    4. Zigbee Restart Loop Detected
      arteck Developer Most Active @HelmutLinner last edited by
      @helmutlinner
      nochmal von GIT installieren bitte..
        HelmutLinner @arteck last edited by
        @arteck ich hab bin auf version 1.8.10 zurück und hab dann von git nochmal 1.8.12 installiert.
        zigbee.0
        2023-07-03 08:21:10.566	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0
        2023-07-03 08:21:10.566	info	terminating
        zigbee.0
        2023-07-03 08:21:10.076	info	Zigbee: disabling joining new devices.
        zigbee.0
        2023-07-03 08:21:10.065	info	cleaned everything up...
        zigbee.0
        2023-07-03 08:21:10.063	error	mappedModel is not defined
        zigbee.0
        2023-07-03 08:21:10.063	error	ReferenceError: mappedModel is not defined at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:582:9) at processTicksAndRejections (node:internal/process/task_queues:96:5)
        zigbee.0
        2023-07-03 08:21:10.062	error	unhandled promise rejection: mappedModel is not defined
        zigbee.0
        2023-07-03 08:21:10.062	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        2023-07-03 08:21:10.060	error	No entity for 0x003c84fffea4cccd
        zigbee.0
        2023-07-03 08:21:10.058	error	No entity for 0x003c84fffeb142d1
        zigbee.0
        2023-07-03 08:21:06.887	info	Zigbee started
        zigbee.0
        2023-07-03 08:21:06.886	info	0x943469fffebad813 (addr 50679): TS0043 - TuYa Wireless switch with 3 buttons (EndDevice)
        zigbee.0
        2023-07-03 08:21:06.886	info	0x003c84fffe09bd3e (addr 7235): R7060 - Woox Smart garden irrigation control (EndDevice)
        zigbee.0
        2023-07-03 08:21:06.885	info	0x540f57fffe96bd40 (addr 36214): GL-G-003P - Gledopto 7W garden light pro (Router)
        zigbee.0
        2023-07-03 08:21:06.883	info	0x540f57fffe96bd34 (addr 33076): GL-G-003P - Gledopto 7W garden light pro (Router)
        zigbee.0
        2023-07-03 08:21:06.874	info	Currently 4 devices are joined:
        zigbee.0
        2023-07-03 08:21:06.854	info	--> transmitPower : normal
        zigbee.0
        2023-07-03 08:21:06.854	info	Unable to disable LED, unsupported function.
        zigbee.0
        2023-07-03 08:21:06.853	info	Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"8 ","revision":"6.7.8.0 build 373"}}
        zigbee.0
        2023-07-03 08:21:01.924	info	Installed Version: ioBroker/ioBroker.zigbee
        zigbee.0
        2023-07-03 08:21:01.626	info	Starting Zigbee npm ...
        zigbee.0
        2023-07-03 08:21:01.625	info	delete old Backup files. keep only last 10
        zigbee.0
        2023-07-03 08:21:01.541	info	starting. Version 1.8.12 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.24
        zigbee.0
        2023-07-03 08:21:00.980	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          arteck Developer Most Active @HelmutLinner last edited by arteck
          @helmutlinner brauchst nicht zurück...
          du kannst direkt immer überklatschen..
          nochmal bitte von GIT..da ist ein Gerät der mucken macht
            @arteck jetzt siehts viel besser aus
            Jetzt stürzt er nicht mehr ab.
            Ich finde allerdings das Devise 0x84b4dbfffee344a4 das er als Fehler ausgibt nicht in der Übersicht.
            zigbee.0
            2023-07-03 08:38:37.795	info	List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
            zigbee.0
            2023-07-03 08:38:30.436	error	Device 0x84b4dbfffee344a4 "undefined" not described in statesMapping.
            zigbee.0
            2023-07-03 08:38:00.839	info	deregister device Ping for deactivated device "0x540f57fffe96bd34"
            zigbee.0
            2023-07-03 08:38:00.804	warn	download icon from https://www.zigbee2mqtt.io/images/devices/GL-G-003P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/GL-G-003P.png
            zigbee.0
            2023-07-03 08:38:00.799	warn	download icon from https://www.zigbee2mqtt.io/images/devices/GL-G-003P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/GL-G-003P.png
            zigbee.0
            2023-07-03 08:38:00.797	info	Zigbee started
            zigbee.0
            2023-07-03 08:38:00.797	info	0x943469fffebad813 (addr 50679): TS0043 - TuYa Wireless switch with 3 buttons (EndDevice)
            zigbee.0
            2023-07-03 08:38:00.795	info	0x003c84fffe09bd3e (addr 7235): R7060 - Woox Smart garden irrigation control (EndDevice)
            zigbee.0
            2023-07-03 08:38:00.795	info	0x540f57fffe96bd40 (addr 36214): GL-G-003P - Gledopto 7W garden light pro (Router)
            zigbee.0
            2023-07-03 08:38:00.792	info	0x540f57fffe96bd34 (addr 33076): GL-G-003P - Gledopto 7W garden light pro (Router)
            zigbee.0
            2023-07-03 08:38:00.768	info	Currently 4 devices are joined:
            zigbee.0
            2023-07-03 08:38:00.711	info	--> transmitPower : normal
            zigbee.0
            2023-07-03 08:38:00.710	info	Unable to disable LED, unsupported function.
            zigbee.0
            2023-07-03 08:38:00.710	info	Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"8 ","revision":"6.7.8.0 build 373"}}
              @helmutlinner sagte in Zigbee Restart Loop Detected:
              0x84b4dbfffee344a4
              und das ist dein Problem.. schaumal in die /opt/iobroker/iobroker-data/zigbee_0/shepherd.db da wird das Gerät noch da sein
              müsstest manuell löschen..
              oder poste die hier dann mach ich es
                HelmutLinner last edited by HelmutLinner
                @arteck
                das steht in der shepherd.db
                {"id":1,"type":"Coordinator","ieeeAddr":"0x84b4dbfffee344a4","nwkAddr":0,"manufId":0,"epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":48879,"inClusterList":[0,3,6,10,25,26,768],"outClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":true,"meta":{},"lastSeen":1688373790062,"defaultSendRequestWhen":"immediate"}
                {"id":2,"type":"Group","groupID":3,"members":[],"meta":{}}
                {"id":3,"type":"Group","groupID":2,"members":[],"meta":{}}
                {"id":4,"type":"Router","ieeeAddr":"0x540f57fffe96bd34","nwkAddr":33076,"manufId":4687,"manufName":"GLEDOPTO","powerSource":"Mains (single phase)","modelId":"GL-G-003P","epList":[11,242],"endpoints":{"11":{"profId":260,"epId":11,"devId":269,"inClusterList":[0,3,4,5,6,8,768,4096],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"GL-G-003P","manufacturerName":"GLEDOPTO","powerSource":0,"zclVersion":3,"appVersion":0,"stackVersion":0,"hwVersion":2,"dateCode":"20221220","swBuildId":"11376801"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":158,"colorTempPhysicalMax":495}},"genOnOff":{"attributes":{"onOff":1}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":0,"stackVersion":0,"hwVersion":2,"dateCode":"20221220","swBuildId":"11376801","zclVersion":3,"interviewCompleted":true,"meta":{"configured":88764544},"lastSeen":1688373695063,"defaultSendRequestWhen":"immediate"}
                {"id":5,"type":"Group","groupID":1,"members":[],"meta":{}}
                {"id":6,"type":"Router","ieeeAddr":"0x540f57fffe96bd40","nwkAddr":36214,"manufId":4687,"manufName":"GLEDOPTO","powerSource":"Mains (single phase)","modelId":"GL-G-003P","epList":[11,242],"endpoints":{"11":{"profId":260,"epId":11,"devId":269,"inClusterList":[0,3,4,5,6,8,768,4096],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"GL-G-003P","manufacturerName":"GLEDOPTO","powerSource":0,"zclVersion":3,"appVersion":0,"stackVersion":0,"hwVersion":2,"dateCode":"20221220","swBuildId":"11376801"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":158,"colorTempPhysicalMax":495}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":0,"stackVersion":0,"hwVersion":2,"dateCode":"20221220","swBuildId":"11376801","zclVersion":3,"interviewCompleted":true,"meta":{"configured":88764544},"lastSeen":1688373696601,"defaultSendRequestWhen":"immediate"}
                {"id":7,"type":"EndDevice","ieeeAddr":"0x003c84fffe09bd3e","nwkAddr":7235,"manufId":4098,"manufName":"_TZ3210_eymunffl","powerSource":"Battery","modelId":"TS0101","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,4,5,6,61184,1],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65534":0,"modelId":"TS0101","manufacturerName":"_TZ3210_eymunffl","powerSource":3,"zclVersion":3,"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":""}},"genOnOff":{"attributes":{"onOff":0,"offWaitTime":0,"onTime":0}}},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":69,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1688368812322,"defaultSendRequestWhen":"immediate"}
                {"id":8,"type":"EndDevice","ieeeAddr":"0x943469fffebad813","nwkAddr":50679,"manufId":4098,"manufName":"_TZ3000_gbm10jnj","powerSource":"Battery","modelId":"TS0043","epList":[1,2,3],"endpoints":{"1":{"profId":260,"epId":1,"devId":0,"inClusterList":[0,1,6],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65503":"\u0000\u0000\u0000\u0000\u0012�<3,\u0012","65506":31,"65508":0,"65534":0,"modelId":"TS0043","manufacturerName":"_TZ3000_gbm10jnj","powerSource":3,"zclVersion":3,"stackVersion":0,"hwVersion":1,"dateCode":"","appVersion":66}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200,"batteryVoltage":30}}},"binds":[],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":0,"inClusterList":[1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"3":{"profId":260,"epId":3,"devId":0,"inClusterList":[1,6],"outClusterList":[],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":66,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":-708457359},"lastSeen":1688348249457,"defaultSendRequestWhen":"immediate"}
                Das sind die Zigbee Geräte dazu
                  @helmutlinner 84b4dbfffee344a4 ist der koordinator....ach das ist so ein ezsp..
                  muss ich mal schauen das der erkannt wird..
                  es knalt schon mal nicht ...das ist schon mal gut
                  kannst du mal den adapter auf debug stellen und im Log nach
                  publishFromState
                  suchen und mir mal posten
                    @arteck im log steht publishFromState : 3 group
                    Zeile 111
                    zigbee.0
                    2023-07-03 18:49:30.490	debug	convert result {"state":{"color_mode":"xy","color":{"x":"0.3697","y":"0.5729"}},"readAfterWriteTime":0}
                    zigbee.0
                    2023-07-03 18:49:30.490	debug	Missing colorTempPhysicalMin and/or colorTempPhysicalMax for group 3!
                    zigbee.0
                    2023-07-03 18:49:30.389	debug	UpdateState: missing device 84b4dbfffee344a4 null
                    zigbee.0
                    zigbee.0
                    2023-07-03 18:49:30.388	debug	UpdateState: missing device 84b4dbfffee344a4 null
                    zigbee.0
                    zigbee.0
                    2023-07-03 18:49:30.376	error	Device 0x84b4dbfffee344a4 "undefined" not described in statesMapping.
                    zigbee.0
                    2023-07-03 18:49:30.300	debug	Type commandMoveToColor device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coordinator","_ieeeAddr":"0x84b4dbfffee344a4","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":48879,"inputClusters":[0,3,6,10,25,26,768],"outputClusters":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1688402970298,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":255},"mapped":null,"name":"Coordinator"} incoming event: {"type":"commandMoveToColor","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coordinator","_ieeeAddr":"0x84b4dbfffee344a4","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":48879,"inputClusters":[0,3,6,10,25,26,768],"outputClusters":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1688402970298,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":255},"endpoint":"[Circular]","data":{"colorx":24228,"colory":37545,"transtime":0},"linkquality":255,"groupID":3,"cluster":"lightingColorCtrl","meta":{"zclTransactionSequenceNumber":6,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                    zigbee.0
                    2023-07-03 18:49:30.300	debug	Received Zigbee message from '0x84b4dbfffee344a4', type 'commandMoveToColor', cluster 'lightingColorCtrl', data '{"colorx":24228,"colory":37545,"transtime":0}' from endpoint 1 with groupID 3
                    zigbee.0
                    2023-07-03 18:49:30.298	debug	handleMessage. {"type":"commandMoveToColor","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coordinator","_ieeeAddr":"0x84b4dbfffee344a4","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":48879,"inputClusters":[0,3,6,10,25,26,768],"outputClusters":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x84b4dbfffee344a4","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1688402970298,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":255},"endpoint":"[Circular]","data":{"colorx":24228,"colory":37545,"transtime":0},"linkquality":255,"groupID":3,"cluster":"lightingColorCtrl","meta":{"zclTransactionSequenceNumber":6,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                    zigbee.0
                    2023-07-03 18:49:30.298	debug	zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":6,"manufacturerCode":null,"commandIdentifier":7},"Payload":{"colorx":24228,"colory":37545,"transtime":0},"Command":{"ID":7,"parameters":[{"name":"colorx","type":33},{"name":"colory","type":33},{"name":"transtime","type":33}],"name":"moveToColor"}},"address":0,"endpoint":1,"linkquality":255,"groupID":3,"wasBroadcast":false,"destinationEndpoint":255}'
                    zigbee.0
                    2023-07-03 18:49:30.296	debug	zigbee-herdsman:adapter:ezsp:debg processMessage: {"messageType":3,"apsFrame":{"profileId":260,"clusterId":768,"sourceEndpoint":1,"destinationEndpoint":255,"options":256,"groupId":3,"sequence":219},"lqi":255,"rssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[17,6,7,164,94,169,146,0,0]}}
                    zigbee.0
                    2023-07-03 18:49:30.295	debug	zigbee-herdsman:adapter:ezsp:ezsp <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":3,"apsFrame":{"profileId":260,"clusterId":768,"sourceEndpoint":1,"destinationEndpoint":255,"options":256,"groupId":3,"sequence":219},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[17,6,7,164,94,169,146,0,0]}}
                    zigbee.0
                    2023-07-03 18:49:30.295	debug	zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 4490014500030401000301ff00010300dbff000000ffff09110607a45ea9920000
                    zigbee.0
                    2023-07-03 18:49:30.295	debug	zigbee-herdsman:adapter:ezsp:uart --> [83401b7e]
                    zigbee.0
                    2023-07-03 18:49:30.295	debug	zigbee-herdsman:adapter:ezsp:uart --> ACK (3)
                    zigbee.0
                    2023-07-03 18:49:30.295	debug	zigbee-herdsman:adapter:ezsp:uart <-- DATA (2,5,0): 2506b1a9112a16b6589449245555934a9c95d8abedce9874f4d7658e58209635ebcdd56f7e
                    zigbee.0
                    2023-07-03 18:49:30.294	debug	zigbee-herdsman:adapter:ezsp:uart <-- [9449245555934a9c95d8abedce9874f4d7658e58209635ebcdd56f7e]
                    zigbee.0
                    2023-07-03 18:49:30.290	debug	zigbee-herdsman:adapter:ezsp:uart <-- [2506b1a97d312a16b658]
                    zigbee.0
                    2023-07-03 18:49:30.289	debug	zigbee-herdsman:adapter:ezsp:uart -+- waiting (5) success
                    zigbee.0
                    2023-07-03 18:49:30.288	debug	zigbee-herdsman:adapter:ezsp:ezsp <== 0x38: {"_cls_":"sendMulticast","_id_":56,"_isRequest_":false,"status":0,"sequence":219}
                    zigbee.0
                    2023-07-03 18:49:30.288	debug	zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 448001380000db
                    zigbee.0
                    2023-07-03 18:49:30.288	debug	zigbee-herdsman:adapter:ezsp:uart --> [82503a7e]
                    zigbee.0
                    2023-07-03 18:49:30.288	debug	zigbee-herdsman:adapter:ezsp:uart --> ACK (2)
                    zigbee.0
                    2023-07-03 18:49:30.287	debug	zigbee-herdsman:adapter:ezsp:uart <-- DATA (1,5,0): 1506a1a96c2a1569956f7e
                    zigbee.0
                    2023-07-03 18:49:30.287	debug	zigbee-herdsman:adapter:ezsp:uart <-- [1506a1a96c2a1569956f7e]
                    zigbee.0
                    2023-07-03 18:49:30.233	debug	zigbee-herdsman:adapter:ezsp:uart -?- waiting (5)
                    zigbee.0
                    2023-07-03 18:49:30.233	debug	zigbee-herdsman:adapter:ezsp:uart --> [410621a96c2a7d31b359974b24aa549149904e24a6e4df618c5998ca1bfc7d5e08517e]
                    zigbee.0
                    2023-07-03 18:49:30.233	debug	zigbee-herdsman:adapter:ezsp:uart --> DATA (4,1,0): 4400013800040100030101000103000c00030d09110607a45ea9920000
                    zigbee.0
                    2023-07-03 18:49:30.232	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"sendMulticast","_id_":56,"_isRequest_":true,"apsFrame":{"clusterId":768,"profileId":260,"sequence":12,"sourceEndpoint":1,"destinationEndpoint":1,"groupId":3,"options":256},"hops":0,"nonmemberRadius":3,"messageTag":13,"message":{"type":"Buffer","data":[17,6,7,164,94,169,146,0,0]}}
                    zigbee.0
                    2023-07-03 18:49:30.232	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> sendMulticast: {"apsFrame":{"clusterId":768,"profileId":260,"sequence":12,"sourceEndpoint":1,"destinationEndpoint":1,"groupId":3,"options":256},"hops":0,"nonmemberRadius":3,"messageTag":13,"message":{"type":"Buffer","data":[17,6,7,164,94,169,146,0,0]}}
                    zigbee.0
                    2023-07-03 18:49:30.230	debug	zigbee-herdsman:controller:group Command 3 lightingColorCtrl.moveToColor({"transtime":0,"colorx":24228,"colory":37545})
                    zigbee.0
                    2023-07-03 18:49:30.228	debug	target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"databaseID":2,"groupID":3,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp","color_temp_percent"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_startup"]}],"model":"group"}
                    zigbee.0
                    2023-07-03 18:49:30.228	debug	convert color, {"x":"0.3697","y":"0.5729"}, {"state":false,"transition":0}
                    zigbee.0
                    2023-07-03 18:49:30.228	debug	Mapped Model: {"_events":{},"_eventsCount":0,"_maxListeners":100,"databaseID":2,"groupID":3,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp","color_temp_percent"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_startup"]}],"model":"group"}
                    zigbee.0
                    2023-07-03 18:49:30.228	debug	entity: 3 group {"type":"group","mapped":{"_events":{},"_eventsCount":0,"_maxListeners":100,"databaseID":2,"groupID":3,"_members":{},"meta":{},"toZigbee":[{"key":["state","brightness","brightness_percent","on_time"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp","color_temp_percent"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color"],"options":[{"type":"binary","name":"color_sync","property":"color_sync","access":2,"value_on":true,"value_off":false,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true)."},{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},null,{"key":["transition"],"attr":[]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"type":"numeric","name":"transition","property":"transition","access":2,"value_min":0,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition)."}]},{"key":["color_temp_startup"]}],"model":"group"},"group":"[Circular]","name":"Group 3"}
                    zigbee.0
                    2023-07-03 18:49:30.227	debug	publishFromState : 3 group
                    zigbee.0
                    2023-07-03 18:49:30.227	debug	Change state 'color' at device 3 type 'group'
                    zigbee.0
                    2023-07-03 18:49:30.183	debug	State Change detected on deactivated Device - ignored
                    zigbee.0
                    2023-07-03 18:49:30.181	debug	State Change detected on deactivated Device - ignored
                    zigbee.0
                    2023-07-03 18:49:30.176	debug	User stateChange zigbee.0.group_3.color {"val":"#bff125","ack":false,"ts":1688402970015,"q":0,"c":"script.js.common.Test.Zigbee_Farbwechsel_Test","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1688402970015}
                    zigbee.0
                    2023-07-03 18:49:30.174	debug	User stateChange zigbee.0.003c84fffea4cccd.color {"val":"#705230","ack":false,"ts":1688402970015,"q":0,"c":"script.js.common.Test.Zigbee_Farbwechsel_Test","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1688402970015}
                    zigbee.0
                    2023-07-03 18:49:30.173	debug	User stateChange zigbee.0.003c84fffeb142d1.color {"val":"#583bed","ack":false,"ts":1688402970015,"q":0,"c":"script.js.common.Test.Zigbee_Farbwechsel_Test","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1688402970015}
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:uart -+- waiting (4) success
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:ezsp <== 0x5: {"_cls_":"nop","_id_":5,"_isRequest_":false}
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 4380010500
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:uart --> [8160597e]
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:uart --> ACK (1)
                    zigbee.0
                    2023-07-03 18:49:24.662	debug	zigbee-herdsman:adapter:ezsp:uart <-- DATA (0,4,0): 0401a1a9512aa5897e
                    zigbee.0
                    2023-07-03 18:49:24.661	debug	zigbee-herdsman:adapter:ezsp:uart <-- [0401a1a9512aa5897e]
                    zigbee.0
                    2023-07-03 18:49:24.648	debug	zigbee-herdsman:adapter:ezsp:uart -?- waiting (4)
                    zigbee.0
                    2023-07-03 18:49:24.647	debug	zigbee-herdsman:adapter:ezsp:uart --> [300121a9512a519c7e]
                    zigbee.0
                    2023-07-03 18:49:24.647	debug	zigbee-herdsman:adapter:ezsp:uart --> DATA (3,0,0): 4300010500
                    zigbee.0
                    2023-07-03 18:49:24.647	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"nop","_id_":5,"_isRequest_":true}
                    zigbee.0
                    2023-07-03 18:49:24.647	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> nop: null
                    zigbee.0
                    2023-07-03 18:49:24.646	debug	zigbee-herdsman:adapter:ezsp:ezsp Time to watchdog ... 0
                    zigbee.0
                    2023-07-03 18:49:21.152	debug	zigbee-herdsman:adapter:ezsp:cast Set MulticastTableEntry #6 for 3 multicast id: 0
                    zigbee.0
                    2023-07-03 18:49:21.151	debug	zigbee-herdsman:adapter:ezsp:uart -+- waiting (3) success
                    zigbee.0
                    2023-07-03 18:49:21.151	debug	zigbee-herdsman:adapter:ezsp:ezsp <== 0x64: {"_cls_":"setMulticastTableEntry","_id_":100,"_isRequest_":false,"status":0}
                    zigbee.0
                    2023-07-03 18:49:21.151	debug	zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 428001640000
                    zigbee.0
                    2023-07-03 18:49:21.151	debug	zigbee-herdsman:adapter:ezsp:uart --> [8070787e]
                    zigbee.0
                    2023-07-03 18:49:21.150	debug	zigbee-herdsman:adapter:ezsp:uart --> ACK (0)
                    zigbee.0
                    2023-07-03 18:49:21.150	debug	zigbee-herdsman:adapter:ezsp:uart <-- DATA (7,3,0): 7300a1a9302a155a057e
                    zigbee.0
                    2023-07-03 18:49:21.150	debug	zigbee-herdsman:adapter:ezsp:uart <-- [2a155a057e]
                    zigbee.0
                    2023-07-03 18:49:21.149	debug	zigbee-herdsman:adapter:ezsp:uart <-- [7300a1a930]
                    zigbee.0
                    2023-07-03 18:49:21.098	debug	zigbee-herdsman:adapter:ezsp:uart -?- waiting (3)
                    zigbee.0
                    2023-07-03 18:49:21.098	debug	zigbee-herdsman:adapter:ezsp:uart --> [270021a9302a7d33b159954a8d527e]
                    zigbee.0
                    2023-07-03 18:49:21.098	debug	zigbee-herdsman:adapter:ezsp:uart --> DATA (2,7,0): 42000164000603000100
                    zigbee.0
                    2023-07-03 18:49:21.097	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"setMulticastTableEntry","_id_":100,"_isRequest_":true,"index":6,"value":{"endpoint":1,"multicastId":3,"networkIndex":0}}
                    zigbee.0
                    2023-07-03 18:49:21.097	debug	zigbee-herdsman:adapter:ezsp:ezsp ==> setMulticastTableEntry: {"index":6,"value":{"endpoint":1,"multicastId":3,"networkIndex":0}}
                    zigbee.0
                    2023-07-03 18:49:21.097	debug	zigbee-herdsman:adapter:ezsp:ezsp <== 0x3f: {"_cls_":"messageSentHandler","_id_":63,"_isRequest_":false,"type":3,"indexOrDestination":65533,"apsFrame":{"profileId":260,"clusterId":768,"sourceEndpoint":1,"destinationEndpoint":255,"options":256,"groupId":3,"sequence":218},"messageTag":12,"status":0,"message":{"type":"Buffer","data":[]}}
                    zigbee.0
                    2023-07-03 18:49:21.097	debug	zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 4190013f0003fdff0401000301ff00010300da0c0000
                    zigbee.0
                    2023-07-03 18:49:21.096	debug	zigbee-herdsman:adapter:ezsp:uart --> [87009f7e]
                    zigbee.0
                    2023-07-03 18:49:21.096	debug	zigbee-herdsman:adapter:ezsp:uart --> ACK (7)
                    zigbee.0
                    2023-07-03 18:49:21.096	debug	zigbee-herdsman:adapter:ezsp:uart <-- DATA (6,2,0): 6203b1a96b2a164fa6904b25a9546d499d4d2771e1ce67ad917e
                    zigbee.0
                    2023-07-03 18:49:21.096	debug	zigbee-herdsman:adapter:ezsp:uart <-- [6b2a164fa6904b25a9546d499d4d2771e1ce67ad917e]
                    zigbee.0
                    2023-07-03 18:49:21.095	debug	zigbee-herdsman:adapter:ezsp:uart <-- [6203b1a9]
                      group
                      die Meldung muss öffters kommen..
                        HelmutLinner @arteck last edited by HelmutLinner
                        @arteck ich hab die einige Male bekommen und jedes Mal stand publishFromState : 3 group
                        wenn ich nach publishfromstate filtere im log kommt:
                        zigbee.0
                        2023-07-05 13:42:20.041	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:42:10.065	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:42:00.583	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:50.072	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:40.083	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:30.593	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:20.026	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:10.045	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:41:00.287	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:50.737	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:40.033	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:30.093	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:20.081	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:10.070	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:40:00.159	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:39:50.037	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:39:40.040	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:39:30.243	debug	publishFromState : 3 group
                        zigbee.0
                        2023-07-05 13:39:20.025	debug	publishFromState : 3 group
                          @arteck
                          die Meldung kommt öfter aber immer gleicher text
                          1003
