    3. Einsteigerfragen
    4. Nodejs und Vis Probleme
      crunchip Forum Testing Most Active @wurschtbrot last edited by
      @wurschtbrot ok, das schalt mal die Instanz aus und aktiviere sie morgen wieder
        Thomas Braun Most Active @wurschtbrot last edited by
        @wurschtbrot
        Oder das Log vom Start des Adapters anschauen.
          wurschtbrot @Thomas Braun last edited by wurschtbrot
          Zeit
          error
          Nachricht
          host.iobr22
          2023-07-09 20:29:51.605	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          systeminfo.0
          2023-07-09 20:29:50.394	error	Cannot read properties of undefined (reading 'getObjectList')
          systeminfo.0
          2023-07-09 20:29:50.392	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
          systeminfo.0
          2023-07-09 20:29:50.389	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
          systeminfo.0
          2023-07-09 20:29:50.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.iobr22
          2023-07-09 20:29:17.242	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          systeminfo.0
          2023-07-09 20:29:16.048	error	Cannot read properties of undefined (reading 'getObjectList')
          systeminfo.0
          2023-07-09 20:29:16.046	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
          systeminfo.0
          2023-07-09 20:29:16.043	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
          systeminfo.0
          2023-07-09 20:29:16.042	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
            @wurschtbrot
            Das vollständige, 'richtige' log. Gibt es mit
            iob logs --watch
              @wurschtbrot probier mal ein upload vom Adapter
                2023-07-09 20:34:32.842  - error: systeminfo.0 (29931) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:32.845  - error: systeminfo.0 (29931) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:32.847  - error: systeminfo.0 (29931) Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:33.366  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 (force=false, process=true)
                2023-07-09 20:34:33.372  - info: systeminfo.0 (29931) terminating
                2023-07-09 20:34:33.374  - warn: systeminfo.0 (29931) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-07-09 20:34:33.414  - info: systeminfo.0 (29931) Got terminate signal TERMINATE_YOURSELF
                2023-07-09 20:34:33.591  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 send kill signal
                2023-07-09 20:34:33.995  - info: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-07-09 20:34:32.795  - info: systeminfo.0 (29931) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                2023-07-09 20:34:32.840  - error: systeminfo.0 (29931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-07-09 20:34:36.631  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 30008
                2023-07-09 20:34:39.474  - info: systeminfo.0 (30008) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
                2023-07-09 20:34:39.515  - error: systeminfo.0 (30008) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-07-09 20:34:39.516  - error: systeminfo.0 (30008) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:39.519  - error: systeminfo.0 (30008) TypeError: Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:39.520  - error: systeminfo.0 (30008) Cannot read properties of undefined (reading 'getObjectList')
                2023-07-09 20:34:40.052  - info: systeminfo.0 (30008) terminating
                2023-07-09 20:34:40.053  - warn: systeminfo.0 (30008) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-07-09 20:34:40.705  - error: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-07-09 20:34:40.707  - info: host.iobr22 Restart adapter system.adapter.systeminfo.0 because enabled
                2023-07-09 20:34:40.708  - warn: host.iobr22 Do not restart adapter system.adapter.systeminfo.0 because restart loop detected
                ich hoffe das reicht so
                  @wurschtbrot https://forum.iobroker.net/post/770008
                    wurschtbrot @crunchip last edited by
                    @crunchip bin da nicht so fit was genau muss ich da machen
                      Dürfte das sein:
                      https://github.com/iobroker-community-adapters/ioBroker.systeminfo/issues/35
                      Wundert mich nur, dass da so lange nichts passiert ist. Der Adapter scheint aber auch verwaist zu sein.
                      foxriver76 created this issue in iobroker-community-adapters/ioBroker.systeminfo
                      open adapter.objects.getObjectList will be removed with controller v4 #35
                        @wurschtbrot
                        Ich zitiere mal:
                        du musst /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js öffnen und dort in Zeile 44 das "object." vor dem getObjectList entfernen.
                        W crunchip 2 Replies Last reply Reply Quote 0
                          : No such file or directoryiobroker.systeminfo/myAdapter.js: line 1: /**
                          /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 2: node_modules: command not found
                          /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: syntax error near unexpected token `c'
                          /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: ` *      (c' 2016- <frankjoke@hotmail.com>
                          das kommt dann
                            @wurschtbrot sagte in Nodejs und Vis Probleme:
                            das kommt dann
                            Wann kommt das? Bitte immer vollständige Eingabezeilen posten.
                              crunchip Forum Testing Most Active @Thomas Braun last edited by
                              @thomas-braun finde ich bei mir gar nicht
                              W Thomas Braun 2 Replies Last reply Reply Quote 0
                                @crunchip
                                pi@iobr22:~ $ /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                pi@iobr22:~ $
                                  @wurschtbrot
                                  Du musst auch einen Editor angeben, mit dem du werkeln willst.
                                  nano ist z. B. einer.
                                  Oder du installierst den Adapter aus dem github, da dürfte das bereinigt sein.
                                    Thomas Braun Most Active @crunchip last edited by
                                    @crunchip
                                    Im Master scheint es auch behoben zu sein:
                                    https://github.com/iobroker-community-adapters/ioBroker.systeminfo/blob/master/myAdapter.js
                                      @thomas-braun bei mir gibt es aber auch kein
                                        @crunchip
                                        Zu warm? Hast du den Adapter installiert?
                                          crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                                          @thomas-braun ja der Adapter läuft bei mir, hab ihn nur in der Regel aus und schalt gelegentlich die Instanz mal ein
                                          gibt vllt mit dem neuen Js-controller/admin nicht mehr
                                            @crunchip
                                            Hier gibt es das:
                                            echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                            -rw-rw-r--+ 1 iobroker iobroker 25K Jul  9 21:08 /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                            1992
