    4. Adapter: ioBroker.unifi
    • maximal1981
      maximal1981 @Hant0r last edited by
      @hant0r
      <block xmlns="https://developers.google.com/blockly/xml" type="controls_forEach" id="vZbxi%A.Z4NK.,]GJf)g" x="13" y="13">
        <field name="VAR" id="pkt|st/Cek!e1rU)d:03">i</field>
        <value name="LIST">
          <block type="selector" id="OPLe^Bf?~}UAZWL/)zt7">
            <field name="TEXT">channel[state.id=unifi.0.default.clients.*.is_guest]</field>
        <statement name="DO">
          <block type="controls_if" id=".1zT|W;Hi*6~j(y-dw44">
              <block type="get_value_var" id="F0$j|B1T|Erp$blJ|5r.">
                <value name="OID">
                  <shadow type="text" id="uHNphjS^h7Zh|eF:[2HV">
                    <field name="TEXT"></field>
                  <block type="variables_get" id="a@;ce{1B.J=16UwPtP(8">
              <block type="controls_if" id="Cc((*OSV]#!gyL;)bhm}">
                  <block type="get_value_var" id="a+V9qy^A)h%.;9[A.p/{">
                    <value name="OID">
                      <shadow type="text">
                      <block type="text_join" id="f7eDd5B[|h%CwdvDH)ZT">
                        <value name="ADD0">
                          <block type="text_getSubstring" id="}F(}=/aI47ar,nmgv3Es">
                            <mutation at1="false" at2="true"></mutation>
                            <field name="WHERE1">FIRST</field>
                            <field name="WHERE2">FROM_END</field>
                            <value name="STRING">
                              <block type="variables_get" id="7:a33VN;jOwS?0#KJHIm">
                            <value name="AT2">
                              <block type="math_number" id="jR;$5/3[PUr~d@q`rVrI">
                                <field name="NUM">9</field>
                        <value name="ADD1">
                          <block type="text" id="}DVtEPx5rLg/1/QX98JY">
                            <field name="TEXT">is_online</field>
                  <block type="debug" id="kV~NE!s|Ek`WRWA_3z=f">
                    <field name="Severity">warn</field>
                    <value name="TEXT">
                      <shadow type="text" id="+/+uj1X|3wvPa+EL==Aa">
                      <block type="get_value_var" id="ld$Y]!h,n*asj4VOLP05">
                        <value name="OID">
                          <shadow type="text" id="lorWqtUi2q{,SgHNm,O(">
                          <block type="text_join" id="%Mj,=I9Y(7rI(SPf26H^">
                            <value name="ADD0">
                              <block type="text_getSubstring" id="A;bSBAJzH#KBwHr(oJ|I">
                                  <block type="variables_get" id="p!Le_?0:lGo(BlaN1p;3">
                                <value name="AT2">
                                  <block type="math_number" id="rd+j#2SK?tM@Kg0$z:k?">
                            <value name="ADD1">
                              <block type="text" id="Ir%@AjEm,i:bfX5S~Ay0">
                                <field name="TEXT">hostname</field>
      • Hant0r
        @maximal1981 Mega, vielen lieben Dank - wieder was gelernt 😄
          Malz1902 last edited by
          also bei mir läuft der 24/7 durch
            warp735 @Malz1902 last edited by
            @malz1902
            Bei mir auch... Nur bei Updates kommen Absturz Meldungen. 1x Neustart und gut ist
              fliegema last edited by
              Moin Freunde des smarten Homes,
              nutze den Adapter (v0.6.6) schon länger und bis dato hat dieser immer tadelos funktioniert.
              Leider bekomme ich nun folgende Fehlermeldungen (leider kommt zwischen debug und info keine andere Meldung zustande):
              Eben habe ich den Adapter zum xten Mal neu gestartet und es kommt kein Fehler mehr und die Datenpunkte werden übertragen.
              Der Controller ist ein: Ubuntu 20.04.6 LTS (GNU/Linux 5.15.0-1038-oracle x86_64) mit Unifi 7.4.162
              Vouchers, Alarm, DPI und Gateway Traffic sind deaktiviert.
              Irgendwelche Ideen?
              Gruss
              • Meister Mopper
                Meister Mopper @fliegema last edited by
                @fliegema sagte in Adapter: ioBroker.unifi:
                Irgendwelche Ideen?
                Hast du heute das update des Adapters durchgeführt? In diesem Fall kommt diese Meldung, weil eine gewisse Zeit der Controller nicht erreichbar ist.
                  fliegema @Meister Mopper last edited by
                  @meister-mopper jup, hatte durch Zufall gesehen, dass es ein Update gibt. Hat mir der vorhergehenden Version aber auch nicht geklappt, es fing direkt nach dem Unif Adapter Update an. Habe auch bis auf 5.1. gedowngraded hat aber leider auch keinen Erfolg gebracht.
                  Kann ich irgendwie noch mehr debug Code zur Verfügung stellen?
                  • Meister Mopper
                    Meister Mopper last edited by Meister Mopper
                    @fliegema
                    Ok, dann stell mal hier das Ergebnis von
                    iob diag ein,
                    aber bitte in code tags
                      Irgendwelche Ideen?
                      einfach mal das passwort neu eintragen in der Instanz
                        fliegema @crunchip last edited by
                        Danke für die Hinweise, hat leider noch nicht geklappt.
                        @crunchip said in Adapter: ioBroker.unifi:
                        Irgendwelche Ideen?
                        Hatte ich bereits probiert und eben erneut ein neues Passwort vergeben. Er synced auch manchmal die Datenpunkte aber verabschiedet sich in den roten Status.
                        @meister-mopper said in Adapter: ioBroker.unifi:
                        @fliegema
                        iob diag ein,
                        2023-07-08 13:51:24.150  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 621374
                        2023-07-08 13:51:25.027  - info: unifi.0 (621374) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-07-08 13:51:25.183  - info: unifi.0 (621374) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v16.20.0, js-controller: 4.0.24
                        2023-07-08 13:51:25.228  - info: unifi.0 (621374) UniFi adapter is ready
                        2023-07-08 13:51:30.556  - error: unifi.0 (621374) [updateUnifiData-login site undefined] error: timeout of 5000ms exceeded, stack: AxiosError: timeout of 5000ms exceeded
                            at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3047:16)
                            at RedirectableRequest.emit (node:events:513:28)
                            at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)
                            at listOnTimeout (node:internal/timers:559:17)
                            at processTimers (node:internal/timers:502:7)
                        2023-07-08 13:51:30.557  - error: unifi.0 (621374) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-07-08 13:51:30.557  - error: unifi.0 (621374) unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                        2023-07-08 13:51:30.557  - error: unifi.0 (621374) TypeError: Cannot read properties of undefined (reading 'captureException')
                            at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53)
                            at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:268:22)
                        2023-07-08 13:51:30.557  - error: unifi.0 (621374) Cannot read properties of undefined (reading 'captureException')
                        2023-07-08 13:51:30.571  - info: unifi.0 (621374) cleaned everything up...
                        2023-07-08 13:51:30.571  - info: unifi.0 (621374) terminating
                        2023-07-08 13:51:30.572  - warn: unifi.0 (621374) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-07-08 13:51:31.135  - error: host.ioBroker instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-07-08 13:51:31.135  - info: host.ioBroker Restart adapter system.adapter.unifi.0 because enabled
                        2023-07-08 13:51:32.215  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 621464
                        2023-07-08 13:51:33.513  - info: unifi.0 (621464) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-07-08 13:51:33.942  - info: unifi.0 (621464) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v16.20.0, js-controller: 4.0.24
                        2023-07-08 13:51:34.084  - info: unifi.0 (621464) UniFi adapter is ready
                        Hier hat er es mal für 1min überlebt, danach wieder auf rot.
                        Versionsstände:
                        Core adapters versions
                        admin:          6.3.5
                        javascript:     7.0.3
                        Operatingsystem:        Ubuntu 22.04.2 LTS
                        Kernel:                 5.15.74-1-pve
                        Installation:           lxc
                        Timezone:               Europe/Berlin (CEST, +0200)
                        User-ID:                1001
                        X-Server:               false
                        Boot Target:            graphical.target
                        Pending OS-Updates:     6
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                                /usr/local/bin/node             v16.20.0
                                                /usr/local/bin/npm              8.19.4
                                                /usr/local/bin/npx              8.19.4
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        *** nodejs is NOT correctly installed ***
                        Hier wunder mich das "nicht korrekt installiert", habe einmal iob fix gemacht und danach kam es auch wieder.
                        Gruss
                        ? crunchip 2 Replies Last reply Reply Quote 0
                          A Former User @fliegema last edited by
                          @fliegema
                          Schau mal, ich denke deine Node Installation ist nicht ok… Nodejs v18 und Node v16…?
                            crunchip Forum Testing Most Active @fliegema last edited by crunchip
                            @fliegema nodejs ist falsch installiert
                            https://forum.iobroker.net/post/460727
                              fliegema @Guest last edited by
                              @ilovegym said in Adapter: ioBroker.unifi:
                              @fliegema
                              Korrekt, habe ich nun korrigiert.
                              Danke für den Link, habe in einem anderen Beitrag noch einen Befehl gefunden, welcher das Verzeichnis löscht, damit die v18 auch endlich startet.
                              Kurze Zusammenfassung, falls noch Jemand diese Infos braucht:
                              Kudos an: Help 1 & Help 2
                              iob stop
                              sudo rm /usr/local/bin/n*
                              sudo apt purge --autoremove nodejs* npm node-* libnode*
                              curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                              apt policy nodejs
                              sudo apt install nodejs
                              sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                              iob fix
                              iob start
                              Die oben genannten Befehle haben bei mir unter
                              sowie
                              Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                              Kernel:                 6.1.21-v7l+
                              und
                              Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                              Kernel:                 5.10.103-v7+
                              funktioniert.
                                                      /usr/bin/node           v18.16.1
                                                      /usr/bin/npm            9.5.1
                                                      /usr/bin/npx            9.5.1
                              Zum Unifi Adapater zurück, der bringt mir leider nach wie vor die gleichen Fehlermeldungen:
                              2023-07-08 16:43:26.513  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 11431
                              2023-07-08 16:43:27.483  - info: unifi.0 (11431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2023-07-08 16:43:27.600  - info: unifi.0 (11431) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.16.1, js-controller: 4.0.24
                              2023-07-08 16:43:27.649  - info: unifi.0 (11431) UniFi adapter is ready
                              2023-07-08 16:43:33.039  - error: unifi.0 (11431) [updateUnifiData-login site undefined] error: timeout of 5000ms exceeded, stack: AxiosError: timeout of 5000ms exceeded
                                  at listOnTimeout (node:internal/timers:569:17)
                                  at process.processTimers (node:internal/timers:512:7)
                              2023-07-08 16:43:33.040  - error: unifi.0 (11431) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2023-07-08 16:43:33.040  - error: unifi.0 (11431) unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                              2023-07-08 16:43:33.040  - error: unifi.0 (11431) TypeError: Cannot read properties of undefined (reading 'captureException')
                              2023-07-08 16:43:33.041  - error: unifi.0 (11431) Cannot read properties of undefined (reading 'captureException')
                              2023-07-08 16:43:33.049  - info: unifi.0 (11431) cleaned everything up...
                              2023-07-08 16:43:33.050  - info: unifi.0 (11431) terminating
                              2023-07-08 16:43:33.050  - warn: unifi.0 (11431) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2023-07-08 16:43:33.608  - error: host.ioBroker instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              2023-07-08 16:43:33.608  - info: host.ioBroker Restart adapter system.adapter.unifi.0 because enabled
                              2023-07-08 16:43:34.670  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 11485
                              2023-07-08 16:43:35.456  - info: unifi.0 (11485) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2023-07-08 16:43:35.537  - info: unifi.0 (11485) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.16.1, js-controller: 4.0.24
                              2023-07-08 16:43:35.603  - info: unifi.0 (11485) UniFi adapter is ready
                              habe auch nochmal Passwort neu eingetragen, leider kein Erfolg.
                                crunchip Forum Testing Most Active last edited by crunchip
                                @fliegema worauf läuft dein unifi bzw welche Firmware?
                                nach deiner nodejs Korrektur mal probiert den Adapter zu löschen und neu zu installieren?
                                ansonsten mal dort nachsehen, eventuell auch bei den bereits geschlossenen
                                https://github.com/iobroker-community-adapters/ioBroker.unifi/issues
                                  mhuber last edited by
                                  ich bekomme bei mir im iobroker Log immer wieder (3-4x am Tag) diese Fehlermeldungen, manchmal funktioniert trotzdem noch alles normal, manchmal scheint aber die Verbindung zum CloudKey unterbrochen zu sein, ein Restart vom Adapter hilft dann immer.
                                  Hab den iobroker im Docker laufen, überall (iobroker, Adapter, CloudKey...) latest Software, war aber auch in den letzten Releaes schon da der Fehler.
                                  Hat jemand einen Tipp?
                                  updateUnifiData site default] error: Request failed with status code 503, stack: AxiosError: Request failed with status code 503 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/core/settle.js:19:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/adapters/http.js:570:11) at IncomingMessage.emit (node:events:525:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1359:12) at processTicksAndRejections (node:internal/process/task_queues:82:21)
                                    @crunchip, Moin.
                                    Adapter löschen und neu installieren hat leider nicht geklappt. Gleiches Fehlerbild.
                                    Der Controller ist Ubuntu 20.04.6 LTS (GNU/Linux 5.15.0-1038-oracle x86_64) mit Unifi 7.4.162
                                    ich werde mal ein Issue aufmachen, gucken wir mal was kommt. Wobei der Log von sehr ähnlich aussieht.
                                    @mhuber said in Adapter: ioBroker.unifi:
                                    maduuto F 2 Replies Last reply Reply Quote 0
                                    • maduuto
                                      maduuto @fliegema last edited by
                                      Ich habe schon wieder das Problem, dass die Anwesenheit einfach nicht übermittelt wird., sprich der Status is_online nicht übermittelt wird (ggf andere Parameter auch nicht die nutze ich nur nicht) Ich probiere mal die Version 6.0.
                                      Unifi Controller ist auf dem aktuellsten Stand. Nach einem Adapterneustart funktioniert das meist einmalig.
                                        crunchip Forum Testing Most Active @maduuto last edited by
                                        @maduuto dss hatte ich auch seit geraumer Zeit, seitdem mach ich einen Neustart der Instanz alle 6 Std.
                                          Digi-Bit @crunchip last edited by
                                          Hallo
                                          Ich würde gerne einen Datenpunkt für WAN2 haben wollen, also wenn da einer schon ist dann sehe ich den nicht 😞
                                          unifi.0.default.health.wan.wan_ip ist ja WAN1
                                          unifi.0.default.health.wan2.wan_ip müsste dann so aussehen oder wie ?
                                          Mann kann ja wohl auch daten punkte selber anlegen aber ich habe da kein Plan wie man das machen soll.
                                          Kann mich da mal einer in die richtige Richtung schuppsen ? ^^
                                          mfg
                                          Digi-Bit
                                            crunchip Forum Testing Most Active @Digi-Bit last edited by
                                            @digi-bit es wird nur das abgerufen was der Adapter bringt
                                            unifi
                                            171
                                            1010
                                            383826
