    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Homoran Global Moderator Administrators @bfelizardo last edited by
      @bfelizardo sagte in Troubleshooting NodeJS update:
      Steckt ja recht viel Info drin
      die würden wir auch gerne sehen
      in den letzten Zeilen wir das letzte log mit ausgegeben. Dort natürlich private Daten "schwärzen"
      bfelizardo 1 Reply Last reply Reply Quote 0
      • bfelizardo
        bfelizardo @Homoran last edited by
        @homoran @thomas-braun
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID:	Raspbian
        Description:	Raspbian GNU/Linux 10 (buster)
        Release:	10
        Codename:	buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         11:33:00 up 22 min,  1 user,  load average: 1.25, 1.44, 1.36
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=54.5'C
        volt=0.8500V
        *** Time and Time Zones ***
                       Local time: Wed 2023-07-05 11:33:00 CEST
                   Universal time: Wed 2023-07-05 09:33:00 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.9G        1.5G        5.7G        8.0M        679M        6.1G
        Swap:           99M          0B         99M
        Total:         8.0G        1.5G        5.8G
                 7875 M total memory
                 1477 M used memory
                  266 M active memory
                 1770 M inactive memory
                 5717 M free memory
                  103 M buffer memory
                  576 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.2G   22G  23% /
        devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
        [Wed Jul  5 11:10:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:2E:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=634d01a8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Wed Jul  5 11:10:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Jul  5 11:10:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Jul  5 11:10:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems (real ones only):
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        562M	/var/
        367M	/var/cache
        362M	/var/cache/apt
        303M	/var/cache/apt/archives
        92M	/var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        358M	/opt/iobroker/backups/
        1.5M	/opt/iobroker/backups/old
        /opt/iobroker/iobroker-data:
        1.3G	/opt/iobroker/iobroker-data/
        342M	/opt/iobroker/iobroker-data/history
        248M	/opt/iobroker/iobroker-data/backup-objects
        231M	/opt/iobroker/iobroker-data/files
        210M	/opt/iobroker/iobroker-data/sonosCache
        149M	/opt/iobroker/iobroker-data/states.jsonl
        31M	/opt/iobroker/iobroker-data/objects.jsonl
        19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        15M	/opt/iobroker/iobroker-data/objects.json.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.16.1
        /usr/bin/node 		v18.16.1
        /usr/bin/npm 		9.7.2
        /usr/bin/npx 		9.7.2
        nodejs:
          Installed: 18.16.1-deb-1nodesource1
          Candidate: 18.16.1-deb-1nodesource1
          Version table:
         *** 18.16.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	6.1.4
        Adapters from github: 	1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
          system.adapter.apple-find-me.1          : apple-find-me         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: ????
          system.adapter.nightscout.0             : nightscout            : iobroker                                 - disabled, port: ????, bind: 0.0.0.0
          system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: ????, bind: 192.168.?.?
          system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
          system.adapter.pushover.1               : pushover              : iobroker                                 - disabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
          system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
        + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
        + system.adapter.withings.0               : withings              : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: ????
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
        Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
        Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
        Adapter    "synochat"     : 1.2.1    , installed 1.2.1
        Adapter    "telegram"     : 1.15.6   , installed 1.15.6
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects: 	38519
        States: 	35458
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 186
        *** Listening Ports ***
        tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       18478      741/io.hm-rpc.1
        tcp        0      0 0.0.0.0:????            0.0.0.0:*               LISTEN      1001       17969      781/io.sonoff.0
        tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       17664      572/iobroker.js-con
        tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       16178      572/iobroker.js-con
        tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       17223      734/io.hm-rpc.0
        tcp        0      0 0.0.0.0:????              0.0.0.0:*               LISTEN      0          17652      578/sshd
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       19609      1040/io.simple-api.
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       18324      1029/io.lovelace.0
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       17996      809/io.sonos.0
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       16255      604/io.admin.0
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       19745      1081/io.web.0
        tcp6       0      0 :::????                 :::*                    LISTEN      1001       20529      1051/io.socketio.0
        tcp6       0      0 :::????                   :::*                    LISTEN      0          17654      578/sshd
        udp        0      0 0.0.0.0:????            0.0.0.0:*                           108        14581      365/avahi-daemon: r
        udp        0      0 0.0.0.0:????           0.0.0.0:*                           108        14583      365/avahi-daemon: r
        udp        0      0 0.0.0.0:????              0.0.0.0:*                           0          15820      569/dhcpcd
        udp        0      0 0.0.0.0:????           0.0.0.0:*                           1001       18510      771/io.mihome-vacuu
        udp6       0      0 :::????                :::*                                108        14584      365/avahi-daemon: r
        udp6       0      0 :::????                 :::*                                108        14582      365/avahi-daemon: r
        2023-07-05 11:16:06.395  - info: alexa2.0 (708) Subscribing to states...
        2023-07-05 11:16:06.648  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
        2023-07-05 11:16:06.666  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
        2023-07-05 11:16:06.671  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.
        2023-07-05 11:16:06.680  - error: daswetter.0 (1720) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.]
        2023-07-05 11:16:06.683  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.uv_index_value": Connection is closed.
        2023-07-05 11:16:06.706  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
        2023-07-05 11:16:08.594  - info: alexa2.0 (708) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-07-05 11:16:31.896  - info: fb-checkpresence.0 (1107) createFbDeviceObjects finished successfully
        2023-07-05 11:16:31.900  - info: fb-checkpresence.0 (1107) states successfully subscribed
        2023-07-05 11:16:31.903  - info: fb-checkpresence.0 (1107) loop successfully started
        2023-07-05 11:16:41.826  - info: alexa2.0 (708) Initialization Done ...
        2023-07-05 11:28:24.018  - info: sonoff.0 (781) Client [XXXX] connection closed: Error: read ECONNRESET
        2023-07-05 11:28:31.614  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
        2023-07-05 11:30:00.129  - info: host.iobroker instance system.adapter.daswetter.0 started with pid ????
        2023-07-05 11:30:03.763  - info: daswetter.0 (3111) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-07-05 11:30:04.120  - info: daswetter.0 (3111) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
        2023-07-05 11:30:27.051  - info: daswetter.0 (3111) still wrong data structure from server received! repaired...
        2023-07-05 11:30:33.154  - info: daswetter.0 (3111) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-07-05 11:30:33.678  - info: daswetter.0 (3111) cleaned everything up...
        2023-07-05 11:30:33.705  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-07-05 11:33:50.597  - info: sonoff.0 (781) Client [XXXX] connection closed: closed
        2023-07-05 11:34:07.677  - info: admin.0 (604) ==> Connected system.user.???? from ::ffff:192.168.?.?
        2023-07-05 11:34:36.056  - info: host.iobroker iobroker upgrade javascript@7.0.3 --debug
        2023-07-05 11:34:38.784  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
        iob diag has finished.
        Press any key for a summary
        crunchip Homoran 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @bfelizardo last edited by crunchip
          @bfelizardo was stimmt da mit deinen Ports nicht?
          außerdem ist buster überfällig
            @crunchip sagte in Troubleshooting NodeJS update:
            und das auch noch ungepflegt
            • bfelizardo
              bfelizardo @crunchip last edited by
              @crunchip
              habe die Port "geschwärzt".
              @crunchip + @Homoran
              Danke für eure Rückmeldung. Da mit dem Update von Buster etc. verstehe ich, aber ist das die Ursache für mein Problem?
              Homoran crunchip 3 Replies Last reply Reply Quote 0
                und wie sollen wir dann z.B. doppelt belegte oder falsche ports erkennen?
                  wie kommt man denn auf so eine Idee, die Ausgabe ist doch dafür da um Fehler zu finden
                  möglicherweise ja
                    hast du tatsächlich von
                    node.js 12.x
                    direkt auf 18 hochgezogen?
                    • bfelizardo
                      @homoran @crunchip
                      sorry mit den Ports, war mir unsicher was ich hier alles öffentlich machen soll.
                      @Homoran ich habe von 14.x auf 18.x hochgezogen.
                      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                        @bfelizardo ok, sollte an und für sich funktionieren von 14 auf 18
                        allerdings aufgrund deiner ungepflegten updates wohl nicht
                        aktuelles OS neu installieren und backup vom iobroker zurückspielen würde ich vorschlagen
                        • bfelizardo
                          @crunchip said in Troubleshooting NodeJS update:
                          ok danke. Werde ich ausprobieren!
                            Thomas Braun Most Active @bfelizardo last edited by Thomas Braun
                            Alles.
                            Zumindest bei npm hast du aber noch händisch herumgefummelt. Die Version passt nicht zum nodejs.
                            iob stop
                            sudo install --reinstall nodejs
                            iob start
                            ausführen.
                            Besser aber das System kompett neu aufsetzen, auf 'Bullseye' 64bit 'Lite'.
                              apollon77 @bfelizardo last edited by
                              npm ERR! notsup Required: {"node":"^12.16.1 || ^10.15.2 || ^8.15.1","npm":"^6.4.1"}npm ERR! notsup Actual: {"npm":"9.7.2","node":"v18.16.1"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-05T08_46_11_943Z-debug-0.log
                              liess ggf mal in dem genannten Logfile - vllt steht da welches paket es bei dir auslöst
                                Stadtschloss last edited by Stadtschloss
                                ich kann leider kein apt-get update machen. Ich erhalte folgenden Fehler:
                                apt-get update
                                Err:1 https://deb.nodesource.com/node_18.x bullseye InRelease
                                  Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                                Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                Hit:3 http://security.debian.org bullseye-security InRelease
                                Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
                                Reading package lists... Done
                                W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease  Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                node --version
                                v18.15.0
                                Was kann ich hier tun?
                                Danke!
                                EDIT:
                                Mein Adblocker blockiert die URL. Problem gelöst 🙂
                                  centrofly last edited by centrofly
                                  Post gelöscht, hat sich auf wundersame Weise selbst geheilt...
                                    Creatorhs last edited by Creatorhs
                                    ich habe leider Probleme nodejs upzudaten.
                                    Ich konnte noch iob stop eingeben und - vermutlich - die alte nodejs Version löschen. Wobei auch schon hier nicht genau die Ausgabe kam, wie im best practice Artikel.
                                    Ich habe dann noch versucht das Repository herunterzuladen und erscheint dann folgende Fehlermeldung:
                                    + apt-get update
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Ign:3 https://packages.grafana.com/oss/deb stable InRelease
                                    OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                    Fehl:5 https://packages.grafana.com/oss/deb stable Release
                                      Certificate verification failed: The certificate is NOT trusted. The certifica        te chain uses expired certificate.  Could not handshake: Error in the certificat        e verification. [IP: 2a04:4e42:6f::729 443]
                                    E: Das Depot »https://packages.grafana.com/oss/deb stable Release« enthält keine        Release-Datei mehr.
                                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur        chgeführt werden, daher ist es standardmäßig deaktiviert.
                                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur        ation finden Sie in der Handbuchseite apt-secure(8).
                                    Error executing command, exiting
                                    Danach geht nichts mehr mit der bisher aufgespielten Version 14, da diese ja weg ich.
                                    Ich habe dann noch versucht "irgendeine" Nodejs zu installieren, was vermutlich der Fehler war:
                                    sudo apt install -y nodejs
                                    jetzt ist die ganz alte Version 12 drauf und zB Javaskript startet nicht mehr.
                                    Kann mir jemand helfen? Ich hab keine Ahnung, wie ich weitermachen soll. Backups sind auf googledrive vorhanden. Wenn ich ganz ehrlich bin bräuchte ich hier auch Hilfe um die wieder einzuspielen.
                                    edit: auch weitere Instanzen, wie zB shelly, tankerkönig, fb-checkpresence, gehen nicht mehr. Ich vermute, da die V12 zu alt ist?!
                                    Creator
                                      crunchip Forum Testing Most Active @Creatorhs last edited by crunchip
                                      @creatorhs sagte in Troubleshooting NodeJS update:
                                      und wie hast du die da rein gebracht, denn in deinem repo steht noch
                                      grafana korrigieren
                                      debian buster
                                      https://www.debian.org/releases/
                                      um deine probleme zu beseitigen, findest du die Lösungen hier https://forum.iobroker.net/user/thomas-braun
                                        Creatorhs @crunchip last edited by Creatorhs
                                        grafana korrigieren
                                        debian buster
                                        Danke für deine schnelle Antwort!
                                        Wie ich die reingebracht habe?! Durch das letzte Update, habe mich an die Artikel hier gehalten. Hatte nur vorhin unter "Hosts" die V14 gesehen, daher meine Aussage. Weiß nicht mehr sicher, welches das letzte Update war, ist schon etwas her...
                                        Grafana korrigieren: Wie?
                                        mit dem letzten Link, den du geschrieben hattest: Was möchtest du mir dort zeigen?
                                        Danke für die Hilfe.
                                        EDIT: Danke, lese mir die links durch...
                                          da stehn alle Threads( die oberen) zu deinen Problemen
                                          an welche? dann würde ja keine v12 drin stehen
                                            Thomas Braun Most Active @Creatorhs last edited by
                                            @creatorhs
                                            Bzgl. nodejs kannst du auch probieren mit der aktuellen Beta vom iob_diag-Skript das gerade ziehen zu lassen.
                                            Nutzt dir aber nix bei den anderen Dingen, die da bei dir im Argen liegen.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143726
