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.724 - info: alexa2.0 (1542) terminating
                                          2023-07-03 23:38:24.720 - info: pushover.0 (1208) terminating
                                          2023-07-03 23:38:24.728 - info: rpi2.0 (1431) terminating
                                          2023-07-03 23:38:24.731 - info: pushover.0 (1208) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:24.767 - info: sma-em.0 (23059) terminating
                                          2023-07-03 23:38:24.769 - info: yahka.1 (30056) terminating
                                          2023-07-03 23:38:24.803 - info: backitup.0 (1784) terminating
                                          2023-07-03 23:38:24.832 - info: fritzdect.0 (1765) terminating
                                          2023-07-03 23:38:24.835 - info: admin.0 (4902) terminating
                                          2023-07-03 23:38:24.929 - info: host.tims-pi1 instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.173 - info: host.tims-pi1 instance system.adapter.email.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.184 - error: shelly.0 (12292) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-07-03 23:38:25.210 - error: shelly.0 (12292) unhandled promise rejection: DB closed
                                          2023-07-03 23:38:25.213 - error: shelly.0 (12292) Error: DB closed
                                          2023-07-03 23:38:25.214 - error: shelly.0 (12292) DB closed
                                          2023-07-03 23:38:25.322 - info: zigbee2mqtt.0 (4233) Connect to Zigbee2MQTT over websocket connection.
                                          2023-07-03 23:38:25.174 - info: host.tims-pi1 instance system.adapter.notification-manager.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.388 - info: host.tims-pi1 instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.390 - info: host.tims-pi1 instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.393 - info: host.tims-pi1 instance system.adapter.sma-em.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.544 - info: host.tims-pi1 instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.545 - info: host.tims-pi1 instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.546 - info: host.tims-pi1 instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.548 - info: host.tims-pi1 stopInstance system.adapter.shelly.0 killing pid 12292
                                          2023-07-03 23:38:25.661 - info: zigbee2mqtt.0 (4233) terminating
                                          2023-07-03 23:38:25.662 - info: zigbee2mqtt.0 (4233) Terminated (NO_ERROR): Without reason
                                          2023-07-03 23:38:25.674 - info: host.tims-pi1 instance system.adapter.mihome-vacuum.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.675 - info: host.tims-pi1 instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.675 - info: host.tims-pi1 instance system.adapter.wled.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.812 - info: host.tims-pi1 instance system.adapter.homepilot20.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.813 - info: host.tims-pi1 instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.815 - info: host.tims-pi1 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.920 - info: host.tims-pi1 instance system.adapter.yahka.1 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.922 - info: host.tims-pi1 instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.922 - info: host.tims-pi1 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:25.948 - info: host.tims-pi1 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.017 - info: host.tims-pi1 instance system.adapter.pushover.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.051 - info: host.tims-pi1 instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.116 - info: host.tims-pi1 instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.196 - info: zigbee2mqtt.0 (4233) terminating
                                          2023-07-03 23:38:26.198 - warn: zigbee2mqtt.0 (4233) Cannot get view: Connection is closed.
                                          2023-07-03 23:38:26.117 - info: host.tims-pi1 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.227 - info: host.tims-pi1 instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.228 - info: host.tims-pi1 instance system.adapter.daikin.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.229 - info: host.tims-pi1 instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.319 - info: host.tims-pi1 instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
                                          2023-07-03 23:38:26.320 - info: host.tims-pi1 instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                                          removed 97 packages, and changed 16 packages in 45s
                                          143 packages are looking for funding
                                            @ticaki Ok
                                            Ist die Befehlsreihenfolge da oben ernst? .. iobroker stoppen, dann starten, dann host rebooten (was ihn wieder stoppt und nach dem reboot startet) ??
                                            Weiterhin ist da slog hioer aber ein js.controller upgrade via Admin. Passt nicht ganz zum normalen Restart ...
                                            generell:
                                            Das DB Closed by Shelly beim Stoppen passieren kann ist "bekannt" und glaube ein issue offen. Da wird wohl was nicht sauber beendet.
                                            Der nächste Fehler tippe ich könnte von zigbee kommen der scheinbar nach dem stoppen versucht irgendwelche views zu lesen ... Bitte issue bei zigbee öffnen wenn nicht schon da ist.
                                            580
                                            185219
