    3. Einsteigerfragen
    4. Nodejs und Vis Probleme
      wurschtbrot @crunchip last edited by
      @crunchip
      alles gemacht aber ohne besserung
      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @wurschtbrot last edited by
        @wurschtbrot ok, das schalt mal die Instanz aus und aktiviere sie morgen wieder
          Thomas Braun Most Active @wurschtbrot last edited by
          @wurschtbrot
          Oder das Log vom Start des Adapters anschauen.
            wurschtbrot @Thomas Braun last edited by wurschtbrot
            Zeit
            error
            Nachricht
            host.iobr22
            2023-07-09 20:29:51.605	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            systeminfo.0
            2023-07-09 20:29:50.394	error	Cannot read properties of undefined (reading 'getObjectList')
            systeminfo.0
            2023-07-09 20:29:50.392	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
            systeminfo.0
            2023-07-09 20:29:50.389	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
            systeminfo.0
            2023-07-09 20:29:50.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.iobr22
            2023-07-09 20:29:17.242	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            systeminfo.0
            2023-07-09 20:29:16.048	error	Cannot read properties of undefined (reading 'getObjectList')
            systeminfo.0
            2023-07-09 20:29:16.046	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
            systeminfo.0
            2023-07-09 20:29:16.043	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
            systeminfo.0
            2023-07-09 20:29:16.042	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
              @wurschtbrot
              Das vollständige, 'richtige' log. Gibt es mit
              iob logs --watch
                @wurschtbrot probier mal ein upload vom Adapter
                  2023-07-09 20:34:32.842  - error: systeminfo.0 (29931) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:32.845  - error: systeminfo.0 (29931) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:32.847  - error: systeminfo.0 (29931) Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:33.366  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 (force=false, process=true)
                  2023-07-09 20:34:33.372  - info: systeminfo.0 (29931) terminating
                  2023-07-09 20:34:33.374  - warn: systeminfo.0 (29931) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2023-07-09 20:34:33.414  - info: systeminfo.0 (29931) Got terminate signal TERMINATE_YOURSELF
                  2023-07-09 20:34:33.591  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 send kill signal
                  2023-07-09 20:34:33.995  - info: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2023-07-09 20:34:32.795  - info: systeminfo.0 (29931) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                  2023-07-09 20:34:32.840  - error: systeminfo.0 (29931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2023-07-09 20:34:36.631  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 30008
                  2023-07-09 20:34:39.474  - info: systeminfo.0 (30008) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                  2023-07-09 20:34:39.515  - error: systeminfo.0 (30008) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2023-07-09 20:34:39.516  - error: systeminfo.0 (30008) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:39.519  - error: systeminfo.0 (30008) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:39.520  - error: systeminfo.0 (30008) Cannot read properties of undefined (reading 'getObjectList')
                  2023-07-09 20:34:40.052  - info: systeminfo.0 (30008) terminating
                  2023-07-09 20:34:40.053  - warn: systeminfo.0 (30008) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2023-07-09 20:34:40.705  - error: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2023-07-09 20:34:40.707  - info: host.iobr22 Restart adapter system.adapter.systeminfo.0 because enabled
                  2023-07-09 20:34:40.708  - warn: host.iobr22 Do not restart adapter system.adapter.systeminfo.0 because restart loop detected
                  ich hoffe das reicht so
                    @wurschtbrot https://forum.iobroker.net/post/770008
                      @crunchip bin da nicht so fit was genau muss ich da machen
                        Dürfte das sein:
                        https://github.com/iobroker-community-adapters/ioBroker.systeminfo/issues/35
                        Wundert mich nur, dass da so lange nichts passiert ist. Der Adapter scheint aber auch verwaist zu sein.
                        foxriver76 created this issue in iobroker-community-adapters/ioBroker.systeminfo
                        open adapter.objects.getObjectList will be removed with controller v4 #35
                          @wurschtbrot
                          Ich zitiere mal:
                          du musst /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js öffnen und dort in Zeile 44 das "object." vor dem getObjectList entfernen.
                          W crunchip 2 Replies Last reply Reply Quote 0
                            : No such file or directoryiobroker.systeminfo/myAdapter.js: line 1: /**
                            /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 2: node_modules: command not found
                            /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: syntax error near unexpected token `c'
                            /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: ` *      (c' 2016- <frankjoke@hotmail.com>
                            das kommt dann
                              @wurschtbrot sagte in Nodejs und Vis Probleme:
                              das kommt dann
                              Wann kommt das? Bitte immer vollständige Eingabezeilen posten.
                                crunchip Forum Testing Most Active @Thomas Braun last edited by
                                @thomas-braun finde ich bei mir gar nicht
                                W Thomas Braun 2 Replies Last reply Reply Quote 0
                                  @crunchip
                                  pi@iobr22:~ $ /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                  pi@iobr22:~ $
                                    @wurschtbrot
                                    Du musst auch einen Editor angeben, mit dem du werkeln willst.
                                    nano ist z. B. einer.
                                    Oder du installierst den Adapter aus dem github, da dürfte das bereinigt sein.
                                      Thomas Braun Most Active @crunchip last edited by
                                      @crunchip
                                      Im Master scheint es auch behoben zu sein:
                                      https://github.com/iobroker-community-adapters/ioBroker.systeminfo/blob/master/myAdapter.js
                                        @thomas-braun bei mir gibt es aber auch kein
                                          @crunchip
                                          Zu warm? Hast du den Adapter installiert?
                                            crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                                            @thomas-braun ja der Adapter läuft bei mir, hab ihn nur in der Regel aus und schalt gelegentlich die Instanz mal ein
                                            gibt vllt mit dem neuen Js-controller/admin nicht mehr
                                            1993
