- Home
- Deutsch
- Einsteigerfragen
- Einbindung von Geräten
- [gelöst] Zigbee Problem - Coordinator per Ethernet
ich habe gerade eine neue iobroker VM in Proxmox mit Debian 12 aufgesetzt und den ioBroker mit dem Einzeiler erfolgreich aufgesetzt.
Skript v.2023-04-16 *** BASE SYSTEM *** Architecture : x86_64 Docker : false Virtualization : kvm Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 17:13:10 up 9 days, 21:24, 3 users, load average: 0.00, 0.04, 0.06 CPU threads: 2 *** Time and Time Zones *** Local time: Thu 2023-07-06 17:13:10 CEST Universal time: Thu 2023-07-06 15:13:10 UTC RTC time: Thu 2023-07-06 15:13:10 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** nils /home/nils nils cdrom floppy audio dip video plugdev users netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 4.1G 916M 2.7G 544K 736M 3.2G Swap: 1.0G 0B 1.0G Total: 5.1G 916M 3.7G 3915 M total memory 873 M used memory 281 M active memory 882 M inactive memory 2568 M free memory 104 M buffer memory 598 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.9G 0 1.9G 0% /dev tmpfs tmpfs 392M 536K 392M 1% /run /dev/sda1 ext4 15G 3.1G 11G 23% / tmpfs tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 392M 0 392M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Jun 26 19:49:09 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Mon Jun 26 19:49:10 2023] EXT4-fs (sda1): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 459M /var/ 245M /var/cache 238M /var/cache/apt 167M /var/lib 162M /var/cache/apt/archives Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 11.6M in the file system. /opt/iobroker/backups: 8.8M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 127M /opt/iobroker/iobroker-data/ 94M /opt/iobroker/iobroker-data/files 52M /opt/iobroker/iobroker-data/files/javascript.admin 34M /opt/iobroker/iobroker-data/files/javascript.admin/static 33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 5.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map 4.6M /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js 4.5M /opt/iobroker/iobroker-data/files/web.admin/static/js/2.b1d56998.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.16.1 /usr/bin/node v18.16.1 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.1-deb-1nodesource1 Candidate: 18.16.1-deb-1nodesource1 Version table: *** 18.16.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages 100 /var/lib/dpkg/status 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 7.0.3 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.discovery.0 : discovery : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : iobroker - disabled, port: tcp://192.168.178.6:20108 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "javascript" : 7.0.3 , installed 7.0.3 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.8.10 , installed 1.8.10 Objects and States Please stand by - This may take a while Objects: 240 States: 186 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org/debian-security bookworm-security InRelease Hit:4 https://deb.nodesource.com/node_18.x bookworm InRelease Reading package lists... Pending Updates: 1 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 62329 8477/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 62336 8477/iobroker.js-co tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14820 487/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 12832 1/init tcp6 0 0 :::8081 :::* LISTEN 1001 62565 8495/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 62701 8582/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 14822 487/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 12834 1/init udp 0 0 0.0.0.0:111 0.0.0.0:* 0 12833 1/init udp6 0 0 :::111 :::* 0 12835 1/init *** Log File - Last 25 Lines *** 2023-07-06 17:06:22.809 - error: zigbee.0 (8726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-06 17:06:22.810 - error: zigbee.0 (8726) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-06 17:06:22.841 - error: zigbee.0 (8726) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18) 2023-07-06 17:06:22.841 - error: zigbee.0 (8726) Cannot read properties of undefined (reading 'Error') 2023-07-06 17:06:22.848 - info: zigbee.0 (8726) cleaned everything up... 2023-07-06 17:06:22.851 - info: zigbee.0 (8726) Zigbee: disabling joining new devices. 2023-07-06 17:06:22.868 - warn: zigbee.0 (8726) Failed to stop zigbee during startup 2023-07-06 17:06:22.868 - info: zigbee.0 (8726) terminating 2023-07-06 17:06:22.869 - warn: zigbee.0 (8726) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-06 17:06:23.414 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-06 17:06:23.414 - error: host.iobroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-06 17:06:23.414 - error: host.iobroker Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-06 17:06:23.414 - error: host.iobroker Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-06 17:06:23.414 - error: host.iobroker Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-06 17:06:23.415 - error: host.iobroker Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-06 17:06:23.415 - error: host.iobroker Caught by controller[1]: at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18) 2023-07-06 17:06:23.415 - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-06 17:06:23.415 - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled 2023-07-06 17:06:23.415 - warn: host.iobroker Do not restart adapter system.adapter.zigbee.0 because restart loop detected 2023-07-06 17:07:42.731 - info: host.iobroker "system.adapter.zigbee.0" disabledAls Coordinator nutze ich ein TI-CC26X2R1, als TCP-Modul das USR-TCP232-T2 TTL. Es befindet sich im richtigen Netzwerksegment und ist vom ioBroker pingbar.
Das Modul habe ich (mehrfach überprüft) mit 3 V, GND und gedrehtem TX/RX angeschlossen.
Den Coordinator habe ich mit der neuesten Firmware von Koenkk mittlerweile dreimal mit erfolgreichem log und Verifizierung mit UniFlash gesflashed (aktuelle Firmware CC2652R_coordinator_20230507.hex).
Im ioBroker habe ich das Gerät wie folgt testweise eingebunden:
Es hilft nichts, ich bekomme keine Verbindung zum Koordinator.
Hier das debug log, hoffentlich hat jemand eine Idee, wo die Ursache zu finden ist:
host.iobroker 2023-07-06 17:07:42.731 info "system.adapter.zigbee.0" disabled host.iobroker 2023-07-06 17:17:32.502 info "system.adapter.zigbee.0" enabled host.iobroker 2023-07-06 17:17:32.535 info instance system.adapter.zigbee.0 started with pid 9619 zigbee.0 2023-07-06 17:17:35.193 info starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-06 17:17:35.288 info delete old Backup files. keep only last 10 zigbee.0 2023-07-06 17:17:35.290 info Starting Zigbee npm ... zigbee.0 2023-07-06 17:17:35.679 info Installed Version: iobroker.zigbee@1.8.10 zigbee.0 2023-07-06 17:17:39.991 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} zigbee.0 2023-07-06 17:17:39.999 info Unable to disable LED, unsupported function. zigbee.0 2023-07-06 17:17:40.013 info --> transmitPower : normal zigbee.0 2023-07-06 17:17:40.020 info Currently no devices. zigbee.0 2023-07-06 17:17:40.021 info Zigbee started zigbee.0 2023-07-06 17:17:40.024 error Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms zigbee.0 2023-07-06 17:17:40.025 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee.0 2023-07-06 17:17:40.026 error unhandled promise rejection: Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:17:40.052 error TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) zigbee.0 2023-07-06 17:17:40.052 error Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:17:40.060 info cleaned everything up... zigbee.0 2023-07-06 17:17:40.062 info Zigbee: disabling joining new devices. zigbee.0 2023-07-06 17:17:40.561 info terminating zigbee.0 2023-07-06 17:17:40.563 warn Terminated (UNCAUGHT_EXCEPTION): Without reason host.iobroker 2023-07-06 17:17:41.108 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iobroker 2023-07-06 17:17:41.108 error Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') host.iobroker 2023-07-06 17:17:41.109 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 host.iobroker 2023-07-06 17:17:41.109 error Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) host.iobroker 2023-07-06 17:17:41.109 error Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) host.iobroker 2023-07-06 17:17:41.109 error Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) host.iobroker 2023-07-06 17:17:41.111 error Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) host.iobroker 2023-07-06 17:17:41.111 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iobroker 2023-07-06 17:17:41.111 info Restart adapter system.adapter.zigbee.0 because enabled host.iobroker 2023-07-06 17:18:11.135 info instance system.adapter.zigbee.0 started with pid 9637 zigbee.0 2023-07-06 17:18:13.742 info starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-06 17:18:13.839 info delete old Backup files. keep only last 10 zigbee.0 2023-07-06 17:18:13.841 info Starting Zigbee npm ... zigbee.0 2023-07-06 17:18:14.269 info Installed Version: iobroker.zigbee@1.8.10 zigbee.0 2023-07-06 17:18:15.595 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} zigbee.0 2023-07-06 17:18:15.608 info Unable to disable LED, unsupported function. zigbee.0 2023-07-06 17:18:15.622 info --> transmitPower : normal zigbee.0 2023-07-06 17:18:15.808 info Currently no devices. zigbee.0 2023-07-06 17:18:15.809 info Zigbee started zigbee.0 2023-07-06 17:18:15.812 error Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms zigbee.0 2023-07-06 17:18:15.814 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee.0 2023-07-06 17:18:15.815 error unhandled promise rejection: Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:18:15.849 error TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) zigbee.0 2023-07-06 17:18:15.849 error Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:18:15.865 info cleaned everything up... zigbee.0 2023-07-06 17:18:15.866 info Zigbee: disabling joining new devices. zigbee.0 2023-07-06 17:18:16.365 info terminating zigbee.0 2023-07-06 17:18:16.366 warn Terminated (UNCAUGHT_EXCEPTION): Without reason host.iobroker 2023-07-06 17:18:16.910 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iobroker 2023-07-06 17:18:16.910 error Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') host.iobroker 2023-07-06 17:18:16.911 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 host.iobroker 2023-07-06 17:18:16.911 error Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) host.iobroker 2023-07-06 17:18:16.911 error Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) host.iobroker 2023-07-06 17:18:16.911 error Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) host.iobroker 2023-07-06 17:18:16.911 error Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) host.iobroker 2023-07-06 17:18:16.911 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iobroker 2023-07-06 17:18:16.912 info Restart adapter system.adapter.zigbee.0 because enabled host.iobroker 2023-07-06 17:18:46.936 info instance system.adapter.zigbee.0 started with pid 9652 zigbee.0 2023-07-06 17:18:49.562 info starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-06 17:18:49.657 info delete old Backup files. keep only last 10 zigbee.0 2023-07-06 17:18:49.659 info Starting Zigbee npm ... zigbee.0 2023-07-06 17:18:50.051 info Installed Version: iobroker.zigbee@1.8.10 zigbee.0 2023-07-06 17:18:51.367 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} zigbee.0 2023-07-06 17:18:51.375 info Unable to disable LED, unsupported function. zigbee.0 2023-07-06 17:18:51.390 info --> transmitPower : normal zigbee.0 2023-07-06 17:18:51.397 info Currently no devices. zigbee.0 2023-07-06 17:18:51.398 info Zigbee started zigbee.0 2023-07-06 17:18:51.400 error Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms zigbee.0 2023-07-06 17:18:51.401 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). zigbee.0 2023-07-06 17:18:51.402 error unhandled promise rejection: Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:18:51.430 error TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) zigbee.0 2023-07-06 17:18:51.431 error Cannot read properties of undefined (reading 'Error') zigbee.0 2023-07-06 17:18:51.443 info cleaned everything up... zigbee.0 2023-07-06 17:18:51.444 info Zigbee: disabling joining new devices. zigbee.0 2023-07-06 17:18:51.945 info terminating zigbee.0 2023-07-06 17:18:51.946 warn Terminated (UNCAUGHT_EXCEPTION): Without reason host.iobroker 2023-07-06 17:18:52.488 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iobroker 2023-07-06 17:18:52.488 error Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') host.iobroker 2023-07-06 17:18:52.488 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 host.iobroker 2023-07-06 17:18:52.489 error Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) host.iobroker 2023-07-06 17:18:52.489 error Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) host.iobroker 2023-07-06 17:18:52.489 error Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) host.iobroker 2023-07-06 17:18:52.489 error Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) host.iobroker 2023-07-06 17:18:52.489 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iobroker 2023-07-06 17:18:52.490 info Restart adapter system.adapter.zigbee.0 because enabled host.iobroker 2023-07-06 17:18:52.490 warn Do not restart adapter system.adapter.zigbee.0 because restart loop detectedSchönen Gruß
Thomas -
@meister-mopper was zeigt dein Stick unter current Status?
was mir noch auffällt, dein Stick hat die 192.168.178.6, deine Remote Server Adresse ist 192.168.0.201
bei mir hat der Stick die 10.1.20.7 und der Remote ist eins höher, sprich 10.1.20.8
An der Remote Server Adresse kann ich nichts ändern, weil ich das Ding ja als tcp-server eingestellt habe. Daran sollte es aus meiner Sicht nicht liegen.
@meister-mopper sagte in Zigbee Problem - Coordinator per Ethernet:
mich wunder nur das es ein anderer Adressbereich ist. Aber bei dir sieht es so aus, als wenn nicht gesendet/empfangen wird, somit logisch das dein zigbee nicht funktioniert
hast du es mal mit 5V probiert?
ich selbst hab ein
anderesModel, ein USR-TCP232-T2 -
@crunchip sagte in Zigbee Problem - Coordinator per Ethernet:
Da habe ich eher die Befürchtung, das Ding zu bruzzeln.
Ich blicke so langsam bei den Modulen nicht mehr durch. Ich dachte, das USR-TCP232-T2 TTL ist baugleich zum USR-TCP232-T2.
Wenn ich mir die Bilder im Netz anschaue, zweifle ich. Auf meinem steht die Bezeichnung nicht aufgedruckt, lediglich ein Aufkleber "QC-PASS 34" (vmtl. Quality check).
Es ist dieses,Hast Du vielleicht einen Link für Dein Modul, dann würde ich es nochmal mit dem versuchen.
https://www.amazon.de/gp/product/B01GPMFXB2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
vllt findest du da Info`s
https://forum.iobroker.net/post/647127 -
@meister-mopper installier mal die 1.8.13 von GIT..und schau nochmal
und mach Sentry aus bitte..
drauf klicken.. sollte dann grau werden
dann..
welche IP rufst du auf um auf das Interface zu kommen ??
@arteck aber bei ihm kommen ja gar keine Daten, siehe https://forum.iobroker.net/post/1013377
müssten da nicht bei Count schon paar bytes zu sehen sein, ohne zigbee Instanz? -
v1.8.13
Läääääääääuuuuuuuuft!!!
host.iobroker 2023-07-07 11:33:35.878 info "system.adapter.zigbee.0" enabled host.iobroker 2023-07-07 11:33:35.908 info instance system.adapter.zigbee.0 started with pid 10418 zigbee.0 2023-07-07 11:33:38.449 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 zigbee.0 2023-07-07 11:33:38.480 debug Objects client ready ... initialize now zigbee.0 2023-07-07 11:33:38.482 debug Objects create System PubSub Client zigbee.0 2023-07-07 11:33:38.483 debug Objects create User PubSub Client zigbee.0 2023-07-07 11:33:38.496 debug Objects client initialize lua scripts zigbee.0 2023-07-07 11:33:38.502 debug Objects connected to redis: 127.0.0.1:9001 zigbee.0 2023-07-07 11:33:38.518 debug Redis States: Use Redis connection: 127.0.0.1:9000 zigbee.0 2023-07-07 11:33:38.525 debug States create System PubSub Client zigbee.0 2023-07-07 11:33:38.526 debug States create User PubSub Client zigbee.0 2023-07-07 11:33:38.536 debug States connected to redis: 127.0.0.1:9000 zigbee.0 2023-07-07 11:33:38.561 debug Plugin sentry Do not initialize Plugin (enabled=false) zigbee.0 2023-07-07 11:33:38.568 debug Plugin sentry destroyed because not initialized correctly zigbee.0 2023-07-07 11:33:38.721 info starting. Version 1.8.13 (non-npm: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-07 11:33:38.759 debug Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.6:20108","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}} zigbee.0 2023-07-07 11:33:38.816 info delete old Backup files. keep only last 10 zigbee.0 2023-07-07 11:33:38.818 info Starting Zigbee npm ... zigbee.0 2023-07-07 11:33:38.819 debug Starting zigbee-herdsman... zigbee.0 2023-07-07 11:33:39.334 info Installed Version: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310 zigbee.0 2023-07-07 11:33:39.340 debug Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_07_07-11_33_38.tar.gz success zigbee.0 2023-07-07 11:33:43.912 debug zigbee-herdsman started zigbee.0 2023-07-07 11:33:43.913 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} zigbee.0 2023-07-07 11:33:43.920 debug Zigbee network parameters: panID=6754 channel=11 extendedPanID=4966e526004b1200 zigbee.0 2023-07-07 11:33:43.921 info Unable to disable LED, unsupported function. zigbee.0 2023-07-07 11:33:43.922 info --> transmitPower : normal zigbee.0 2023-07-07 11:33:43.928 info Currently no devices. zigbee.0 2023-07-07 11:33:43.929 info Zigbee started zigbee.0 2023-07-07 11:33:43.929 debug Config value 0xdddddddddddddddd : Network value 0x00124b0026e56649 zigbee.0 2023-07-07 11:33:43.932 error Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms zigbee.0 2023-07-07 11:33:43.932 debug Fix without changes. And restart adapter. zigbee.0 2023-07-07 11:33:43.937 debug getGroups result: {} host.iobroker 2023-07-07 11:33:43.997 info stopInstance system.adapter.zigbee.0 (force=false, process=true) zigbee.0 2023-07-07 11:33:44.002 info Got terminate signal TERMINATE_YOURSELF zigbee.0 2023-07-07 11:33:44.003 info cleaned everything up... zigbee.0 2023-07-07 11:33:44.005 info Zigbee: disabling joining new devices. zigbee.0 2023-07-07 11:33:44.020 info debug devices set to [] host.iobroker 2023-07-07 11:33:44.041 info stopInstance system.adapter.zigbee.0 send kill signal zigbee.0 2023-07-07 11:33:44.504 info terminating zigbee.0 2023-07-07 11:33:44.505 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason host.iobroker 2023-07-07 11:33:45.042 info stopInstance system.adapter.zigbee.0 killing pid 10418 host.iobroker 2023-07-07 11:33:45.060 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) host.iobroker 2023-07-07 11:33:47.066 info instance system.adapter.zigbee.0 started with pid 10433 zigbee.0 2023-07-07 11:33:49.574 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 zigbee.0 2023-07-07 11:33:49.609 debug Objects client ready ... initialize now zigbee.0 2023-07-07 11:33:49.611 debug Objects create System PubSub Client zigbee.0 2023-07-07 11:33:49.612 debug Objects create User PubSub Client zigbee.0 2023-07-07 11:33:49.625 debug Objects client initialize lua scripts zigbee.0 2023-07-07 11:33:49.631 debug Objects connected to redis: 127.0.0.1:9001 zigbee.0 2023-07-07 11:33:49.646 debug Redis States: Use Redis connection: 127.0.0.1:9000 zigbee.0 2023-07-07 11:33:49.651 debug States create System PubSub Client zigbee.0 2023-07-07 11:33:49.652 debug States create User PubSub Client zigbee.0 2023-07-07 11:33:49.660 debug States connected to redis: 127.0.0.1:9000 zigbee.0 2023-07-07 11:33:49.689 debug Plugin sentry Do not initialize Plugin (enabled=false) zigbee.0 2023-07-07 11:33:49.738 debug Plugin sentry destroyed because not initialized correctly zigbee.0 2023-07-07 11:33:49.887 info starting. Version 1.8.13 (non-npm: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 zigbee.0 2023-07-07 11:33:49.929 debug Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.6:20108","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}} zigbee.0 2023-07-07 11:33:49.986 info delete old Backup files. keep only last 10 zigbee.0 2023-07-07 11:33:49.988 info Starting Zigbee npm ... zigbee.0 2023-07-07 11:33:49.989 debug Starting zigbee-herdsman... zigbee.0 2023-07-07 11:33:50.475 info Installed Version: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310 zigbee.0 2023-07-07 11:33:50.484 debug Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_07_07-11_33_49.tar.gz success zigbee.0 2023-07-07 11:33:51.797 debug zigbee-herdsman started zigbee.0 2023-07-07 11:33:51.798 info Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} zigbee.0 2023-07-07 11:33:51.805 debug Zigbee network parameters: panID=6754 channel=11 extendedPanID=4966e526004b1200 zigbee.0 2023-07-07 11:33:51.806 info Unable to disable LED, unsupported function. zigbee.0 2023-07-07 11:33:51.806 info --> transmitPower : normal zigbee.0 2023-07-07 11:33:51.818 info Currently no devices. zigbee.0 2023-07-07 11:33:51.819 info Zigbee started zigbee.0 2023-07-07 11:33:51.823 debug getGroups result: {} zigbee.0 2023-07-07 11:33:51.872 info debug devices set to [] zigbee.0 2023-07-07 11:34:25.820 debug getGroups result: {} zigbee.0 2023-07-07 11:34:25.838 debug LQI succeeded for 'Coordinator' zigbee.0 2023-07-07 11:34:25.849 debug Routing for 'Coordinator': {"table":[]} zigbee.0 2023-07-07 11:34:25.849 debug Routing table succeeded for 'Coordinator' zigbee.0 2023-07-07 11:34:25.850 debug Get map succeeded [] zigbee.0 2023-07-07 11:34:25.850 debug getMap result: {"lqis":[],"routing":[]} zigbee.0 2023-07-07 11:34:25.870 debug getCoordinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310","channel":"11","port":"tcp://192.168.178.6:20108","type":"zStack3x0","revision":20230507,"version":"2-1.2.7.1."} zigbee.0 2023-07-07 11:34:25.980 debug getDevices result: [{"_id":"0x00124b0026e56649","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b0026e56649","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281,10],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":null,"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},"endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281,10],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"name":"0x00124b0026e56649"},"common":{},"native":{}}] zigbee.0 2023-07-07 11:34:26.061 info List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}] zigbee.0 2023-07-07 11:34:26.163 debug getExclude result: [] 2023-07-07 11:34:26.166 debug getBinding result: []Bisschen Daten sind auch geflossen:
Vielen Dank @arteck
Edit:
Ach ja, auch an @haus-automatisierung für die Inspiration!
