    4. iob diag - Skript
    iob diag - Skript
    • bahnuhr
      bahnuhr Forum Testing Most Active @Thomas Braun last edited by
      [Sun Jul  2 17:58:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Jul  2 17:58:54 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems (real ones only):
      TARGET SOURCE                    FSTYPE OPTIONS
      /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
      `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bs
      Und bei diesen Punkten hattest du mal irgendwo was zu mir gesagt.
      Wollten wir irgendwann nochmal thematisieren.
      Muss ich da nochmal ran?
      • uweklatt
        uweklatt last edited by uweklatt
        ich nutze hier Docker innerhalb LXC auf Proxmox.
        Das Script liefert hier folgende Ausgaben:
        *** iob diag is starting up, please wait ***
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the  characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-06-21
        *** BASE SYSTEM ***
        Hardware Vendor : LENOVO
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.0.1
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:58:39 up 32 days, 23:48,  0 users,  load average: 0.32, 0.19, 0.12
        CPU threads: 4
        *** Time and Time Zones ***
        Mon Jul  3 16:58:39 UTC 2023
        Mon Jul  3 18:58:39 CEST 2023
        CEST +0200
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            7.8G        3.2G        764M         40M        3.8G        4.2G
        Swap:           7.8G         21M        7.8G
        Total:           15G        3.3G        8.6G
                 7824 M total memory
                 3242 M used memory
                 1453 M active memory
                 5083 M inactive memory
                  764 M free memory
                  661 M buffer memory
                 3156 M swap cache
                 7835 M total swap
                   21 M used swap
                 7814 M free swap
        *** FILESYSTEM ***
        Filesystem                       Type     Size  Used Avail Use% Mounted on
        overlay                          overlay   61G  9.0G   49G  16% /
        tmpfs                            tmpfs     64M     0   64M   0% /dev
        shm                              tmpfs     64M     0   64M   0% /dev/shm
        /dev/mapper/pve-vm--100--disk--0 ext4      61G  9.0G   49G  16% /opt/iobroker
        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/asound
        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/acpi
        tmpfs                            tmpfs    3.9G     0  3.9G   0% /proc/scsi
        tmpfs                            tmpfs    3.9G     0  3.9G   0% /sys/firmware
        [Wed May 31 19:10:12 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Wed May 31 19:10:13 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
        [Wed May 31 19:10:21 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Wed May 31 19:10:23 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
        [Fri Jun  2 19:26:35 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
        [Fri Jun  2 19:29:53 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
        [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): write access unavailable, skipping orphan cleanup
        [Fri Jun  2 19:31:31 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
        [Fri Jun  2 19:40:07 2023] EXT4-fs (dm-8): mounted filesystem without journal. Opts: noload. Quota mode: none.
        [Tue Jun 27 11:17:24 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Tue Jun 27 11:29:11 2023] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        /opt/iobroker    /dev/mapper/pve-vm--100--disk--0[/iobroker]        ext4   rw,relatime,stripe=16
        /etc/resolv.conf /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/resolv.conf] ext4   rw,relatime,stripe=16
        /etc/hostname    /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hostname]    ext4   rw,relatime,stripe=16
        /etc/hosts       /dev/mapper/pve-vm--100--disk--0[/var/lib/docker/containers/98253a498faf226446e852c96f43eadc28b0f9459846d9b0bf086638afa12436/hosts]       ext4   rw,relatime,stripe=16
        /var:
        33M	/var/
        31M	/var/lib
        18M	/var/lib/apt/lists
        18M	/var/lib/apt
        13M	/var/lib/dpkg
        /opt/iobroker/backups:
        5.5M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        196M	/opt/iobroker/iobroker-data/
        104M	/opt/iobroker/iobroker-data/files
        63M	/opt/iobroker/iobroker-data/backup-objects
        52M	/opt/iobroker/iobroker-data/files/javascript.admin
        34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        7.2M	/opt/iobroker/iobroker-data/states.jsonl
        6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        5.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.16.1
        /usr/bin/node 		v18.16.1
        /usr/bin/npm 		9.5.1
        /usr/bin/npx 		9.5.1
        nodejs:
          Installed: 18.16.1-deb-1nodesource1
          Candidate: 18.16.1-deb-1nodesource1
          Version table:
         *** 18.16.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	7.0.3
        Adapters from github: 	1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
          system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          system.adapter.info.0                   : info                  : iobroker                                 - disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        stable        : http://iobroker.live/repo/sources-dist.json
        beta          : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Objects and States
        Objects: 	3398
        States: 	3035
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72780677   532/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72780670   532/iobroker.js-con
        tcp        0      0 127.0.0.11:32827        0.0.0.0:*               LISTEN      0          72777013   -
        tcp        0      0 192.168.178.223:18998   0.0.0.0:*               LISTEN      1000       72781358   607/io.javascript.0
        tcp6       0      0 :::61991                :::*                    LISTEN      1000       72784653   791/io.harmony.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72789074   878/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72780750   554/io.admin.0
        udp        0      0 127.0.0.11:56903        0.0.0.0:*                           0          72777012   -
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       72784654   791/io.harmony.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       73940879   34550/io.chromecast
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        		     v.2023-06-21
        model name	: Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.0.1
        Installation: 		Docker
        Kernel: 		x86_64
        Userland: 		amd64
        Timezone: 		Etc/UTC
        User-ID: 		0
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.1
        			/usr/bin/npm 		9.5.1
        			/usr/bin/npx 		9.5.1
        Recommended versions are nodejs 16.20.1 and npm 8.19.4
        MEMORY:
        Mem:            7.8G        3.3G        753M         40M        3.8G        4.2G
        Swap:           7.8G         21M        7.8G
        Active iob-Instances: 	14
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		3398
        States: 		3035
        Size of iob-Database:
        === Mark text until here for copying ===
        Tschau
        Uwe
        DJMarc75 Meister Mopper 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @uweklatt last edited by
          @uweklatt sagte in iob diag - Skript:
          Tschau
          und Deine Frage lautet ? Oder war Dein Beitrag nur eine Feststellung ??
            Thomas Braun Most Active @DJMarc75 last edited by
            @djmarc75 sagte in iob diag - Skript:
            Keine Frage, das war nur ein Test der Beta-Version des Skripts.
            @uweklatt Danke schön!
            DJMarc75 B 2 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @Thomas Braun last edited by DJMarc75
              @thomas-braun sagte in iob diag - Skript:
              Dann entschuldige ich mich natürlich ! ... bei @uweklatt
              uweklatt 1 Reply Last reply Reply Quote 0
              • uweklatt
                uweklatt @DJMarc75 last edited by
                @djmarc75 🍻
                • Meister Mopper
                  Meister Mopper @uweklatt last edited by
                  Warum wird das noch immer gemacht, wo doch selbst Proxmox aus Sicherheitsgründen eine docker Umgebung in einer VM empfiehlt.
                  Ja, es läuft auch im LXC, aber 🤷‍♂️ 😬
                  • uweklatt
                    uweklatt @Meister Mopper last edited by
                    @meister-mopper
                    ...weil es resourcensparender ist.
                    Tschau
                    Uwe
                      bommel_030 @Thomas Braun last edited by
                      Neben vielen anderen hübschen Dingen erfährt man ja auch
                      Adapters from github:   8
                      Kannst du in deinem Skript auch einbauen, dass die betroffenen Adapter namentlich erwähnt werden? Oder hast du nen Hinweis wo ich das rausfinde?
                        Thomas Braun Most Active @bommel_030 last edited by
                        @bommel_030 sagte in iob diag - Skript:
                        Könnte ich. Hab ich aber bewusst nicht, damit die Liste nicht so lang wird.
                        cd /opt/iobroker && npm ls | grep github
                        schmeißt dir die raus.
                          Stmiko last edited by
                          cooles script, aber:
                          Wenn ich 'iob diag' eingebe passiert nichts. Muss ich das script händisch nachinstallieren?
                          Der installation_fixer hats auch nicht geheilt?
                          curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh funktioniert 🙂
                          Lg
                            Thomas Braun Most Active @Stmiko last edited by
                            @stmiko
                            In welcher Umgebung rufst du das auf?
                            Kannst ja den Output aus dem manuellen Aufruf verwenden...
                              Stmiko @Thomas Braun last edited by
                              @thomas-braun Ist ein Proxmox LXC mit Debian:
                                                   v.2023-04-16
                              Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                              Kernel:                 6.2.16-4-pve
                              Installation:           lxc
                              Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
                              Timezone:
                              User-ID:                0
                              X-Server:               false
                              Boot Target:            graphical.target
                                                      /usr/bin/npm            9.5.1
                                                      /usr/bin/npx            9.5.1
                              Recommended versions are nodejs 18.x.y and npm 9.x.y
                              MEMORY:
                              Mem:            8.2G        2.8G        2.6G        0.0K        2.8G        5.4G
                              Swap:             0B          0B          0B
                              Total:          8.2G        2.8G        2.6G
                              Active iob-Instances:   28
                              Active repo(s): beta
                              ioBroker Core:          js-controller           5.0.8
                                                      admin                   6.6.0
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : LXC-Debian10                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.vis-material-webfont.0   : vis-material-webfont  : LXC-Debian10                             -  enabled
                              + system.adapter.web.0                    : web                   : LXC-Debian10                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                36921
                              States:                 27584
                              30M     /opt/iobroker/iobroker-data/objects.jsonl
                              18M     /opt/iobroker/iobroker-data/objects.json.migrated
                              18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              8.0M    /opt/iobroker/iobroker-data/states.jsonl
                              3.7M    /opt/iobroker/iobroker-data/states.json.migrated
                              3.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                @stmiko sagte in iob diag - Skript:
                                Und root shell. Lass den Mist bleiben.
                                  @thomas-braun bin halt ein fauler Hund.....:)
                                  Liegt es am root?
                                  R Thomas Braun 2 Replies Last reply Reply Quote 0
                                    reutli @Stmiko last edited by
                                    Das hat nichts mit "faul" sondern "fahrlässig" bis "lebensmüde" zu tun!
                                      @stmiko
                                      Da liegt es immer dran, weil es so grundlegend falsch wie nur was ist.
                                      • bahnuhr
                                        iob diag fordern wir ja recht häufig an.
                                        Und dabei kommt es oft vor, dass wir nur das summary zurück bekommen.
                                        Also immer wieder nachhaken müssen, dass doch das gesamte diag gesendet wird.
                                        Vielleicht wäre es eine Idee doch den stop rauszunehmen, dass man halt nur 1 Durchlauf (mit allem) bekommt.
                                          Thomas Braun Most Active @bahnuhr last edited by
                                          @bahnuhr
                                          Ich plane, das vielleicht mit Optionen zu machen.
                                          Also so ungefähr:
                                          iob diag --summary
                                          iob diag --full
                                          bahnuhr paul53 2 Replies Last reply Reply Quote 0
                                          • bahnuhr
                                            @Thomas-Braun
                                            auch gut.
                                            Ist aber für manche wieder eine Hürde mehr.
                                            738
                                            151257
