    4. (erledigt) Javascript startet nicht mehr
      hm_krause @DJMarc75 last edited by
      @djmarc75
      Auf dem Geekom läuft Proxmox und der Iobroker in einer VM
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 12 (bookworm)
      Kernel:                 6.1.0-10-amd64
      Installation:           kvm
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                              /usr/bin/node           v18.16.1
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            4.1G        2.8G        594M        593K        1.1G        1.3G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        2.8G        1.6G
      Active iob-Instances:   36
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
        system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                19863
      States:                 17455
      Size of iob-Database:
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      30M     /opt/iobroker/iobroker-data/states.jsonl
      • DJMarc75
        DJMarc75 @hm_krause last edited by
        @hm_krause und jetzt die Langfassung bitte
          @djmarc75
          i```
          code_text
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : kvm
          Distributor ID: Debian
          Description:    Debian GNU/Linux 12 (bookworm)
          Release:        12
          Codename:       bookworm
          PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
          NAME="Debian GNU/Linux"
          VERSION_ID="12"
          VERSION="12 (bookworm)"
          VERSION_CODENAME=bookworm
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           15:41:53 up  1:19,  2 users,  load average: 0.11, 0.23, 0.30
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Fri 2023-07-07 15:41:53 CEST
                     Universal time: Fri 2023-07-07 13:41:53 UTC
                           RTC time: Fri 2023-07-07 13:41:53
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.1G        2.7G        634M        593K        1.1G        1.4G
          Swap:           1.0G          0B        1.0G
          Total:          5.1G        2.7G        1.7G
                   3915 M total memory
                   2586 M used memory
                    411 M active memory
                   2439 M inactive memory
                    605 M free memory
                    121 M buffer memory
                    919 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  1.9G     0  1.9G   0% /dev
          tmpfs          tmpfs     392M  580K  391M   1% /run
          /dev/sda1      ext4      125G   11G  108G   9% /
          tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
          [Fri Jul  7 14:22:52 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Jul  7 14:22:53 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          464M    /var/
          249M    /var/cache
          242M    /var/cache/apt
          168M    /var/lib
          166M    /var/cache/apt/archives
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          778M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          5.2G    /opt/iobroker/iobroker-data/
          4.7G    /opt/iobroker/iobroker-data/history
          362M    /opt/iobroker/iobroker-data/files
          268M    /opt/iobroker/iobroker-data/history/backup-objects
          140M    /opt/iobroker/iobroker-data/history/files
          334M    /opt/iobroker/iobroker-data/history/objects.jsonl
          129M    /opt/iobroker/iobroker-data/history/objects.json.migrated
          129M    /opt/iobroker/iobroker-data/history/objects.json.bak.migrated
          114M    /opt/iobroker/iobroker-data/history/states.jsonl
          48M     /opt/iobroker/iobroker-data/history/states.json.migrated
          *** NodeJS-Installation ***
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     7.0.3
          Adapters from github:   5
          Adapter State
            system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
          + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
          + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
          + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
            system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "device-watcher": 2.9.1   , installed 2.9.1
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
          Adapter    "fronius"      : 1.1.3    , installed 1.1.3
          Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "linux-control": 1.1.3    , installed 1.1.3
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "operating-hours": 1.0.4  , installed 1.0.4
          Adapter    "resol"        : 1.1.6    , installed 1.1.6
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "telegram"     : 1.15.6   , installed 1.15.6
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "zigbee"       : 1.8.12   , installed 1.8.10 [Updatable]
          Objects and States
          Objects:        19863
          States:         17455
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 https://deb.nodesource.com/node_18.x bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          25794      2122/upsd
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15403      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17037      534/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       46424      5557/iobroker.js-co
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       44765      5557/iobroker.js-co
          tcp        0      0 192.168.178.4:8081      0.0.0.0:*               LISTEN      1001       46477      5575/io.admin.0
          tcp        0      0 192.168.178.4:42010     0.0.0.0:*               LISTEN      1001       46555      5636/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       44843      5666/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       45477      5756/io.sonoff.0
          tcp        0      0 192.168.178.4:3493      0.0.0.0:*               LISTEN      0          25793      2122/upsd
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1276       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17039      534/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45894      6450/io.web.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53015      8055/io.simple-api.
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55444      8116/io.upnp.0
          udp        0      0 0.0.0.0:41000           0.0.0.0:*                           1001       53111      8116/io.upnp.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14766      1/init
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       45536      5786/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       45537      5786/io.tuya.0
          udp6       0      0 :::111                  :::*                                0          13851      1/init
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
          2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
          2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
          2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:23:47
          2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]: Node.js v18.16.1
          2023-07-07 15:14:43.708  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-07-07 15:14:43.708  - info: host.iobroker Do not restart adapter system.adapter.javascript.0 because disabled or deleted
          2023-07-07 15:23:00.054  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 9517
          2023-07-07 15:23:05.960  - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2023-07-07 15:30:00.074  - info: host.iobroker instance system.adapter.ical.0 started with pid 9552
          2023-07-07 15:30:04.092  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9567
          2023-07-07 15:30:07.927  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2023-07-07 15:30:19.772  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            Homoran Global Moderator Administrators @hm_krause last edited by Homoran
            bei
            @hm_krause sagte in Javascript startet nicht mehr:
            entry.json: Unexpected end of JSON input
            würde ich versuchen den
            nochmal drüberzuinstallieren
            wieso hast du denn diese Version?
            github:	7.1.0
            latest:	7.1.0 for 24 days
            stable:	6.1.4 for 7 months
            die ist nicht stable
              hm_krause @Homoran last edited by
              github: 7.1.0
              ..wo ist denn das?
              Adapter schon neu installiert, ohne Erfolg
                wie?
                mit welchen Meldungen?
                wo ist denn das?
                das ist gar nichts.
                7.0.3 ist eine sehr frühe Beta gewesen. Aber selbst die Tester sind inzwischen auf 7.1.0
                  Habe den Adapter jetzt nochmal neu installiert und er läuft.
                  Was auch immer da vorher war.
                    @hm_krause sagte in (erledigt) Javascript startet nicht mehr:
                    wo ist/war der Unterschied zu
                    stand doch im log
                    Datei defekt
                    Deswegen die Frage was du jetzt anders gemacht hast.
                    Welche Version läuft denn jetzt?
                      Bin mit der 7.0.3, wie zuvor auch, unterwegs.
                        @hm_krause Danke!
                        die Antwort auf die wichtigere Frage
                        @homoran sagte in (erledigt) Javascript startet nicht mehr:
                        bitte auch noch.
                          Ich hatte, nachdem Backitup durchgelaufen war, gesehen das der Adapter nicht gestartet war (mit den oben gezeigetn Fehlern)
                          Daraufhin hatte ich diesen gelöscht und wieder neu Installiert.
                          Da diese Fehler dann aber immer noch da waren habe ich hier um Hilfe gebeten.
                          Es gab eigentlich keinen Unterschied zur letzten Installation.
                          Das Protokoll hatte ich zwischenzeitlich gelöscht.
                            Danke, wenn auch seltsam.
                            699
