    2. Русский
    3. ioBroker
    4. Визуализация
    5. ioBroker.vis Драйвер
    6. Разные вопросы по Vis
    • sigma
      sigma last edited by
      @Bluefox:
      Используй hqwidgets- Lock
      Там можно перенастроить все надписи и картинки на нужные тебе. `
      Огромное спасибо! Так
      ~~![](</s><URL url=)<link_text text="https://monosnap.com/file/Yg4g8CsLPrKeZ ... GGv1vl.png">https://monosnap.com/file/Yg4g8CsLPrKeZfiXatVmozpeGGv1vl.png</link_text>" />
      намного понятнее и красивее~~
        smoker_vvo last edited by
        Народ! Отцы Основатели! подскажите в чем проблема!?
        web.0 2017-10-13 20:38:06.899 info 2017-10-13T10:38:06.897Z Connected system.user.admin
        web.0 2017-10-13 20:38:06.883 info 2017-10-13T10:38:06.882Z Connected system.user.admin
        web.0 2017-10-13 20:38:03.378 info http server listening on port 8082
        web.0 2017-10-13 20:38:03.378 info socket.io server listening on port 8082
        web.0 2017-10-13 20:38:03.115 info starting. Version 2.1.3 in C:/ioBroker/node_modules/iobroker.web, node: v6.9.5
        host.GoldFish2 2017-10-13 20:38:02.389 info instance system.adapter.web.0 started with pid 6048
        host.GoldFish2 2017-10-13 20:37:32.386 info Restart adapter system.adapter.web.0 because enabled
        host.GoldFish2 2017-10-13 20:37:32.385 error instance system.adapter.web.0 terminated with code 0 (OK)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:98:9)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:67:7)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at C:\ioBroker\node_modules\iobroker.web\node_modules\socket.io\lib\socket.js:503:12
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at Socket.emit (events.js:191:7)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at emitTwo (events.js:106:13)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at Socket. (C:\ioBroker\node_modules\iobroker.web\node_modules\iobroker.socketio\lib\socket.js:886:25)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at subscribe (C:\ioBroker\node_modules\iobroker.web\node_modules\iobroker.socketio\lib\socket.js:267:42)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: at RegExp (native)
        host.GoldFish2 2017-10-13 20:37:32.385 error Caught by controller[0]: SyntaxError: Invalid regular expression: /+30/: Nothing to repeat
        web.0 2017-10-13 20:37:31.444 info 2017-10-13T10:37:31.444Z Connected system.user.admin
        web.0 2017-10-13 20:37:30.360 info 2017-10-13T10:37:30.360Z Connected system.user.admin
        web.0 2017-10-13 20:37:25.420 info 2017-10-13T10:37:25.420Z Connected system.user.admin
        web.0 2017-10-13 20:37:22.290 info 2017-10-13T10:37:22.290Z Connected system.user.admin
        web.0 2017-10-13 20:37:21.926 info 2017-10-13T10:37:21.925Z Connected system.user.admin
        web.0 2017-10-13 20:37:21.402 info 2017-10-13T10:37:21.398Z Connected system.user.admin
        web.0 2017-10-13 20:37:21.202 info http server listening on port 8082
        web.0 2017-10-13 20:37:21.202 info socket.io server listening on port 8082
        web.0 2017-10-13 20:37:20.922 info starting. Version 2.1.3 in C:/ioBroker/node_modules/iobroker.web, node: v6.9.5
        host.GoldFish2 2017-10-13 20:37:20.164 info instance system.adapter.web.0 started with pid 4840
        host.GoldFish2 2017-10-13 20:36:50.155 info Restart adapter system.adapter.web.0 because enabled
        host.GoldFish2 2017-10-13 20:36:50.155 error instance system.adapter.web.0 terminated with code 0 (OK)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:98:9)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:67:7)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at C:\ioBroker\node_modules\iobroker.web\node_modules\socket.io\lib\socket.js:503:12
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at Socket.emit (events.js:191:7)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at emitTwo (events.js:106:13)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at Socket. (C:\ioBroker\node_modules\iobroker.web\node_modules\iobroker.socketio\lib\socket.js:886:25)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at subscribe (C:\ioBroker\node_modules\iobroker.web\node_modules\iobroker.socketio\lib\socket.js:267:42)
        host.GoldFish2 2017-10-13 20:36:50.155 error Caught by controller[0]: at RegExp (native)
        host.GoldFish2 2017-10-13 20:36:50.154 error Caught by controller[0]: SyntaxError: Invalid regular expression: /+30/: Nothing to repeat
        Поменял диапазоны температур и система стала зависать
        Стабильно перегружается VIS
        • Bluefox
          Bluefox last edited by
          @smoker_vvo:
          Стабильно перегружается VIS `
          У тебя одна переменная называется +30
          Если у тебя нет такой переменной, то поменяй диапазон на просто 30 без плюса
          • sigma
            А как "правильно" заменить иконку (favicon.png) на web интерфейсе на свою?
            • Bluefox
              @sigma:
              А как "правильно" заменить иконку (favicon.png) на web интерфейсе на свою? `
              Никак.
              Можно конечно, но всё пути неправильные.
                Не понял про переменные… выглядит все во так
                  От жеж…. Я кажется понял, при отрицательной температуре пишем -30, при положительной просто 30. Верно?
                  • Bluefox
                    @smoker_vvo:
                    От жеж…. Я кажется понял, при отрицательной температуре пишем -30, при положительной просто 30. Верно? `
                    Да
                      Пасиб!
                        Freemen last edited by
                        Извиняюсь, может плохо искал по форуму решение своей проблемы. Суть в том что с некоторых пор в браузере Chrome у страниц vis у меня перестал работать элемент Speech to text, пишет что заблокирован микрофон. Как его разблокировать я понял, для страницы google.com без проблем, но для страниц VIS с этим элементом ни как не проходит, то ли запрос не такой шлет страница, то ли я в "лыжи обутый".
                        • sigma
                          Какая-то странная ситуация произошла с vis: в какой-то момент, ново-добавленые элементы перестали отображаться в web-интерфейсе. В edit-режиме, элементы отображаются, редактируются. Их можно менять (например, связывать с другим state), перемещать по экрану - все эти изменения тут же отображаются на web-интерфейсе. А вот если добавить любой новый элемент, даже элементарную кнопку, то он не отображается на web. В логе ошибок нет. Что бы это было?
                            Вот обновил vis и обнаружил что оказывается нужна лицензия. Регистрировался я раньше и получил API ключ. Теперь захожу "тыкаю" в лицензии просит подтвердить емейл, нажимаю…и ничего. Малюсинькими буковками бета версия свяжитесь с нами, класс...
                              Может кто то подскажет все таки что у меня не так с Speech to text и как все таки получить эту лицензию.
                                Очень жаль. Так и не получил ответы. Никто не хочет подсказать как все таки получить эту лицензию на VIS (и нужна ли она вообще). И что все таки у меня не так с элементом Speech to text, почему я не могу открыть в Chrome для страницы доступ к микрофону.
                                • I
                                  instalator last edited by
                                  @Freemen:
                                  Очень жаль. Так и не получил ответы. Никто не хочет подсказать как все таки получить эту лицензию на VIS (и нужна ли она вообще). И что все таки у меня не так с элементом Speech to text, почему я не могу открыть в Chrome для страницы доступ к микрофону. `
                                  А что не ясного с этих предложений?
                                  __Для пользования vis необходимо получить лицензионный ключ.
                                  vis бесплатен для личного использования в некоммерческих целях. Для использования vis в коммерческих целях необходимо заплатить за лицензию.
                                  Лицензионный ключ можно получить здесь iobroker.net после регистрации.__
                                  Что не понятного с микрофоном?
                                    instalator, я очень благодарен за ответ. Но все дело в том что то что Вы предложили я уже делал 1001 раз. Зарегистрировался давно, даже не помню для чего нужен был app-key :), но вот лицензии у меня нет. Нажимая на лицензии получаю подтвердите email адрес нажимаю на ссылку попадаю в профиль нажимаю послать подтверждение и ничего, мигает бета версия свяжитесь с нами (на почту ничего не приходит). По поводу микрофона делал я то что на скриншоте у Вас, для страницы vis десятки раз и ничего, сайт не прописывается в хроме, проверил для других сайтов они прописываются рядом с гуглом.
                                    • I
                                      @Freemen:
                                      instalator, я очень благодарен за ответ. Но все дело в том что то что Вы предложили я уже делал 1001 раз. Зарегистрировался давно, даже не помню для чего нужен был app-key :), но вот лицензии у меня нет. Нажимая на лицензии получаю подтвердите email адрес нажимаю на ссылку попадаю в профиль нажимаю послать подтверждение и ничего, мигает бета версия свяжитесь с нами (на почту ничего не приходит). По поводу микрофона делал я то что на скриншоте у Вас, для страницы vis десятки раз и ничего, сайт не прописывается в хроме, проверил для других сайтов они прописываются рядом с гуглом. `
                                      http://forum.iobroker.net/viewtopic.php?f=13&t=8622
                                      а по поводу холма это уже в настройках браузера надо смотреть, может обновить хром, почисть куки, кэш и тп
                                        @instalator:
                                        @Freemen:
                                        а по поводу холма это уже в настройках браузера надо смотреть, может обновить хром, почисть куки, кэш и тп `
                                        Спасибо, по поводу подтверждения написал. Версия браузера последняя, обновлять уже нечего :), почистил и ничего…Как было так и есть - элемент не работает.
                                          Haus last edited by
                                          @Freemen:
                                          @instalator:
                                          @Freemen:
                                          Спасибо, по поводу подтверждения написал. Версия браузера последняя, обновлять уже нечего :), почистил и ничего…Как было так и есть - элемент не работает. `
                                          Это всё из за HTTP(чего то там изменилось в браузерах), "instalator" проверяет в HTTPS там проблем нету. Сделай через letsencrypt https и будет тебе счастье 🙂
                                            @Haus:
                                            @Freemen:
                                            @instalator:
                                            Спасибо, по поводу подтверждения написал. Версия браузера последняя, обновлять уже нечего :), почистил и ничего…Как было так и есть - элемент не работает. Это всё из за HTTP(чего то там изменилось в браузерах), "instalator" проверяет в HTTPS там проблем нету. Сделай через letsencrypt https и будет тебе счастье :)
                                            Каждый раз убеждаюсь, если не все понимаешь то лучше не лезь. И опять на те же грабли. Воспользовался советом, решил включить https, поскольку в сертификатах полный ноль, то почитав об letsencrypt подумал что не пройдет, ну нет у меня домена. Посмотрел, есть какие то сертификаты паблик и приват, думаю дай включу. Результат подключение по порту 8082 отсутствует. Но самая большая глупость была это сделать для admin. Теперь нет доступа никуда. Сижу курю бамбук, где теперь изменить и что изменять фиг поймешь. Информации много но она как то разбросана, например читаю instalator пишет о подобной проблеме, задает вопрос как решить проблему с доступом к админ, потом же пишет все нашел. Что нашел? Где нашел? Известно ему и Богу а Bluefox наверное догадался что он нашел :).
                                            218
                                            65131
