    4. ZigBee neue Version 1.8.x
      MP_Trixi @arteck last edited by MP_Trixi
      @arteck
      Hi, ich habe einen neuen Raspi, dort ioBroker frisch installiert und dann die Zigbee DB aus dem Restore geholt. Die Instanz startet und ich kann auch zB die Innr schalten. Bekomme auch Meldung der Türkontakte. Wenn ich aber versuche die Tuya zu schalten stürzt der Adapter ab:
      2023-07-10 20:06:16.428 - error: zigbee.0 (12691) Send command to 0xa4c138f1b70d8be7 failed with no error code (undefined)
      2023-07-10 20:06:16.431 - error: zigbee.0 (12691) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-07-10 20:06:16.431 - error: zigbee.0 (12691) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      2023-07-10 20:06:16.459 - error: zigbee.0 (12691) TypeError: Cannot read properties of undefined (reading 'Error')
      at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
      at /opt/iobroker/node_modules/iobroker.zigbee/main.js:707:26
      2023-07-10 20:06:16.459 - error: zigbee.0 (12691) Cannot read properties of undefined (reading 'Error')
      2023-07-10 20:06:16.515 - info: zigbee.0 (12691) cleaned everything up...
      2023-07-10 20:06:16.791 - info: zigbee.0 (12691) Zigbee: disabling joining new devices.
      2023-07-10 20:06:17.018 - info: zigbee.0 (12691) terminating
      2023-07-10 20:06:17.020 - warn: zigbee.0 (12691) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-07-10 20:06:17.675 - error: host.smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      2023-07-10 20:06:17.676 - error: host.smarthome Caught by controller[0]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
      2023-07-10 20:06:17.677 - error: host.smarthome Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:707:26
      2023-07-10 20:06:17.677 - error: host.smarthome instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-07-10 20:06:17.677 - info: host.smarthome Restart adapter system.adapter.zigbee.0 because enabled
      Habe schon mal neu von github installiert. Ohne Erfolg. Ist das ein generelles Thema oder liegt es an meinem Restore? Brauchst noch was an Infos von mir?
        @mp_trixi schalte die Sentry aus.. läufts dann ?? wenn ja installier mal die GIT verison
          @arteck
          Sentry aus ist so,richtig?
          Damit stürzt der Adapter nicht mehr ab. Die Tuya gehen aber trotzdem nicht mehr. Nach Adapterstart ist schon der falsche Schaltstatus drin. Schaltung erzeugt den log-Eintrag:
          zigbee.0 2023-07-11 09:00:08.936	error	Send command to 0xa4c1380afb5051e2 failed with no error code (undefined)
          Die Installation via Katze/github hatte ich gemacht. Hier nochmal die Info zu den Steckdosen:
          6650E441-C2BC-4F5F-9F37-840B37EFC06B.jpeg B659B4CD-1E2D-4D57-93FC-D75C35415972.jpeg E637ECB4-047A-4B6A-A92A-9C0F1530D520.jpeg
            arteck Developer Most Active @MP_Trixi last edited by
            @mp_trixi hast du gerade auch von GIT installiert ?
              @arteck
              Ja, gerade aktuell:
              Habe jetzt „Publish“ Info Meldungen im Log (die sind glaube ich neu). Sentry noch aus, aber gleiches Verhalten wie gerade beschrieben bei den Tuya
              Er zeigt v1.8.15 an
                @mp_trixi sagte in ZigBee neue Version 1.8.x:
                zeigmal
                  @arteck
                  hier mal alle Zigbee Einträge seit Restart nach Github Installation:
                  2023-07-11 09:14:42.453 - info: zigbee.0 (6116) Starting Zigbee npm ...
                  2023-07-11 09:14:43.281 - info: zigbee.0 (6116) Installed Version: ioBroker/ioBroker.zigbee#80e9165d16f8096f4f762ba273e3aa801845cd49
                  2023-07-11 09:14:43.719 - info: zigbee.0 (6116) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221102}}
                  2023-07-11 09:14:43.728 - info: zigbee.0 (6116) Unable to disable LED, unsupported function.
                  2023-07-11 09:14:43.730 - info: zigbee.0 (6116) --> transmitPower : high
                  2023-07-11 09:14:43.758 - info: zigbee.0 (6116) Currently 33 devices are joined:
                  2023-07-11 09:14:43.945 - info: zigbee.0 (6116) 0xa4c1388ffe36decc (addr 15858): A1Z - Nous Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:43.957 - info: zigbee.0 (6116) 0xa4c138dc44bd0f4a (addr 43960): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:43.959 - info: zigbee.0 (6116) 0xc4988600000fc431 (addr 29267): SP 220 - Innr Smart plug (Router)
                  2023-07-11 09:14:43.962 - info: zigbee.0 (6116) 0x18fc26000004a8e1 (addr 24488): SP 220 - Innr Smart plug (Router)
                  2023-07-11 09:14:43.964 - info: zigbee.0 (6116) 0xa4c1385e4f940aa8 (addr 50392): A1Z - Nous Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:43.965 - info: zigbee.0 (6116) 0xa4c138e29b759d31 (addr 1672): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                  2023-07-11 09:14:43.968 - info: zigbee.0 (6116) 0x00124b00290f0c60 (addr 17294): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:43.969 - info: zigbee.0 (6116) 0x00158d00090d8fa4 (addr 45648): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2023-07-11 09:14:43.972 - info: zigbee.0 (6116) 0xc4988600000fc1b2 (addr 39348): SP 220 - Innr Smart plug (Router)
                  2023-07-11 09:14:43.974 - info: zigbee.0 (6116) 0x00124b00290fda20 (addr 9814): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:43.976 - info: zigbee.0 (6116) 0x54ef4410000c39c2 (addr 37608): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                  2023-07-11 09:14:43.978 - info: zigbee.0 (6116) 0x00124b00290f0c38 (addr 34801): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:43.979 - info: zigbee.0 (6116) 0x00158d0008c9c98a (addr 56826): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2023-07-11 09:14:43.981 - info: zigbee.0 (6116) 0x00124b00290f8649 (addr 28474): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:43.984 - info: zigbee.0 (6116) 0x84ba20fffe56851a (addr 38791): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:43.987 - info: zigbee.0 (6116) 0x84ba20fffe504f79 (addr 24633): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:43.989 - info: zigbee.0 (6116) 0x84ba20fffe567412 (addr 49063): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:43.991 - info: zigbee.0 (6116) 0x00124b0029202889 (addr 63927): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:43.993 - info: zigbee.0 (6116) 0x84ba20fffe50527f (addr 9111): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:43.995 - info: zigbee.0 (6116) 0x84ba20fffe82e9d2 (addr 64088): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:43.998 - info: zigbee.0 (6116) 0x84ba20fffe566f6f (addr 48216): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                  2023-07-11 09:14:44.000 - info: zigbee.0 (6116) 0x00158d0007f80dd4 (addr 4559): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                  2023-07-11 09:14:44.002 - info: zigbee.0 (6116) 0x00124b00290fefe9 (addr 44613): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:44.003 - info: zigbee.0 (6116) 0xa4c1382cc75bfab7 (addr 191): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                  2023-07-11 09:14:44.006 - info: zigbee.0 (6116) 0xa4c138f1b70d8be7 (addr 63225): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:44.008 - info: zigbee.0 (6116) 0xa4c1380afb5051e2 (addr 2379): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:44.010 - info: zigbee.0 (6116) 0xa4c138170b27dbb6 (addr 50037): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                  2023-07-11 09:14:44.011 - info: zigbee.0 (6116) 0x00124b00290fe28c (addr 59722): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:44.013 - info: zigbee.0 (6116) 0x00124b00290fe1f8 (addr 2022): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:44.016 - info: zigbee.0 (6116) 0x00158d000911f1ac (addr 22113): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2023-07-11 09:14:44.018 - info: zigbee.0 (6116) 0x00158d0008c97feb (addr 20802): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                  2023-07-11 09:14:44.020 - info: zigbee.0 (6116) 0x00124b00290fd65b (addr 46911): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                  2023-07-11 09:14:44.022 - info: zigbee.0 (6116) 0x18fc260000049470 (addr 36518): SP 220 - Innr Smart plug (Router)
                  2023-07-11 09:14:44.023 - info: zigbee.0 (6116) Zigbee started
                  2023-07-11 09:14:44.030 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/A1Z.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/A1Z.png
                  2023-07-11 09:14:44.052 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                  2023-07-11 09:14:44.063 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/A1Z.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/A1Z.png
                  2023-07-11 09:14:44.115 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                  2023-07-11 09:14:44.120 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                  2023-07-11 09:14:44.124 - warn: zigbee.0 (6116) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                  2023-07-11 09:14:44.373 - info: zigbee.0 (6116) debug devices set to []
                  2023-07-11 09:14:45.322 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:14:46.003 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:14:46.032 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:14:47.597 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:14:47.607 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:14:47.616 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:14:47.637 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:14:47.648 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:14:47.657 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:14:47.667 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:15:08.275 - info: zigbee.0 (6116) Publish {"temperature":24.46}
                  2023-07-11 09:15:10.559 - warn: zigbee.0 (6116) DeviceAvailability:Failed to ping 0xa4c1388ffe36decc TS011F
                  2023-07-11 09:15:10.928 - info: zigbee.0 (6116) Publish {"voltage":3000}
                  2023-07-11 09:15:10.937 - info: zigbee.0 (6116) Publish {"battery":100}
                  2023-07-11 09:15:11.651 - warn: zigbee.0 (6116) DeviceAvailability:Failed to ping 0xa4c1385e4f940aa8 TS011F
                  2023-07-11 09:15:18.545 - info: zigbee.0 (6116) Publish {"energy":0.01}
                  2023-07-11 09:15:18.680 - info: zigbee.0 (6116) Publish {"voltage":233}
                  2023-07-11 09:15:29.668 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:15:29.680 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:15:30.943 - info: zigbee.0 (6116) List of port: [{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"626a1ae89b93eb11ac711b4f3d98b6d1","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"DM01F5RM","pnpId":"usb-FTDI_FT230X_Basic_UART_DM01F5RM-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyAMA0"}]
                  2023-07-11 09:16:01.390 - info: zigbee.0 (6116) Publish {"humidity":66.75}
                  2023-07-11 09:16:03.129 - error: zigbee.0 (6116) Send command to 0xa4c1380afb5051e2 failed with no error code (undefined)
                  2023-07-11 09:16:04.621 - info: zigbee.0 (6116) Publish {"energy":4.37}
                  2023-07-11 09:16:04.733 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:16:15.724 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:16:15.732 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:16:30.143 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:16:30.169 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:16:31.157 - info: zigbee.0 (6116) Publish {"energy":3.65}
                  2023-07-11 09:16:31.280 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:16:35.128 - info: zigbee.0 (6116) Publish {"current":0.17}
                  2023-07-11 09:16:35.147 - info: zigbee.0 (6116) Publish {"power":24}
                  2023-07-11 09:16:57.617 - error: zigbee.0 (6116) Send command to 0xa4c1380afb5051e2 failed with no error code (undefined)
                  2023-07-11 09:18:01.161 - info: zigbee.0 (6116) Publish {"energy":3.65}
                  2023-07-11 09:19:07.555 - info: zigbee.0 (6116) Publish {"energy":0.29}
                  2023-07-11 09:19:07.685 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:19:17.929 - info: zigbee.0 (6116) Publish {"temperature":22.27}
                  2023-07-11 09:19:18.675 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:19:18.685 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:19:23.123 - info: zigbee.0 (6116) Publish {"temperature":25.14}
                  2023-07-11 09:20:08.267 - info: zigbee.0 (6116) Publish {"temperature":25.15}
                  2023-07-11 09:20:27.070 - info: zigbee.0 (6116) Publish {"temperature":21.27}
                  2023-07-11 09:20:43.415 - info: zigbee.0 (6116) Publish {"energy":0.01}
                  2023-07-11 09:20:43.553 - info: zigbee.0 (6116) Publish {"voltage":232}
                  2023-07-11 09:20:54.542 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:20:54.553 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:20:58.179 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:20:58.203 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:21:03.180 - info: zigbee.0 (6116) Publish {"current":0.18}
                  2023-07-11 09:21:03.199 - info: zigbee.0 (6116) Publish {"power":24}
                  2023-07-11 09:21:07.758 - info: zigbee.0 (6116) Publish {"humidity":57.53}
                  2023-07-11 09:21:31.692 - info: zigbee.0 (6116) Publish {"energy":4.37}
                  2023-07-11 09:21:31.805 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:21:42.795 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:21:42.805 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:21:51.953 - info: zigbee.0 (6116) Publish {"energy":3.65}
                  2023-07-11 09:21:52.056 - info: zigbee.0 (6116) Publish {"power":26,"current":0.17,"voltage":235}
                  2023-07-11 09:22:12.561 - info: zigbee.0 (6116) Publish {"humidity":56.18}
                  2023-07-11 09:22:13.096 - info: zigbee.0 (6116) Publish {"illuminance":39690,"illuminance_lux":9309}
                  2023-07-11 09:22:15.477 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:22:15.664 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:22:16.218 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:22:16.857 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:22:24.163 - info: zigbee.0 (6116) Publish {"power":35}
                  2023-07-11 09:22:29.132 - info: zigbee.0 (6116) Publish {"power":24}
                  2023-07-11 09:24:31.255 - info: zigbee.0 (6116) Publish {"energy":0.29}
                  2023-07-11 09:24:31.378 - info: zigbee.0 (6116) Publish {"voltage":234}
                  2023-07-11 09:24:42.368 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:24:42.378 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:25:28.192 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:25:28.216 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:25:33.440 - info: zigbee.0 (6116) Publish {"current":0.18}
                  2023-07-11 09:25:33.457 - info: zigbee.0 (6116) Publish {"power":24}
                  2023-07-11 09:25:49.174 - info: zigbee.0 (6116) Publish {"power":35}
                  2023-07-11 09:25:54.230 - info: zigbee.0 (6116) Publish {"current":0.21}
                  2023-07-11 09:26:01.170 - info: zigbee.0 (6116) Publish {"current":0.18}
                  2023-07-11 09:26:08.287 - info: zigbee.0 (6116) Publish {"energy":0.01}
                  2023-07-11 09:26:08.388 - info: zigbee.0 (6116) Publish {"voltage":233}
                  2023-07-11 09:26:17.149 - info: zigbee.0 (6116) Publish {"power":24}
                  2023-07-11 09:26:19.378 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:26:19.388 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:26:43.153 - info: zigbee.0 (6116) Publish {"current":0.21}
                  2023-07-11 09:26:48.152 - info: zigbee.0 (6116) Publish {"current":0.18}
                  2023-07-11 09:26:58.754 - info: zigbee.0 (6116) Publish {"energy":4.37}
                  2023-07-11 09:26:58.864 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:27:07.155 - info: zigbee.0 (6116) Publish {"power":42}
                  2023-07-11 09:27:09.854 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:27:09.864 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:27:11.152 - info: zigbee.0 (6116) Publish {"current":0.21}
                  2023-07-11 09:27:12.183 - info: zigbee.0 (6116) Publish {"power":28}
                  2023-07-11 09:27:12.749 - info: zigbee.0 (6116) Publish {"energy":3.65}
                  2023-07-11 09:27:12.853 - info: zigbee.0 (6116) Publish {"power":26,"current":0.21,"voltage":235}
                  2023-07-11 09:27:16.172 - info: zigbee.0 (6116) Publish {"current":0.18}
                  2023-07-11 09:29:03.181 - info: zigbee.0 (6116) Publish {"power":85}
                  2023-07-11 09:29:04.667 - info: zigbee.0 (6116) Publish {"energy":3.66}
                  2023-07-11 09:29:06.172 - info: zigbee.0 (6116) Publish {"current":0.31}
                  2023-07-11 09:29:08.165 - info: zigbee.0 (6116) Publish {"power":115}
                  2023-07-11 09:29:15.165 - info: zigbee.0 (6116) Publish {"power":127}
                  2023-07-11 09:29:17.169 - info: zigbee.0 (6116) Publish {"current":0.35}
                  2023-07-11 09:29:20.163 - info: zigbee.0 (6116) Publish {"power":209}
                  2023-07-11 09:29:22.221 - info: zigbee.0 (6116) Publish {"current":0.41}
                  2023-07-11 09:29:25.169 - info: zigbee.0 (6116) Publish {"power":184}
                  2023-07-11 09:29:27.183 - info: zigbee.0 (6116) Publish {"current":0.45}
                  2023-07-11 09:29:32.183 - info: zigbee.0 (6116) Publish {"current":0.5}
                  2023-07-11 09:29:33.165 - info: zigbee.0 (6116) Publish {"power":204}
                  2023-07-11 09:29:37.172 - info: zigbee.0 (6116) Publish {"current":0.57}
                  2023-07-11 09:29:38.171 - info: zigbee.0 (6116) Publish {"power":250}
                  2023-07-11 09:29:42.169 - info: zigbee.0 (6116) Publish {"current":0.7}
                  2023-07-11 09:29:43.169 - info: zigbee.0 (6116) Publish {"power":208}
                  2023-07-11 09:29:45.539 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:29:45.784 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:29:46.269 - info: zigbee.0 (6116) Publish {"state":"ON"}
                  2023-07-11 09:29:46.908 - info: zigbee.0 (6116) Publish {"state":"OFF"}
                  2023-07-11 09:29:47.162 - info: zigbee.0 (6116) Publish {"current":0.56}
                  2023-07-11 09:29:48.182 - info: zigbee.0 (6116) Publish {"power":177}
                  2023-07-11 09:29:49.182 - info: zigbee.0 (6116) Publish {"temperature":25.71}
                  2023-07-11 09:29:49.303 - info: zigbee.0 (6116) Publish {"humidity":54.08}
                  2023-07-11 09:29:52.164 - info: zigbee.0 (6116) Publish {"current":0.47}
                  2023-07-11 09:29:53.308 - info: zigbee.0 (6116) Publish {"power":194}
                  2023-07-11 09:29:54.966 - info: zigbee.0 (6116) Publish {"energy":0.29}
                  2023-07-11 09:29:55.087 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:29:57.176 - info: zigbee.0 (6116) Publish {"current":0.57}
                  2023-07-11 09:29:58.171 - info: zigbee.0 (6116) Publish {"power":183}
                  2023-07-11 09:29:59.078 - info: zigbee.0 (6116) Publish {"voltage":2995,"battery":97,"device_temperature":33,"power_outage_count":165,"contact":true}
                  2023-07-11 09:30:02.253 - info: zigbee.0 (6116) Publish {"current":0.52}
                  2023-07-11 09:30:06.078 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:30:06.087 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:30:07.200 - info: zigbee.0 (6116) Publish {"current":0.49}
                  2023-07-11 09:30:09.186 - info: zigbee.0 (6116) Publish {"power":172}
                  2023-07-11 09:30:23.171 - info: zigbee.0 (6116) Publish {"power":187}
                  2023-07-11 09:30:28.169 - info: zigbee.0 (6116) Publish {"power":159}
                  2023-07-11 09:30:30.169 - info: zigbee.0 (6116) Publish {"current":0.45}
                  2023-07-11 09:30:33.178 - info: zigbee.0 (6116) Publish {"power":172}
                  2023-07-11 09:30:35.171 - info: zigbee.0 (6116) Publish {"current":0.49}
                  2023-07-11 09:30:38.176 - info: zigbee.0 (6116) Publish {"power":183}
                  2023-07-11 09:30:40.171 - info: zigbee.0 (6116) Publish {"current":0.57}
                  2023-07-11 09:30:44.178 - info: zigbee.0 (6116) Publish {"power":160}
                  2023-07-11 09:30:45.208 - info: zigbee.0 (6116) Publish {"current":0.5}
                  2023-07-11 09:30:46.636 - info: zigbee.0 (6116) Publish {"humidity":66.08}
                  2023-07-11 09:30:48.219 - info: zigbee.0 (6116) Publish {"illuminance":40216,"illuminance_lux":10508}
                  2023-07-11 09:30:50.192 - info: zigbee.0 (6116) Publish {"current":0.45}
                  2023-07-11 09:31:02.190 - info: zigbee.0 (6116) Publish {"power":189}
                  2023-07-11 09:31:05.175 - info: zigbee.0 (6116) Publish {"current":0.49}
                  2023-07-11 09:31:07.173 - info: zigbee.0 (6116) Publish {"power":153}
                  2023-07-11 09:31:10.179 - info: zigbee.0 (6116) Publish {"current":0.44}
                  2023-07-11 09:31:33.177 - info: zigbee.0 (6116) Publish {"energy":0.01}
                  2023-07-11 09:31:33.311 - info: zigbee.0 (6116) Publish {"voltage":233}
                  2023-07-11 09:31:35.201 - info: zigbee.0 (6116) Publish {"power":174}
                  2023-07-11 09:31:37.389 - info: zigbee.0 (6116) Publish {"current":0.47}
                  2023-07-11 09:31:37.900 - info: zigbee.0 (6116) Publish {"illuminance":40397,"illuminance_lux":10955}
                  2023-07-11 09:31:40.175 - info: zigbee.0 (6116) Publish {"power":197}
                  2023-07-11 09:31:42.182 - info: zigbee.0 (6116) Publish {"current":0.56}
                  2023-07-11 09:31:44.302 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:31:44.311 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:31:47.175 - info: zigbee.0 (6116) Publish {"current":0.52}
                  2023-07-11 09:31:51.178 - info: zigbee.0 (6116) Publish {"power":184}
                  2023-07-11 09:32:01.199 - info: zigbee.0 (6116) Publish {"power":170}
                  2023-07-11 09:32:05.187 - info: zigbee.0 (6116) Publish {"current":0.45}
                  2023-07-11 09:32:06.185 - info: zigbee.0 (6116) Publish {"power":159}
                  2023-07-11 09:32:17.181 - info: zigbee.0 (6116) Publish {"power":207}
                  2023-07-11 09:32:19.179 - info: zigbee.0 (6116) Publish {"current":0.52}
                  2023-07-11 09:32:22.208 - info: zigbee.0 (6116) Publish {"power":173}
                  2023-07-11 09:32:25.831 - info: zigbee.0 (6116) Publish {"energy":4.37}
                  2023-07-11 09:32:25.938 - info: zigbee.0 (6116) Publish {"voltage":235}
                  2023-07-11 09:32:26.209 - info: zigbee.0 (6116) Publish {"current":0.47}
                  2023-07-11 09:32:29.305 - info: zigbee.0 (6116) Publish {"power":186}
                  2023-07-11 09:32:31.787 - info: zigbee.0 (6116) Publish {"energy":3.67}
                  2023-07-11 09:32:33.230 - info: zigbee.0 (6116) Publish {"current":0.52}
                  2023-07-11 09:32:34.195 - info: zigbee.0 (6116) Publish {"power":212}
                  2023-07-11 09:32:36.929 - info: zigbee.0 (6116) Publish {"power":0}
                  2023-07-11 09:32:36.938 - info: zigbee.0 (6116) Publish {"current":0}
                  2023-07-11 09:32:38.202 - info: zigbee.0 (6116) Publish {"current":0.58}
                  2023-07-11 09:32:39.195 - info: zigbee.0 (6116) Publish {"power":230}
                  2023-07-11 09:32:43.207 - info: zigbee.0 (6116) Publish {"current":0.43}
                  2023-07-11 09:32:44.203 - info: zigbee.0 (6116) Publish {"power":181}
                  2023-07-11 09:32:49.195 - info: zigbee.0 (6116) Publish {"power":142}
                  2023-07-11 09:32:53.097 - info: zigbee.0 (6116) Publish {"illuminance":40726,"illuminance_lux":11817}
                  2023-07-11 09:32:54.283 - info: zigbee.0 (6116) Publish {"power":156}
                  2023-07-11 09:32:59.212 - info: zigbee.0 (6116) Publish {"power":145}
                  2023-07-11 09:33:00.534 - info: zigbee.0 (6116) Publish {"voltage":3035,"battery":100,"device_temperature":28,"power_outage_count":43,"contact":true}
                  2023-07-11 09:33:05.571 - info: zigbee.0 (6116) Publish {"local_temperature":25.1}
                  2023-07-11 09:33:06.245 - info: zigbee.0 (6116) Publish {"power":172}
                  2023-07-11 09:33:08.216 - info: zigbee.0 (6116) Publish {"current":0.49}
                  2023-07-11 09:33:11.192 - info: zigbee.0 (6116) Publish {"power":147}
                  2023-07-11 09:33:13.343 - info: zigbee.0 (6116) Publish {"current":0.44}
                  2023-07-11 09:33:16.222 - info: zigbee.0 (6116) Publish {"power":164}
                  2023-07-11 09:33:18.676 - info: zigbee.0 (6116) Publish {"current":0.52}
                  2023-07-11 09:33:21.212 - info: zigbee.0 (6116) Publish {"power":205}
                  2023-07-11 09:33:26.208 - info: zigbee.0 (6116) Publish {"power":188}
                  2023-07-11 09:33:31.198 - info: zigbee.0 (6116) Publish {"power":201}
                  2023-07-11 09:33:31.771 - info: zigbee.0 (6116) Publish {"illuminance":40909,"illuminance_lux":12325}
                  2023-07-11 09:33:36.292 - info: zigbee.0 (6116) Publish {"power":190}
                  2023-07-11 09:33:53.201 - info: zigbee.0 (6116) Publish {"power":217}
                  2023-07-11 09:33:57.215 - info: zigbee.0 (6116) Publish {"current":0.44}
                  2023-07-11 09:33:58.208 - info: zigbee.0 (6116) Publish {"power":148}
                  2023-07-11 09:34:08.503 - info: zigbee.0 (6116) Publish {"temperature":26.01}
                  2023-07-11 09:34:13.388 - info: zigbee.0 (6116) Publish {"power":160}
                  2023-07-11 09:34:14.207 - info: zigbee.0 (6116) Publish {"current":0.47}
                  2023-07-11 09:34:18.200 - info: zigbee.0 (6116) Publish {"power":141}
                  2023-07-11 09:34:19.199 - info: zigbee.0 (6116) Publish {"current":0.43}
                  2023-07-11 09:34:23.216 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:34:24.281 - info: zigbee.0 (6116) Publish {}
                  2023-07-11 09:34:28.212 - info: zigbee.0 (6116) Publish {"power":148}
                  2023-07-11 09:34:29.199 - info: zigbee.0 (6116) Publish {"current":0.43}
                  2023-07-11 09:34:33.200 - info: zigbee.0 (6116) Publish {"power":161}
                  Die fehlgeschalgene Pings sind Nous die ich aktuell nicht eingesteckt habe (hatte die ja als die nicht mehr gingen durch die Tuya ersetzt) und nur noch für Testzwecke drin sind.
                  Die error sind die Tuya-Schaltversuche
                    Send command to
                    kannst du die neu anlernen ..
                      @arteck
                      die Tuya? Einfach neu Pairen oder entfernen und dann neu Pairen?
                        MP_Trixi @MP_Trixi last edited by MP_Trixi
                        @arteck
                        hab sie ohne zu löschen neu verbunden. Allerdings kam am Standort immer nur
                        2023-07-11 10:02:49.606 - warn: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' announced itself
                        und die Steckdose ging danach sofort aus dem Pairing-Mode.
                        Ich musste sie nahe dem Controller einstecken (Bad ging so, da nahe am Raspi), damit auch das Interview startete:
                        2023-07-11 10:22:51.082 - info: zigbee.0 (6116) Starting interview of '0xa4c138dc44bd0f4a'
                        2023-07-11 10:22:51.094 - warn: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' announced itself
                        2023-07-11 10:22:51.480 - info: zigbee.0 (6116) Successfully interviewed '0xa4c138dc44bd0f4a', device has successfully been paired
                        2023-07-11 10:22:51.480 - info: zigbee.0 (6116) Device '0xa4c138dc44bd0f4a' is supported, identified as: TuYa Smart plug (with power monitoring) (TS011F_plug_1)
                        2023-07-11 10:22:51.482 - info: zigbee.0 (6116) Configuring 0xa4c138dc44bd0f4a TS011F
                        2023-07-11 10:22:52.397 - info: zigbee.0 (6116) DeviceConfigure successful 0xa4c138dc44bd0f4a TS011F
                        Publish Meldungen sind noch da, schalten geht jetzt - Sentry wieder rein?
                          Sentry wieder rein?
                          ne lass aus
                          Latzi 1 Reply Last reply Reply Quote 0
                            rewenode @arteck last edited by
                            @arteck Wie es aussieht klappt es mit der 1.8.15. Timestamp ok, Werte werde ich die nächsten Tage mal im Auge behalten.
                            Danke für den Fix
                            Reiner
                            • Latzi
                              Latzi @arteck last edited by
                              @arteck
                              ich habe hier einen Tuya ZY-M100-S und versucht diesen einzubinden (Zigbee Adapter Version 1.8.18, Admin 6.6.1, js-Controller 4.0.24), auf zigbee2mqtt.io ist der Sensor gelistet.
                              Leider wird bei mir ein TS0601 erkannt
                              Mit folgender Meldung im log (schaut unauffällig aus):
                              2023-07-20 18:18:00.856 - info: zigbee.0 (784) Starting interview of '0xa4c138611008805f'
                              2023-07-20 18:18:01.022 - info: zigbee.0 (784) Successfully interviewed '0xa4c138611008805f', device has successfully been paired
                              2023-07-20 18:18:38.900 - info: zigbee.0 (784) Starting interview of '0xa4c138611008805f'
                              Unter den Objekten schaut´s so aus:
                              und der Inhalt von msg_from_zigbee beinhaltet:
                                "type": "commandDataReport",
                                "data": {
                                  "seq": 46080,
                                  "dpValues": [
                                      "dp": 9,
                                      "datatype": 2,
                                      "data": {
                                        "type": "Buffer",
                                        "data": [
                                          0,
                                          0,
                                          0,
                                          129
                                "linkquality": 97,
                                "groupID": 0,
                                "cluster": "manuSpecificTuya",
                                "meta": {
                                  "zclTransactionSequenceNumber": 246,
                                  "manufacturerCode": null,
                                  "frameControl": {
                                    "frameType": 1,
                                    "manufacturerSpecific": false,
                                    "direction": 1,
                                    "disableDefaultResponse": false,
                                    "reservedBits": 0
                                "endpoint_id": 1
                              Siehst du eine Möglichkeit den Sensor zu integrieren, da ich mich nicht im Stande sehe dies zu tun?
                              Falls du noch mehr Info´s brauchst, gib Bescheid.
                              Vielen Dank für deine Rückmeldung!
                                @latzi sagte in ZigBee neue Version 1.8.x:
                                zeigen wo
                                • Latzi
                                  Guten Morgen @arteck
                                  hier zu finden: https://www.zigbee2mqtt.io/devices/ZY-M100-S.html
                                    arteck Developer Most Active @Latzi last edited by arteck
                                    @latzi dann wirds ne neue charge geben deiner _tze204_qasjif9e ist noch nicht inder config drin
                                    zuerst adapter von GIT installieren ..dann die Zeile tauschen (position ca. 4180)
                                    fingerprint: tuya.fingerprint('TS0601', ['_TZE204_sxm7l9xa']),
                                    nach
                                    fingerprint: tuya.fingerprint('TS0601', ['_TZE204_sxm7l9xa', '_TZE204_qasjif9e']),
                                    in der
                                    /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js
                                    dann adapter neu starten.. evtl. musst du deu pairen
                                    • Latzi
                                      @arteck
                                      sehr cool, Dankeschön - ein Schritt weiter.
                                      In den Objekten tauchen jetzt deutlich mehr Datenpunkte auf, es werden aber nur illuminance, link_quality und msg_from_zigbeeaktualisiert, der Rest bleibt null.
                                      Hast du dazu auch noch eine Idee?
                                      Vielen, herzlichen Dank für deine grenzgeniale Arbeit hier!
                                        @latzi die null werte kannst du beschreiben.. womit kein plan
                                        ? Latzi 2 Replies Last reply Reply Quote 0
                                          A Former User @arteck last edited by
                                          @arteck sagte in ZigBee neue Version 1.8.x:
                                          Hi, fleissiger lieber Developer 🙂
                                          hast du dir mal das Issue Occupancy timeout angeschaut ?
                                            arteck Developer Most Active @Guest last edited by arteck
                                            @ilovegym issue gesehen.. ja nachgestellt nein 🙂
                                            machmal bitte
                                            https://github.com/ioBroker/ioBroker.zigbee/wiki/debug-messages-with-zigbee.0.info.debugmessages
                                            und ändere den Wert.. poste mal was unter ELEVATED steht und die msg_from_zigbee .. vielleicht seh ich da schon was
                                            S ? 2 Replies Last reply Reply Quote -1
                                            81.1k
                                            385
                                            85209
