ZigBee neue Version 1.8.x
alle die Batterieprobleme haben mal testen bitte
https://github.com/ioBroker/ioBroker.zigbee/tarball/testBattery
Hi, ich habe einen neuen Raspi, dort ioBroker frisch installiert und dann die Zigbee DB aus dem Restore geholt. Die Instanz startet und ich kann auch zB die Innr schalten. Bekomme auch Meldung der Türkontakte. Wenn ich aber versuche die Tuya zu schalten stürzt der Adapter ab:
2023-07-10 20:06:16.428 - error: zigbee.0 (12691) Send command to 0xa4c138f1b70d8be7 failed with no error code (undefined) 2023-07-10 20:06:16.431 - error: zigbee.0 (12691) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-10 20:06:16.431 - error: zigbee.0 (12691) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-10 20:06:16.459 - error: zigbee.0 (12691) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:707:26 2023-07-10 20:06:16.459 - error: zigbee.0 (12691) Cannot read properties of undefined (reading 'Error') 2023-07-10 20:06:16.515 - info: zigbee.0 (12691) cleaned everything up... 2023-07-10 20:06:16.791 - info: zigbee.0 (12691) Zigbee: disabling joining new devices. 2023-07-10 20:06:17.018 - info: zigbee.0 (12691) terminating 2023-07-10 20:06:17.020 - warn: zigbee.0 (12691) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-10 20:06:17.675 - error: host.smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) 2023-07-10 20:06:17.677 - error: host.smarthome Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:707:26 2023-07-10 20:06:17.677 - error: host.smarthome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-10 20:06:17.677 - info: host.smarthome Restart adapter system.adapter.zigbee.0 because enabledHabe schon mal neu von github installiert. Ohne Erfolg. Ist das ein generelles Thema oder liegt es an meinem Restore? Brauchst noch was an Infos von mir?
@mp_trixi schalte die Sentry aus.. läufts dann ?? wenn ja installier mal die GIT verison
@arteck
Sentry aus ist so,richtig?
Damit stürzt der Adapter nicht mehr ab. Die Tuya gehen aber trotzdem nicht mehr. Nach Adapterstart ist schon der falsche Schaltstatus drin. Schaltung erzeugt den log-Eintrag:
zigbee.0 2023-07-11 09:00:08.936 error Send command to 0xa4c1380afb5051e2 failed with no error code (undefined)Die Installation via Katze/github hatte ich gemacht. Hier nochmal die Info zu den Steckdosen:
@mp_trixi hast du gerade auch von GIT installiert ?
@arteck
Ja, gerade aktuell:
Habe jetzt „Publish“ Info Meldungen im Log (die sind glaube ich neu). Sentry noch aus, aber gleiches Verhalten wie gerade beschrieben bei den Tuya
Er zeigt v1.8.15 an
@arteck
hier mal alle Zigbee Einträge seit Restart nach Github Installation:2023-07-11 09:14:42.453 - info: zigbee.0 (6116) Starting Zigbee npm ... 2023-07-11 09:14:43.281 - info: zigbee.0 (6116) Installed Version: ioBroker/ioBroker.zigbee#80e9165d16f8096f4f762ba273e3aa801845cd49 2023-07-11 09:14:43.719 - info: zigbee.0 (6116) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}} 2023-07-11 09:14:43.728 - info: zigbee.0 (6116) Unable to disable LED, unsupported function. 2023-07-11 09:14:43.730 - info: zigbee.0 (6116) --> transmitPower : high 2023-07-11 09:14:43.758 - info: zigbee.0 (6116) Currently 33 devices are joined: 2023-07-11 09:14:43.945 - info: zigbee.0 (6116) 0xa4c1388ffe36decc (addr 15858): A1Z - Nous Smart plug (with power monitoring) (Router) 2023-07-11 09:14:43.957 - info: zigbee.0 (6116) 0xa4c138dc44bd0f4a (addr 43960): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) 2023-07-11 09:14:43.959 - info: zigbee.0 (6116) 0xc4988600000fc431 (addr 29267): SP 220 - Innr Smart plug (Router) 2023-07-11 09:14:43.962 - info: zigbee.0 (6116) 0x18fc26000004a8e1 (addr 24488): SP 220 - Innr Smart plug (Router) 2023-07-11 09:14:43.964 - info: zigbee.0 (6116) 0xa4c1385e4f940aa8 (addr 50392): A1Z - Nous Smart plug (with power monitoring) (Router) 2023-07-11 09:14:43.965 - info: zigbee.0 (6116) 0xa4c138e29b759d31 (addr 1672): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) 2023-07-11 09:14:43.968 - info: zigbee.0 (6116) 0x00124b00290f0c60 (addr 17294): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:43.969 - info: zigbee.0 (6116) 0x00158d00090d8fa4 (addr 45648): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) 2023-07-11 09:14:43.972 - info: zigbee.0 (6116) 0xc4988600000fc1b2 (addr 39348): SP 220 - Innr Smart plug (Router) 2023-07-11 09:14:43.974 - info: zigbee.0 (6116) 0x00124b00290fda20 (addr 9814): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:43.976 - info: zigbee.0 (6116) 0x54ef4410000c39c2 (addr 37608): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice) 2023-07-11 09:14:43.978 - info: zigbee.0 (6116) 0x00124b00290f0c38 (addr 34801): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:43.979 - info: zigbee.0 (6116) 0x00158d0008c9c98a (addr 56826): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) 2023-07-11 09:14:43.981 - info: zigbee.0 (6116) 0x00124b00290f8649 (addr 28474): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:43.984 - info: zigbee.0 (6116) 0x84ba20fffe56851a (addr 38791): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:43.987 - info: zigbee.0 (6116) 0x84ba20fffe504f79 (addr 24633): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:43.989 - info: zigbee.0 (6116) 0x84ba20fffe567412 (addr 49063): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:43.991 - info: zigbee.0 (6116) 0x00124b0029202889 (addr 63927): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:43.993 - info: zigbee.0 (6116) 0x84ba20fffe50527f (addr 9111): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:43.995 - info: zigbee.0 (6116) 0x84ba20fffe82e9d2 (addr 64088): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:43.998 - info: zigbee.0 (6116) 0x84ba20fffe566f6f (addr 48216): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice) 2023-07-11 09:14:44.000 - info: zigbee.0 (6116) 0x00158d0007f80dd4 (addr 4559): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice) 2023-07-11 09:14:44.002 - info: zigbee.0 (6116) 0x00124b00290fefe9 (addr 44613): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:44.003 - info: zigbee.0 (6116) 0xa4c1382cc75bfab7 (addr 191): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice) 2023-07-11 09:14:44.006 - info: zigbee.0 (6116) 0xa4c138f1b70d8be7 (addr 63225): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) 2023-07-11 09:14:44.008 - info: zigbee.0 (6116) 0xa4c1380afb5051e2 (addr 2379): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) 2023-07-11 09:14:44.010 - info: zigbee.0 (6116) 0xa4c138170b27dbb6 (addr 50037): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router) 2023-07-11 09:14:44.011 - info: zigbee.0 (6116) 0x00124b00290fe28c (addr 59722): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:44.013 - info: zigbee.0 (6116) 0x00124b00290fe1f8 (addr 2022): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:44.016 - info: zigbee.0 (6116) 0x00158d000911f1ac (addr 22113): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) 2023-07-11 09:14:44.018 - info: zigbee.0 (6116) 0x00158d0008c97feb (addr 20802): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice) 2023-07-11 09:14:44.020 - info: zigbee.0 (6116) 0x00124b00290fd65b (addr 46911): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice) 2023-07-11 09:14:44.022 - info: zigbee.0 (6116) 0x18fc260000049470 (addr 36518): SP 220 - Innr Smart plug (Router) 2023-07-11 09:14:44.023 - info: zigbee.0 (6116) Zigbee started 2023-07-11 09:14:44.030 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/A1Z.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/A1Z.png 2023-07-11 09:14:44.052 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png 2023-07-11 09:14:44.063 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/A1Z.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/A1Z.png 2023-07-11 09:14:44.115 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png 2023-07-11 09:14:44.120 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png 2023-07-11 09:14:44.124 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png 2023-07-11 09:14:44.373 - info: zigbee.0 (6116) debug devices set to [] 2023-07-11 09:14:45.322 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:14:46.003 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:14:46.032 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:14:47.597 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:14:47.607 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:14:47.616 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:14:47.637 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:14:47.648 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:14:47.657 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:14:47.667 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:15:08.275 - info: zigbee.0 (6116) Publish {"temperature":24.46} 2023-07-11 09:15:10.559 - warn: zigbee.0 (6116) DeviceAvailability:Failed to ping 0xa4c1388ffe36decc TS011F 2023-07-11 09:15:10.928 - info: zigbee.0 (6116) Publish {"voltage":3000} 2023-07-11 09:15:10.937 - info: zigbee.0 (6116) Publish {"battery":100} 2023-07-11 09:15:11.651 - warn: zigbee.0 (6116) DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F 2023-07-11 09:15:18.545 - info: zigbee.0 (6116) Publish {"energy":0.01} 2023-07-11 09:15:18.680 - info: zigbee.0 (6116) Publish {"voltage":233} 2023-07-11 09:15:29.668 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:15:29.680 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:15:30.943 - info: zigbee.0 (6116) List of port: [{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}] 2023-07-11 09:16:01.390 - info: zigbee.0 (6116) Publish {"humidity":66.75} 2023-07-11 09:16:03.129 - error: zigbee.0 (6116) Send command to 0xa4c1380afb5051e2 failed with no error code (undefined) 2023-07-11 09:16:04.621 - info: zigbee.0 (6116) Publish {"energy":4.37} 2023-07-11 09:16:04.733 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:16:15.724 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:16:15.732 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:16:30.143 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:16:30.169 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:16:31.157 - info: zigbee.0 (6116) Publish {"energy":3.65} 2023-07-11 09:16:31.280 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:16:35.128 - info: zigbee.0 (6116) Publish {"current":0.17} 2023-07-11 09:16:35.147 - info: zigbee.0 (6116) Publish {"power":24} 2023-07-11 09:16:57.617 - error: zigbee.0 (6116) Send command to 0xa4c1380afb5051e2 failed with no error code (undefined) 2023-07-11 09:18:01.161 - info: zigbee.0 (6116) Publish {"energy":3.65} 2023-07-11 09:19:07.555 - info: zigbee.0 (6116) Publish {"energy":0.29} 2023-07-11 09:19:07.685 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:19:17.929 - info: zigbee.0 (6116) Publish {"temperature":22.27} 2023-07-11 09:19:18.675 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:19:18.685 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:19:23.123 - info: zigbee.0 (6116) Publish {"temperature":25.14} 2023-07-11 09:20:08.267 - info: zigbee.0 (6116) Publish {"temperature":25.15} 2023-07-11 09:20:27.070 - info: zigbee.0 (6116) Publish {"temperature":21.27} 2023-07-11 09:20:43.415 - info: zigbee.0 (6116) Publish {"energy":0.01} 2023-07-11 09:20:43.553 - info: zigbee.0 (6116) Publish {"voltage":232} 2023-07-11 09:20:54.542 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:20:54.553 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:20:58.179 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:20:58.203 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:21:03.180 - info: zigbee.0 (6116) Publish {"current":0.18} 2023-07-11 09:21:03.199 - info: zigbee.0 (6116) Publish {"power":24} 2023-07-11 09:21:07.758 - info: zigbee.0 (6116) Publish {"humidity":57.53} 2023-07-11 09:21:31.692 - info: zigbee.0 (6116) Publish {"energy":4.37} 2023-07-11 09:21:31.805 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:21:42.795 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:21:42.805 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:21:51.953 - info: zigbee.0 (6116) Publish {"energy":3.65} 2023-07-11 09:21:52.056 - info: zigbee.0 (6116) Publish {"power":26,"current":0.17,"voltage":235} 2023-07-11 09:22:12.561 - info: zigbee.0 (6116) Publish {"humidity":56.18} 2023-07-11 09:22:13.096 - info: zigbee.0 (6116) Publish {"illuminance":39690,"illuminance_lux":9309} 2023-07-11 09:22:15.477 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:22:15.664 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:22:16.218 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:22:16.857 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:22:24.163 - info: zigbee.0 (6116) Publish {"power":35} 2023-07-11 09:22:29.132 - info: zigbee.0 (6116) Publish {"power":24} 2023-07-11 09:24:31.255 - info: zigbee.0 (6116) Publish {"energy":0.29} 2023-07-11 09:24:31.378 - info: zigbee.0 (6116) Publish {"voltage":234} 2023-07-11 09:24:42.368 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:24:42.378 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:25:28.192 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:25:28.216 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:25:33.440 - info: zigbee.0 (6116) Publish {"current":0.18} 2023-07-11 09:25:33.457 - info: zigbee.0 (6116) Publish {"power":24} 2023-07-11 09:25:49.174 - info: zigbee.0 (6116) Publish {"power":35} 2023-07-11 09:25:54.230 - info: zigbee.0 (6116) Publish {"current":0.21} 2023-07-11 09:26:01.170 - info: zigbee.0 (6116) Publish {"current":0.18} 2023-07-11 09:26:08.287 - info: zigbee.0 (6116) Publish {"energy":0.01} 2023-07-11 09:26:08.388 - info: zigbee.0 (6116) Publish {"voltage":233} 2023-07-11 09:26:17.149 - info: zigbee.0 (6116) Publish {"power":24} 2023-07-11 09:26:19.378 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:26:19.388 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:26:43.153 - info: zigbee.0 (6116) Publish {"current":0.21} 2023-07-11 09:26:48.152 - info: zigbee.0 (6116) Publish {"current":0.18} 2023-07-11 09:26:58.754 - info: zigbee.0 (6116) Publish {"energy":4.37} 2023-07-11 09:26:58.864 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:27:07.155 - info: zigbee.0 (6116) Publish {"power":42} 2023-07-11 09:27:09.854 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:27:09.864 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:27:11.152 - info: zigbee.0 (6116) Publish {"current":0.21} 2023-07-11 09:27:12.183 - info: zigbee.0 (6116) Publish {"power":28} 2023-07-11 09:27:12.749 - info: zigbee.0 (6116) Publish {"energy":3.65} 2023-07-11 09:27:12.853 - info: zigbee.0 (6116) Publish {"power":26,"current":0.21,"voltage":235} 2023-07-11 09:27:16.172 - info: zigbee.0 (6116) Publish {"current":0.18} 2023-07-11 09:29:03.181 - info: zigbee.0 (6116) Publish {"power":85} 2023-07-11 09:29:04.667 - info: zigbee.0 (6116) Publish {"energy":3.66} 2023-07-11 09:29:06.172 - info: zigbee.0 (6116) Publish {"current":0.31} 2023-07-11 09:29:08.165 - info: zigbee.0 (6116) Publish {"power":115} 2023-07-11 09:29:15.165 - info: zigbee.0 (6116) Publish {"power":127} 2023-07-11 09:29:17.169 - info: zigbee.0 (6116) Publish {"current":0.35} 2023-07-11 09:29:20.163 - info: zigbee.0 (6116) Publish {"power":209} 2023-07-11 09:29:22.221 - info: zigbee.0 (6116) Publish {"current":0.41} 2023-07-11 09:29:25.169 - info: zigbee.0 (6116) Publish {"power":184} 2023-07-11 09:29:27.183 - info: zigbee.0 (6116) Publish {"current":0.45} 2023-07-11 09:29:32.183 - info: zigbee.0 (6116) Publish {"current":0.5} 2023-07-11 09:29:33.165 - info: zigbee.0 (6116) Publish {"power":204} 2023-07-11 09:29:37.172 - info: zigbee.0 (6116) Publish {"current":0.57} 2023-07-11 09:29:38.171 - info: zigbee.0 (6116) Publish {"power":250} 2023-07-11 09:29:42.169 - info: zigbee.0 (6116) Publish {"current":0.7} 2023-07-11 09:29:43.169 - info: zigbee.0 (6116) Publish {"power":208} 2023-07-11 09:29:45.539 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:29:45.784 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:29:46.269 - info: zigbee.0 (6116) Publish {"state":"ON"} 2023-07-11 09:29:46.908 - info: zigbee.0 (6116) Publish {"state":"OFF"} 2023-07-11 09:29:47.162 - info: zigbee.0 (6116) Publish {"current":0.56} 2023-07-11 09:29:48.182 - info: zigbee.0 (6116) Publish {"power":177} 2023-07-11 09:29:49.182 - info: zigbee.0 (6116) Publish {"temperature":25.71} 2023-07-11 09:29:49.303 - info: zigbee.0 (6116) Publish {"humidity":54.08} 2023-07-11 09:29:52.164 - info: zigbee.0 (6116) Publish {"current":0.47} 2023-07-11 09:29:53.308 - info: zigbee.0 (6116) Publish {"power":194} 2023-07-11 09:29:54.966 - info: zigbee.0 (6116) Publish {"energy":0.29} 2023-07-11 09:29:55.087 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:29:57.176 - info: zigbee.0 (6116) Publish {"current":0.57} 2023-07-11 09:29:58.171 - info: zigbee.0 (6116) Publish {"power":183} 2023-07-11 09:29:59.078 - info: zigbee.0 (6116) Publish {"voltage":2995,"battery":97,"device_temperature":33,"power_outage_count":165,"contact":true} 2023-07-11 09:30:02.253 - info: zigbee.0 (6116) Publish {"current":0.52} 2023-07-11 09:30:06.078 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:30:06.087 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:30:07.200 - info: zigbee.0 (6116) Publish {"current":0.49} 2023-07-11 09:30:09.186 - info: zigbee.0 (6116) Publish {"power":172} 2023-07-11 09:30:23.171 - info: zigbee.0 (6116) Publish {"power":187} 2023-07-11 09:30:28.169 - info: zigbee.0 (6116) Publish {"power":159} 2023-07-11 09:30:30.169 - info: zigbee.0 (6116) Publish {"current":0.45} 2023-07-11 09:30:33.178 - info: zigbee.0 (6116) Publish {"power":172} 2023-07-11 09:30:35.171 - info: zigbee.0 (6116) Publish {"current":0.49} 2023-07-11 09:30:38.176 - info: zigbee.0 (6116) Publish {"power":183} 2023-07-11 09:30:40.171 - info: zigbee.0 (6116) Publish {"current":0.57} 2023-07-11 09:30:44.178 - info: zigbee.0 (6116) Publish {"power":160} 2023-07-11 09:30:45.208 - info: zigbee.0 (6116) Publish {"current":0.5} 2023-07-11 09:30:46.636 - info: zigbee.0 (6116) Publish {"humidity":66.08} 2023-07-11 09:30:48.219 - info: zigbee.0 (6116) Publish {"illuminance":40216,"illuminance_lux":10508} 2023-07-11 09:30:50.192 - info: zigbee.0 (6116) Publish {"current":0.45} 2023-07-11 09:31:02.190 - info: zigbee.0 (6116) Publish {"power":189} 2023-07-11 09:31:05.175 - info: zigbee.0 (6116) Publish {"current":0.49} 2023-07-11 09:31:07.173 - info: zigbee.0 (6116) Publish {"power":153} 2023-07-11 09:31:10.179 - info: zigbee.0 (6116) Publish {"current":0.44} 2023-07-11 09:31:33.177 - info: zigbee.0 (6116) Publish {"energy":0.01} 2023-07-11 09:31:33.311 - info: zigbee.0 (6116) Publish {"voltage":233} 2023-07-11 09:31:35.201 - info: zigbee.0 (6116) Publish {"power":174} 2023-07-11 09:31:37.389 - info: zigbee.0 (6116) Publish {"current":0.47} 2023-07-11 09:31:37.900 - info: zigbee.0 (6116) Publish {"illuminance":40397,"illuminance_lux":10955} 2023-07-11 09:31:40.175 - info: zigbee.0 (6116) Publish {"power":197} 2023-07-11 09:31:42.182 - info: zigbee.0 (6116) Publish {"current":0.56} 2023-07-11 09:31:44.302 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:31:44.311 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:31:47.175 - info: zigbee.0 (6116) Publish {"current":0.52} 2023-07-11 09:31:51.178 - info: zigbee.0 (6116) Publish {"power":184} 2023-07-11 09:32:01.199 - info: zigbee.0 (6116) Publish {"power":170} 2023-07-11 09:32:05.187 - info: zigbee.0 (6116) Publish {"current":0.45} 2023-07-11 09:32:06.185 - info: zigbee.0 (6116) Publish {"power":159} 2023-07-11 09:32:17.181 - info: zigbee.0 (6116) Publish {"power":207} 2023-07-11 09:32:19.179 - info: zigbee.0 (6116) Publish {"current":0.52} 2023-07-11 09:32:22.208 - info: zigbee.0 (6116) Publish {"power":173} 2023-07-11 09:32:25.831 - info: zigbee.0 (6116) Publish {"energy":4.37} 2023-07-11 09:32:25.938 - info: zigbee.0 (6116) Publish {"voltage":235} 2023-07-11 09:32:26.209 - info: zigbee.0 (6116) Publish {"current":0.47} 2023-07-11 09:32:29.305 - info: zigbee.0 (6116) Publish {"power":186} 2023-07-11 09:32:31.787 - info: zigbee.0 (6116) Publish {"energy":3.67} 2023-07-11 09:32:33.230 - info: zigbee.0 (6116) Publish {"current":0.52} 2023-07-11 09:32:34.195 - info: zigbee.0 (6116) Publish {"power":212} 2023-07-11 09:32:36.929 - info: zigbee.0 (6116) Publish {"power":0} 2023-07-11 09:32:36.938 - info: zigbee.0 (6116) Publish {"current":0} 2023-07-11 09:32:38.202 - info: zigbee.0 (6116) Publish {"current":0.58} 2023-07-11 09:32:39.195 - info: zigbee.0 (6116) Publish {"power":230} 2023-07-11 09:32:43.207 - info: zigbee.0 (6116) Publish {"current":0.43} 2023-07-11 09:32:44.203 - info: zigbee.0 (6116) Publish {"power":181} 2023-07-11 09:32:49.195 - info: zigbee.0 (6116) Publish {"power":142} 2023-07-11 09:32:53.097 - info: zigbee.0 (6116) Publish {"illuminance":40726,"illuminance_lux":11817} 2023-07-11 09:32:54.283 - info: zigbee.0 (6116) Publish {"power":156} 2023-07-11 09:32:59.212 - info: zigbee.0 (6116) Publish {"power":145} 2023-07-11 09:33:00.534 - info: zigbee.0 (6116) Publish {"voltage":3035,"battery":100,"device_temperature":28,"power_outage_count":43,"contact":true} 2023-07-11 09:33:05.571 - info: zigbee.0 (6116) Publish {"local_temperature":25.1} 2023-07-11 09:33:06.245 - info: zigbee.0 (6116) Publish {"power":172} 2023-07-11 09:33:08.216 - info: zigbee.0 (6116) Publish {"current":0.49} 2023-07-11 09:33:11.192 - info: zigbee.0 (6116) Publish {"power":147} 2023-07-11 09:33:13.343 - info: zigbee.0 (6116) Publish {"current":0.44} 2023-07-11 09:33:16.222 - info: zigbee.0 (6116) Publish {"power":164} 2023-07-11 09:33:18.676 - info: zigbee.0 (6116) Publish {"current":0.52} 2023-07-11 09:33:21.212 - info: zigbee.0 (6116) Publish {"power":205} 2023-07-11 09:33:26.208 - info: zigbee.0 (6116) Publish {"power":188} 2023-07-11 09:33:31.198 - info: zigbee.0 (6116) Publish {"power":201} 2023-07-11 09:33:31.771 - info: zigbee.0 (6116) Publish {"illuminance":40909,"illuminance_lux":12325} 2023-07-11 09:33:36.292 - info: zigbee.0 (6116) Publish {"power":190} 2023-07-11 09:33:53.201 - info: zigbee.0 (6116) Publish {"power":217} 2023-07-11 09:33:57.215 - info: zigbee.0 (6116) Publish {"current":0.44} 2023-07-11 09:33:58.208 - info: zigbee.0 (6116) Publish {"power":148} 2023-07-11 09:34:08.503 - info: zigbee.0 (6116) Publish {"temperature":26.01} 2023-07-11 09:34:13.388 - info: zigbee.0 (6116) Publish {"power":160} 2023-07-11 09:34:14.207 - info: zigbee.0 (6116) Publish {"current":0.47} 2023-07-11 09:34:18.200 - info: zigbee.0 (6116) Publish {"power":141} 2023-07-11 09:34:19.199 - info: zigbee.0 (6116) Publish {"current":0.43} 2023-07-11 09:34:23.216 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:34:24.281 - info: zigbee.0 (6116) Publish {} 2023-07-11 09:34:28.212 - info: zigbee.0 (6116) Publish {"power":148} 2023-07-11 09:34:29.199 - info: zigbee.0 (6116) Publish {"current":0.43} 2023-07-11 09:34:33.200 - info: zigbee.0 (6116) Publish {"power":161}Die fehlgeschalgene Pings sind Nous die ich aktuell nicht eingesteckt habe (hatte die ja als die nicht mehr gingen durch die Tuya ersetzt) und nur noch für Testzwecke drin sind.
Die error sind die Tuya-Schaltversuche
@arteck
die Tuya? Einfach neu Pairen oder entfernen und dann neu Pairen? -
@arteck
hab sie ohne zu löschen neu verbunden. Allerdings kam am Standort immer nur2023-07-11 10:02:49.606 - warn: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' announced itselfund die Steckdose ging danach sofort aus dem Pairing-Mode.
Ich musste sie nahe dem Controller einstecken (Bad ging so, da nahe am Raspi), damit auch das Interview startete:
2023-07-11 10:22:51.082 - info: zigbee.0 (6116) Starting interview of '0xa4c138dc44bd0f4a' 2023-07-11 10:22:51.094 - warn: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' announced itself 2023-07-11 10:22:51.480 - info: zigbee.0 (6116) Successfully interviewed '0xa4c138dc44bd0f4a', device has successfully been paired 2023-07-11 10:22:51.480 - info: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' is supported, identified as: TuYa Smart plug (with power monitoring) (TS011F_plug_1) 2023-07-11 10:22:51.482 - info: zigbee.0 (6116) Configuring 0xa4c138dc44bd0f4a TS011F 2023-07-11 10:22:52.397 - info: zigbee.0 (6116) DeviceConfigure successful 0xa4c138dc44bd0f4a TS011FPublish Meldungen sind noch da, schalten geht jetzt - Sentry wieder rein?
@arteck Wie es aussieht klappt es mit der 1.8.15. Timestamp ok, Werte werde ich die nächsten Tage mal im Auge behalten.
Danke für den Fix
Reiner
ich habe hier einen Tuya ZY-M100-S und versucht diesen einzubinden (Zigbee Adapter Version 1.8.18, Admin 6.6.1, js-Controller 4.0.24), auf zigbee2mqtt.io ist der Sensor gelistet.
Leider wird bei mir ein TS0601 erkannt
Mit folgender Meldung im log (schaut unauffällig aus):
2023-07-20 18:18:00.856 - info: zigbee.0 (784) Starting interview of '0xa4c138611008805f' 2023-07-20 18:18:01.022 - info: zigbee.0 (784) Successfully interviewed '0xa4c138611008805f', device has successfully been paired 2023-07-20 18:18:38.900 - info: zigbee.0 (784) Starting interview of '0xa4c138611008805f'Unter den Objekten schaut´s so aus:
und der Inhalt von
msg_from_zigbeebeinhaltet:{ "type": "commandDataReport", "data": { "seq": 46080, "dpValues": [ { "dp": 9, "datatype": 2, "data": { "type": "Buffer", "data": [ 0, 0, 0, 129 ] } } ] }, "linkquality": 97, "groupID": 0, "cluster": "manuSpecificTuya", "meta": { "zclTransactionSequenceNumber": 246, "manufacturerCode": null, "frameControl": { "frameType": 1, "manufacturerSpecific": false, "direction": 1, "disableDefaultResponse": false, "reservedBits": 0 } }, "endpoint_id": 1 }Siehst du eine Möglichkeit den Sensor zu integrieren, da ich mich nicht im Stande sehe dies zu tun?
Falls du noch mehr Info´s brauchst, gib Bescheid.Vielen Dank für deine Rückmeldung!
Guten Morgen @arteck
hier zu finden: https://www.zigbee2mqtt.io/devices/ZY-M100-S.html
@latzi dann wirds ne neue charge geben deiner _tze204_qasjif9e ist noch nicht inder config drin
zuerst adapter von GIT installieren ..dann die Zeile tauschen (position ca. 4180)
fingerprint: tuya.fingerprint('TS0601', ['_TZE204_sxm7l9xa']),nach
fingerprint: tuya.fingerprint('TS0601', ['_TZE204_sxm7l9xa', '_TZE204_qasjif9e']),in der
/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.jsdann adapter neu starten.. evtl. musst du deu pairen
@arteck
sehr cool, Dankeschön - ein Schritt weiter.In den Objekten tauchen jetzt deutlich mehr Datenpunkte auf, es werden aber nur
illuminance,link_qualityundmsg_from_zigbeeaktualisiert, der Rest bleibtnull.
Hast du dazu auch noch eine Idee?
Vielen, herzlichen Dank für deine grenzgeniale Arbeit hier!
@latzi die null werte kannst du beschreiben.. womit kein plan
@arteck sagte in ZigBee neue Version 1.8.x:
Hi, fleissiger lieber Developer
hast du dir mal das Issue Occupancy timeout angeschaut ?
