    4. Test Adapter Bosch ebik connect / flow
    • Z
      Zec @Zec last edited by
      Ich habe Bosch angeschrieben, ob der Akkustand kurzfristig zum Onlineportal übertragen werden könnte.
      Folgende Antwort habe ich soeben erhalten:
      • bahnuhr
        @tombox
        seit heute im log:
        host.iobroker
        2023-06-06 21:08:05.472	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51)
        host.iobroker
        2023-06-06 21:08:05.471	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'replace')
        host.iobroker
        2023-06-06 21:08:05.470	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        bosch-ebike.0
        2023-06-06 21:08:04.273	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bosch-ebike.0
        2023-06-06 21:08:04.270	info	terminating
        bosch-ebike.0
        2023-06-06 21:08:04.228	error	Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-06 21:08:04.227	error	TypeError: Cannot read properties of undefined (reading 'replace') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:149:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
        bosch-ebike.0
        2023-06-06 21:08:04.218	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
        bosch-ebike.0
        2023-06-06 21:08:04.217	error	Unhandled promise rejection. This error originated either by throwing inside of an asyn
        Instanz bleibt rot.
        Ist ein Problem bekannt ?
        T draexler 2 Replies Last reply Reply Quote 0
          tombox @bahnuhr last edited by
          @bahnuhr singleKey Umstellung von Bosch müsste man anpassen
          bahnuhr 1 Reply Last reply Reply Quote 2
          • draexler
            draexler @bahnuhr last edited by
            @bahnuhr Schließe mich mal an
            • bahnuhr
              bahnuhr Forum Testing Most Active @tombox last edited by
              @tombox
              Bist du dran.
                @bahnuhr noch nicht habe erst in 1-2 Wochen zeit
                bahnuhr 2 Replies Last reply Reply Quote 1
                • bahnuhr
                  @tombox sagte in Test Adapter Bosch ebik connect / flow:
                  alles klar.
                  wenn ich helfen kann sag Bescheid
                  • bahnuhr
                    @tombox
                    konntest du schon etwas umsetzen ?
                      @bahnuhr Nein leider gerade keine zeit
                      • bahnuhr
                        @tombox
                        Guten Morgen,
                        sag mal Bescheid ob ich dich da irgendwie unterstützen kann.
                        mfg
                        Dieter
                        • I
                          IOMax last edited by
                          Ich freue mich auch schon darauf, wenn es wieder funktioniert. Ich teste auch gerne.
                            backfisch88 last edited by
                            gibts hierzu schon news?
                            • bahnuhr
                              Ist @tombox im Urlaub ?
                              oder krank?
                              oder kommt zu diesem Adapter momentan einfach nicht.
                              Hat da irgendwer Infos?
                                Bitte mal die github version testen ob der login für flow wieder geht
                                ste_glei bahnuhr 2 Replies Last reply Reply Quote 4
                                • ste_glei
                                  ste_glei @tombox last edited by
                                  funktioniert wieder
                                  danke
                                  • bahnuhr
                                    @tombox
                                    Danke, super klappt wieder.
                                      läuft wieder! besten dank!
                                      • Marco Stieg
                                        Marco Stieg last edited by
                                        Hallo zusammen.
                                        Hat schon jemand die Problematik gelöst, dass die Zeit in Bewegung immer eine Stunde zuviel ausgibt?
                                          Marcus007 last edited by
                                          Wird an dem Adapter noch was gemacht?
                                          Gruss Marcus
                                            tombox @Marcus007 last edited by
                                            @marcus007 ja bitte beta channel von iobroker verwenden
                                            draexler 1 Reply Last reply Reply Quote 0
                                            178
                                            32288
