    4. hm-rega down nach Umzug
    • O
      oscool90 @sigi234 last edited by
      @sigi234 Node 20.4.0, NPM 9.7.2
      • DJMarc75
        DJMarc75 @oscool90 last edited by DJMarc75
        @oscool90 sagte in hm-rega down nach Umzug:
        Das System habe ich gerade neu aufgesetzt.
        Node 20.x ist noch lange nicht empfohlen sondern 18.x 😉
        Zeig mal was
        iob diag
        auswirft
        • O
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           06:54:26 up  8:20,  3 users,  load average: 0.19, 0.23, 0.21
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=44.8'C
          volt=0.9360V
          *** Time and Time Zones ***
                         Local time: Mon 2023-07-10 06:54:26 BST
                     Universal time: Mon 2023-07-10 05:54:26 UTC
                           RTC time: n/a
                          Time zone: Europe/London (BST, +0100)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        1.1G        1.7G         35M        1.1G        2.6G
          Swap:            99M          0B         99M
          Total:          3.9G        1.1G        1.8G
                   3794 M total memory
                   1064 M used memory
                   1272 M active memory
                    610 M inactive memory
                   1651 M free memory
                    133 M buffer memory
                    944 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       59G  5.8G   51G  11% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
          [Sun Jul  9 22:33:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74        072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-ser        ial-consoles
          [Sun Jul  9 22:33:49 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
          [Sun Jul  9 22:33:49 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
          [Sun Jul  9 22:33:51 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,errors=remount-ro
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          1.4G    /var/
          783M    /var/lib
          599M    /var/lib/piVCCU3
          545M    /var/lib/piVCCU3/rootfs
          332M    /var/cache
          Archived and active journals take up 136.0M in the file system.
          /opt/iobroker/backups:
          11M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          132M    /opt/iobroker/iobroker-data/
          100M    /opt/iobroker/iobroker-data/files
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          18M     /opt/iobroker/iobroker-data/objects.jsonl
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c        9.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
          5.4M    /opt/iobroker/iobroker-data/files/jarvis/js/index-566ba00e.js
          4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922        d.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.4.0
          /usr/bin/node           v20.4.0
          /usr/bin/npm            9.7.2
          /usr/bin/npx            9.7.2
          nodejs:
            Installed: 20.4.0-deb-1nodesource1
            Candidate: 20.4.0-deb-1nodesource1
            Version table:
           *** 20.4.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_20.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.history.0                : history               : raspberrypi                              - disabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "hm-rega"      : 3.0.46   , installed 3.0.44 [Updatable]
          Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.9-beta.2
          Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
          Objects and States
          Objects:        1319
          States:         1034
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_20.x bullseye InRelease
          Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15776      832/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16735      832/iobroker.js-con
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13268      910/dnsmasq
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21288      3769/io.jarvis.0
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          49552      8937/cupsd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15502      888/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19124      2644/io.sonoff.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18234      2376/node-red
          tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN      1001       49163      8644/io.hm-rpc.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15504      888/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18119      1798/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          49551      8937/cupsd
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13267      910/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13264      910/dnsmasq
          udp        0      0 0.0.0.0:53578           0.0.0.0:*                           108        13904      379/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          51286      8940/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13902      379/avahi-daemon: r
          udp6       0      0 :::35405                :::*                                108        13905      379/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        13903      379/avahi-daemon: r
          2023-07-10 06:42:55.281  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:43:25.286  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:43:55.292  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:44:25.297  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:44:55.302  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:45:25.307  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:45:55.312  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:46:25.317  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:46:55.323  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:47:25.327  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:47:55.335  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:48:25.362  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:48:55.375  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:49:25.383  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:49:55.388  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:50:25.394  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:50:55.408  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:51:25.414  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:51:55.420  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:52:25.428  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:52:55.433  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:53:25.439  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:53:55.443  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:54:25.449  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
          2023-07-10 06:54:55.456  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
            sigi234 Forum Testing Most Active @oscool90 last edited by
            Falsche Node Version!
            • O
              oscool90 last edited by oscool90
              Danke für eure Hilfe! Habe versucht, node mit nvm zurückzudrehen. Laut Konsole hat das wohl auch geklappt. Habe vorher den iobroker gestoppt.
              pi@raspberrypi:~ $ node -v
              v18.16.1
              pi@raspberrypi:~ $ npm -v
              9.5.1
              Nach Start des iobroker wird in der Weboberfläche aber immer noch node 20.4.0 angezeigt; hm-rega funktioniert noch nicht (gleich Meldung wie oben). Kann ich prüfen, ob zwei Versionen von node gleichzeitig laufen?! Wie kann ich das korrigieren?
                Thomas Braun Most Active @oscool90 last edited by Thomas Braun
                Das ist Bestandteil von
                iob diag
                Stell die Zeitzone richtig, schalt den Desktop-Krempel aus.
                Und was ist da kaputt?
                Bring die Adapter auf Stand.
                • O
                  Hallo Thomas,
                  dann auf ein Neues:
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                   08:31:29 up  9:57,  3 users,  load average: 0.07, 0.38, 0.34
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=45.2'C
                  volt=0.9360V
                                 Local time: Mon 2023-07-10 08:31:30 BST
                             Universal time: Mon 2023-07-10 07:31:30 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        952M        1.6G         35M        1.3G        2.7G
                  Swap:            99M          0B         99M
                  Total:          3.9G        952M        1.7G
                           3794 M total memory
                            952 M used memory
                           1162 M active memory
                            804 M inactive memory
                           1552 M free memory
                            143 M buffer memory
                           1145 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       59G  6.0G   50G  11% /
                  [Sun Jul  9 22:33:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Sun Jul  9 22:33:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.4G    /var/
                  783M    /var/lib
                  332M    /var/cache
                  135M    /opt/iobroker/iobroker-data/
                  6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
                  /home/pi/.nvm/versions/node/v18.16.1/bin/node           v18.16.1
                  /home/pi/.nvm/versions/node/v18.16.1/bin/npm            9.5.1
                  /home/pi/.nvm/versions/node/v18.16.1/bin/npx            9.5.1
                  *** nodejs is NOT correctly installed ***
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                  Objects and States
                  Objects:        1319
                  States:         1034
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       204254     41977/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       204259     41977/iobroker.js-c
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       204550     42183/io.jarvis.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       204531     42143/io.sonoff.0
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       205283     42059/node-red
                  tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN      1001       204397     42094/io.hm-rpc.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       205227     42004/io.admin.0
                  2023-07-10 08:27:15.924  - info: host.raspberrypi iobroker upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  2023-07-10 08:27:15.934  - info: host.raspberrypi iobroker upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  2023-07-10 08:27:15.944  - info: host.raspberrypi iobroker upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  2023-07-10 08:27:15.956  - info: host.raspberrypi iobroker upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  2023-07-10 08:27:15.976  - info: host.raspberrypi iobroker upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  2023-07-10 08:27:15.986  - info: host.raspberrypi iobroker upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                  2023-07-10 08:27:15.996  - info: host.raspberrypi iobroker upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                  2023-07-10 08:27:16.006  - info: host.raspberrypi iobroker upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                  2023-07-10 08:27:16.362  - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-07-10 08:27:17.078  - info: host.raspberrypi iobroker exit 0
                  2023-07-10 08:27:18.858  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 42423
                  2023-07-10 08:27:21.170  - info: hm-rega.0 (42423) starting. Version 3.0.46 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v20.4.0, js-controller: 4.0.24
                  2023-07-10 08:27:21.306  - info: hm-rega.0 (42423) [REGASCRIPTS] Successfully updated datapoints.fn
                  2023-07-10 08:27:21.345  - info: hm-rega.0 (42423) subscribe .BidCoS-RF.50.PRESS_SHORT
                  2023-07-10 08:27:21.387  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:27:51.409  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:28:21.429  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:28:51.446  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:29:21.464  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:29:51.481  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:30:21.505  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:30:51.523  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:31:21.535  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:31:51.545  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  2023-07-10 08:32:21.554  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
                  Ich sehe zwar
                  mir fehlen aber die Kenntnisse zur Reparatur. Welche Schritte sind hier notwendig?
                  Ich nutze die Desktop-Oberfläche des Pi ohnehin nicht. Wie kann ich sie ausschalten?
                  Wie prüfe ich die Zeit? Zumindest augenscheinlich passt die Systemzeit.
                  Was meinst du mit "Adapter auf Stand bringen"?
                    Ich gehe mal davon aus, das du nicht in London wohnst.
                    Stell es in
                    sudo raspi-config
                    ein. Irgendwo unter 'Localization'.
                    Dort kann man auch den Desktop ausstellen. Unter 'Boot Options' auf 'CLI with login' umstellen.
                    ls -lah /var/lib/lxcfs/cgroup
                    sagt?
                    Und bitte bitte nodejs NIEMALS mit nvm oder ähnlichen Tools anpacken.
                    Schau in meiner Signatur wie man das richtig über den Paketmanager macht.
                    Wenn das alles gerade gezogen wurde:
                    aktualisieren.
                    • O
                      Hallo Thomas,
                      danke für deine ausführliche Antwort.
                      Localization steht jetzt auf Berlin.
                      Grafische Oberfläche ausschalten:
                      1b1886c4-610d-46d7-b66d-58fdc11e285b-grafik.png Dürfte bereits aus sein, wenn ich es richtig verstehe.
                      Den Befehl ls -lah /var/lib/lxcfs/cgroup verstehe ich nicht, sorry. Bei LXC handelt es sich wohl um ein eigenes System(?), in dem ich mit meinen bescheidenen Kenntnissen nicht allein herumwühlen möchte.
                      Das mit NVM habe ich vorher geahnt... Konnte es nun deinstallieren und node v18 aufsetzen.
                      Vis und JavaScript sind auch aktualisiert. Ich nutze Jarvis/Grafana. Ist ein aktuelles Vis notwendig, damit die anderen Adapter korrekt arbeiten?
                      Und siehe da: Der ReGa-Adapter läuft jetzt. 😊 Werde später ans Testen gehen. Falls ich mich nicht mehr melde, läuft alles und ich darf mich vielmals bedanken!
                        Du musst diesen Punkt bestätigen. Dann einen Neustart, wenn es nicht ohnehin von raspi-config beim Verlassen vorgeschlagen wird.
                        Zeig mal die Ausgabe von iob diag nun.
                        Mit
                        schaut man, welche Rechte da erforderlich sein könnten. Ich vermute, das ist irgendwas von pivCCU.
                        • O
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                           10:45:18 up 6 min,  1 user,  load average: 0.70, 0.73, 0.39
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=47.7'C
                          volt=0.9360V
                                         Local time: Mon 2023-07-10 10:45:18 CEST
                                     Universal time: Mon 2023-07-10 08:45:18 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            3.8G        877M        2.0G        1.0M        891M        2.8G
                          Swap:            99M          0B         99M
                          Total:          3.9G        877M        2.1G
                                   3794 M total memory
                                    877 M used memory
                                    986 M active memory
                                    585 M inactive memory
                                   2025 M free memory
                                     86 M buffer memory
                                    804 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G  5.9G   50G  11% /
                          tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                          [Mon Jul 10 10:39:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74        072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-ser        ial-consoles
                          [Mon Jul 10 10:39:09 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                          [Mon Jul 10 10:39:09 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                          [Mon Jul 10 10:39:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          /var:
                          1.4G    /var/
                          783M    /var/lib
                          332M    /var/cache
                          Archived and active journals take up 168.0M in the file system.
                          119M    /opt/iobroker/iobroker-data/
                          103M    /opt/iobroker/iobroker-data/files
                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                          33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a        8.chunk.js.map
                          5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42        .chunk.js.map
                          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
                          /usr/bin/nodejs         v18.16.1
                          /usr/bin/node           v18.16.1
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Installed: 18.16.1-deb-1nodesource1
                            Candidate: 18.16.1-deb-1nodesource1
                            Version table:
                           *** 18.16.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                  500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     7.0.3
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                            system.adapter.web.0                    : web                   : raspberrypi        - disabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                          + instance is alive
                          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                          Adapter    "vis"          : 1.4.16   , installed 1.4.16
                          Objects and States
                          Objects:        1324
                          States:         1040
                          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                          Pending Updates: 0
                          Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN        1001       21460      4380/io.jarvis.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          14745      859/sshd: /usr/sbin
                          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          15475      888/dnsmasq
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN        1001       25807      4262/node-red
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       21433      4348/io.sonoff.0
                          tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN        1001       25827      4290/io.hm-rpc.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       25740      4200/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       23884      4200/iobroker.js-co
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN        0          1635       817/cupsd
                          tcp6       0      0 :::22                   :::*                    LISTEN        0          15456      859/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN        1001       23929      4219/io.admin.0
                          tcp6       0      0 ::1:631                 :::*                    LISTEN        0          1634       817/cupsd
                          udp        0      0 10.0.3.1:53             0.0.0.0:*        0          15474      888/dnsmasq
                          udp        0      0 0.0.0.0:67              0.0.0.0:*        0          15471      888/dnsmasq
                          udp        0      0 0.0.0.0:631             0.0.0.0:*        0          15501      891/cups-browsed
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        14595      365/avahi-daemon: r
                          udp        0      0 0.0.0.0:44409           0.0.0.0:*        108        14597      365/avahi-daemon: r
                          udp6       0      0 :::42084                :::*        108        14598      365/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*        108        14596      365/avahi-daemon: r
                          2023-07-10 10:44:44.373  - info: host.raspberrypi iobroker upload [19] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swi        pe/img/noSwipe.jpg image/jpeg
                          2023-07-10 10:44:44.387  - info: host.raspberrypi iobroker upload [18] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes        .js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                          2023-07-10 10:44:44.406  - info: host.raspberrypi iobroker upload [17] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js        widgets/swipe/js/jquery.roundabout.min.js application/javascript
                          2023-07-10 10:44:44.425  - info: host.raspberrypi iobroker upload [16] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js        widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                          2023-07-10 10:44:44.445  - info: host.raspberrypi iobroker upload [15] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html tex        t/html
                          2023-07-10 10:44:44.473  - info: host.raspberrypi iobroker upload [14] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets        /tabs/jquery.sliderTabs.js application/javascript
                          2023-07-10 10:44:44.489  - info: host.raspberrypi iobroker upload [13] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png        widgets/tabs/styles/images/indicator.png image/png
                          2023-07-10 10:44:44.508  - info: host.raspberrypi iobroker upload [12] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActiv        e.png widgets/tabs/styles/images/indicatorActive.png image/png
                          2023-07-10 10:44:44.528  - info: host.raspberrypi iobroker upload [11] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png        widgets/tabs/styles/images/leftArrow.png image/png
                          2023-07-10 10:44:44.550  - info: host.raspberrypi iobroker upload [10] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow        .png widgets/tabs/styles/images/leftPanelArrow.png image/png
                          2023-07-10 10:44:44.573  - info: host.raspberrypi iobroker upload [9] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png        widgets/tabs/styles/images/rightArrow.png image/png
                          2023-07-10 10:44:44.589  - info: host.raspberrypi iobroker upload [8] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow        .png widgets/tabs/styles/images/rightPanelArrow.png image/png
                          2023-07-10 10:44:44.611  - info: host.raspberrypi iobroker upload [7] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css        widgets/tabs/styles/jquery.sliderTabs.css text/css
                          2023-07-10 10:44:44.629  - info: host.raspberrypi iobroker upload [6] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.        orig widgets/tabs/styles/jquery.sliderTabs.css.orig null
                          2023-07-10 10:44:44.652  - info: host.raspberrypi iobroker upload [5] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.        css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                          2023-07-10 10:44:44.678  - info: host.raspberrypi iobroker upload [4] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/h        tml
                          2023-07-10 10:44:44.694  - info: host.raspberrypi iobroker upload [3] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.htm        l text/html
                          2023-07-10 10:44:44.711  - info: host.raspberrypi iobroker upload [2] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/h        omematic.html text/html
                          2023-07-10 10:44:44.738  - info: host.raspberrypi iobroker upload [1] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/spe        cial.html text/html
                          2023-07-10 10:44:44.757  - info: host.raspberrypi iobroker upload [0] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/wea        ther.html text/html
                          2023-07-10 10:44:44.848  - info: host.raspberrypi iobroker upload [3] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                          2023-07-10 10:44:44.858  - info: host.raspberrypi iobroker upload [2] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/htm        l
                          2023-07-10 10:44:44.872  - info: host.raspberrypi iobroker upload [1] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                          2023-07-10 10:44:44.880  - info: host.raspberrypi iobroker upload [0] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/java        script
                          2023-07-10 10:44:45.976  - info: host.raspberrypi iobroker exit 0
                          homematic-ip pivccu
                          314
