    3. Einsteigerfragen
    4. Nodejs und Vis Probleme
      crunchip Forum Testing Most Active @wurschtbrot last edited by
      @wurschtbrot die Meldung im Host bestätigen und danach den Adapter neu starten, sollte es immer noch nicht gehen, dann den iobroker einmal neu starten
        wurschtbrot @crunchip last edited by
        @crunchip
        alles gemacht aber ohne besserung
        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
          @wurschtbrot ok, das schalt mal die Instanz aus und aktiviere sie morgen wieder
            Thomas Braun Most Active @wurschtbrot last edited by
            @wurschtbrot
            Oder das Log vom Start des Adapters anschauen.
              wurschtbrot @Thomas Braun last edited by wurschtbrot
              Zeit
              error
              Nachricht
              host.iobr22
              2023-07-09 20:29:51.605	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              systeminfo.0
              2023-07-09 20:29:50.394	error	Cannot read properties of undefined (reading 'getObjectList')
              systeminfo.0
              2023-07-09 20:29:50.392	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
              systeminfo.0
              2023-07-09 20:29:50.389	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
              systeminfo.0
              2023-07-09 20:29:50.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              host.iobr22
              2023-07-09 20:29:17.242	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              systeminfo.0
              2023-07-09 20:29:16.048	error	Cannot read properties of undefined (reading 'getObjectList')
              systeminfo.0
              2023-07-09 20:29:16.046	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
              systeminfo.0
              2023-07-09 20:29:16.043	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
              systeminfo.0
              2023-07-09 20:29:16.042	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
                @wurschtbrot
                Das vollständige, 'richtige' log. Gibt es mit
                iob logs --watch
                  @wurschtbrot probier mal ein upload vom Adapter
                    2023-07-09 20:34:32.842  - error: systeminfo.0 (29931) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:32.845  - error: systeminfo.0 (29931) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:32.847  - error: systeminfo.0 (29931) Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:33.366  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 (force=false, process=true)
                    2023-07-09 20:34:33.372  - info: systeminfo.0 (29931) terminating
                    2023-07-09 20:34:33.374  - warn: systeminfo.0 (29931) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-07-09 20:34:33.414  - info: systeminfo.0 (29931) Got terminate signal TERMINATE_YOURSELF
                    2023-07-09 20:34:33.591  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 send kill signal
                    2023-07-09 20:34:33.995  - info: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2023-07-09 20:34:32.795  - info: systeminfo.0 (29931) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                    2023-07-09 20:34:32.840  - error: systeminfo.0 (29931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-07-09 20:34:36.631  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 30008
                    2023-07-09 20:34:39.474  - info: systeminfo.0 (30008) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                    2023-07-09 20:34:39.515  - error: systeminfo.0 (30008) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-07-09 20:34:39.516  - error: systeminfo.0 (30008) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:39.519  - error: systeminfo.0 (30008) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:39.520  - error: systeminfo.0 (30008) Cannot read properties of undefined (reading 'getObjectList')
                    2023-07-09 20:34:40.052  - info: systeminfo.0 (30008) terminating
                    2023-07-09 20:34:40.053  - warn: systeminfo.0 (30008) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-07-09 20:34:40.705  - error: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2023-07-09 20:34:40.707  - info: host.iobr22 Restart adapter system.adapter.systeminfo.0 because enabled
                    2023-07-09 20:34:40.708  - warn: host.iobr22 Do not restart adapter system.adapter.systeminfo.0 because restart loop detected
                    ich hoffe das reicht so
                      @wurschtbrot https://forum.iobroker.net/post/770008
                        @crunchip bin da nicht so fit was genau muss ich da machen
                          Dürfte das sein:
                          https://github.com/iobroker-community-adapters/ioBroker.systeminfo/issues/35
                          Wundert mich nur, dass da so lange nichts passiert ist. Der Adapter scheint aber auch verwaist zu sein.
                          foxriver76 created this issue in iobroker-community-adapters/ioBroker.systeminfo
                          open adapter.objects.getObjectList will be removed with controller v4 #35
                            @wurschtbrot
                            Ich zitiere mal:
                            du musst /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js öffnen und dort in Zeile 44 das "object." vor dem getObjectList entfernen.
                            W crunchip 2 Replies Last reply Reply Quote 0
                              : No such file or directoryiobroker.systeminfo/myAdapter.js: line 1: /**
                              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 2: node_modules: command not found
                              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: syntax error near unexpected token `c'
                              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: ` *      (c' 2016- <frankjoke@hotmail.com>
                              das kommt dann
                                @wurschtbrot sagte in Nodejs und Vis Probleme:
                                das kommt dann
                                Wann kommt das? Bitte immer vollständige Eingabezeilen posten.
                                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                                  @thomas-braun finde ich bei mir gar nicht
                                  W Thomas Braun 2 Replies Last reply Reply Quote 0
                                    @crunchip
                                    pi@iobr22:~ $ /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                    pi@iobr22:~ $
                                      @wurschtbrot
                                      Du musst auch einen Editor angeben, mit dem du werkeln willst.
                                      nano ist z. B. einer.
                                      Oder du installierst den Adapter aus dem github, da dürfte das bereinigt sein.
                                        Thomas Braun Most Active @crunchip last edited by
                                        @crunchip
                                        Im Master scheint es auch behoben zu sein:
                                        https://github.com/iobroker-community-adapters/ioBroker.systeminfo/blob/master/myAdapter.js
                                          @thomas-braun bei mir gibt es aber auch kein
                                            @crunchip
                                            Zu warm? Hast du den Adapter installiert?
                                            1993
