    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
    • bfelizardo
      bfelizardo @Homoran last edited by
      @homoran @thomas-braun
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 10 (buster)
      Release:	10
      Codename:	buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       11:33:00 up 22 min,  1 user,  load average: 1.25, 1.44, 1.36
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=54.5'C
      volt=0.8500V
      *** Time and Time Zones ***
                     Local time: Wed 2023-07-05 11:33:00 CEST
                 Universal time: Wed 2023-07-05 09:33:00 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:           7.9G        1.5G        5.7G        8.0M        679M        6.1G
      Swap:           99M          0B         99M
      Total:         8.0G        1.5G        5.8G
               7875 M total memory
               1477 M used memory
                266 M active memory
               1770 M inactive memory
               5717 M free memory
                103 M buffer memory
                576 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.2G   22G  23% /
      devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
      [Wed Jul  5 11:10:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:2E:40 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=634d01a8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Wed Jul  5 11:10:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Jul  5 11:10:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Jul  5 11:10:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      562M	/var/
      367M	/var/cache
      362M	/var/cache/apt
      303M	/var/cache/apt/archives
      92M	/var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      358M	/opt/iobroker/backups/
      1.5M	/opt/iobroker/backups/old
      /opt/iobroker/iobroker-data:
      1.3G	/opt/iobroker/iobroker-data/
      342M	/opt/iobroker/iobroker-data/history
      248M	/opt/iobroker/iobroker-data/backup-objects
      231M	/opt/iobroker/iobroker-data/files
      210M	/opt/iobroker/iobroker-data/sonosCache
      149M	/opt/iobroker/iobroker-data/states.jsonl
      31M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      15M	/opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.16.1
      /usr/bin/node 		v18.16.1
      /usr/bin/npm 		9.7.2
      /usr/bin/npx 		9.7.2
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	1
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled
        system.adapter.apple-find-me.1          : apple-find-me         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: ????
        system.adapter.nightscout.0             : nightscout            : iobroker                                 - disabled, port: ????, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: ????, bind: 192.168.?.?
        system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
        system.adapter.pushover.1               : pushover              : iobroker                                 - disabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
        system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0, run as: ????
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: ????, bind: 0.0.0.0 (SSL), run as: ????
      + system.adapter.withings.0               : withings              : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: ????
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.16 [Updatable]
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "synochat"     : 1.2.1    , installed 1.2.1
      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects: 	38519
      States: 	35458
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
      Reading package lists...
      Pending Updates: 186
      *** Listening Ports ***
      tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       18478      741/io.hm-rpc.1
      tcp        0      0 0.0.0.0:????            0.0.0.0:*               LISTEN      1001       17969      781/io.sonoff.0
      tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       17664      572/iobroker.js-con
      tcp        0      0 127.0.0.1:????          0.0.0.0:*               LISTEN      1001       16178      572/iobroker.js-con
      tcp        0      0 192.168.?.?:????   0.0.0.0:*               LISTEN      1001       17223      734/io.hm-rpc.0
      tcp        0      0 0.0.0.0:????              0.0.0.0:*               LISTEN      0          17652      578/sshd
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       19609      1040/io.simple-api.
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       18324      1029/io.lovelace.0
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       17996      809/io.sonos.0
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       16255      604/io.admin.0
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       19745      1081/io.web.0
      tcp6       0      0 :::????                 :::*                    LISTEN      1001       20529      1051/io.socketio.0
      tcp6       0      0 :::????                   :::*                    LISTEN      0          17654      578/sshd
      udp        0      0 0.0.0.0:????            0.0.0.0:*                           108        14581      365/avahi-daemon: r
      udp        0      0 0.0.0.0:????           0.0.0.0:*                           108        14583      365/avahi-daemon: r
      udp        0      0 0.0.0.0:????              0.0.0.0:*                           0          15820      569/dhcpcd
      udp        0      0 0.0.0.0:????           0.0.0.0:*                           1001       18510      771/io.mihome-vacuu
      udp6       0      0 :::????                :::*                                108        14584      365/avahi-daemon: r
      udp6       0      0 :::????                 :::*                                108        14582      365/avahi-daemon: r
      2023-07-05 11:16:06.395  - info: alexa2.0 (708) Subscribing to states...
      2023-07-05 11:16:06.648  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
      2023-07-05 11:16:06.666  - error: daswetter.0 (1720) exception in await insertIntoList [Error: DB closed]
      2023-07-05 11:16:06.671  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.
      2023-07-05 11:16:06.680  - error: daswetter.0 (1720) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.snowline_value": Connection is closed.]
      2023-07-05 11:16:06.683  - error: daswetter.0 (1720) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_5.Hour_6.uv_index_value": Connection is closed.
      2023-07-05 11:16:06.706  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
      2023-07-05 11:16:08.594  - info: alexa2.0 (708) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-07-05 11:16:31.896  - info: fb-checkpresence.0 (1107) createFbDeviceObjects finished successfully
      2023-07-05 11:16:31.900  - info: fb-checkpresence.0 (1107) states successfully subscribed
      2023-07-05 11:16:31.903  - info: fb-checkpresence.0 (1107) loop successfully started
      2023-07-05 11:16:41.826  - info: alexa2.0 (708) Initialization Done ...
      2023-07-05 11:28:24.018  - info: sonoff.0 (781) Client [XXXX] connection closed: Error: read ECONNRESET
      2023-07-05 11:28:31.614  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
      2023-07-05 11:30:00.129  - info: host.iobroker instance system.adapter.daswetter.0 started with pid ????
      2023-07-05 11:30:03.763  - info: daswetter.0 (3111) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-07-05 11:30:04.120  - info: daswetter.0 (3111) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
      2023-07-05 11:30:27.051  - info: daswetter.0 (3111) still wrong data structure from server received! repaired...
      2023-07-05 11:30:33.154  - info: daswetter.0 (3111) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-07-05 11:30:33.678  - info: daswetter.0 (3111) cleaned everything up...
      2023-07-05 11:30:33.705  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-05 11:33:50.597  - info: sonoff.0 (781) Client [XXXX] connection closed: closed
      2023-07-05 11:34:07.677  - info: admin.0 (604) ==> Connected system.user.???? from ::ffff:192.168.?.?
      2023-07-05 11:34:36.056  - info: host.iobroker iobroker upgrade javascript@7.0.3 --debug
      2023-07-05 11:34:38.784  - info: sonoff.0 (781) Client [XXXX] connected with secret ????
      iob diag has finished.
      Press any key for a summary
      crunchip Homoran 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @bfelizardo last edited by crunchip
        @bfelizardo was stimmt da mit deinen Ports nicht?
        außerdem ist buster überfällig
        bfelizardo 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @bfelizardo last edited by
          @crunchip sagte in Troubleshooting NodeJS update:
          und das auch noch ungepflegt
          @bfelizardo sagte in Troubleshooting NodeJS update:
          • bfelizardo
            bfelizardo @crunchip last edited by
            @crunchip
            habe die Port "geschwärzt".
            @crunchip + @Homoran
            Danke für eure Rückmeldung. Da mit dem Update von Buster etc. verstehe ich, aber ist das die Ursache für mein Problem?
            Homoran crunchip 3 Replies Last reply Reply Quote 0
              und wie sollen wir dann z.B. doppelt belegte oder falsche ports erkennen?
                wie kommt man denn auf so eine Idee, die Ausgabe ist doch dafür da um Fehler zu finden
                möglicherweise ja
                  hast du tatsächlich von
                  node.js 12.x
                  direkt auf 18 hochgezogen?
                  • bfelizardo
                    @homoran @crunchip
                    sorry mit den Ports, war mir unsicher was ich hier alles öffentlich machen soll.
                    @Homoran ich habe von 14.x auf 18.x hochgezogen.
                    crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                      @bfelizardo ok, sollte an und für sich funktionieren von 14 auf 18
                      allerdings aufgrund deiner ungepflegten updates wohl nicht
                      aktuelles OS neu installieren und backup vom iobroker zurückspielen würde ich vorschlagen
                      • bfelizardo
                        @crunchip said in Troubleshooting NodeJS update:
                        ok danke. Werde ich ausprobieren!
                          Thomas Braun Most Active @bfelizardo last edited by Thomas Braun
                          Alles.
                          Zumindest bei npm hast du aber noch händisch herumgefummelt. Die Version passt nicht zum nodejs.
                          iob stop
                          sudo install --reinstall nodejs
                          iob start
                          ausführen.
                          Besser aber das System kompett neu aufsetzen, auf 'Bullseye' 64bit 'Lite'.
                            apollon77 @bfelizardo last edited by
                            npm ERR! notsup Required: {"node":"^12.16.1 || ^10.15.2 || ^8.15.1","npm":"^6.4.1"}npm ERR! notsup Actual: {"npm":"9.7.2","node":"v18.16.1"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-05T08_46_11_943Z-debug-0.log
                            liess ggf mal in dem genannten Logfile - vllt steht da welches paket es bei dir auslöst
                              Stadtschloss last edited by Stadtschloss
                              ich kann leider kein apt-get update machen. Ich erhalte folgenden Fehler:
                              apt-get update
                              Err:1 https://deb.nodesource.com/node_18.x bullseye InRelease
                                Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                              Hit:2 http://ftp.debian.org/debian bullseye InRelease
                              Hit:3 http://security.debian.org bullseye-security InRelease
                              Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
                              Reading package lists... Done
                              W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/bullseye/InRelease  Could not connect to deb.nodesource.com:443 (0.0.0.0). - connect (111: Connection refused) Could not connect to deb.nodesource.com:443 (::). - connect (111: Connection refused)
                              W: Some index files failed to download. They have been ignored, or old ones used instead.
                              node --version
                              v18.15.0
                              Was kann ich hier tun?
                              Danke!
                              EDIT:
                              Mein Adblocker blockiert die URL. Problem gelöst 🙂
                                centrofly last edited by centrofly
                                Post gelöscht, hat sich auf wundersame Weise selbst geheilt...
                                  Creatorhs last edited by Creatorhs
                                  ich habe leider Probleme nodejs upzudaten.
                                  Ich konnte noch iob stop eingeben und - vermutlich - die alte nodejs Version löschen. Wobei auch schon hier nicht genau die Ausgabe kam, wie im best practice Artikel.
                                  Ich habe dann noch versucht das Repository herunterzuladen und erscheint dann folgende Fehlermeldung:
                                  + apt-get update
                                  OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Ign:3 https://packages.grafana.com/oss/deb stable InRelease
                                  OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                  Fehl:5 https://packages.grafana.com/oss/deb stable Release
                                    Certificate verification failed: The certificate is NOT trusted. The certifica        te chain uses expired certificate.  Could not handshake: Error in the certificat        e verification. [IP: 2a04:4e42:6f::729 443]
                                  E: Das Depot »https://packages.grafana.com/oss/deb stable Release« enthält keine        Release-Datei mehr.
                                  N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur        chgeführt werden, daher ist es standardmäßig deaktiviert.
                                  N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur        ation finden Sie in der Handbuchseite apt-secure(8).
                                  Error executing command, exiting
                                  Danach geht nichts mehr mit der bisher aufgespielten Version 14, da diese ja weg ich.
                                  Ich habe dann noch versucht "irgendeine" Nodejs zu installieren, was vermutlich der Fehler war:
                                  sudo apt install -y nodejs
                                  jetzt ist die ganz alte Version 12 drauf und zB Javaskript startet nicht mehr.
                                  Kann mir jemand helfen? Ich hab keine Ahnung, wie ich weitermachen soll. Backups sind auf googledrive vorhanden. Wenn ich ganz ehrlich bin bräuchte ich hier auch Hilfe um die wieder einzuspielen.
                                  edit: auch weitere Instanzen, wie zB shelly, tankerkönig, fb-checkpresence, gehen nicht mehr. Ich vermute, da die V12 zu alt ist?!
                                  Creator
                                    crunchip Forum Testing Most Active @Creatorhs last edited by crunchip
                                    @creatorhs sagte in Troubleshooting NodeJS update:
                                    und wie hast du die da rein gebracht, denn in deinem repo steht noch
                                    grafana korrigieren
                                    debian buster
                                    https://www.debian.org/releases/
                                    um deine probleme zu beseitigen, findest du die Lösungen hier https://forum.iobroker.net/user/thomas-braun
                                      Creatorhs @crunchip last edited by Creatorhs
                                      grafana korrigieren
                                      debian buster
                                      Danke für deine schnelle Antwort!
                                      Wie ich die reingebracht habe?! Durch das letzte Update, habe mich an die Artikel hier gehalten. Hatte nur vorhin unter "Hosts" die V14 gesehen, daher meine Aussage. Weiß nicht mehr sicher, welches das letzte Update war, ist schon etwas her...
                                      Grafana korrigieren: Wie?
                                      mit dem letzten Link, den du geschrieben hattest: Was möchtest du mir dort zeigen?
                                      Danke für die Hilfe.
                                      EDIT: Danke, lese mir die links durch...
                                        da stehn alle Threads( die oberen) zu deinen Problemen
                                        an welche? dann würde ja keine v12 drin stehen
                                          Thomas Braun Most Active @Creatorhs last edited by
                                          @creatorhs
                                          Bzgl. nodejs kannst du auch probieren mit der aktuellen Beta vom iob_diag-Skript das gerade ziehen zu lassen.
                                          Nutzt dir aber nix bei den anderen Dingen, die da bei dir im Argen liegen.
                                            Chu last edited by Chu
                                            ich hab eben das Update von nodeJS 14 auf 18 gemacht. Nach dieser Anleitung: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                                            type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            /usr/bin/npx
                                            v18.17.1
                                            v18.17.1
                                            9.6.7
                                            9.6.7
                                            Jedoch erkennt der ioBroker die Version nicht:
                                            und das update für den Admin Adapter kann ebenfalls nicht durchgeführt werden wegen zu geringer nodeJS Version.
                                            Hat jemand eine Idee wie ich den ioBroker die neue Version nutzen lasse?
                                            Thomas Braun C 2 Replies Last reply Reply Quote 0
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143616
