    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @bahnuhr last edited by
      @bahnuhr sagte in iob diag - Skript:
      Ist das richtig ?
      Ja, das ist richtig.
      Ich hab noch keinen Weg gefunden, den Status sicher festzunageln.
      • bahnuhr
        bahnuhr Forum Testing Most Active @Thomas Braun last edited by
        [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems (real ones only):
        TARGET SOURCE                    FSTYPE OPTIONS
        /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
        `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bs
        Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
        Wollten wir irgendwann nochmal thematisieren.
        Muss ich da nochmal ran?
        • uweklatt
          uweklatt last edited by uweklatt
          ich nutze hier Docker innerhalb LXC auf Proxmox.
          Das Script liefert hier folgende Ausgaben:
          *** iob diag is starting up, please wait ***
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the  characters at start and end.
          It helps us to help you!
          Press any key to continue
          Skript v.2023-06-21
          *** BASE SYSTEM ***
          Hardware Vendor : LENOVO
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v8.0.1
          Virtualization  : Docker
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
          CPU threads: 4
          *** Time and Time Zones ***
          Mon Jul  3 16:58:39 UTC 2023
          Mon Jul  3 18:58:39 CEST 2023
          CEST +0200
          Etc/UTC
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
          Swap:           7.8G         21M        7.8G
          Total:           15G        3.3G        8.6G
                   7824 M total memory
                   3242 M used memory
                   1453 M active memory
                   5083 M inactive memory
                    764 M free memory
                    661 M buffer memory
                   3156 M swap cache
                   7835 M total swap
                     21 M used swap
                   7814 M free swap
          *** FILESYSTEM ***
          Filesystem                       Type     Size  Used Avail Use% Mounted on
          overlay                          overlay   61G  9.0G   49G  16% /
          tmpfs                            tmpfs     64M     0   64M   0% /dev
          shm                              tmpfs     64M     0   64M   0% /dev/shm
          /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
          tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
          tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
          tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
          tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
          [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
          [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
          [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
          [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
          /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
          /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
          /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
          /var:
          33M	/var/
          31M	/var/lib
          18M	/var/lib/apt/lists
          18M	/var/lib/apt
          13M	/var/lib/dpkg
          /opt/iobroker/backups:
          5.5M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          196M	/opt/iobroker/iobroker-data/
          104M	/opt/iobroker/iobroker-data/files
          63M	/opt/iobroker/iobroker-data/backup-objects
          52M	/opt/iobroker/iobroker-data/files/javascript.admin
          34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          23M	/opt/iobroker/iobroker-data/objects.jsonl
          7.2M	/opt/iobroker/iobroker-data/states.jsonl
          6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.16.1
          /usr/bin/node 		v18.16.1
          /usr/bin/npm 		9.5.1
          /usr/bin/npx 		9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 127.0.0.1
          States:                     jsonl on 127.0.0.1
          Core adapters versions
          js-controller: 	4.0.24
          admin: 		6.3.5
          javascript: 	7.0.3
          Adapters from github: 	1
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
            system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            system.adapter.info.0                   : info                  : iobroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
            system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          stable        : http://iobroker.live/repo/sources-dist.json
          beta          : http://iobroker.live/repo/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Objects and States
          Objects: 	3398
          States: 	3035
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
          Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
          tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
          tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
          udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
          		     v.2023-06-21
          model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v8.0.1
          Installation: 		Docker
          Kernel: 		x86_64
          Userland: 		amd64
          Timezone: 		Etc/UTC
          User-ID: 		0
          X-Server: 		false
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.1
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          Recommended versions are nodejs 16.20.1 and npm 8.19.4
          MEMORY:
          Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
          Swap:           7.8G         21M        7.8G
          Active iob-Instances: 	14
          ioBroker Core: 		js-controller 		4.0.24
          			admin 			6.3.5
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		3398
          States: 		3035
          Size of iob-Database:
          === Mark text until here for copying ===
          Tschau
          Uwe
          DJMarc75 Meister Mopper 2 Replies Last reply Reply Quote 0
          • DJMarc75
            DJMarc75 @uweklatt last edited by
            @uweklatt sagte in iob diag - Skript:
            Tschau
            und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
              Thomas Braun Most Active @DJMarc75 last edited by
              @djmarc75 sagte in iob diag - Skript:
              Keine Frage, das war nur ein Test der Beta-Version des Skripts.
              @uweklatt Danke schön!
              DJMarc75 B 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Thomas Braun last edited by DJMarc75
                @thomas-braun sagte in iob diag - Skript:
                Dann entschuldige ich mich natürlich ! ... bei @uweklatt
                uweklatt 1 Reply Last reply Reply Quote 0
                • uweklatt
                  uweklatt @DJMarc75 last edited by
                  @djmarc75 🍻
                  • Meister Mopper
                    Meister Mopper @uweklatt last edited by
                    Warum wird das noch immer gemacht, wo doch selbst Proxmox aus Sicherheitsgründen eine docker Umgebung in einer VM empfiehlt.
                    Ja, es läuft auch im LXC, aber 🤷‍♂️ 😬
                    • uweklatt
                      uweklatt @Meister Mopper last edited by
                      @meister-mopper
                      ...weil es resourcensparender ist.
                      Tschau
                      Uwe
                        bommel_030 @Thomas Braun last edited by
                        Neben vielen anderen hübschen Dingen erfährt man ja auch
                        Adapters from github:   8
                        Kannst du in deinem Skript auch einbauen, dass die betroffenen Adapter namentlich erwähnt werden? Oder hast du nen Hinweis wo ich das rausfinde?
                          Thomas Braun Most Active @bommel_030 last edited by
                          @bommel_030 sagte in iob diag - Skript:
                          Könnte ich. Hab ich aber bewusst nicht, damit die Liste nicht so lang wird.
                          cd /opt/iobroker && npm ls | grep github
                          schmeißt dir die raus.
                            Stmiko last edited by
                            cooles script, aber:
                            Wenn ich 'iob diag' eingebe passiert nichts. Muss ich das script händisch nachinstallieren?
                            Der installation_fixer hats auch nicht geheilt?
                            curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh funktioniert 🙂
                            Lg
                              Thomas Braun Most Active @Stmiko last edited by
                              @stmiko
                              In welcher Umgebung rufst du das auf?
                              Kannst ja den Output aus dem manuellen Aufruf verwenden...
                                Stmiko @Thomas Braun last edited by
                                @thomas-braun Ist ein Proxmox LXC mit Debian:
                                                     v.2023-04-16
                                Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                Kernel:                 6.2.16-4-pve
                                Installation:           lxc
                                Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                                Timezone:
                                User-ID:                0
                                X-Server:               false
                                Boot Target:            graphical.target
                                                        /usr/bin/npm            9.5.1
                                                        /usr/bin/npx            9.5.1
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            8.2G        2.8G        2.6G        0.0K        2.8G        5.4G
                                Swap:             0B          0B          0B
                                Total:          8.2G        2.8G        2.6G
                                Active iob-Instances:   28
                                Active repo(s): beta
                                ioBroker Core:          js-controller           5.0.8
                                                        admin                   6.6.0
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : LXC-Debian10                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : LXC-Debian10                             -  enabled
                                + system.adapter.web.0                    : web                   : LXC-Debian10                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                36921
                                States:                 27584
                                30M     /opt/iobroker/iobroker-data/objects.jsonl
                                18M     /opt/iobroker/iobroker-data/objects.json.migrated
                                18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                8.0M    /opt/iobroker/iobroker-data/states.jsonl
                                3.7M    /opt/iobroker/iobroker-data/states.json.migrated
                                3.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  @stmiko sagte in iob diag - Skript:
                                  Und root shell. Lass den Mist bleiben.
                                    @thomas-braun bin halt ein fauler Hund.....:)
                                    Liegt es am root?
                                    R Thomas Braun 2 Replies Last reply Reply Quote 0
                                      reutli @Stmiko last edited by
                                      Das hat nichts mit "faul" sondern "fahrlässig" bis "lebensmüde" zu tun!
                                        @stmiko
                                        Da liegt es immer dran, weil es so grundlegend falsch wie nur was ist.
                                        • bahnuhr
                                          iob diag fordern wir ja recht häufig an.
                                          Und dabei kommt es oft vor, dass wir nur das summary zurück bekommen.
                                          Also immer wieder nachhaken müssen, dass doch das gesamte diag gesendet wird.
                                          Vielleicht wäre es eine Idee doch den stop rauszunehmen, dass man halt nur 1 Durchlauf (mit allem) bekommt.
                                            @bahnuhr
                                            Ich plane, das vielleicht mit Optionen zu machen.
                                            Also so ungefähr:
                                            iob diag --summary
                                            iob diag --full
                                            bahnuhr paul53 2 Replies Last reply Reply Quote 0
                                            738
                                            154384
