    4. Test Adapter vis 2.0 (Alpha)
      Homoran Global Moderator Administrators @Marsx79 last edited by
      @marsx79 sagte in Test Adapter vis 2.0 (Alpha):
      Gibt es überhaupt ein Separates?
      nein, aber man kann die Logstufe der Instanz auf debug schalten, dann ist es schonmal nicht mehr
      Im "normalen" ioBroker Log
      dann nach vis2 filtern.
      Muss also irgendwo ein Fehler drin sein.
      das würde dir u.a. die Browserkonsole erzählen
        Marsx79 last edited by Marsx79
        Danke für die Infos!
        Diese Fehler werden über die Konsole ausgegeben.
        DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/vis-2-beta/static/js/main.39cd355f.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        DevTools failed to load source map: Could not load content for chrome-extension://mmhlniccooihdimnnjhamobppdhaolme/lib/tp/browser-polyfill.min.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
        DevTools failed to load source map: Could not load content for http://192.168.178.3:8082/vis-2-beta/static/js/3.fcae646b.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        bootstrap.jsx:20 iobroker.vis-2-beta@2.0.33 using theme "colored"
        main.39cd355f.js:2
        main.39cd355f.js:2 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
        main.39cd355f.js:2 Help us to create open source project with reactJS!
        main.39cd355f.js:2 See you :)
        api.js:13 (24) [{…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}, {…}]
        3.fcae646b.chunk.js:2 Translate: background
        3.fcae646b.chunk.js:2 Version vis-google-fonts: 0.0.1
        3.fcae646b.chunk.js:2 Version vis-jqui-mfd: 1.0.12
        3.fcae646b.chunk.js:2 Metro version: "1.2.0"
        3.fcae646b.chunk.js:2 Version players: 0.1.0
        3.fcae646b.chunk.js:2 Version Info-Adapter-Widget: 0.0.9
        3.fcae646b.chunk.js:2 Download the Vue Devtools extension for a better development experience:
        https://github.com/vuejs/vue-devtools
        3.fcae646b.chunk.js:2 You are running Vue in development mode.
        Make sure to turn on production mode when deploying for production.
        See more tips at https://vuejs.org/guide/deployment.html
        3.fcae646b.chunk.js:2 Version vis-materialdesign: 0.5.9
        3.fcae646b.chunk.js:2 Translate: jqui_html_dialog
        3.fcae646b.chunk.js:2 Translate: jqui_icon_dialog
        3.fcae646b.chunk.js:2 Translate: jqui_container_dialog
        3.fcae646b.chunk.js:2 Translate: bars
        3.fcae646b.chunk.js:2 Translate: dwd
        3.fcae646b.chunk.js:2 Translate: hqwidgets
        3.fcae646b.chunk.js:2 Translate: info
        3.fcae646b.chunk.js:2 Translate: jqplot
        3.fcae646b.chunk.js:2 Translate: jqui-mfd
        3.fcae646b.chunk.js:2 Translate: materialdesign
        3.fcae646b.chunk.js:2 Translate: metro
        3.fcae646b.chunk.js:2 Translate: players
        3.fcae646b.chunk.js:2 Translate: swipe
        3.fcae646b.chunk.js:2 Translate: timeandweather
        3.fcae646b.chunk.js:2 Translate: tabs
        3.fcae646b.chunk.js:2 vis-materialdesign: sentry datapoint 'vis-materialdesign.0.sentry' not exist! Go to the adapter settings to activate it.
        (anonymous) @ 3.fcae646b.chunk.js:2
        initializeSentry @ widgets.min.js:1
        await in initializeSentry (async)
        (anonymous) @ materialdesign.js:35
        (anonymous) @ widgets.min.js:1
        (anonymous) @ visEngine.jsx:1165
        Promise.then (async)
        emit @ visEngine.jsx:1165
        getObject @ widgets.min.js:1
        getVersion @ widgets.min.js:1
        (anonymous) @ materialdesign.js:32
        i @ 3.fcae646b.chunk.js:2
        setTimeout (async)
        waitForVisConnected @ widgets.min.js:1
        showVersion @ materialdesign.js:31
        3.fcae646b.chunk.js:2 Someone installs handler without to remove it!
        n.registerChangeHandler @ visEngine.jsx:1509
        i @ visCanWidget.jsx:90
        Wo @ main.39cd355f.js:2
        Li @ main.39cd355f.js:2
        Cs @ main.39cd355f.js:2
        Hl @ main.39cd355f.js:2
        gl @ main.39cd355f.js:2
        zl @ main.39cd355f.js:2
        al @ main.39cd355f.js:2
        ol @ main.39cd355f.js:2
        V @ main.39cd355f.js:2
        T @ main.39cd355f.js:2
        3.fcae646b.chunk.js:2 TypeError: Cannot read properties of undefined (reading 'length')
            at Function.value (visRxWidget.jsx:118:46)
            at new i (visRxWidget.jsx:95:48)
            at i.<anonymous> (createSuper.js:11:24)
            at new i (BasicViewInWidget8.jsx:23:25)
            at Wo (main.39cd355f.js:2:6743048)
            at Li (main.39cd355f.js:2:6763489)
            at Cs (main.39cd355f.js:2:6809634)
            at Hl (main.39cd355f.js:2:6797775)
            at gl (main.39cd355f.js:2:6797703)
            at zl (main.39cd355f.js:2:6797566)
            at al (main.39cd355f.js:2:6794346)
            at ol (main.39cd355f.js:2:6792897)
            at V (main.39cd355f.js:2:8223976)
            at MessagePort.T (main.39cd355f.js:2:8224510)
        di @ main.39cd355f.js:2
        n.callback @ main.39cd355f.js:2
        Do @ main.39cd355f.js:2
        xs @ main.39cd355f.js:2
        Hs @ main.39cd355f.js:2
        Ms @ main.39cd355f.js:2
        (anonymous) @ main.39cd355f.js:2
        Vl @ main.39cd355f.js:2
        main.39cd355f.js:2 Uncaught TypeError: Cannot read properties of undefined (reading 'length')
        value @ visRxWidget.jsx:118
        i @ visRxWidget.jsx:95
        (anonymous) @ createSuper.js:11
        i @ BasicViewInWidget8.jsx:23
          duesterk last edited by duesterk
          ich habe ein Problem mit dem hinzufügen eines Objekts im Vis.2 Material Widget.
          Ich habe dazu ein Issue beim Vis2 Widget Material Adapter eröffnet.
          Ich bin aber nicht sicher, ob es von Vis.2 oder eben vom Material Widget kommt.
          Eventuell kann mir ja hier jemand helfen.
          https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/153
          duesterk created this issue in ioBroker/ioBroker.vis-2-widgets-material
          closed V0.5.3 Bug Add objects #153
          • Feuersturm
            Feuersturm @duesterk last edited by
            @duesterk Ich hab dir mal im github issue geantwortet. Kann versuchen es bei mir nachzustellen.
            Mittlerweile gibt es auch vis2 version v2.0.35 auf npm
              duesterk @Feuersturm last edited by
              @feuersturm Danke fürs prüfen, ich habe auch mit V2.0.35 das gleiche Problem.
              Es ist auch sehr seltsam, habe noch weiter an meiner Vis in Vis.2 gearbeitet und konnte keinweiteres Objekt finden, welches nicht funktioniert.
              Nur das genannte Objekt und ein paar wenige andere bekomme ich einfach nicht eingebunden.
              Habe auch die Objekte schon gelöscht und nachdem der Adapter die Objekte wieder neu hinzugefügt hat, habe ich immer noch das selbe Problem.
                wolfgam last edited by
                ich stehe hier irgendwie am Schlauch.
                • wie funktioniert der Steal von Attributen?
                • wie bekomme ich die Auswahlliste möglicher CSS Attribute angezeigt (z.B. border-style = dotted, dashed, solid,...)?
                VG
                Wolfgang
                • MichaelSc
                  MichaelSc last edited by
                  Neue VIS2-Installation, zeigt sich wie folgt:
                  Was muss ich noch tun?
                    apollon77 @MichaelSc last edited by
                    @michaelsc versuch nochmal manuell zu migrieren, da scheint wohl die automatische übernahme nicht geklappt zuhaben. siehe post #1
                    MichaelSc 1 Reply Last reply Reply Quote 1
                    • MichaelSc
                      MichaelSc @apollon77 last edited by
                      @apollon77 said in Test Adapter vis 2.0 (Alpha):
                      @michaelsc versuch nochmal manuell zu migrieren...
                      Mein Fehler. Der Hinweis auf Post #1 war schon goldrichtig: Der Adapter vis-metro war nicht richtig installiert.
                      Nachdem ich den dann nochmal installiert hatte, kam im Aufruf "192.168.178.201:8082/vis-2-beta/edit.html?ALF1#..." sofort der Editor.
                      Danke sehr!
                      • MichaelSc
                        Auf den ersten Blick: Da funktioniert ja schon soooooooviel in meinem großen Projekt - ich bin erstaunt und hocherfreut.
                        Auf den zweiten Blick:
                        • Scrollen in längeren Views scheint noch nicht zu gehen, oder ich muss da noch eine Einstellung anpassen.
                        • Die von mir gerne benutzten Pop-Up-Views kommen anscheinend noch nicht.
                        Aber das schau ich mir noch in Ruhe an und werde dann Details anfragen.
                        Vielen Dank!
                        ice987 1 Reply Last reply Reply Quote 0
                        • ice987
                          ice987 @MichaelSc last edited by
                          @michaelsc sagte in Test Adapter vis 2.0 (Alpha):
                          https://github.com/ioBroker/ioBroker.vis/issues/612 ?
                          ice987987 created this issue in ioBroker/ioBroker.vis
                          closed vis2.x: "Basic HTML"-widget, not scrollable/not full height in runtime shown #31
                          MichaelSc 1 Reply Last reply Reply Quote 0
                          • MichaelSc
                            MichaelSc @ice987 last edited by
                            @ice987 Danke, ist also nach meinem Verständnis dann ein erkanntes Issue und noch offen. Okay.
                            • MichaelSc
                              Wenn ich jetzt der Ansicht bin, dass ein Vis-Inventwo Universal Widget mit der Popup-Funktion...
                              ...bei Änderung des zur Steuerung eingestellten Datenpunktes...
                              nicht reagiert, sprich: Den Popup nicht einleitet - WAS muss ich dann tun? Das hier erst als Frage einstellen (was hiermit geschehen ist) oder beim Widget-Hersteller vis-inventwo anfragen, ob ihr Widget schon unter VIS-2-beta lauffähig ist?
                              • MichaelSc
                                web.0
                                2023-07-06 08:02:14.902 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: RGraph.Effects.Gauge is undefined😞 "tplRGgauge/elem.rgraphValueChange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#ALF1_Solaranzeige_4 line 1 > injectedScript:973:21\nonchange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#ALF1_Solaranzeige_4 line 1 > injectedScript:138:30\n36167/i/n.onStateChange/<@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n36167/i/n.onStateChange@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575\n83251/value/<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721569\nvalue@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543\n83251/value/</<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\ni@http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250\n"
                                web.0
                                2023-07-06 08:00:08.960 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: Cannot read properties of undefined (reading 'Grow')): "TypeError: Cannot read properties of undefined (reading 'Grow')\n at elem.rgraphValueChange (<anonymous>:973:42)\n at Object.onchange [as callback] (<anonymous>:138:30)\n at http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n at Array.forEach (<anonymous>)\n at n.onStateChange (http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721568\n at Array.forEach (<anonymous>)\n at t.value (http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\n at i (http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250)"
                                Zeigt dieser Fehler auf ein bestimmtes Widget?
                                Ich kann nur raten:
                                allerdings wird hier ja der richtige Wert angezeigt.
                                Wie kommt man dem Verursacher auf die Spur?
                                  @michaelsc mach doch mal Github issue bei vis2 und/oder gauge?
                                  • MichaelSc
                                    MichaelSc @apollon77 last edited by MichaelSc
                                    @apollon77 Trotz "Suche" finde ich kein VIS2 in Github, kannst Du bitte helfen?
                                    sigi234 arteck 2 Replies Last reply Reply Quote 0
                                      sigi234 Forum Testing Most Active @MichaelSc last edited by
                                        arteck Developer Most Active @MichaelSc last edited by
                                        @michaelsc https://github.com/ioBroker/ioBroker.vis
                                        • MichaelSc
                                          MichaelSc @arteck last edited by
                                          @arteck ah danke: Suchte nach "vis2" oder "vis-2" - also in "vis" einstellen, okay.
                                          • MichaelSc
                                            MichaelSc @sigi234 last edited by
                                            @sigi234 Danke!
                                            780
                                            262369
