    4. Test Adapter vis 2.0 (Alpha)
    • MichaelSc
      MichaelSc last edited by
      web.0
      2023-07-06 08:02:14.902 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: RGraph.Effects.Gauge is undefined😞 "tplRGgauge/elem.rgraphValueChange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#ALF1_Solaranzeige_4 line 1 > injectedScript:973:21\nonchange@http://192.168.178.201:8082/vis-2-beta/edit.html?ALF1#ALF1_Solaranzeige_4 line 1 > injectedScript:138:30\n36167/i/n.onStateChange/<@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n36167/i/n.onStateChange@http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575\n83251/value/<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721569\nvalue@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543\n83251/value/</<@http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\ni@http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250\n"
      web.0
      2023-07-06 08:00:08.960 error Error: can't update states object for zoe2.0.VF1AG000X65218215.charge_level(TypeError: Cannot read properties of undefined (reading 'Grow')): "TypeError: Cannot read properties of undefined (reading 'Grow')\n at elem.rgraphValueChange (<anonymous>:973:42)\n at Object.onchange [as callback] (<anonymous>:138:30)\n at http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348602\n at Array.forEach (<anonymous>)\n at n.onStateChange (http://192.168.178.201:8082/vis-2-beta/static/js/167.5a545327.chunk.js:1:348575)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721568\n at Array.forEach (<anonymous>)\n at t.value (http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:721543)\n at http://192.168.178.201:8082/vis-2-beta/static/js/main.98b40ce7.js:2:713606\n at i (http://192.168.178.201:8082/vis-2-beta/static/js/618.b9cdaf52.chunk.js:2:90250)"
      Zeigt dieser Fehler auf ein bestimmtes Widget?
      Ich kann nur raten:
      allerdings wird hier ja der richtige Wert angezeigt.
      Wie kommt man dem Verursacher auf die Spur?
        apollon77 @MichaelSc last edited by
        @michaelsc mach doch mal Github issue bei vis2 und/oder gauge?
        MichaelSc 1 Reply Last reply Reply Quote 0
        • MichaelSc
          MichaelSc @apollon77 last edited by MichaelSc
          @apollon77 Trotz "Suche" finde ich kein VIS2 in Github, kannst Du bitte helfen?
          sigi234 arteck 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @MichaelSc last edited by
            @michaelsc sagte in Test Adapter vis 2.0 (Alpha):
            https://github.com/ioBroker/ioBroker.vis/issues
              arteck Developer Most Active @MichaelSc last edited by
              @michaelsc https://github.com/ioBroker/ioBroker.vis
              • MichaelSc
                MichaelSc @arteck last edited by
                @arteck ah danke: Suchte nach "vis2" oder "vis-2" - also in "vis" einstellen, okay.
                • MichaelSc
                  MichaelSc @sigi234 last edited by
                  @sigi234 Danke!
                  • Feuersturm
                    Feuersturm @wolfgam last edited by
                    @wolfgam sagte in Test Adapter vis 2.0 (Alpha):
                    wie funktioniert der Steal von Attributen?
                    Was meinst du damit?
                    wie bekomme ich die Auswahlliste möglicher CSS Attribute angezeigt (z.B. border-style = dotted, dashed, solid,...)?
                    Du meinst diese Option hier, wo es unter vis1 ein Dropdown gibt oder?
                    Da ist bei VIS2 wohl ein Bug, ich hab dort auch keine Auswahl. Bitte erstelle hierzu ein entsprechene issue (https://github.com/ioBroker/ioBroker.vis/issues)
                      mik @apollon77 last edited by
                      @apollon77
                      vielleicht hat ja jemand eine Idee?
                      Ich möchte meine neue Visu auf einem Raspberry Pi mit Display ausgeben. Erstellen will ich diese schon mit VIS2. Da ich den Chromium-Browser nicht in den Nightmode bekomme (funktioniert zwar mit Erweiterungen, wird aber von der VIS nicht erkannt), möchte ich die Farben schon in der Visu dunkel gestalten. Dies funktioniert soweit gut. Jedoch wird der Hintergrund des Navigationsbereiches immer weiß dargestellt.
                      Gibt es eine einfache Lösung, den Hintergrund dieses Bereiches in der Farbe zu ändern?
                      LG Michael
                      • MichaelSc
                        MichaelSc @mik last edited by
                        @mik Hi,
                        bei mir funktioniert diese Einstellung auf der Navigationsseite, auch unter VIS2:
                        LG
                        Michael
                          mik @MichaelSc last edited by
                          @michaelsc
                          bei mir funktioniert das für den eigentlichen Anzeigebereich der VIS, jedoch nicht für den automatisch eingeblendeten Navigationsbereich. Dieser bezieht sich nur auf die Systemeinstellung light-mode (dann ist dieser Navigationsbereich weiß) oder dark-mode (dann schwarz). Im Browser auf dem PC funktioniert alles super. Jedoch gibt es auf meinem RasPi mit Raspberry Pi OS diese Einstellung nicht und die Vis bezieht sich immer auf den light-mode. Dies ist an dem Wandbildschirm abends absolut störend, da viel zu hell.
                          MichaelSc Feuersturm 2 Replies Last reply Reply Quote 0
                          • MichaelSc
                            @mik Hi, was ist denn bitte Dein "automatisch eingeblendeter Navigationsbereich"?
                            Ich habe den Navigationsbereich auf allen unseren Views selber verwaltet in einem
                            Dort wird dann die Navi aufgerufen/eingeblendet:
                              @michaelsc
                              Das ist die Funktion von VIS2, welche ich gerne nutzen möchte:
                              Hast du das Widget im responsive-mode eingebaut?
                              • MichaelSc
                                @mik Ah, ja, sorry: Die Funktion kannte ich noch nicht und ich benutze sie nicht.
                                Und responsive-mode nutze ich auch nicht, weil ich eh die ganze VIS-Darstellung und -Bedienung auf Tablets habe, Kiosker an der Wand oder auf Tablet-Haltern. Da ist responsive-mode entbehrlich.
                                  @michaelsc
                                  ja, ich tue mir auch bissl schwer mit responsive. Meine ursprüngliche VISU läuft schon seit etlichen Jahren super auf meinem Wandtablet. Jetzt wollte ich auf einen RasPi mit Display umsteigen und in diesem Zuge auch gleich eine neue VISU basteln, natürlich schon mit VIS2 und dessen doch sehr umfangreichen Möglichkeiten. Bin aber wohl noch etwas zu früh. Insgesamt finde ich das neue VIS super, freue mich schon auf die finale Version.
                                  • MichaelSc
                                    @mik Ja, bislang ist VIS2 sehr vielversprechend - ich habe noch ein paar kleinere Fehler entdeckt, so dass also bei mir die PopUp-Views noch nicht funktionieren. Damit hab ich viel gelöst (Fehlermeldungen anzeigen usw usw).
                                    Aber wird schon werden.
                                    • Feuersturm
                                      Feuersturm @mik last edited by
                                      @mik sagte in Test Adapter vis 2.0 (Alpha):
                                      Hi, dann erstelle bitte einmal ein Aussagekräftiges issue (am besten auch mit Bildern) auf github im vis Projekt.
                                        LJSven last edited by
                                        Ich bekomme den Adater nicht ans laufen. Es erscheint immer wieder die Meldung, dass die web Version nicht korrekt ist.
                                        Allerdings ist die 5.5.3 installiert.
                                        Was mache ich falsch?
                                          Thomas Braun Most Active @LJSven last edited by
                                          @ljsven sagte in Test Adapter vis 2.0 (Alpha):
                                          Du postest Screenshots von Text.
                                          Deine Versionen sind nicht konsistent aus einem Repo.
                                          Mach einen Upload von allem.
                                          iob upload all
                                            LJSven @Thomas Braun last edited by
                                            @thomas-braun sagte in Test Adapter vis 2.0 (Alpha):
                                            iob upload all
                                            Danke @Thomas-Braun! Das Problem ist damit erledigt.
                                            Ich will den ioBroker "mehr oder weniger" als Infodisplay im Flur nutzen in Verbindung mit Anthias. Dazu möchte ich über ioBroker und dem RSS feed Infos abrufen und darstellen. Mich stört aber, daß immer dieser Loading Screen kommt. Kann man das "verhindern?"
                                            780
                                            228855
