    3. Einsteigerfragen
    4. Nodejs und Vis Probleme
      wurschtbrot @Thomas Braun last edited by
      2023-07-09 20:34:32.842  - error: systeminfo.0 (29931) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
      2023-07-09 20:34:32.845  - error: systeminfo.0 (29931) TypeError: Cannot read properties of undefined (reading 'getObjectList')
          at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55)
          at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37)
          at Adapter.emit (node:events:513:28)
          at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
      2023-07-09 20:34:32.847  - error: systeminfo.0 (29931) Cannot read properties of undefined (reading 'getObjectList')
      2023-07-09 20:34:33.366  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 (force=false, process=true)
      2023-07-09 20:34:33.372  - info: systeminfo.0 (29931) terminating
      2023-07-09 20:34:33.374  - warn: systeminfo.0 (29931) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-07-09 20:34:33.414  - info: systeminfo.0 (29931) Got terminate signal TERMINATE_YOURSELF
      2023-07-09 20:34:33.591  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 send kill signal
      2023-07-09 20:34:33.995  - info: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-07-09 20:34:32.795  - info: systeminfo.0 (29931) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
      2023-07-09 20:34:32.840  - error: systeminfo.0 (29931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-07-09 20:34:36.631  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 30008
      2023-07-09 20:34:39.474  - info: systeminfo.0 (30008) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
      2023-07-09 20:34:39.515  - error: systeminfo.0 (30008) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-07-09 20:34:39.516  - error: systeminfo.0 (30008) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
      2023-07-09 20:34:39.519  - error: systeminfo.0 (30008) TypeError: Cannot read properties of undefined (reading 'getObjectList')
      2023-07-09 20:34:39.520  - error: systeminfo.0 (30008) Cannot read properties of undefined (reading 'getObjectList')
      2023-07-09 20:34:40.052  - info: systeminfo.0 (30008) terminating
      2023-07-09 20:34:40.053  - warn: systeminfo.0 (30008) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-07-09 20:34:40.705  - error: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-07-09 20:34:40.707  - info: host.iobr22 Restart adapter system.adapter.systeminfo.0 because enabled
      2023-07-09 20:34:40.708  - warn: host.iobr22 Do not restart adapter system.adapter.systeminfo.0 because restart loop detected
      ich hoffe das reicht so
        crunchip Forum Testing Most Active @wurschtbrot last edited by
        @wurschtbrot https://forum.iobroker.net/post/770008
          wurschtbrot @crunchip last edited by
          @crunchip bin da nicht so fit was genau muss ich da machen
            Thomas Braun Most Active @wurschtbrot last edited by
            Dürfte das sein:
            https://github.com/iobroker-community-adapters/ioBroker.systeminfo/issues/35
            Wundert mich nur, dass da so lange nichts passiert ist. Der Adapter scheint aber auch verwaist zu sein.
            foxriver76 created this issue in iobroker-community-adapters/ioBroker.systeminfo
            open adapter.objects.getObjectList will be removed with controller v4 #35
              @wurschtbrot
              Ich zitiere mal:
              du musst /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js öffnen und dort in Zeile 44 das "object." vor dem getObjectList entfernen.
              W crunchip 2 Replies Last reply Reply Quote 0
                : No such file or directoryiobroker.systeminfo/myAdapter.js: line 1: /**
                /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 2: node_modules: command not found
                /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: syntax error near unexpected token `c'
                /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: ` *      (c' 2016- <frankjoke@hotmail.com>
                das kommt dann
                  @wurschtbrot sagte in Nodejs und Vis Probleme:
                  das kommt dann
                  Wann kommt das? Bitte immer vollständige Eingabezeilen posten.
                    crunchip Forum Testing Most Active @Thomas Braun last edited by
                    @thomas-braun finde ich bei mir gar nicht
                    W Thomas Braun 2 Replies Last reply Reply Quote 0
                      @crunchip
                      pi@iobr22:~ $ /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                      pi@iobr22:~ $
                        @wurschtbrot
                        Du musst auch einen Editor angeben, mit dem du werkeln willst.
                        nano ist z. B. einer.
                        Oder du installierst den Adapter aus dem github, da dürfte das bereinigt sein.
                          Thomas Braun Most Active @crunchip last edited by
                          @crunchip
                          Im Master scheint es auch behoben zu sein:
                          https://github.com/iobroker-community-adapters/ioBroker.systeminfo/blob/master/myAdapter.js
                            @thomas-braun bei mir gibt es aber auch kein
                              @crunchip
                              Zu warm? Hast du den Adapter installiert?
                                crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                                @thomas-braun ja der Adapter läuft bei mir, hab ihn nur in der Regel aus und schalt gelegentlich die Instanz mal ein
                                gibt vllt mit dem neuen Js-controller/admin nicht mehr
                                  @crunchip
                                  Hier gibt es das:
                                  echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                  -rw-rw-r--+ 1 iobroker iobroker 25K Jul  9 21:08 /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                    @thomas-braun sagte in Nodejs und Vis Probleme:
                                    Zugriff auf '/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                      :räusper:
                                      wir befinden uns in den Einsteigerfragen!
                                      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                        @crunchip
                                        In der Version aus dem Beta-Repo:
                                                this.D(`Adapter ${this.ains} starting.`);
                                                this.getObjectList = this.c2p(adapter.objects.getObjectList).bind(adapter.objects);
                                                this.getForeignState = this.c2p(adapter.getForeignState).bind(adapter);
                                        Da ist der Fehler noch drin.
                                        Github kommt so daher:
                                            static initAdapter() {
                                                states = {};
                                                this.getObjectList = this.c2p(adapter.getObjectList);
                                                this.getForeignState = this.c2p(adapter.getForeignState);
                                                this.setForeignState = this.c2p(adapter.setForeignState);
                                                this.getState = this.c2p(adapter.getState);
                                          crunchip Forum Testing Most Active @Homoran last edited by
                                          @homoran hihi, gar nicht darauf geachtet
                                            @homoran sagte in Nodejs und Vis Probleme:
                                            Ich helf dem @crunchip doch gerade... 😛
                                            1993
